Problems installing Java
Solved Problems installing Java
Post by aybsee on Mon Jul 06, 2009 9:44 am
I am having trouble downloading the Version 6 update 14 of java.I continue to get part way thru installation,then get " Error 25099 Unzipping core files failed ".I've tried to remove older versions of Java but can't find any sign of anything " Java " in Control Panel>Programs>Uninstall or change a program. From what i can see i haven't got Java installed now,but previously did and now it's just disappeared.Any advise please?
aybsee
Posts Posts : 102
Joined Joined : 2008-12-19
OS OS : wnidows vista home premium
Points Points : 29462
Solved Re: Problems installing Java
Post by aybsee on Mon Jul 06, 2009 12:42 pm
problem solved
aybsee
Posts Posts : 102
