A little help?
A little help?
Post by completelyclueless on Sat Jun 27, 2009 2:09 am
Ok, I'm not sure if I'm posting in the right part of the forum but, in normal mode I can't use the internet OR system restore, but when I go into safemode I can use the internet but STILL cannot restore. Also I have scanned for viruses and spyware and had nothing show up.. anyone know what the problem is?
completelyclueless
OS : Windows XP Professional
Re: A little help?
Post by Lance(HAOH) on Sat Jun 27, 2009 5:38 am
Hi, there could only be one possibility to your problem:
You have turned off system restore in the control panel.
I recommend that if you are still unable to do a system restore, insert the XP recovery disk, boot your computer with it and do a restore. Awesome (sparkly)
Lance(HAOH)
OS : Windows XP Professional, Windows 7 Enterprise, Windows 8 Professional WMC, Ubuntu Linux
