WinBlueSoft - crying for help
Page 1 of 2 1, 2  Next
Re: WinBlueSoft - crying for help
Post by koalabear on 22nd June 2009, 6:41 pm
It still says that my NOD32 is working.
koalabear
Posts Posts : 53
Joined Joined : 2009-06-22
Points Points : 27325
Post by Origin on 22nd June 2009, 6:43 pm
Looks like we are going to have to do this is safe mode,
Can you do the following in Safe Mode with Networking, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode with Networking" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.) Once in the start up menu, select "Safe Mode with Networking", then do the following instructions:
Now follow the ComboFix instructions.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31513
Post by koalabear on 22nd June 2009, 6:54 pm
my problems don't end.... I cannot access safe mode...I select it but then it starts to show lots of lines with [You must be registered and logged in to see this link.] including and then it restarts and takes me back to choose between safe mode and normal.
Sad tearing
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 6:57 pm
Can you still access normal Safe mode not safe mode with networking?
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 6:58 pm
nope, neither of them.
koalabear
Posts Posts : 53
Post by Belahzur on 22nd June 2009, 6:59 pm
New ideas. Please post a new Hijack This log, I want to kill some other items too.
Points Points : 245101
Post by koalabear on 22nd June 2009, 7:04 pm
here it is....
Scan saved at 21:04:02, on 22.6.2009
C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
C:\WINDOWS\Explorer.exe
C:\Program Files\Analog Devices\Core\smax4pnp.exe
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\MOM.EXE
C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe
C:\Program Files\Winamp\winampa.exe
C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\ccc.exe
C:\Program Files\WIDCOMM\Bluetooth Software\BTTray.exe
C:\PROGRA~1\WIDCOMM\BLUETO~1\BTSTAC~1.EXE
C:\WINDOWS\system32\agrsmsvc.exe
C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe
C:\DOCUME~1\Kordic\LOCALS~1\Temp\winuutq.exe
C:\DOCUME~1\Kordic\LOCALS~1\Temp\winlqsfs.exe
\Arhitekt-397a7d\c\MGtools\analyse.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Search,Default_Search_URL = [You must be registered and logged in to see this link.]
F2 - REG:system.ini: Shell=Explorer.exe "C:\Program Files\Outlook Express\wab.exe"
O4 - HKLM\..\Run: [StartCCC] C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe
O4 - HKLM\..\Run: [SoundMAX] C:\Program Files\Analog Devices\SoundMAX\Smax4.exe /tray
O4 - HKLM\..\Run: [QlbCtrl] %ProgramFiles%\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe /Start
O4 - HKLM\..\Run: [Cleanup] C:\Documents and Settings\Kordic\Contacts\svchost.exe
O4 - HKLM\..\Run: [PWRISOVM.EXE] C:\Program Files\PowerISO\PWRISOVM.EXE
O4 - HKLM\..\Run: [WinampAgent] "C:\Program Files\Winamp\winampa.exe"
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Ahead\Lib\NeroCheck.exe
O4 - HKLM\..\Run: [egui] "C:\Program Files\ESET\ESET NOD32 Antivirus\egui.exe" /hide /waitservice
O4 - HKLM\..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe"
O4 - HKCU\..\Run: [Cleanup] C:\Documents and Settings\Kordic\Contacts\svchost.exe
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-21-583907252-1202660629-682003330-1003\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe (User 'Kordic')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
O4 - Global Startup: AutoCAD Startup Accelerator.lnk = C:\Program Files\Common Files\Autodesk Shared\acstart16.exe
O4 - Global Startup: Bluetooth.lnk = ?
O8 - Extra context menu item: I&zvoz u Microsoft Excel - [You must be registered and logged in to see this link.]
O8 - Extra context menu item: Send to &Bluetooth Device... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
O9 - Extra button: Istraivanje - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O10 - Unknown file in Winsock LSP: c:\windows\system32\lspcfm.dll
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} (Java Runtime Environment 1.6.0) - [You must be registered and logged in to see this link.]
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\WINDOWS\system32\agrsmsvc.exe
O23 - Service: Autodesk Licensing Service - Autodesk - C:\Program Files\Common Files\Autodesk Shared\Service\AdskScSrv.exe
O23 - Service: Bluetooth Service (btwdins) - Broadcom Corporation. - C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
O23 - Service: Eset HTTP Server (EhttpSrv) - Unknown owner - C:\Program Files\ESET\ESET NOD32 Antivirus\EHttpSrv.exe (file missing)
O23 - Service: NBService - Nero AG - C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe
End of file - 7447 bytes
koalabear
Posts Posts : 53
Post by Belahzur on 22nd June 2009, 7:07 pm
Some new items showed up, yet I'm suprised Origins Hijack This fix actually worked, because registry editing was disabled.
