System Security has taken over...need help.
Post by KWEST on 15th July 2009, 11:23 pm
Unfortunately I've been hit with the dreaded System Security malware as well. It's really dug in as I can not run Malwarebytes, Spyware Doctor and most of my exe. files. I had to go to safe mode just to get online and post this. Please walk me through the steps to manually remove this. Thanks.
KWEST
Posts Posts : 5
Joined Joined : 2009-07-15
Points Points : 27037
Re: System Security has taken over...need help.
Post by Belahzur on 16th July 2009, 12:01 am
Please download Hijack This via this link:
Run it and do a system scan with logfile.
Copy and past the log back here.
Points Points : 245091
Post by KWEST on 16th July 2009, 12:19 am
With help from the other postings on this site I was able to troubleshoot and I'm now back up & running again. The tech replies on the other posts were enough to get me started and in the right direction. Thanks!
KWEST
Posts Posts : 5
Post by Origin on 16th July 2009, 4:25 pm
Are you still having problems?
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31503
Post by KWEST on 17th July 2009, 4:10 pm
Yes - I thought everything was cleared, but now Windows will not boot up. I even tried safe mode, and it locks up as well. I think a key start-up component was deleted or left corrupt during the cleaning process. How can I reboot? Thanks.
KWEST
Posts Posts : 5
Post by Origin on 18th July 2009, 12:26 am
So you can't boot in either normal mode or safe mode? Try the following:
Please download this file: [You must be registered and logged in to see this link.]
  1. Insert a black CD into your CD draw.
  2. Double click the rescuecd.exe file on your Desktop.
  3. Hit the "Burn CD" button and allow it to burn, it shouldn't take too long.
  4. Next, reboot your computer, keep the CD inside the draw.
  5. Your computer should boot from the CD and boot to the Avira rescue disc.
  6. Next, see this guide here: [You must be registered and logged in to see this link.]
Posts Posts : 2685
Post by KWEST on 20th July 2009, 5:37 pm
Using an Iolo software I found around the house, it appears the "partition is corrupt"...and while the CD identifies this issue it locks-up when it's time to correct the problem. Will the Avira CD still help or do I need to head in a different direction? I can still run my CD-Rom so is there something out there I can run to clear this whole "partition" thing up? Thanks.
KWEST
Posts Posts : 5
Post by Origin on 21st July 2009, 5:51 pm
I suggest formatting your computer, if you can't seem to get into safe mode or normal mode then a format is required.
Posts Posts : 2685
