2 key works but can not get @ symbol when pressing shift and 2
Solved 2 key works but can not get @ symbol when pressing shift and 2
Post by Fenway0077 on Thu Jul 16, 2009 4:32 pm
Naturally I am writing this from a different computer, but a co-worker of mine said her @ button doesnt work - she can press 2 and it'll work but when she presses shift it wont make the @ sign - it just makes two small slash kind of marks -
I dont have access to her computer - but I thought I'd still check here anyway -
Thanks!
Fenway0077
Posts Posts : 44
Joined Joined : 2009-05-08
OS OS : XP Home SP3
Points Points : 27771
Solved Re: 2 key works but can not get @ symbol when pressing shift and 2
Post by Doctor Inferno on Fri Jul 17, 2009 7:52 am
Do other number keys work with the shift key? Did she recently install software which might make this happen?
Post by Fenway0077 on Fri Jul 17, 2009 4:51 pm
She hasnt made any changes, and yes, every other key works just fine - so strange!
Fenway0077
Posts Posts : 44
OS OS : XP Home SP3
Post by Doctor Inferno on Sun Jul 19, 2009 7:50 am
Try this:
Start >> Control Panel >> Regional Settings >> Languages Tab >> Details.
From here select the layout you need and choose a default if you want more than one.
