Antivirus System Pro
Post by FonzyD2A on Tue Jul 07, 2009 7:50 pm
Hi Doc,
I've downloaded and installed malwarebyte anti-malware but it won't open for some reason. I'm being bombarded by bankerfox.a and win32/nuqel warnings with constant popups about other sites and removal/protection software.
Any ideas?
Fonz
FonzyD2A
Joined Joined : 2009-07-07
Points Points : 27093
Re: Antivirus System Pro
Post by Belahzur on Tue Jul 07, 2009 8:11 pm
Points Points : 245069
