WinBlueSoft - crying for help
Page 1 of 2 1, 2  Next
Post by koalabear on Mon Jun 22, 2009 2:02 pm
Can someone please help me?
I got infected by this WinBlueSoft this morning...I don't know what else can I do to remove it...I browsed through this page and...I tried that mbam.exe but that thing can't open for me. I tried downloading DDS by sUBs, hijackthis too, but nothing.
Please help me, I'm getting hopeless.
Please note that I'm not some computer-expert..
Thank you!
koalabear
Posts Posts : 53
Joined Joined : 2009-06-22
Points Points : 27275
Re: WinBlueSoft - crying for help
Post by Origin on Mon Jun 22, 2009 3:12 pm
  3. Then look in the left hand bottom of the program and press "Registry"
  4. When the registry list opens, drag the line between the two windows so you can see which registry hive you need.
  5. Next, open the HKEY_LOCAL_MACHINE, and navigate to the following key:
  6. Now look in the right side pane for two run values that are just random numbers.
  7. Once you have found the value(s), right click it and press "Delete"
  8. Okay the prompt and close IceSword.
**If you are unable to open the zipped file, download IceSword from here:
  • Please download IceSword from here, I unzipped it so you should only get the .exe file:
  • Once the file has downloaded, see if you can do the above instructions.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31463
Post by koalabear on Mon Jun 22, 2009 3:25 pm
I got to step no.6...I don't have just numbers here.
koalabear
Posts Posts : 53
Post by Belahzur on Mon Jun 22, 2009 3:52 pm
Origin got the key wrong, the problem is in this key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
Then in the right side pane of Winlogon, find AppInit_DLLs, which points are "blocker.dll"
Delete the AppInit_DLLs value.
See if you can run Hijack This then.
Points Points : 245049
Post by koalabear on Mon Jun 22, 2009 3:56 pm
I don't have AppInit_DLLs in the folder.
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 4:19 pm
Hello can you rename HijackThis to Flowers.exe See if it runs.
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 4:26 pm
I found this AppInit_DLLs file in Windows folder...should I delete it?
I tried renameing HijackThis...not working.
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 4:35 pm
Whats the name of the file?
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 4:37 pm
AppInit_DLLs
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 4:44 pm
No I don't think you should, many of those are crucial to the system.
Download MGtools from here: [You must be registered and logged in to see this link.]
Now follow the instructions on this page:
Once you haver MGtools extracted to your C:\ drive there will be a file there called Analyze.exe That file will be HijackThis, now follow these directions:
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 4:48 pm
That link is not working...
downloaded it from another one...will see if it works
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 4:51 pm
Weird works on my end, download it here:
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 4:55 pm
I downloaded it and runed it. It created MGTools folder but there is only empty temp folder and filelog and sysinfo file in it Sad tearing
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 4:58 pm
Locate and delete this file: C:\windows\system32\blocker.dll
Now see if you can run HijackThis.
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 5:01 pm
I did it with MGTools...here it is :
Scan saved at 19:00:05, on 22.6.2009
C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
C:\WINDOWS\Explorer.exe
C:\WINDOWS\system32\agrsmsvc.exe
C:\Program Files\Analog Devices\Core\smax4pnp.exe
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\MOM.EXE
C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe
C:\Program Files\Winamp\winampa.exe
C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe
C:\Program Files\DNA\btdna.exe
C:\WINDOWS\system32\setup2.exe
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\ccc.exe
C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe
C:\Program Files\WIDCOMM\Bluetooth Software\BTTray.exe
C:\PROGRA~1\WIDCOMM\BLUETO~1\BTSTAC~1.EXE
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\Program Files\MSN Messenger\usnsvc.exe
C:\DOCUME~1\Kordic\LOCALS~1\Temp\winrlkbyt.exe
C:\DOCUME~1\Kordic\LOCALS~1\Temp\dqpo.exe
C:\Program Files\Winamp\winamp.exe
\Arhitekt-397a7d\C\MGtools\analyse.exe
C:\Program Files\ESET\ESET NOD32 Antivirus\ekrn.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Search,Default_Search_URL = [You must be registered and logged in to see this link.]
