Need help removing System Security
Post by yooperman on 29th June 2009, 8:39 pm
I'm running Windows XP and can't get rid of System Security. It is preventing me from opening up programs. I have tried booting up in safe mode, but I get a blue error screen. It says that a problem has been detected and windows has shut down. I'm stuck and don't know what to try next.
yooperman
Posts Posts : 8
Joined Joined : 2009-06-29
Points Points : 27220
Re: Need help removing System Security
Post by Belahzur on 29th June 2009, 8:42 pm
  2. Will IceSword open?
Points Points : 245111
Post by yooperman on 29th June 2009, 8:45 pm
Ice Sword will not open
yooperman
Posts Posts : 8
Post by Belahzur on 29th June 2009, 8:53 pm
Did it extract fine?
Can you rename the file to winlogon.exe and see if it runs?
Post by yooperman on 29th June 2009, 8:57 pm
I have it extracted and on the desktop without any problems. I also renamed it to winlogon.exe, but it didn't run.
yooperman
Posts Posts : 8
Post by Belahzur on 29th June 2009, 9:08 pm
Post by yooperman on 29th June 2009, 9:17 pm
I cannot open dds.scr. I'm prevented from opening up a browser on my computer so I'm doing this through a second laptop and transferring the file via USB drive. Is this ok?
yooperman
Posts Posts : 8
Post by Belahzur on 29th June 2009, 9:29 pm
Yep.
Post by yooperman on 29th June 2009, 9:36 pm
ok, good. So the dds.scr is on my desktop and won't open. What else can I try?
yooperman
Posts Posts : 8
Post by Belahzur on 29th June 2009, 11:39 pm
Please download MGTools using the links on this page:
Once downloaded, run MGTools.exe, which probably won't run because of the infection right now.
However, MGTools will still drop it's files, so navigate to this folder in bold:
C:\MGTools
Inside there, there is a file called "Analyze.exe" which is actually Hijack This.
See if you can run it.
Post by yooperman on 30th June 2009, 12:08 am
MGtools.exe ran and opened up a command prompt
yooperman
Posts Posts : 8
Post by yooperman on 30th June 2009, 2:13 am
OK. I looked around the site and found some extra help on what to do next. Here is the log file.
Scan saved at 9:55:01 PM, on 6/29/2009
Platform: Windows XP SP1 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
C:\Program Files\QuickTime\QTTask.exe
C:\WINDOWS\System32\ctfmon.exe
C:\Documents and Settings\user\Desktop\MGtools.exe
C:\WINDOWS\System32\cmd.exe
C:\WINDOWS\system32\ntvdm.exe
C:\MGTools\analyse.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = 127.0.0.1
R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - (no file)
F2 - REG:system.ini: UserInit=C:\WINDOWS\system32\userinit.exe,C:\WINDOWS\System32\sdra64.exe,
O2 - BHO: C:\WINDOWS\System32\gsf83iujid.dll - {D76AB2A1-00F3-42BD-F434-00BBC39C8953} - C:\WINDOWS\System32\gsf83iujid.dll
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
O4 - HKLM\..\Run: [Apoint] C:\Program Files\Apoint2K\Apoint.exe
O4 - HKLM\..\Run: [ezShieldProtector for Px] C:\WINDOWS\System32\ezSP_Px.exe
O4 - HKLM\..\Run: [Drag'n Drop CD+DVD] C:\Program Files\Drag'n Drop CD+DVD\BinFiles\DragDrop.exe /StartUp
O4 - HKLM\..\Run: [NDSTray.exe] "C:\Program Files\Toshiba\ConfigFree\NDSTray.exe"
O4 - HKLM\..\Run: [DpUtil] C:\Program Files\TOSHIBA\DualPointUtility\TEDTray.exe
O4 - HKLM\..\Run: [THotkey] C:\Program Files\Toshiba\Toshiba Applet\thotkey.exe
O4 - HKLM\..\Run: [TPWRSAVE] C:\Program Files\Toshiba\Toshiba Applet\tpwrsave.exe -S
O4 - HKLM\..\Run: [TMEPROP] C:\Program Files\Toshiba\Toshiba Applet\TMEPROP.exe -S
O4 - HKLM\..\Run: [ATIModeChange] Ati2mdxx.exe
O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
O4 - HKLM\..\Run: [LtMoh] C:\Program Files\ltmoh\Ltmoh.exe
O4 - HKLM\..\Run: [Pinger] C:\TOSHIBA\ivp\ISM\pinger.exe /run
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\System32\spool\drivers\w32x86\3\hpztsb07.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_01\bin\jusched.exe"
O4 - HKLM\..\Run: [Motive SmartBridge] C:\PROGRA~1\SBCLIG~1\SMARTB~1\MotiveSB.exe
O4 - HKLM\..\Run: [EPSON Stylus CX6600 Series] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATI9EA.EXE /P26 "EPSON Stylus CX6600 Series" /O6 "USB001" /M "Stylus CX6600"
O4 - HKLM\..\Run: [sysldtray] C:\windows\ld11.exe
O4 - HKLM\..\Run: [15458614] C:\Documents and Settings\All Users\Application Data\15458614\15458614.exe
O4 - HKLM\..\Run: [reader_s] C:\WINDOWS\System32\reader_s.exe
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\System32\ctfmon.exe
O4 - HKCU\..\Run: [] C:\WINDOWS\TEMP\jcmun28s8z.exe
O4 - HKCU\..\Run: [A00FDB507.exe] C:\WINDOWS\TEMP\_A00FDB507.exe
