Urgent Help---Audio device problem
Solved Urgent Help---Audio device problem
Post by uvita on 10th July 2009, 2:25 pm
I have Realtek HD Audio and all my output devices are working and I can even adjust the volumes there but I am having problems with imput...this is how it looks
I tried clicking on advanced but yet its grayed out so not able to do anything.....i cannot hear sound when I record...please help...
uvita
Posts Posts : 163
Joined Joined : 2009-01-06
OS OS : Windows Vista with Media Edition
Points Points : 29900
Solved Re: Urgent Help---Audio device problem
Post by Doctor Inferno on 10th July 2009, 3:31 pm
Those volume control is for input/recording only, not for output. I think you might have mistaken.
Points Points : 104640
Post by uvita on 10th July 2009, 5:07 pm
yes i know they are for imput recording......I usually record things so that i can watch later but yesterday when i recorded i could not hear sound.....I wondered what happened so tested to see if my device was recording properly when it told me that it could not recognize stereo mix in recording. So yes i have problem with the imput/recording.....the output works fine
Also now one side of my speakers which till yesterday was working fine is not working
uvita
Posts Posts : 163
Post by mariealabama on 11th July 2009, 4:54 am
Have you tried reinstalling the driver for your sound card?
Right click My Computer
Click on Properties
Click the tab that says Hardware
Open the device manager and look for anything that has a yellow exclamation point or question mark
If there is nothing then click on Audio, find your device and try either updating the driver or "rolling back" the driver, the driver may have updated itself and the old driver may still work with all the features you are wanting
mariealabama
Posts Posts : 107
Joined Joined : 2009-04-10
OS OS : dual boot Win XP SP2 and Win 7 32 bit
Points Points : 28335
Post by uvita on 11th July 2009, 3:44 pm
No i have not....I do not know how to and which driver I need to reinstall...All I know is my computer has Realtec Audio Imput Device/Realtek High Definition Audio
There are no question mark anywhere
uvita
Posts Posts : 163
Post by mariealabama on 13th July 2009, 2:05 am
go to your computer manufacturers website and download and instal the most current driver.
mariealabama
Posts Posts : 107
Post by uvita on 25th July 2009, 10:52 pm
i willl....thanks
uvita
Posts Posts : 163