R3 - URLSearchHook: DefaultSearchHook Class - {C94E154B-1459-4A47-966B-4B843BEFC7DB} - C:\Program Files\AskSearch\bin\DefaultSearch.dll
F2 - REG:system.ini: Shell=Explorer.exe "C:\Program Files\Outlook Express\wab.exe"
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O4 - HKLM\..\Run: [StartCCC] C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe
O4 - HKLM\..\Run: [SoundMAX] C:\Program Files\Analog Devices\SoundMAX\Smax4.exe /tray
O4 - HKLM\..\Run: [QlbCtrl] %ProgramFiles%\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe /Start
O4 - HKLM\..\Run: [Cleanup] C:\Documents and Settings\Kordic\Contacts\svchost.exe
O4 - HKLM\..\Run: [PWRISOVM.EXE] C:\Program Files\PowerISO\PWRISOVM.EXE
O4 - HKLM\..\Run: [WinampAgent] "C:\Program Files\Winamp\winampa.exe"
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Ahead\Lib\NeroCheck.exe
O4 - HKLM\..\Run: [egui] "C:\Program Files\ESET\ESET NOD32 Antivirus\egui.exe" /hide /waitservice
O4 - HKLM\..\Run: [AVG7_CC] C:\PROGRA~1\Grisoft\AVG7\avgcc.exe /STARTUP
O4 - HKLM\..\RunOnce: [Malwarebytes' Anti-Malware] C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe /install /silent
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe"
O4 - HKCU\..\Run: [Cleanup] C:\Documents and Settings\Kordic\Contacts\svchost.exe
O4 - HKCU\..\Run: [BitTorrent DNA] "C:\Program Files\DNA\btdna.exe"
O4 - HKCU\..\Run: [setup2.exe] C:\WINDOWS\system32\setup2.exe
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\Run: [AVG7_Run] C:\PROGRA~1\Grisoft\AVG7\avgw.exe /RUNONCE (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-21-583907252-1202660629-682003330-1003\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe (User 'Kordic')
O4 - HKUS\S-1-5-21-583907252-1202660629-682003330-1003\..\Run: [setup2.exe] C:\WINDOWS\system32\setup2.exe (User 'Kordic')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
O4 - Global Startup: AutoCAD Startup Accelerator.lnk = C:\Program Files\Common Files\Autodesk Shared\acstart16.exe
O4 - Global Startup: Bluetooth.lnk = ?
O8 - Extra context menu item: I&zvoz u Microsoft Excel - [You must be registered and logged in to see this link.]
O8 - Extra context menu item: Send to &Bluetooth Device... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
O9 - Extra button: Istraživanje - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O10 - Unknown file in Winsock LSP: c:\windows\system32\lspcfm.dll
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} (Java Runtime Environment 1.6.0) - [You must be registered and logged in to see this link.]
O17 - HKLM\System\CCS\Services\Tcpip\..\{5864CB14-1664-4ECB-BEA0-F37208407BFA}: NameServer = 85.255.112.225,85.255.112.199
O17 - HKLM\System\CCS\Services\Tcpip\..\{E70F942A-4CC0-4075-BFA4-274B1F4F1211}: NameServer = 85.255.112.225,85.255.112.199
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: NameServer = 85.255.112.225,85.255.112.199
O17 - HKLM\System\CS2\Services\Tcpip\Parameters: NameServer = 85.255.112.225,85.255.112.199
O17 - HKLM\System\CS3\Services\Tcpip\Parameters: NameServer = 85.255.112.225,85.255.112.199
O17 - HKLM\System\CS4\Services\Tcpip\Parameters: NameServer = 85.255.112.225,85.255.112.199
O17 - HKLM\System\CS5\Services\Tcpip\Parameters: NameServer = 85.255.112.225,85.255.112.199
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: NameServer = 85.255.112.225,85.255.112.199
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\WINDOWS\system32\agrsmsvc.exe
O23 - Service: Autodesk Licensing Service - Autodesk - C:\Program Files\Common Files\Autodesk Shared\Service\AdskScSrv.exe
O23 - Service: AVG7 Alert Manager Server (Avg7Alrt) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgamsvr.exe
O23 - Service: AVG7 Update Service (Avg7UpdSvc) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgupsvc.exe
O23 - Service: AVG E-mail Scanner (AVGEMS) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgemc.exe
O23 - Service: Bluetooth Service (btwdins) - Broadcom Corporation. - C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
O23 - Service: Eset HTTP Server (EhttpSrv) - Unknown owner - C:\Program Files\ESET\ESET NOD32 Antivirus\EHttpSrv.exe (file missing)
O23 - Service: Eset Service (ekrn) - ESET - C:\Program Files\ESET\ESET NOD32 Antivirus\ekrn.exe
O23 - Service: NBService - Nero AG - C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe
End of file - 9599 bytes
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 5:11 pm
  • Open HijackThis. (In this case Analyze.exe)
  • See [You must be registered and logged in to see this link.] for how to disable your AV. (Mcafee)
    Do not mouse click combofix's window whilst it's running. That may cause it to stall.
