Antivirus System Pro Alert- DESPERATE HELP NEEDED PLEASE
Re: Antivirus System Pro Alert- DESPERATE HELP NEEDED PLEASE
Post by preveli on Thu Jul 09, 2009 7:38 am
I have no idea what all this means!! However what do I do now?
preveli
Posts Posts : 46
Joined Joined : 2009-07-07
Points Points : 27471
Post by Belahzur on Thu Jul 09, 2009 1:43 pm
Don't worry, Combofix does a very deep scan and shows us a lot of information we need to help diagnose and remove your problm. The log looks fine, just need to delete a service.
Go to Start > Run. In the run box, copy and paste in:
sc delete junppfxucntu
Hit enter.
Points Points : 245049
Post by preveli on Thu Jul 09, 2009 2:48 pm
Oh My God!!! Fab I'm typing this from my computer!! You lot are brilliant!!! FAB FAB FAB!!
Thank you so much - haven't checked anything else yet but the "thing" is gone and the internet is working.
Just one thing would you recommend I change my browser to try and help prevent this happening again? Or is there anything else I should try and do to prevent this?
Many Many thanks.
preveli
Posts Posts : 46
Post by Origin on Thu Jul 09, 2009 5:22 pm
Glad we could help Smile
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31463
Post by preveli on Thu Jul 09, 2009 7:49 pm
Thank you for your help, still confused and worried as to how it got there in the first place. I have Netprotect plus care of McAfee with firewall, antivirus etc all regularly updated, scans run every friday. My Windows is set automatic updates. I also have Spyware Terminator (Real-Time Shield enabled) running??!!
Anyhow I will double check your recommendations above and go have a look at Firefox.
Many congratulations to your website and everything it provides and all your hard work and help it is very much appreciated.
preveli
Posts Posts : 46
