I think i've narrowed my problem down to the Axel Davis Viru
I think i've narrowed my problem down to the Axel Davis Virus. Now what to do?
Post by Infinite on 15th July 2009, 2:34 am
Unfortunately, I couldnt use HJ on the PC i'm having problems with. Here's why:
I have the Gateway 3250S desktop PC running Windows XP Home Edition. So far, I've attempted to use the Gateway Recovery option at boot (F11), but during the last 5% of the recovery, there are a lot of windows files that are either corrupt, missing or cannot be moved. When the recovery process is completed, I am able to get to the XP Splash screen, and it freezes up. In safe mode with networking, I am able to see that there are a looooooot of files missing (Internet Explorer, for example, along with the Disk Defragment and other maintenance programs within XP). I was able to fix Internet Explorer by putting installing it from the ie.inf file and files i downloaded onto another PC. After running a chkdsk, the problem of freezing at the XP Splash screen. And now, I cant even get into safe mode, as it automatically reboots.
So i tried running the system recovery again, and I took notice of the files that that couldnt be moved or were corrupt. Among them I noticed AXEL.DAV. I've read about this virus on the net, and I've come to find out that this is a REALLY destructive piece of code. It looks like it's infected the recovery partition on a broad scale to FUBAR a lot of the required files to successfully launch the recovery.
Here is my question:
Can I remove the virus using a Anti-Virus rescue disk at boot up, in the hopes of being able to use the recovery partition to restore the system? Is there even a way to remove the malicious files from the recovery partition?
My last resort... LAST LAST LAST resort, is to use an xp pro disk to format everything and start from scratch, especially since I cant get a Gateway System Restore disk from Gateway.
Thank you in advance.
Infinite
Posts Posts : 32
Joined Joined : 2009-07-15
OS OS : Windows Vista Home Premium, XP
Points Points : 27276
Re: I think i've narrowed my problem down to the Axel Davis Viru
Post by Belahzur on 15th July 2009, 3:12 pm
Points Points : 245079
Post by Infinite on 15th July 2009, 4:48 pm
How do I install hijack this on a machine that won't boot up?
Infinite
Posts Posts : 32
Post by Origin on 15th July 2009, 5:02 pm
Hello you are going to have to do this in another computer if you can boot in the infected one:
Please download this file: [You must be registered and logged in to see this link.]
  1. Insert a black CD into your CD draw.
  2. Double click the rescuecd.exe file on your Desktop.
  3. Hit the "Burn CD" button and allow it to burn, it shouldn't take too long.
  4. Next, reboot your computer, keep the CD inside the draw.
  5. Your computer should boot from the CD and boot to the Avira rescue disc.
  6. Next, see this guide here: [You must be registered and logged in to see this link.]
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31493
Post by Infinite on 16th July 2009, 3:06 am
^^^ I just completed this process, and did the same thing with bitdefender. No viruses found.
Infinite
Posts Posts : 32
Post by Infinite on 16th July 2009, 3:07 am
I tried the recovery partition, and still a bunch of axel.dav files are causing errors.
Infinite
Posts Posts : 32
Post by Origin on 16th July 2009, 5:24 pm
Are you able to boot in safe mode?
Posts Posts : 2685
Post by Infinite on 17th July 2009, 1:54 am
^^^^ nope. Cant do that anymore either.
Infinite
Posts Posts : 32
Post by Origin on 17th July 2009, 11:32 pm
If you can't boot in safe mode or normal mode at all I suggest formatting the computer, it would be the best thing to do.
Posts Posts : 2685
Post by Infinite on 18th July 2009, 1:27 am
^^ Thanks. I did that this morning, and I used some of the tools and suggestions that you gave in another thread to protect the PC.
Infinite
Posts Posts : 32
Post by Origin on 18th July 2009, 1:28 am
I'll give you some recommendations:
Posts Posts : 2685
Post by Infinite on 18th July 2009, 2:19 am
^^^ yeah i saw this information in another post and followed suit. Thanks.
Infinite
Posts Posts : 32