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 5:30 pm
I'm not able to diable my NOD32 nor to run combo-fix Sad tearing
koalabear
Posts Posts : 53
Post by koalabear on Mon Jun 22, 2009 5:36 pm
I accidentally restarted my computer and now it seems that WunBlueSoft is gone...is it possible that it's all gone even without running that Combo-Fix? :S
although I still can't runn NOD32 and my net keeps comming up with that ''cannot find server''....but those annoying messages are gone.
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 5:50 pm
Its gone because you fixed the infected lines in HijackThis but its not totally gone from your system as there are leftovers that could trigger it to come back.
Please do the following:
Open up Task Manager(Ctrl + Shift + Esc.), Locate egui.exe and highlight it by clicking on it, once highlighted, click on the "End Process" button. Now try running ComboFix.
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 5:53 pm
I'm such a pain in the arse...sorry! But...when I press Ctrl+Shift+Esc it says Task Manager has been disabled by your administrator. I don't know why it says so 'cause I'm the administrator on this pc.
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 6:07 pm
Most likely its due to virus, lets try a different approach,
  • Open HijackThis(Analyze.exe)
  • Click on the Open the Misc Tools section button
  • Navigate to System tools and click on Open process manager
  • Now locate egui.exe and click on the Kill process button
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 6:11 pm
there is no egui.exe here
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 6:17 pm
I need to see a list of your processes, please do the following:
  • Once there, click on the copy to clip board button
  • The process list should now be on your clip board, paste the list in your next reply
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 6:20 pm
Process list saved on 20:20:07, on 22.6.2009
[pid] [full path to filename] [file version] [company name]
