WinBlueSoft problems
Post by philosophicalbass on Sat Jun 20, 2009 12:07 pm
Hey all,
I have WinBlueSoft and no antispyware program I've tried except killbox will run...and killbox isn't helping much as blocker.dll apparently isn't in the system32 folder
Any ideas?
Thanks SO MUCH for helping me out, by the way...I'm saying that in advance. I'd hate to reformat!
philosophicalbass
Posts Posts : 34
Joined Joined : 2009-06-20
Points Points : 27358
Re: WinBlueSoft problems
Post by Belahzur on Sat Jun 20, 2009 2:52 pm
Points Points : 245059
Post by philosophicalbass on Sat Jun 20, 2009 9:48 pm
Done. It won't run. I mean, the download was fine, and it installed, but it won't open. Shucks.
philosophicalbass
Posts Posts : 34
Post by Belahzur on Sun Jun 21, 2009 12:32 am
Right click the setup file, select Rename. Rename it to 123.exe, and see if it runs now.
Post by philosophicalbass on Sun Jun 21, 2009 2:10 am
Not working! Ack
philosophicalbass
Posts Posts : 34
Post by philosophicalbass on Sun Jun 21, 2009 2:14 am
You did mean rename hijackthis.exe to 123.exe, right? That doesn't work to get the program to run, sadly.
philosophicalbass
Posts Posts : 34
Post by philosophicalbass on Sun Jun 21, 2009 11:08 am
Okay, through what must be a miracle the fake Windows Security Center application set up by the malware bugged and Windows shut it down. What's interesting is now I'm not getting pop-up ads, nor is my internet use abnormal, yet it seems like blocker.dll, wherever it is, is still running as I still can't open Hijackthis. I'm going to keep my computer running all night, in case this situation is helpful...so, when I come back and I have received further instructions in this thread, the virus won't be running in all its incarnations.
philosophicalbass
Posts Posts : 34
This just happened, by the way; I'm not just trying to bump the thread :-p
philosophicalbass
Posts Posts : 34
Post by Belahzur on Sun Jun 21, 2009 1:51 pm
Post by philosophicalbass on Sun Jun 21, 2009 8:56 pm
DDS (Ver_09-05-14.01) - NTFSx86
Run by mitchell kaplan at 13:49:17.89 on Sun 06/21/2009
Internet Explorer: 8.0.6001.18702 BrowserJavaVersion: 1.6.0_13
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.510.54 [GMT -7:00]
AV: Symantec AntiVirus Corporate Edition *On-access scanning enabled* (Updated) {FB06448E-52B8-493A-90F3-E43226D3305C}
FW: Norton Internet Worm Protection *disabled* {990F9400-4CEE-43EA-A83A-D013ADD8EA6E}
FW: Symantec Client Firewall *enabled* {5CB76A43-5FAD-476B-B9FF-26FA61F13187}
C:\WINDOWS\system32\svchost -k rpcss
C:\WINDOWS\system32\svchost.exe -k WudfServiceGroup
C:\WINDOWS\system32\svchost.exe -k NetworkService
C:\WINDOWS\system32\svchost.exe -k LocalService
C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
C:\Program Files\Be Secure 2007\Symantec Client Firewall\ISSVC.exe
C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe
C:\PROGRA~1\COMMON~1\AOL\ACS\AOLacsd.exe
C:\Program Files\Be Secure 2007\Symantec AntiVirus\DefWatch.exe
C:\Program Files\iolo\common\lib\ioloServiceManager.exe
C:\Program Files\Common Files\LogiShrd\LVCOMSER\LVComSer.exe
C:\Program Files\Spyware Doctor\pctsAuxs.exe
C:\Program Files\Spyware Doctor\pctsSvc.exe
C:\Program Files\Spyware Doctor\pctsTray.exe
C:\Program Files\Be Secure 2007\Symantec AntiVirus\Rtvscan.exe
C:\Program Files\Be Secure 2007\Symantec Client Firewall\SymSPort.exe
C:\Program Files\Viewpoint\Common\ViewpointService.exe
C:\WINDOWS\wanmpsvc.exe
C:\WINDOWS\ehome\mcrdsvc.exe
C:\WINDOWS\system32\wbem\wmiprvse.exe
C:\WINDOWS\System32\alg.exe
C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
C:\WINDOWS\System32\svchost.exe -k HTTPFilter
C:\Program Files\HP\QuickPlay\QPService.exe
C:\Program Files\hpq\HP Wireless Assistant\HP Wireless Assistant.exe
C:\WINDOWS\ehome\ehtray.exe
C:\Program Files\HPQ\Quick Launch Buttons\EabServr.exe
C:\Program Files\Common Files\LogiShrd\LComMgr\Communications_Helper.exe
C:\Program Files\Logitech\QuickCam\Quickcam.exe
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\PROGRA~1\BESECU~1\SYMANT~2\VPTray.exe
C:\PROGRA~1\hpq\Shared\HPQTOA~1.EXE
C:\Program Files\Hp\HP Software Update\HPWuSchd2.exe
C:\Program Files\DNA\btdna.exe
C:\WINDOWS\system32\setup2.exe
C:\Program Files\palmOne\Hotsync.exe
C:\Program Files\Common Files\Logishrd\LQCVFX\COCIManager.exe
C:\Documents and Settings\mitchell kaplan\Desktop\dds.scr
philosophicalbass
Posts Posts : 34
Post by philosophicalbass on Sun Jun 21, 2009 8:58 pm
uWindow Title = Microsoft Internet Explorer presented by Comcast
mWindow Title = Microsoft Internet Explorer presented by Comcast
uInternet Connection Wizard,ShellNext = [You must be registered and logged in to see this link.]
