System security problem
Page 1 of 2
Page 1 of 2 • 1, 2
- jrfoy2Novice
OS : xp
Rubies : 3233
I have downloaded anti-virus programs but the virus won't allow me to run them. I opened the first time users guide here and it wouldn't let me open the Java download either.
Help.....
John
Help.....
John
- OriginTech Colleague
OS : Windows Xp Sp3
Rubies : 7036
See if you can run HijackThis:
Please download the current version of HijackThis from HERE
- Double click and run the installer.
- It will install to C:\Program Files\Trend Micro\HijackThis\hijackthis.exe
- After installing, you should get the user agreement, press accept and Hijack This will run.
- Select Do a system scan and save a log file. This will open a notepad file of everything Hijack This found, copy and paste it back here.
While my help is always free, please consider donating to keep this site alive: Donate
- jrfoy2Novice
OS : xp
Rubies : 3233
Still blocked it.
John
John
OS : Windows Xp Sp3
Rubies : 7036
Download IceSword from here:
http://rapidshare.com/files/246323341/IceSword.exe
Tell me if it stays open.
- jrfoy2Novice
OS : xp
Rubies : 3233
I still get the "warning the file you are opening is infected" on lower right when I try to open it. It starts to open for less than a half second and stops when the warning comes on. This also happens when trying to open a program like Window Washer on the windows screen. It also delays getting onto IE but finally lets me on.
John
John
- BelahzurSite Admin
OS : 7 Home Premium x64
Rubies : 218220
Right click the IceSword you have now, select Rename. Rename IceSword.exe to winlogon.exe and see if it will run now.
Site Admin / Security Administrator
[Prework] - Please PM me if I fail to respond within 24hrs.
- jrfoy2Novice
OS : xp
Rubies : 3233
couldn't open it as winlog.exe either. It opens momentarily then goes away.....CRAP
I'm donating anyway. Thanks for trying so hard for someone you've never met. A great service. I need an updated computer anyway.
John
John
OS : Windows Xp Sp3
Rubies : 7036
See if you can run ComboFix:
- Download combofix from here
Link 1
Link 2
- See HERE for how to disable your AV. (Mcafee)
- Double click on ComboFix.exe.
- Follow the prompts. NOTE:
- ComboFix will check to see if the Microsoft Windows Recovery Console is installed.
***It's strongly recommended to have the Recovery Console installed before doing any malware removal.*** - Allow combofix to run
- Post C:\combofix.txt back here.
Do not mouse click combofix's window whilst it's running. That may cause it to stall.
- jrfoy2Novice
OS : xp
Rubies : 3233
It tried to run (a second) which is longer then the others but they were interrupted by the virus.
John
John
Rubies : 218220
Can you download Hijack This from here?
http://www.mediafire.com/?dlt5m1lyjwk
Page 1 of 2 • 1, 2
Similar topics
Page 1 of 2