804 C:\WINDOWS\System32\smss.exe 5.1.2600.2180 Microsoft Corporation
880 C:\WINDOWS\system32\winlogon.exe 5.1.2600.2180 Microsoft Corporation
924 C:\WINDOWS\system32\services.exe 5.1.2600.2180 Microsoft Corporation
948 C:\WINDOWS\system32\lsass.exe 5.1.2600.2180 Microsoft Corporation
1136 C:\WINDOWS\system32\Ati2evxx.exe 6.14.10.4174 ATI Technologies Inc.
1152 C:\WINDOWS\system32\svchost.exe 5.1.2600.2180 Microsoft Corporation
1360 C:\WINDOWS\System32\svchost.exe 5.1.2600.2180 Microsoft Corporation
1384 C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe 5.1.0.3000 Broadcom Corporation.
1756 C:\WINDOWS\system32\Ati2evxx.exe 6.14.10.4174 ATI Technologies Inc.
1876 C:\WINDOWS\system32\spoolsv.exe 5.1.2600.2696 Microsoft Corporation
2016 C:\WINDOWS\Explorer.exe 6.0.2900.2894 Microsoft Corporation
388 C:\Program Files\Analog Devices\Core\smax4pnp.exe 6.0.0.82 Analog Devices, Inc.
560 C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe 6.3.8.1 Hewlett-Packard Development Company, L.P.
576 C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\MOM.EXE 2.0.0.0 Advanced Micro Devices Inc.
636 C:\Program Files\Java\jre6\bin\jusched.exe 6.0.130.3 Sun Microsystems, Inc.
844 C:\Program Files\Winamp\winampa.exe
1164 C:\WINDOWS\system32\ctfmon.exe 5.1.2600.2180 Microsoft Corporation
1276 C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe 2.0.5.0 Nero AG
1336 C:\Program Files\WIDCOMM\Bluetooth Software\BTTray.exe 5.1.0.3000 Broadcom Corporation.
1928 C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\ccc.exe 2.0.0.0 ATI Technologies Inc.
2100 C:\PROGRA~1\WIDCOMM\BLUETO~1\BTSTAC~1.EXE 5.1.0.3000 Broadcom Corporation.
2380 C:\WINDOWS\system32\agrsmsvc.exe 1.0.0.4 Agere Systems
2460 C:\Program Files\Java\jre6\bin\jqs.exe 6.0.130.3 Sun Microsystems, Inc.
2480 C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE 7.0.9466.0 Microsoft Corporation
2916 C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe 2.0.5.0 Nero AG
3004 C:\Program Files\Hewlett-Packard\Shared\hpqwmiex.exe 2.0.2.3 Hewlett-Packard Development Company, L.P.
3096 C:\Program Files\Common Files\Ahead\Lib\NMIndexStoreSvr.exe 2.0.5.0 Nero AG
2692 C:\Program Files\Internet Explorer\IEXPLORE.EXE 6.0.2900.2180 Microsoft Corporation
2160 C:\DOCUME~1\Kordic\LOCALS~1\Temp\winsbhp.exe
3804 C:\Program Files\Internet Explorer\IEXPLORE.EXE 6.0.2900.2180 Microsoft Corporation
3944 C:\DOCUME~1\Kordic\LOCALS~1\Temp\suiujl.exe
4320 C:\Program Files\ESET\ESET NOD32 Antivirus\ekrn.exe 3.0.642.0 ESET
5176 \Arhitekt-397a7d\c\MGtools\analyse.exe
thank you so much for helping me...
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 6:32 pm
Kill a process in HijackThis
  • Now locate the following process(es)
    winsbhp.exe
    suiujl.exe
    ekrn.exe
  • and click on the Kill process button
Now locate and delete these files:
Now try to run ComboFix
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 6:41 pm
It still says that my NOD32 is working.
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 6:43 pm
Looks like we are going to have to do this is safe mode,
Can you do the following in Safe Mode with Networking, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode with Networking" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.) Once in the start up menu, select "Safe Mode with Networking", then do the following instructions:
Now follow the ComboFix instructions.
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 6:54 pm
my problems don't end.... I cannot access safe mode...I select it but then it starts to show lots of lines with [You must be registered and logged in to see this link.] including and then it restarts and takes me back to choose between safe mode and normal.
Sad tearing
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 6:57 pm
Can you still access normal Safe mode not safe mode with networking?
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 6:58 pm
nope, neither of them.
koalabear
Posts Posts : 53
Post by Belahzur on Mon Jun 22, 2009 6:59 pm
New ideas. Please post a new Hijack This log, I want to kill some other items too.
Post by koalabear on Mon Jun 22, 2009 7:04 pm
here it is....
Scan saved at 21:04:02, on 22.6.2009
C:\DOCUME~1\Kordic\LOCALS~1\Temp\winuutq.exe
C:\DOCUME~1\Kordic\LOCALS~1\Temp\winlqsfs.exe
O4 - HKLM\..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
End of file - 7447 bytes
koalabear
Posts Posts : 53
Post by Belahzur on Mon Jun 22, 2009 7:07 pm
Some new items showed up, yet I'm suprised Origins Hijack This fix actually worked, because registry editing was disabled.
There's a file on your machine I can't find anything on, which maybe regenerating this infection, so I want to get it uploaded and scanned.
Submit a file for analysis.
  1. Please visit this website: [You must be registered and logged in to see this link.]
  2. Press the "Browse" button and locate the following file in bold:
    C:\WINDOWS\system32\lspcfm.dll
  3. Press the "Submit File button to submit the file for analysis.
  4. Allow it to be scanned, it could take a few minutes depending on server load.
  5. Copy and paste the result back here.
Post by koalabear on Mon Jun 22, 2009 7:14 pm
I can't open that page...it just loads for ages and then ''cannot find server''.
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 7:17 pm
Thats due to the Rookit, looks like we are going to have to kill it manually,
  1. Unzip it and start GMER.
Posts Posts : 2685
Post by Belahzur on Mon Jun 22, 2009 7:18 pm
Two more online scanners to try::
Let me know which (if) one works, and upload the file for a scan.
Post by koalabear on Mon Jun 22, 2009 8:04 pm
neither of those sites work for me...
GMER 1.0.15.14972 - [You must be registered and logged in to see this link.]