There's a file on your machine I can't find anything on, which maybe regenerating this infection, so I want to get it uploaded and scanned.
Submit a file for analysis.
  1. Please visit this website: [You must be registered and logged in to see this link.]
  2. Press the "Browse" button and locate the following file in bold:
    C:\WINDOWS\system32\lspcfm.dll
  3. Press the "Submit File button to submit the file for analysis.
  4. Allow it to be scanned, it could take a few minutes depending on server load.
  5. Copy and paste the result back here.
Post by koalabear on 22nd June 2009, 7:14 pm
I can't open that page...it just loads for ages and then ''cannot find server''.
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 7:17 pm
Thats due to the Rookit, looks like we are going to have to kill it manually,
  1. Unzip it and start GMER.
Posts Posts : 2685
Post by Belahzur on 22nd June 2009, 7:18 pm
Two more online scanners to try::
Let me know which (if) one works, and upload the file for a scan.
Post by koalabear on 22nd June 2009, 8:04 pm
neither of those sites work for me...
GMER 1.0.15.14972 - [You must be registered and logged in to see this link.]
Rootkit scan 2009-06-22 22:03:47
---- System - GMER 1.0.15 ----
SSDT sptd.sys ZwCreateKey [0xBA6BE0D0]
SSDT sptd.sys ZwEnumerateKey [0xBA6C3FB2]
SSDT sptd.sys ZwEnumerateValueKey [0xBA6C4340]
SSDT sptd.sys ZwOpenKey [0xBA6BE0B0]
SSDT sptd.sys ZwQueryKey [0xBA6C4418]
SSDT sptd.sys ZwQueryValueKey [0xBA6C4298]
SSDT sptd.sys ZwSetValueKey [0xBA6C44AA]
INT 0x06 \??\C:\WINDOWS\system32\drivers\Haspnt.sys (HASP Kernel Device Driver for Windows NT/Aladdin Knowledge Systems) AE74C16D
INT 0x0E \??\C:\WINDOWS\system32\drivers\Haspnt.sys (HASP Kernel Device Driver for Windows NT/Aladdin Knowledge Systems) AE74BFC2
Code 8A9A9688 ZwFlushInstructionCache
Code 8AADD446 IofCallDriver
Code 8AADD4C6 IofCompleteRequest
---- Kernel code sections - GMER 1.0.15 ----
.text ntkrnlpa.exe!IofCallDriver 804EF15A 5 Bytes JMP 8AADD44B
.text ntkrnlpa.exe!IofCompleteRequest 804EF1EA 5 Bytes JMP 8AADD4CB
PAGE ntkrnlpa.exe!ZwFlushInstructionCache 805B5288 5 Bytes JMP 8A9A968C
? C:\WINDOWS\system32\drivers\sptd.sys The process cannot access the file because it is being used by another process.
.text USBPORT.SYS!DllUnload B9C8180C 5 Bytes JMP 8AC801C8
? C:\WINDOWS\system32\drivers\pukmnn.sys The system cannot find the file specified. !