mURLSearchHooks: H - No File
BHO: {02478D38-C3F9-4efb-9B51-7695ECA05670} - No File
BHO: RealPlayer Download and Record Plugin for Internet Explorer: {3049c3e9-b461-4bc5-8870-4c09146192ca} - c:\program files\real\realplayer\rpbrowserrecordplugin.dll
BHO: {371ebd01-4415-4f57-a786-73328aefbf58} - c:\windows\system32\mljjg.dll
BHO: Spybot-S&D IE Protection: {53707962-6f74-2d53-2644-206d7942484f} - c:\program files\spybot - search & destroy\SDHelper.dll
BHO: AOL Toolbar Launcher: {7c554162-8cb7-45a4-b8f4-8ea1c75885f9} - c:\program files\aol\aol toolbar 2.0\aoltb.dll
BHO: Google Toolbar Notifier BHO: {af69de43-7d58-4638-b6fa-ce66b5ad205d} - c:\program files\google\googletoolbarnotifier\2.0.301.7164\swg.dll
BHO: GNX Rolex: {e919a377-7b3b-4737-b6e1-38930f9b4256} - c:\windows\drnpfdxxsn.dll
TB: AOLToolBand Class: {de9c389f-3316-41a7-809b-aa305ed9d922} - c:\program files\aol\aol toolbar 2.0\aoltb.dll
TB: {C4069E3A-68F1-403E-B40E-20066696354B} - No File
TB: {2318C2B1-4965-11D4-9B18-009027A5CD4F} - No File
TB: {EF99BD32-C1FB-11D2-892F-0090271D4F88} - No File
EB: Real.com: {fe54fa40-d68c-11d2-98fa-00c0f0318afe} - c:\windows\system32\Shdocvw.dll
uRun: [Aim6]
uRun: [SpybotSD TeaTimer] c:\program files\spybot - search & destroy\TeaTimer.exe
uRun: [BitTorrent DNA] "c:\program files\dna\btdna.exe"
uRun: [setup2.exe] c:\windows\system32\setup2.exe
mRun: [ATIPTA] "c:\program files\ati technologies\ati control panel\atiptaxx.exe"
mRun: [SynTPEnh] c:\program files\synaptics\syntp\SynTPEnh.exe
mRun: [RecGuard] c:\windows\sminst\RecGuard.exe
mRun: [QPService] "c:\program files\hp\quickplay\QPService.exe"
mRun: [hpWirelessAssistant] "c:\program files\hpq\hp wireless assistant\HP Wireless Assistant.exe"
mRun: [ehTray] c:\windows\ehome\ehtray.exe
mRun: [eabconfg.cpl] "c:\program files\hpq\quick launch buttons\EabServr.exe" /Start
mRun: [Cpqset] c:\program files\hpq\default settings\cpqset.exe
mRun: [LogitechCommunicationsManager] "c:\program files\common files\logishrd\lcommgr\Communications_Helper.exe"
mRun: [LogitechQuickCamRibbon] "c:\program files\logitech\quickcam\Quickcam.exe" /hide
mRun: [ccApp] "c:\program files\common files\symantec shared\ccApp.exe"
mRun: [vptray] c:\progra~1\besecu~1\symant~2\VPTray.exe
mRun: [Adobe Reader Speed Launcher] "c:\program files\adobe\reader 8.0\reader\Reader_sl.exe"
mRun: [HotSync] "c:\program files\palmsource\desktop\HotSync.exe" -AllUsers
mRun: [SunJavaUpdateSched] "c:\program files\java\jre6\bin\jusched.exe"
mRun: [HP Software Update] c:\program files\hp\hp software update\HPWuSchd2.exe
mRun: [WinBlueSoft] c:\program files\winbluesoft software\winbluesoft\WinBlueSoft.exe -min
mRun: [ISTray] "c:\program files\spyware doctor\pctsTray.exe"
dRun: [swg] c:\program files\google\googletoolbarnotifier\1.2.1128.5462\GoogleToolbarNotifier.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\hotsyn~1.lnk - c:\program files\palmone\Hotsync.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\micros~1.lnk - c:\program files\microsoft office\office10\OSA.EXE
IE: &AOL Toolbar Search - c:\program files\aol\aol toolbar 2.0\aoltbhtml.dll/search.html