Rootkit scan 2009-06-22 22:03:47
---- System - GMER 1.0.15 ----
SSDT sptd.sys ZwCreateKey [0xBA6BE0D0]
SSDT sptd.sys ZwEnumerateKey [0xBA6C3FB2]
SSDT sptd.sys ZwEnumerateValueKey [0xBA6C4340]
SSDT sptd.sys ZwOpenKey [0xBA6BE0B0]
SSDT sptd.sys ZwQueryKey [0xBA6C4418]
SSDT sptd.sys ZwQueryValueKey [0xBA6C4298]
SSDT sptd.sys ZwSetValueKey [0xBA6C44AA]
INT 0x06 \??\C:\WINDOWS\system32\drivers\Haspnt.sys (HASP Kernel Device Driver for Windows NT/Aladdin Knowledge Systems) AE74C16D
INT 0x0E \??\C:\WINDOWS\system32\drivers\Haspnt.sys (HASP Kernel Device Driver for Windows NT/Aladdin Knowledge Systems) AE74BFC2
Code 8A9A9688 ZwFlushInstructionCache
Code 8AADD446 IofCallDriver
Code 8AADD4C6 IofCompleteRequest
---- Kernel code sections - GMER 1.0.15 ----
.text ntkrnlpa.exe!IofCallDriver 804EF15A 5 Bytes JMP 8AADD44B
.text ntkrnlpa.exe!IofCompleteRequest 804EF1EA 5 Bytes JMP 8AADD4CB
PAGE ntkrnlpa.exe!ZwFlushInstructionCache 805B5288 5 Bytes JMP 8A9A968C
? C:\WINDOWS\system32\drivers\sptd.sys The process cannot access the file because it is being used by another process.
.text USBPORT.SYS!DllUnload B9C8180C 5 Bytes JMP 8AC801C8
? C:\WINDOWS\system32\drivers\pukmnn.sys The system cannot find the file specified. !
---- User code sections - GMER 1.0.15 ----
.text C:\Program Files\MSN Messenger\msnmsgr.exe[728] kernel32.dll!SetUnhandledExceptionFilter 7C8447ED 5 Bytes JMP 004DE392 C:\Program Files\MSN Messenger\msnmsgr.exe (Messenger/Microsoft Corporation)
.text C:\WINDOWS\System32\svchost.exe[1344] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 100046D0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] kernel32.dll!CreateProcessInternalW 7C819704 5 Bytes JMP 100072A0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] ADVAPI32.dll!CryptGenKey 77E114B1 5 Bytes JMP 100053B0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] CRYPT32.dll!PFXImportCertStore 77AEF748 5 Bytes JMP 100053C0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetCreateUrlA + 1A5 771C2714 5 Bytes JMP 10006CB0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetCloseHandle 771C4DAC 5 Bytes JMP 10005920 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!HttpQueryInfoA 771C7842 5 Bytes JMP 100063E0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetReadFile 771C812C 5 Bytes JMP 10003070 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetQueryDataAvailable 771D8A17 5 Bytes JMP 10003040 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetGetCookieExA 771D9506 5 Bytes JMP 10002A70 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetReadFileExW 771F8071 5 Bytes JMP 100030A0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetReadFileExA 771F8D78 5 Bytes JMP 100030D0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\System32\svchost.exe[1344] WININET.dll!InternetSetCookieExW 77215AD2 5 Bytes JMP 10002810 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 100046D0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] kernel32.dll!CreateProcessInternalW 7C819704 5 Bytes JMP 100072A0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] ADVAPI32.dll!CryptGenKey 77E114B1 5 Bytes JMP 100053B0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetCreateUrlA + 1A5 771C2714 5 Bytes JMP 10006CB0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetCloseHandle 771C4DAC 5 Bytes JMP 10005920 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!HttpQueryInfoA 771C7842 5 Bytes JMP 100063E0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetReadFile 771C812C 5 Bytes JMP 10003070 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetQueryDataAvailable 771D8A17 5 Bytes JMP 10003040 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetGetCookieExA 771D9506 5 Bytes JMP 10002A70 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetReadFileExW 771F8071 5 Bytes JMP 100030A0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetReadFileExA 771F8D78 5 Bytes JMP 100030D0 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] WININET.dll!InternetSetCookieExW 77215AD2 5 Bytes JMP 10002810 C:\WINDOWS\system32\lspcfm.dll