---- User code sections - GMER 1.0.15 ----
.text C:\Program Files\MSN Messenger\msnmsgr.exe[728] kernel32.dll!SetUnhandledExceptionFilter 7C8447ED 5 Bytes JMP 004DE392 C:\Program Files\MSN Messenger\msnmsgr.exe (Messenger/Microsoft Corporation)
.text C:\WINDOWS\System32\svchost.exe[1344] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 100046D0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] kernel32.dll!CreateProcessInternalW 7C819704 5 Bytes JMP 100072A0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] ADVAPI32.dll!CryptGenKey 77E114B1 5 Bytes JMP 100053B0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] CRYPT32.dll!PFXImportCertStore 77AEF748 5 Bytes JMP 100053C0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetCreateUrlA + 1A5 771C2714 5 Bytes JMP 10006CB0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetCloseHandle 771C4DAC 5 Bytes JMP 10005920 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!HttpQueryInfoA 771C7842 5 Bytes JMP 100063E0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetReadFile 771C812C 5 Bytes JMP 10003070 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetQueryDataAvailable 771D8A17 5 Bytes JMP 10003040 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetGetCookieExA 771D9506 5 Bytes JMP 10002A70 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetReadFileExW 771F8071 5 Bytes JMP 100030A0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetReadFileExA 771F8D78 5 Bytes JMP 100030D0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetSetCookieExW 77215AD2 5 Bytes JMP 10002810 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 100046D0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] kernel32.dll!CreateProcessInternalW 7C819704 5 Bytes JMP 100072A0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] ADVAPI32.dll!CryptGenKey 77E114B1 5 Bytes JMP 100053B0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetCreateUrlA + 1A5 771C2714 5 Bytes JMP 10006CB0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetCloseHandle 771C4DAC 5 Bytes JMP 10005920 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!HttpQueryInfoA 771C7842 5 Bytes JMP 100063E0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetReadFile 771C812C 5 Bytes JMP 10003070 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetQueryDataAvailable 771D8A17 5 Bytes JMP 10003040 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetGetCookieExA 771D9506 5 Bytes JMP 10002A70 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetReadFileExW 771F8071 5 Bytes JMP 100030A0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetReadFileExA 771F8D78 5 Bytes JMP 100030D0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetSetCookieExW 77215AD2 5 Bytes JMP 10002810 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] CRYPT32.dll!PFXImportCertStore 77AEF748 5 Bytes JMP 100053C0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 01E146D0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] kernel32.dll!CreateProcessInternalW 7C819704 5 Bytes JMP 01E172A0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] ADVAPI32.dll!CryptGenKey 77E114B1 5 Bytes JMP 01E153B0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] CRYPT32.dll!PFXImportCertStore 77AEF748 5 Bytes JMP 01E153C0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetCreateUrlA + 1A5 771C2714 5 Bytes JMP 01E16CB0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetCloseHandle 771C4DAC 5 Bytes JMP 01E15920 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!HttpQueryInfoA 771C7842 5 Bytes JMP 01E163E0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetReadFile 771C812C 5 Bytes JMP 01E13070 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetQueryDataAvailable 771D8A17 5 Bytes JMP 01E13040 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetGetCookieExA 771D9506 5 Bytes JMP 01E12A70 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetReadFileExW 771F8071 5 Bytes JMP 01E130A0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetReadFileExA 771F8D78 5 Bytes JMP 01E130D0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetSetCookieExW 77215AD2 5 Bytes JMP 01E12810 C:\WINDOWS\system32\lspcfm.dll
koalabear
Posts Posts : 53
---- Kernel IAT/EAT - GMER 1.0.15 ----
IAT atapi.sys[HAL.dll!READ_PORT_UCHAR] [BA6BEAD4] sptd.sys
IAT atapi.sys[HAL.dll!READ_PORT_BUFFER_USHORT] [BA6BEC1A] sptd.sys
IAT atapi.sys[HAL.dll!READ_PORT_USHORT] [BA6BEB9C] sptd.sys
IAT atapi.sys[HAL.dll!WRITE_PORT_BUFFER_USHORT] [BA6BF748] sptd.sys
IAT atapi.sys[HAL.dll!WRITE_PORT_UCHAR] [BA6BF61E] sptd.sys
IAT \SystemRoot\system32\DRIVERS\i8042prt.sys[HAL.dll!READ_PORT_UCHAR] [BA6D429A] sptd.sys
Device \FileSystem\Ntfs \Ntfs 8AF051E8
AttachedDevice \FileSystem\Ntfs \Ntfs eamon.sys (Amon monitor/ESET)
Device \FileSystem\Fastfat \FatCdrom 8A6E5790
Device \Driver\NetBT \Device\NetBT_Tcpip_{E70F942A-4CC0-4075-BFA4-274B1F4F1211} 8AB61790
Device \Driver\usbuhci \Device\USBPDO-0 8AC7F1E8
Device \Driver\dmio \Device\DmControl\DmIoDaemon 8AE951E8
Device \Driver\dmio \Device\DmControl\DmConfig 8AE951E8
Device \Driver\dmio \Device\DmControl\DmPnP 8AE951E8
Device \Driver\dmio \Device\DmControl\DmInfo 8AE951E8
Device \Driver\usbehci \Device\USBPDO-1 8AC681E8
Device \Driver\usbuhci \Device\USBPDO-2 8AC7F1E8
Device \Driver\usbuhci \Device\USBPDO-3 8AC7F1E8
Device \Driver\usbehci \Device\USBPDO-4 8AC681E8
AttachedDevice \Driver\Tcpip \Device\Tcp epfwtdir.sys
Device \Driver\usbuhci \Device\USBPDO-5 8AC7F1E8
Device \Driver\usbuhci \Device\USBPDO-6 8AC7F1E8
Device \Driver\Ftdisk \Device\HarddiskVolume1 8AF071E8
Device \Driver\atapi \Device\Ide\IdeDeviceP0T0L0-3 8AF061E8
Device \Driver\atapi \Device\Ide\IdePort0 8AF061E8
Device \Driver\atapi \Device\Ide\IdePort1 8AF061E8
Device \Driver\atapi \Device\Ide\IdeDeviceP1T0L0-e 8AF061E8
