Speaker Problems
Solved Speaker Problems
Post by uvita on 11th July 2009, 4:08 pm
Till two days ago my speakers were working fine and now suddenly one speaker works on my laptop...The other one comes and goes....I think from all where I try to get help that it seems my audio devices may be messed up and need reinstalling....I have realtek Audio Imput/Device and Realtek High Definition Audio. I do not know anything about computers and hence do not know how to do reinstalling etc and what to reinstall but I went into device manger and under sound video and game controllers these are the things I see
Audio Codecs
Legacy Audio Devices
Legacy Video Capture Devices
Media Control devices
Video Codecs
Please help
uvita
Posts Posts : 163
Joined Joined : 2009-01-06
OS OS : Windows Vista with Media Edition
Points Points : 29890
Solved Re: Speaker Problems
Post by Keollyn on 12th July 2009, 1:57 pm
You know, it could simply be a problem with the wiring. Sometimes the issue is what we don't expect.
Keollyn
Posts Posts : 35
Joined Joined : 2009-07-06
Points Points : 27169
Post by Codechanger22 on 12th July 2009, 3:02 pm
Figure out what audio device you have and search google eg.
If you have realtek 5625 search google for 'download audio driver realtek 5625' or let xp auto update your driver.
But as previous post suggests, it could be wiring or worst case broken soldering
Codechanger22
Posts Posts : 3
Joined Joined : 2009-07-11
OS OS : Xp pro
Points Points : 27085
Post by mariealabama on 13th July 2009, 2:58 am
If updating the driver does not work, first i would suggest buying speakers due to the fact it may be a motherboard problem.
mariealabama
Posts Posts : 107
Joined Joined : 2009-04-10
OS OS : dual boot Win XP SP2 and Win 7 32 bit
Points Points : 28325
Post by uvita on 25th July 2009, 10:50 pm
ok....thanks
uvita
Posts Posts : 163