.text C:\WINDOWS\system32\svchost.exe[1576] CRYPT32.dll!PFXImportCertStore 77AEF748 5 Bytes JMP 100053C0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] kernel32.dll!VirtualProtect 7C801AD0 5 Bytes JMP 01E146D0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] kernel32.dll!CreateProcessInternalW 7C819704 5 Bytes JMP 01E172A0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] ADVAPI32.dll!CryptGenKey 77E114B1 5 Bytes JMP 01E153B0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] CRYPT32.dll!PFXImportCertStore 77AEF748 5 Bytes JMP 01E153C0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetCreateUrlA + 1A5 771C2714 5 Bytes JMP 01E16CB0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetCloseHandle 771C4DAC 5 Bytes JMP 01E15920 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!HttpQueryInfoA 771C7842 5 Bytes JMP 01E163E0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetReadFile 771C812C 5 Bytes JMP 01E13070 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetQueryDataAvailable 771D8A17 5 Bytes JMP 01E13040 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetGetCookieExA 771D9506 5 Bytes JMP 01E12A70 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetReadFileExW 771F8071 5 Bytes JMP 01E130A0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetReadFileExA 771F8D78 5 Bytes JMP 01E130D0 C:\WINDOWS\system32\lspcfm.dll
.text C:\Program Files\Internet Explorer\iexplore.exe[2092] WININET.dll!InternetSetCookieExW 77215AD2 5 Bytes JMP 01E12810 C:\WINDOWS\system32\lspcfm.dll
koalabear
Posts Posts : 53
---- Kernel IAT/EAT - GMER 1.0.15 ----
IAT atapi.sys[HAL.dll!READ_PORT_UCHAR] [BA6BEAD4] sptd.sys
IAT atapi.sys[HAL.dll!READ_PORT_BUFFER_USHORT] [BA6BEC1A] sptd.sys
IAT atapi.sys[HAL.dll!READ_PORT_USHORT] [BA6BEB9C] sptd.sys
IAT atapi.sys[HAL.dll!WRITE_PORT_BUFFER_USHORT] [BA6BF748] sptd.sys
IAT atapi.sys[HAL.dll!WRITE_PORT_UCHAR] [BA6BF61E] sptd.sys
IAT \SystemRoot\system32\DRIVERS\i8042prt.sys[HAL.dll!READ_PORT_UCHAR] [BA6D429A] sptd.sys
Device \FileSystem\Ntfs \Ntfs 8AF051E8
AttachedDevice \FileSystem\Ntfs \Ntfs eamon.sys (Amon monitor/ESET)
Device \FileSystem\Fastfat \FatCdrom 8A6E5790
Device \Driver\NetBT \Device\NetBT_Tcpip_{E70F942A-4CC0-4075-BFA4-274B1F4F1211} 8AB61790
Device \Driver\usbuhci \Device\USBPDO-0 8AC7F1E8
Device \Driver\dmio \Device\DmControl\DmIoDaemon 8AE951E8
Device \Driver\dmio \Device\DmControl\DmConfig 8AE951E8
Device \Driver\dmio \Device\DmControl\DmPnP 8AE951E8
Device \Driver\dmio \Device\DmControl\DmInfo 8AE951E8
Device \Driver\usbehci \Device\USBPDO-1 8AC681E8
Device \Driver\usbuhci \Device\USBPDO-2 8AC7F1E8
Device \Driver\usbuhci \Device\USBPDO-3 8AC7F1E8
Device \Driver\usbehci \Device\USBPDO-4 8AC681E8
AttachedDevice \Driver\Tcpip \Device\Tcp epfwtdir.sys
Device \Driver\usbuhci \Device\USBPDO-5 8AC7F1E8
Device \Driver\usbuhci \Device\USBPDO-6 8AC7F1E8
Device \Driver\Ftdisk \Device\HarddiskVolume1 8AF071E8
Device \Driver\atapi \Device\Ide\IdeDeviceP0T0L0-3 8AF061E8
Device \Driver\atapi \Device\Ide\IdePort0 8AF061E8
Device \Driver\atapi \Device\Ide\IdePort1 8AF061E8
Device \Driver\atapi \Device\Ide\IdeDeviceP1T0L0-e 8AF061E8
Device \Driver\NetBT \Device\NetBt_Wins_Export 8AB61790
Device \Driver\NetBT \Device\NetbiosSmb 8AB61790
Device \Driver\NetBT \Device\NetBT_Tcpip_{5864CB14-1664-4ECB-BEA0-F37208407BFA} 8AB61790
Device \Driver\usbuhci \Device\USBFDO-0 8AC7F1E8
Device \Driver\usbuhci \Device\USBFDO-1 8AC7F1E8
Device \FileSystem\MRxSmb \Device\LanmanDatagramReceiver 8A104790
Device \Driver\usbehci \Device\USBFDO-2 8AC681E8
Device \FileSystem\MRxSmb \Device\LanmanRedirector 8A104790
Device \Driver\usbuhci \Device\USBFDO-3 8AC7F1E8
Device \Driver\usbuhci \Device\USBFDO-4 8AC7F1E8
Device \Driver\Ftdisk \Device\FtControl 8AF071E8
Device \Driver\usbuhci \Device\USBFDO-5 8AC7F1E8
Device \Driver\usbehci \Device\USBFDO-6 8AC681E8
Device \FileSystem\Fastfat \Fat 8A6E5790
AttachedDevice \FileSystem\Fastfat \Fat eamon.sys (Amon monitor/ESET)
Device \FileSystem\Cdfs \Cdfs 8ABFC790
koalabear
Posts Posts : 53
Post by koalabear on Mon Jun 22, 2009 8:05 pm
---- Services - GMER 1.0.15 ----
Service C:\WINDOWS\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys (*** hidden *** ) [SYSTEM] MSIVXserv.sys <-- ROOTKIT !!!