O4 - HKCU\..\Run: [12CFG515-K641-55SF-N66P] C:\RECYCLER\S-1-5-21-0243636035-3055115376-381863306-1556\pqlmq.exe
O4 - HKCU\..\Run: [reader_s] C:\Documents and Settings\user\reader_s.exe
O4 - HKCU\..\Run: [hsf7husjnfg98gi498aejhiugjkdg4] C:\WINDOWS\TEMP\jcmun28s8z.exe
O4 - S-1-5-18 Startup: IEHOME.LNK = C:\Documents and Settings\Default User\Local Settings\Temp\iehome.bat (User 'SYSTEM')
O4 - .DEFAULT Startup: IEHOME.LNK = C:\Documents and Settings\Default User\Local Settings\Temp\iehome.bat (User 'Default user')
O4 - .DEFAULT User Startup: IEHOME.LNK = C:\Documents and Settings\Default User\Local Settings\Temp\iehome.bat (User 'Default user')
O4 - Global Startup: RAMASST.lnk = C:\WINDOWS\system32\RAMASST.exe
O4 - Global Startup: SBC Self Support Tool.lnk = C:\Program Files\SBC LightSpeed Self Support Tool\bin\matcli.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\OFFICE11\REFIEBAR.DLL
O9 - Extra button: Related - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
O9 - Extra 'Tools' menuitem: Show &Related Links - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
O14 - IERESET.INF: START_PAGE_URL=http://www.toshiba.com
O20 - Winlogon Notify: __c00AF084 - C:\WINDOWS\System32\__c00AF084.dat
O22 - SharedTaskScheduler: rtasgvfu76ew8ndkfno94 - {D76AB2A1-00F3-42BD-F434-00BBC39C8953} - C:\WINDOWS\System32\gsf83iujid.dll
O23 - Service: Ati HotKey Poller - Unknown owner - C:\WINDOWS\System32\Ati2evxx.exe
O23 - Service: avast!antivirus - Unknown owner - C:\WINDOWS\System32\avast!Antivirus.exe
O23 - Service: Background Intelligent Transfer Service (BITS) - Unknown owner - C:\WINDOWS\
O23 - Service: DVD-RAM_Service - Matsushita Electric Industrial Co., Ltd. - C:\WINDOWS\System32\DVDRAMSV.exe
O23 - Service: SoundMAX Agent Service (SoundMAX Agent Service (default)) - Analog Devices, Inc. - C:\Program Files\Analog Devices\SoundMAX\SMAgent.exe
O23 - Service: THKEYS - Unknown owner - C:\Program Files\Toshiba\Toshiba Applet\thkeys.exe
O23 - Service: TME3SRV - IEC - C:\Program Files\Toshiba\Toshiba Applet\tme3srv.exe
O23 - Service: websrvx - Unknown owner - C:\Program Files\websrvx\websrvx.exe
O23 - Service: Automatic Updates (wuauserv) - Unknown owner - C:\WINDOWS\
End of file - 6757 bytes
yooperman
Posts Posts : 8
Post by Belahzur on 30th June 2009, 8:40 am
Oh dear...
This machine only has SP1 installed, when we are now at SP3, which means you've left security holes open for so long, the malware has damaged so much we can't reverse it.
I'm afraid I have bad news.
Your system is infected with a polymorphic file infector called Virut. Virut is capable of infecting all the machine's executable files (.exe) and screensaver files (.scr). However, the problem is that the virus has a number of bugs in its code, and as a result, it may misinfect a proportion of executable files and therefore, the files are corrupted beyond repair. As of now, security experts suggest that a format and clean install, or destructive recovery if you have an OEM recovery partition, is the best way to clean the infection and it is the best and safest way to return the machine to its normal working state.
Backup all your documents and important items (personal data, work documents, etc) only. DO NOT backup any executable files (softwares) and screensavers (*.scr). It attempts to infect any accessed .exe or .scr files by appending itself to the executable.
Also, avoid backing up compressed files (zip/cab/rar) files that have .exe or .scr files inside them. Virut can penetrate and infect .exe files inside compressed files too.
Recent variants also modify htm, html, asp and php files.
Do not back up to another machine, as it may become compromised. Burn to DVD/CD, or to an external drive which has nothing else on it, and which you can format should it happen to become infected from the backups.
For more information, please see [You must be registered and logged in to see this link.]
Instructions how to format and reinstall Windows can be found [You must be registered and logged in to see this link.]
Post by yooperman on 30th June 2009, 4:16 pm
Thank you very much for you help and concern. If it's as bad as you say, I think I will just use this as an excuse to get a new computer. As you can tell, it's about time anyway.
yooperman
Posts Posts : 8
system security
Post by jfpoolman1234 on 30th June 2009, 10:10 pm
download or extract anyhing, please help me![b]
jfpoolman1234
Posts Posts : 14
Joined Joined : 2009-06-30
OS OS : windows xp
Points Points : 27216