IE: &Google Search - c:\program files\google\GoogleToolbar1.dll/cmsearch.html
IE: &Search - ?p=ZCfox000
IE: &Translate English Word - c:\program files\google\GoogleToolbar1.dll/cmwordtrans.html
IE: Backward Links - c:\program files\google\GoogleToolbar1.dll/cmbacklinks.html
IE: Cached Snapshot of Page - c:\program files\google\GoogleToolbar1.dll/cmcache.html
IE: E&xport to Microsoft Excel - c:\progra~1\micros~4\office10\EXCEL.EXE/3000
IE: Similar Pages - c:\program files\google\GoogleToolbar1.dll/cmsimilar.html
IE: Translate Page into English - c:\program files\google\GoogleToolbar1.dll/cmtrans.html
IE: {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - {53707962-6F74-2D53-2644-206D7942484F} - c:\program files\spybot - search & destroy\SDHelper.dll
DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} - c:\program files\yahoo!\common\Yinsthelper.dll
DPF: {A4639D2F-774E-11D3-A490-00C04F6843FB} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {F58E1CEF-A068-4C15-BA5E-587CAF3EE8C6} - [You must be registered and logged in to see this link.]
TCP: NameServer = 85.255.112.231,85.255.112.98
TCP: {489210C2-9EA4-4DDA-B0B3-ADF1A79CEA29} = 85.255.112.231,85.255.112.98
TCP: {DD69C08E-89EC-41AD-B552-D446C862A951} = 85.255.112.231,85.255.112.98
Handler: asp - {8D32BA61-D15B-11d4-894B-000000000000} - c:\program files\common files\eztools\hsppp.dll
Handler: cdo - {CD00020A-8B95-11D1-82DB-00C04FB1625D} - c:\program files\common files\microsoft shared\web folders\PKMCDO.DLL
Handler: ezstor - {8D32BA61-D15B-11d4-894B-000000000000} - c:\program files\common files\eztools\hsppp.dll
Handler: hsp - {8D32BA61-D15B-11d4-894B-000000000000} - c:\program files\common files\eztools\hsppp.dll
Handler: x-asp - {8D32BA61-D15B-11d4-894B-000000000000} - c:\program files\common files\eztools\hsppp.dll
Handler: x-cnote - {8D32BA61-D15B-11d4-894B-000000000000} - c:\program files\common files\eztools\hsppp.dll
Handler: x-hsp - {8D32BA61-D15B-11d4-894B-000000000000} - c:\program files\common files\eztools\hsppp.dll
Handler: x-zip - {8D32BA61-D15B-11d4-894B-000000000000} - c:\program files\common files\eztools\hsppp.dll
Handler: zip - {8D32BA61-D15B-11d4-894B-000000000000} - c:\program files\common files\eztools\hsppp.dll
Notify: AtiExtEvent - Ati2evxx.dll
Notify: NavLogon - c:\windows\system32\NavLogon.dll
SSODL: MonAlrt - {b861f83d-e23b-42fb-a387-a0a8245595bb} - c:\windows\installer\{b861f83d-e23b-42fb-a387-a0a8245595bb}\MonAlrt.dll
SSODL: zip - {1de6c66a-b5cb-4e04-9611-f8d432658720} - c:\windows\installer\{1de6c66a-b5cb-4e04-9611-f8d432658720}\zip.dll
SSODL: bokpkov - {E7B35CA8-0996-49FD-9651-2D114F09E1F4} - c:\windows\bokpkov.dll
SSODL: altvxvm - {FD5CA636-51C7-4349-9F02-717A53E3AA48} - c:\windows\altvxvm.dll
FF - ProfilePath -
R0 PCTCore;PCTools KDS;c:\windows\system32\drivers\PCTCore.sys [2009-6-20 130936]
R1 SAVRT;SAVRT;c:\program files\be secure 2007\symantec antivirus\savrt.sys [2005-12-19 337592]
R1 SAVRTPEL;SAVRTPEL;c:\program files\be secure 2007\symantec antivirus\Savrtpel.sys [2005-12-19 54968]
R2 ccEvtMgr;Symantec Event Manager;c:\program files\common files\symantec shared\ccEvtMgr.exe [2006-3-7 192160]