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys@start 1
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys@type 1
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys@imagepath \systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys@group file system
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys\modules
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys\modules@MSIVXserv \\?\globalroot\systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys\modules@MSIVXl \\?\globalroot\systemroot\system32\MSIVXanxylksdotehtivyfxonkdirapuhpqwb.dll
Reg HKLM\SYSTEM\ControlSet001\Services\MSIVXserv.sys\modules@MSIVXclk \\?\globalroot\systemroot\system32\MSIVXdjlnmplwnabwqwaihtirhrivrjkxgokl.dll
Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys@start 1
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys@type 1
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys@imagepath \systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys@group file system
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys\modules
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys\modules@MSIVXserv \\?\globalroot\systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys\modules@MSIVXl \\?\globalroot\systemroot\system32\MSIVXanxylksdotehtivyfxonkdirapuhpqwb.dll
Reg HKLM\SYSTEM\ControlSet002\Services\MSIVXserv.sys\modules@MSIVXclk \\?\globalroot\systemroot\system32\MSIVXdjlnmplwnabwqwaihtirhrivrjkxgokl.dll
Reg HKLM\SYSTEM\ControlSet002\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys@start 1
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys@type 1
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys@imagepath \systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys@group file system
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys\modules
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys\modules@MSIVXserv \\?\globalroot\systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys\modules@MSIVXl \\?\globalroot\systemroot\system32\MSIVXanxylksdotehtivyfxonkdirapuhpqwb.dll
Reg HKLM\SYSTEM\ControlSet003\Services\MSIVXserv.sys\modules@MSIVXclk \\?\globalroot\systemroot\system32\MSIVXdjlnmplwnabwqwaihtirhrivrjkxgokl.dll
Reg HKLM\SYSTEM\ControlSet003\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys@start 1
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys@type 1
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys@imagepath \systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys@group file system
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys\modules
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys\modules@MSIVXserv \\?\globalroot\systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys\modules@MSIVXl \\?\globalroot\systemroot\system32\MSIVXanxylksdotehtivyfxonkdirapuhpqwb.dll
Reg HKLM\SYSTEM\CurrentControlSet\Services\MSIVXserv.sys\modules@MSIVXclk \\?\globalroot\systemroot\system32\MSIVXdjlnmplwnabwqwaihtirhrivrjkxgokl.dll
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg@s1 771343423
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg@s2 285507792
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys@start 1
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys@type 1
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys@imagepath \systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys@group file system
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys\modules
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys\modules@MSIVXserv \\?\globalroot\systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys\modules@MSIVXl \\?\globalroot\systemroot\system32\MSIVXanxylksdotehtivyfxonkdirapuhpqwb.dll
Reg HKLM\SYSTEM\ControlSet005\Services\MSIVXserv.sys\modules@MSIVXclk \\?\globalroot\systemroot\system32\MSIVXdjlnmplwnabwqwaihtirhrivrjkxgokl.dll
Reg HKLM\SYSTEM\ControlSet005\Services\sptd\Cfg\14919EA49A8F3B4AA3CF1058D9A64CEC
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@AppInit_DLLs
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@DeviceNotSelectedTimeout 15
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@GDIProcessHandleQuota 10000
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@Spooler yes
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@swapdisk
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@TransmissionRetryTimeout 90
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@USERProcessHandleQuota 10000
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 8:08 pm
Drivers to delete:
MSIVXserv.sys
Files to delete:
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 8:11 pm
I completed the first step, I'm not allowed to do the second by my Administrator. It asks me to reboot now...
koalabear
Posts Posts : 53
Post by koalabear on Mon Jun 22, 2009 8:15 pm
I've rebooted it and here is the file :
Rootkit scan active.
Hidden driver "MSIVXserv.sys" found!
ImagePath: \systemroot\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys
Driver disabled successfully.