Device \Driver\NetBT \Device\NetBt_Wins_Export 8AB61790
Device \Driver\NetBT \Device\NetbiosSmb 8AB61790
Device \Driver\NetBT \Device\NetBT_Tcpip_{5864CB14-1664-4ECB-BEA0-F37208407BFA} 8AB61790
Device \Driver\usbuhci \Device\USBFDO-0 8AC7F1E8
Device \Driver\usbuhci \Device\USBFDO-1 8AC7F1E8
Device \FileSystem\MRxSmb \Device\LanmanDatagramReceiver 8A104790
Device \Driver\usbehci \Device\USBFDO-2 8AC681E8
Device \FileSystem\MRxSmb \Device\LanmanRedirector 8A104790
Device \Driver\usbuhci \Device\USBFDO-3 8AC7F1E8
Device \Driver\usbuhci \Device\USBFDO-4 8AC7F1E8
Device \Driver\Ftdisk \Device\FtControl 8AF071E8
Device \Driver\usbuhci \Device\USBFDO-5 8AC7F1E8
Device \Driver\usbehci \Device\USBFDO-6 8AC681E8
Device \FileSystem\Fastfat \Fat 8A6E5790
AttachedDevice \FileSystem\Fastfat \Fat eamon.sys (Amon monitor/ESET)
Device \FileSystem\Cdfs \Cdfs 8ABFC790
koalabear
Posts Posts : 53
Post by koalabear on 22nd June 2009, 8:05 pm
---- Services - GMER 1.0.15 ----
Service C:\WINDOWS\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys (*** hidden *** ) [SYSTEM] MSIVXserv.sys <-- ROOTKIT !!!
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys@start 1
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys@type 1
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys@imagepath \systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys@group file system
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys\modules
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys\modules@MSIVXserv \\?\globalroot\systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys\modules@MSIVXl \\?\globalroot\systemroot\system32\MSIVXanxylksdotehtivyfxonkdirapuhpqwb.dll
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys\modules@MSIVXclk \\?\globalroot\systemroot\system32\MSIVXdjlnmplwnabwqwaihtirhrivrjkxgokl.dll
Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys@start 1
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys@type 1
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys@imagepath \systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys@group file system
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys\modules
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys\modules@MSIVXserv \\?\globalroot\systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys\modules@MSIVXl \\?\globalroot\systemroot\system32\MSIVXanxylksdotehtivyfxonkdirapuhpqwb.dll
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys\modules@MSIVXclk \\?\globalroot\systemroot\system32\MSIVXdjlnmplwnabwqwaihtirhrivrjkxgokl.dll
Reg HKLM\SYSTEM\ControlSet002\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys@start 1
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys@type 1
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys@imagepath \systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys@group file system
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys\modules
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys\modules@MSIVXserv \\?\globalroot\systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys\modules@MSIVXl \\?\globalroot\systemroot\system32\MSIVXanxylksdotehtivyfxonkdirapuhpqwb.dll
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys\modules@MSIVXclk \\?\globalroot\systemroot\system32\MSIVXdjlnmplwnabwqwaihtirhrivrjkxgokl.dll
Reg HKLM\SYSTEM\ControlSet003\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys@start 1
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys@type 1
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys@imagepath \systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys@group file system
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys\modules
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys\modules@MSIVXserv \\?\globalroot\systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys\modules@MSIVXl \\?\globalroot\systemroot\system32\MSIVXanxylksdotehtivyfxonkdirapuhpqwb.dll
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys\modules@MSIVXclk \\?\globalroot\systemroot\system32\MSIVXdjlnmplwnabwqwaihtirhrivrjkxgokl.dll
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg@s1 771343423
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg@s2 285507792
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys@start 1
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys@type 1
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys@imagepath \systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys@group file system
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys\modules
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys\modules@MSIVXserv \\?\globalroot\systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys\modules@MSIVXl \\?\globalroot\systemroot\system32\MSIVXanxylksdotehtivyfxonkdirapuhpqwb.dll
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys\modules@MSIVXclk \\?\globalroot\systemroot\system32\MSIVXdjlnmplwnabwqwaihtirhrivrjkxgokl.dll
Reg HKLM\SYSTEM\ControlSet005\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@AppInit_DLLs
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@DeviceNotSelectedTimeout 15
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@GDIProcessHandleQuota 10000
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@Spooler yes
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@swapdisk
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@TransmissionRetryTimeout 90
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@USERProcessHandleQuota 10000
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 8:08 pm
Drivers to delete:
MSIVXserv.sys
Files to delete:
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 8:11 pm
I completed the first step, I'm not allowed to do the second by my Administrator. It asks me to reboot now...