R2 ccProxy;Symantec Network Proxy;c:\program files\common files\symantec shared\ccProxy.exe [2006-3-7 202400]
R2 ccSetMgr;Symantec Settings Manager;c:\program files\common files\symantec shared\ccSetMgr.exe [2006-3-7 169632]
R2 ioloFileInfoList;iolo FileInfoList Service;c:\program files\iolo\common\lib\ioloServiceManager.exe [2008-1-6 572776]
R2 ioloSystemService;iolo System Service;c:\program files\iolo\common\lib\ioloServiceManager.exe [2008-1-6 572776]
R2 McrdSvc;Media Center Extender Service;c:\windows\ehome\mcrdsvc.exe [2005-8-5 99328]
R2 sdAuxService;PC Tools Auxiliary Service;c:\program files\spyware doctor\pctsAuxs.exe [2009-6-20 348752]
R2 sdCoreService;PC Tools Security Service;c:\program files\spyware doctor\pctsSvc.exe [2009-6-20 1096584]
R2 Symantec AntiVirus;Symantec AntiVirus;c:\program files\be secure 2007\symantec antivirus\Rtvscan.exe [2006-3-17 1799408]
R2 UacFlt;Philips Composite Class Filter Driver;c:\windows\system32\drivers\uacbflt.sys [2002-6-13 21276]
R2 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\viewpoint\common\ViewpointService.exe [2008-11-16 24652]
R3 EraserUtilRebootDrv;EraserUtilRebootDrv;c:\program files\common files\symantec shared\eengine\EraserUtilRebootDrv.sys [2009-2-28 101936]
R3 HSFHWATI;HSFHWATI;c:\windows\system32\drivers\HSFHWATI.sys [2005-8-22 231424]
R3 NAVENG;NAVENG;c:\progra~1\common~1\symant~1\virusd~1\20090529.003\naveng.sys [2009-5-29 89104]
R3 NAVEX15;NAVEX15;c:\progra~1\common~1\symant~1\virusd~1\20090529.003\navex15.sys [2009-5-29 876144]
S3 SavRoam;SAVRoam;c:\program files\be secure 2007\symantec antivirus\SavRoam.exe [2006-3-17 115952]
philosophicalbass
Posts Posts : 34
Post by philosophicalbass on Sun Jun 21, 2009 8:59 pm
2009-06-21 03:58 38,422 a------- c:\windows\system32\drivers\StMp3Rec.sys
2009-06-21 03:58 --d----- c:\program files\Creative
2009-06-20 10:30 2,736 a------- c:\windows\2954vir3z75.exe
2009-06-20 04:37 --d----- C:\!KillBox
2009-06-20 03:47 159,600 a------- c:\windows\system32\drivers\pctgntdi.sys
2009-06-20 03:47 130,936 a------- c:\windows\system32\drivers\PCTCore.sys
2009-06-20 03:47 73,840 a------- c:\windows\system32\drivers\PCTAppEvent.sys
2009-06-20 03:47 --d----- c:\program files\common files\PC Tools
2009-06-20 03:47 64,392 a------- c:\windows\system32\drivers\pctplsg.sys
2009-06-20 03:47 --d----- c:\program files\Spyware Doctor
2009-06-20 03:47 --d----- c:\docume~1\mitche~1\applic~1\PC Tools
2009-06-20 03:47 --d----- c:\docume~1\alluse~1\applic~1\PC Tools
2009-06-20 03:35 38,160 a------- c:\windows\system32\drivers\mbamswissarmy.sys
2009-06-20 03:35 19,096 a------- c:\windows\system32\drivers\mbam.sys
2009-06-20 03:35 --d----- c:\docume~1\alluse~1\applic~1\Malwarebytes
2009-06-20 03:35 --d----- c:\program files\Malwarebytes' Anti-Malware
2009-06-20 03:28 335 a------- C:\spyhunter.fix
2009-06-20 03:28 --d----- c:\program files\Enigma Software Group
2009-06-20 03:22 0 a------- c:\windows\vpc32.INI
2009-06-19 00:07 11,622 a------- c:\windows\8679spz185.ocx
2009-06-18 17:18 17,602 a------- c:\windows\system32\6693vi5uz4c4.ocx
2009-06-18 01:51 --d----- c:\windows\system32\Adobe
