WinBlue Soft..PLEASE help
Re: WinBlue Soft..PLEASE help
Post by Belahzur on 27th June 2009, 6:28 pm
Please delete this file in bold:
c:\windows\system32\17286h5z9tool.bin
You aren't running Anti Virus Software
Please install Avira antivirus otherwise you won't be protected.
ComboFix /u
Points Points : 245121
Post by in deep trouble on 27th June 2009, 10:53 pm
Much Better! Thank very much, your the best Hooray!
in deep trouble
Posts Posts : 20
Joined Joined : 2009-06-23
Points Points : 27302