koalabear
Posts Posts : 53
Post by koalabear on 22nd June 2009, 8:15 pm
I've rebooted it and here is the file :
Rootkit scan active.
Hidden driver "MSIVXserv.sys" found!
ImagePath: \systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Driver disabled successfully.
Rootkit scan completed.
Driver "MSIVXserv.sys" deleted successfully.
File "C:\WINDOWS\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys" deleted successfully.
Completed script processing.
Finished! Terminate.
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 8:16 pm
See if you can run Malwarebytes now.
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 8:17 pm
yes, I can. Smile
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 8:18 pm
Thats great new, please do a quick scan and post all the contents of the log back here Smile
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 8:24 pm
here it is :
Malwarebytes' Anti-Malware 1.38
Database version: 2283
22.6.2009 22:23:46
mbam-log-2009-06-22 (22-23-39).txt
Objects scanned: 97186
Time elapsed: 3 minute(s), 14 second(s)
Memory Processes Infected: 2
Registry Values Infected: 1
Registry Data Items Infected: 11
Files Infected: 9
C:\Documents and Settings\Kordic\Local Settings\Temp\winkodhi.exe (Trojan.Agent) -> No action taken.
C:\Documents and Settings\Kordic\Local Settings\Temp\dpqrbk.exe (Trojan.Downloader) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\taskman (Backdoor.Bot) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\DisableRegistryTools (Hijack.Regedit) -> Bad: (1) Good: (0) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\DisableTaskMgr (Hijack.TaskManager) -> Bad: (1) Good: (0) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\AntiVirusDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\FirewallDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> No action taken.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Tcpip\Parameters\Interfaces\{5864cb14-1664-4ecb-bea0-f37208407bfa}\NameServer (Trojan.DNSChanger) -> Data: 85.255.112.225,85.255.112.199 -> No action taken.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Tcpip\Parameters\Interfaces\{e70f942a-4cc0-4075-bfa4-274b1f4f1211}\NameServer (Trojan.DNSChanger) -> Data: 85.255.112.225,85.255.112.199 -> No action taken.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{5864cb14-1664-4ecb-bea0-f37208407bfa}\NameServer (Trojan.DNSChanger) -> Data: 85.255.112.225,85.255.112.199 -> No action taken.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{e70f942a-4cc0-4075-bfa4-274b1f4f1211}\NameServer (Trojan.DNSChanger) -> Data: 85.255.112.225,85.255.112.199 -> No action taken.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\Tcpip\Parameters\Interfaces\{5864cb14-1664-4ecb-bea0-f37208407bfa}\NameServer (Trojan.DNSChanger) -> Data: 85.255.112.225,85.255.112.199 -> No action taken.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\Tcpip\Parameters\Interfaces\{e70f942a-4cc0-4075-bfa4-274b1f4f1211}\NameServer (Trojan.DNSChanger) -> Data: 85.255.112.225,85.255.112.199 -> No action taken.
c:\RECYCLER\s-1-5-21-1708502002-5774778955-212626128-2853\rundll32.exe (Trojan.Dropper) -> No action taken.
