need urgent help with spyware
Post by Nabeha on Wed Jul 08, 2009 1:39 pm
My computer is infected with viruses can u plz tell me where can i get free scanning and spyware removal..
Nabeha
Joined Joined : 2009-07-08
OS OS : windows xp
Points Points : 27073
Re: need urgent help with spyware
Post by Belahzur on Wed Jul 08, 2009 2:19 pm
Points Points : 245059
