No Sound
Solved No Sound
Post by Sir $wat on Wed Jul 01, 2009 2:21 am
My Friend's pc canoot play any audio file. Programs are loaded to play it but there is no sound coming from the speakers.
The driver is intalled and everything but still no sound.
Anything to do with codecs?
Points Points : 34151
Solved Re: No Sound
Post by Doctor Inferno on Wed Jul 01, 2009 12:29 pm
What player are you using? Is the audio jack plugged in the computer?
Solved Re: No Sound
Post by Sir $wat on Wed Jul 01, 2009 6:25 pm
yea, everything is plugged in correctly. They r using Windows media player and the also tried to play music on Nero.
The computer was recently redone.
Solved Re: No Sound
Post by Doctor Inferno on Thu Jul 02, 2009 9:14 am
Probably missing a codec, get VLC and try again. No codec is need when using VLC.
Solved Re: No Sound
Post by Sir $wat on Thu Jul 02, 2009 10:31 am
Tanx Doc,
i'll let u know