c:\program files\outlook express\wab.exe.tmp (Trojan.Downloader) -> No action taken.
c:\WINDOWS\Tasks\{5B57CF47-0BFA-43c6-ACF9-3B3653DCADBA}.job (Trojan.FakeAlert) -> No action taken.
c:\WINDOWS\Temp\tempo-2191406.tmp (Trojan.DNSChanger) -> No action taken.
c:\WINDOWS\Temp\tempo-2192734.tmp (Trojan.DNSChanger) -> No action taken.
c:\WINDOWS\system32\MSIVXanxylksdotehtivyfxonkdirapuhpqwb.dll (Trojan.Agent) -> No action taken.
c:\WINDOWS\system32\MSIVXdjlnmplwnabwqwaihtirhrivrjkxgokl.dll (Trojan.Agent) -> No action taken.
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 8:26 pm
Good, the infection is getting beat, now you should be able to run DDS,
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 8:30 pm
I downloaded that but when I run it it opens a .txt with lots of gibberish...just a lot of letters
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 8:34 pm
Upload the .txt to rapidhsare for em to look at, do the following:
go to this site: [You must be registered and logged in to see this link.]
Once there, click on the Choose button and locate the DDS.txt and click ok. The file should upload and then it will give you a link to download the file from. Please post the link back here.
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 8:37 pm
koalabear
Posts Posts : 53
I just saw that it's now .txt.... It openes after I click on dds icon...just that.
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 8:39 pm
You uploaded the wrong file, you gave me the application instead of the log Wink
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 8:41 pm
I get only that after I click Run
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 8:46 pm
When you click on the dds.scr icon a black CMD window should appear, it will give you some brief description of what the tool does while in the background the scan is taking place. Once the scan is finished, two logs will pop up, a DDS.txt and a Attach.txt, I need to see the DDS.txt. Make sure you save both of them to the desktop. If you didn't save them then please run the scan again.
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 8:49 pm
when I download it from the second link and run it I get the message that it is not a valid Win32 application...
when I run it from the first link I get that notepad screen with lots of letters.
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 8:50 pm
Instead of uploading it can you post all contents of the log back here. It may take two or more posts.
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 8:57 pm
this is all that makes any sense between losts of unconnected letters :
  S e l e c t d e s t i n a t i o n f o l d e r
E x t r a c t i n g % s S k i p p i n g % s  U n e x p e c t e d e n d o f a r c h i v e  T h e f i l e " % s " h e a d e r i s c o r r u p t % T h e a r c h i v e c o m m e n t h e a d e r i s c o r r u p t  T h e a r c h i v e c o m m e n t i s c o r r u p t  N o t e n o u g h m e m o r y  U n k n o w n m e t h o d i n % s  C a n n o t o p e n % s  C a n n o t c r e a t e % s  C a n n o t c r e a t e f o l d e r % s  6 C R C f a i l e d i n t h e e n c r y p t e d f i l e % s ( w r o n g p a s s w o r d ? )  C R C f a i l e d i n % s  P a c k e d d a t a C R C f a i l e d i n % s  W r o n g p a s s w o r d f o r % s 5 W r i t e e r r o r i n t h e f i l e % s . P r o b a b l y t h e d i s k i s f u l l  R e a d e r r o r i n t h e f i l e % s  F i l e c l o s e e r r o r  T h e r e q u i r e d v o l u m e i s a b s e n t 2 T h e a r c h i v e i s e i t h e r i n u n k n o w n f o r m a t o r d a m a g e d  E x t r a c t i n g f r o m % s N e x t v o l u m e  T h e a r c h i v e h e a d e r i s c o r r u p t  C l o s e  E r r o r a E r r o r s e n c o u n t e r e d w h i l e p e r f o r m i n g t h e o p e r a t i o n
L o o k a t t h e i n f o r m a t i o n w i n d o w f o r m o r e d e t a i l s PA  b y t e s m o d i f i e d o n  f o l d e r i s n o t a c c e s s i b l e l S o m e f i l e s c o u l d n o t b e c r e a t e d .
P l e a s e c l o s e a l l a p p l i c a t i o n s , r e b o o t W i n d o w s a n d r e s t a r t t h i s i n s t a l l a t i o n \ S o m e i n s t a l l a t i o n f i l e s a r e c o r r u p t .
