Left or right click won't work
Solved Left or right click won't work
Post by davew on Tue Jun 30, 2009 1:42 am
On my HP laptop the the left click won't work or when you tap the mouse pad, but the right click works sometimes. Any ideas on how to fix it? Thank you.
davew
Joined Joined : 2009-06-30
OS OS : Vista
Points Points : 27154
Solved Re: Left or right click won't work
Post by Doctor Inferno on Tue Jun 30, 2009 1:52 pm
You may have disabled the touch pad. There should be a button near the touch pad usually at the top, make sure the light is blue, not orange.
Post by davew on Wed Jul 01, 2009 1:32 am
I figured it out, I downloaded the synaptics pointing device driver from the HP site and its working fine now. Thanks a lot for your advice, sorry to waste your time.
davew
OS OS : Vista
