HP wireless card issues
Solved HP wireless card issues
Post by ThE_RoGuE on Fri Jun 26, 2009 1:00 am
i recently had problems with my machine with Cryptor virus, Belahzur helped me greatly to resolve this issue but since then my wireless card will not detect any networks.. i have a HP Pavilion dv6122ea machine...i tried reinstalling drivers to no avail...is there any hope or should i invest in a new wireless network card???
thanks
ThE_RoGuE
OS : XP
Solved Re: HP wireless card issues
Post by Doctor Inferno on Fri Jun 26, 2009 1:12 pm
Go to Start >> Control Panel >> System and Maintenance >> System >> Device Manager >> select Network Adapters >> Right click your driver and select uninstall.
Install the driver again and see how.
Post by ThE_RoGuE on Fri Jun 26, 2009 2:54 pm
ok m8 i tried your suggestion but it will still not find any networks at all...i had a look at some reviews and it seems this machine is notorious for this and some people say that after replacing the wireless network card it still has issues so it seems to me that it might be a problem with the MOBO... i guess i will need to just try a wireless usb dongle instead
ThE_RoGuE
OS : XP
Post by Doctor Inferno on Sat Jun 27, 2009 11:48 am
Ok. Should be fine.
Post by ThE_RoGuE on Sat Jun 27, 2009 1:09 pm
thanks for your time and help all the same m8 greatly appreciated Thank You!
ThE_RoGuE
OS : XP