P l e a s e d o w n l o a d a f r e s h c o p y a n d r e t r y t h e i n s t a l l a t i o n A l l f i l e s PA E < u l > < l i > P r e s s < b > I n s t a l l < / b > b u t t o n t o s t a r t e x t r a c t i o n . < / l i > < b r > < b r > 6 < l i > U s e < b > B r o w s e < / b > b u t t o n t o s e l e c t t h e d e s t i n a t i o n 4 f o l d e r f r o m t h e f o l d e r s t r e e . I t c a n b e a l s o e n t e r e d  m a n u a l l y . < / l I > < b r > < b r > 8 < l I > I f t h e d e s t i n a t i o n f o l d e r d o e s n o t e x i s t , i t w i l l b e 2 c r e a t e d a u t o m a t i c a l l y b e f o r e e x t r a c t i o n . < / l I > < / u l > PAh        |
version="1.0.0.0"
processorArchitecture="X86"
name="WinRAR SFX"
type="win32"/>
WinRAR SFX module
uiAccess="false"/>
type="win32"
name="Microsoft.Windows.Common-Controls"
version="6.0.0.0"
publicKeyToken="6595b64144ccf1df"
language="*"/>
P e e f e f e f e (f e 2f e
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 9:04 pm
Lets try this locate the DDs.txt file, right click on it and select open with, now click on Word pad (If wordpad isn't present on the list select "browse" and search for word pad.
Are the symbols still appearing?
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 9:07 pm
I don't have dds.txt file! just this .scr...Notepad opens when I click on it.
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 9:11 pm
Alright lets try this, delete the current DDS.scr file and download this one:
Run it and see if you can get those logs, if not we are going to have to use another system scanner.
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 9:14 pm
it says that it is not a valid Win32 application.
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 9:17 pm
oh well lets try RSIT:
  • Download random's system information tool (RSIT) by random/random from [You must be registered and logged in to see this link.] and save it to your desktop.
  • Double click on RSIT.exe to run RSIT.
  • Click Continue at the disclaimer screen.
  • Once it has finished, two logs will open. Please post the contents of both log.txt (<< will be maximized) and info.txt (<< will be minimized)
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 9:23 pm
the same mesagge Sad tearing
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 9:27 pm
It pops out with "not a valid Win32 application."?
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 9:28 pm
yes.
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 9:31 pm
Alright try ComboFix even though it says ESET is still active.
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 9:34 pm
now it says the same for Combo-Fix...did I delete something important so this is happening?
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 9:47 pm
Not that I can think of since I haven't given you anything harmful to run. I am talking to a colleague of mine that will have you sorted out, please be patient for the moment.
Posts Posts : 2685
Post by koalabear on 22nd June 2009, 9:48 pm
ok, thank you for your help.
koalabear
Posts Posts : 53
Post by Origin on 22nd June 2009, 9:53 pm
For the mean time can you reboot your computer and then see if it works.
Posts Posts : 2685
Post by Belahzur on 22nd June 2009, 9:57 pm
I still think that lspcfm is malicious maybe, can you upload a copy of it to rapidshare please? I want a sample of it and I'll upload it.
Post by koalabear on 23rd June 2009, 8:12 am
[You must be registered and logged in to see this link.] wrote:For the mean time can you reboot your computer and then see if it works.
no, still the same.
@Belahzur : what's Ispcfm?
koalabear
Posts Posts : 53
Post by Origin on 23rd June 2009, 5:04 pm
Locate and upload this file to Rapidshare:
Posts Posts : 2685
Post by koalabear on 23rd June 2009, 5:56 pm
now internet isn't working on infected computer either Sad tearing
koalabear
Posts Posts : 53
Post by Belahzur on 23rd June 2009, 6:06 pm
Thank you for the file. It is indeed malware, but guess what? It's a new version of something, not exactly sure what right yet, only 3 scanners find something.
Microsoft 1.4803 2009.06.23 PWS:Win32/Pemsepos.A
NOD32 4181 2009.06.23 a variant of Win32/Kryptik.SR
Sunbelt 3.2.1858.2 2009.06.23 Trojan.Crypt.Krap (v)
Please download the LSPfix from here: [You must be registered and logged in to see this link.]
Unzip it to the Desktop (Important!!) and run it. Check the box that says "I know what I'm doing", and then select each instance of "lspcfm.dll" in the left-hand panel and click >> button to move it to the right-hand panel. Then click Finish to allow LSPfix to rebuild the LSP chain.
Reboot normally and your net connection should be back.
