system is terribly slow and irressposive
Post by priya1984 on 26th June 2009, 7:53 pm
Pl help! The system is so so so slow.
priya1984
Posts Posts : 153
Joined Joined : 2009-02-10
OS OS : Windows XP Professional
Points Points : 29813
Re: system is terribly slow and irressposive
Post by Belahzur on 27th June 2009, 1:27 am
Points Points : 245091