Rootkit scan completed.
Driver "MSIVXserv.sys" deleted successfully.
File "C:\WINDOWS\system32\drivers\MSIVXdqpuiuiycpkbowpklvisnpqwwyrnomtb.sys" deleted successfully.
Completed script processing.
Finished! Terminate.
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 8:16 pm
See if you can run Malwarebytes now.
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 8:17 pm
yes, I can. Smile
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 8:18 pm
Thats great new, please do a quick scan and post all the contents of the log back here Smile
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 8:24 pm
here it is :
Malwarebytes' Anti-Malware 1.38
Database version: 2283
22.6.2009 22:23:46
mbam-log-2009-06-22 (22-23-39).txt
Objects scanned: 97186
Time elapsed: 3 minute(s), 14 second(s)
Memory Processes Infected: 2
Registry Values Infected: 1
Registry Data Items Infected: 11
Files Infected: 9
C:\Documents and Settings\Kordic\Local Settings\Temp\winkodhi.exe (Trojan.Agent) -> No action taken.
C:\Documents and Settings\Kordic\Local Settings\Temp\dpqrbk.exe (Trojan.Downloader) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\taskman (Backdoor.Bot) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\DisableRegistryTools (Hijack.Regedit) -> Bad: (1) Good: (0) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\DisableTaskMgr (Hijack.TaskManager) -> Bad: (1) Good: (0) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\AntiVirusDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\FirewallDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> No action taken.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Tcpip\Parameters\Interfaces\{5864cb14-1664-4ecb-bea0-f37208407bfa}\NameServer (Trojan.DNSChanger) -> Data: 85.255.112.225,85.255.112.199 -> No action taken.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Tcpip\Parameters\Interfaces\{e70f942a-4cc0-4075-bfa4-274b1f4f1211}\NameServer (Trojan.DNSChanger) -> Data: 85.255.112.225,85.255.112.199 -> No action taken.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{5864cb14-1664-4ecb-bea0-f37208407bfa}\NameServer (Trojan.DNSChanger) -> Data: 85.255.112.225,85.255.112.199 -> No action taken.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\Tcpip\Parameters\Interfaces\{e70f942a-4cc0-4075-bfa4-274b1f4f1211}\NameServer (Trojan.DNSChanger) -> Data: 85.255.112.225,85.255.112.199 -> No action taken.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\Tcpip\Parameters\Interfaces\{5864cb14-1664-4ecb-bea0-f37208407bfa}\NameServer (Trojan.DNSChanger) -> Data: 85.255.112.225,85.255.112.199 -> No action taken.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\Tcpip\Parameters\Interfaces\{e70f942a-4cc0-4075-bfa4-274b1f4f1211}\NameServer (Trojan.DNSChanger) -> Data: 85.255.112.225,85.255.112.199 -> No action taken.
c:\RECYCLER\s-1-5-21-1708502002-5774778955-212626128-2853\rundll32.exe (Trojan.Dropper) -> No action taken.
c:\program files\outlook express\wab.exe.tmp (Trojan.Downloader) -> No action taken.
c:\WINDOWS\Tasks\{5B57CF47-0BFA-43c6-ACF9-3B3653DCADBA}.job (Trojan.FakeAlert) -> No action taken.
c:\WINDOWS\Temp\tempo-2191406.tmp (Trojan.DNSChanger) -> No action taken.
c:\WINDOWS\Temp\tempo-2192734.tmp (Trojan.DNSChanger) -> No action taken.
c:\WINDOWS\system32\MSIVXanxylksdotehtivyfxonkdirapuhpqwb.dll (Trojan.Agent) -> No action taken.
c:\WINDOWS\system32\MSIVXdjlnmplwnabwqwaihtirhrivrjkxgokl.dll (Trojan.Agent) -> No action taken.
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 8:26 pm
Good, the infection is getting beat, now you should be able to run DDS,
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 8:30 pm
I downloaded that but when I run it it opens a .txt with lots of gibberish...just a lot of letters
koalabear
Posts Posts : 53
Post by Origin on Mon Jun 22, 2009 8:34 pm
Upload the .txt to rapidhsare for em to look at, do the following:
go to this site: [You must be registered and logged in to see this link.]
Once there, click on the Choose button and locate the DDS.txt and click ok. The file should upload and then it will give you a link to download the file from. Please post the link back here.
Posts Posts : 2685
Post by koalabear on Mon Jun 22, 2009 8:37 pm
koalabear
Posts Posts : 53