2009-06-16 17:43 12,761 a------- c:\windows\system32\1992do9zload5r933.ocx
2009-06-16 06:53 4,800 a------- c:\windows\system32\5389t5ief277z.ocx
2009-06-15 17:10 3,296 a------- c:\windows\system32\2fc59pzware2509.ocx
2009-06-13 09:54 17,171 a------- c:\windows\1dfzv9r1256.bin
2009-06-09 22:21 1,985,024 -------- c:\windows\system32\dllcache\iertutil.dll
2009-06-09 22:21 246,272 -------- c:\windows\system32\dllcache\ieproxy.dll
2009-06-09 22:21 12,800 -------- c:\windows\system32\dllcache\xpshims.dll
2009-06-09 22:21 11,064,832 -------- c:\windows\system32\dllcache\ieframe.dll
2009-06-09 14:36 4,546 a------- c:\windows\905z3worm6aa.exe
2009-06-08 16:48 4,389 a------- c:\windows\1056zir29885.bin
2009-06-08 00:42 7,639 a------- c:\windows\1z291worm275.cpl
2009-06-06 04:30 10,077 a------- c:\windows\system32\714z9pa5se451.dll
2009-06-06 02:24 11,063 a------- c:\windows\system32\4995zpar5e2840.ocx
2009-06-04 15:52 17,283 a------- c:\windows\221z5n9t-a-virus7a0.cpl
2009-06-04 08:18 11,526 a------- c:\windows\system32\7bz1t9ie51701.cpl
2009-06-04 05:09 13,274 a------- c:\windows\system32\za76bac9door58.ocx
2009-06-04 00:56 18,401 a------- c:\windows\73725irzs9e8.dll
2009-06-03 11:50 7,165 a------- c:\windows\6596hacktozl364.ocx
2009-05-26 06:00 9,112 a------- c:\windows\system32\7ccdzo5nloader291.cpl
2009-05-20 20:55 7,404 a------- c:\windows\system32\67569hreat19z32.bin
2009-05-19 15:22 4,970 a------- c:\windows\5aedthr9at154z4.bin
2009-05-12 22:15 5,936,128 a------- c:\windows\system32\dllcache\mshtml.dll
2009-05-12 22:15 915,456 a------- c:\windows\system32\wininet.dll
2009-05-12 22:15 915,456 a------- c:\windows\system32\dllcache\wininet.dll
2009-05-07 08:32 345,600 a------- c:\windows\system32\localspl.dll
2009-05-07 08:32 345,600 -------- c:\windows\system32\dllcache\localspl.dll
2009-05-04 19:55 3,109 a------- c:\windows\system32\z5293worm57b.bin
2009-05-03 09:19 3,216 a------- c:\windows\system32\304225iz9s4d8.exe
2009-04-30 14:22 1,207,808 a------- c:\windows\system32\dllcache\urlmon.dll
2009-04-30 14:22 25,600 -------- c:\windows\system32\dllcache\jsproxy.dll
2009-04-30 14:22 385,536 -------- c:\windows\system32\dllcache\iedkcs32.dll
2009-04-30 04:21 173,056 -------- c:\windows\system32\dllcache\ie4uinit.exe
2009-04-20 23:58 17,650 a------- c:\windows\system32\5b14thi59z008.exe
2009-04-17 05:26 1,847,168 a------- c:\windows\system32\win32k.sys
2009-04-17 05:26 1,847,168 -------- c:\windows\system32\dllcache\win32k.sys
2009-04-15 07:51 585,216 a------- c:\windows\system32\rpcrt4.dll
2009-04-15 07:51 585,216 -------- c:\windows\system32\dllcache\rpcrt4.dll
2009-04-11 03:29 13,712 a------- c:\windows\system32\78e2spar9e529z.exe
2009-04-09 06:39 4,700 a------- c:\windows\system32\4470addwzre59309.bin
2009-04-07 15:41 10,570 a------- c:\windows\system32\699zt5ief819.bin
2009-04-05 17:22 17,248 a------- c:\windows\system32\135z1troj3195.dll
2009-03-31 20:48 8,394 a------- c:\windows\system32\19095worm79z.bin
2009-03-28 01:58 9,987 a------- c:\windows\10149ir5s6z9.exe
2009-03-28 00:58 3,481 a------- c:\windows\9z535a9ktool4c.exe
2009-03-25 13:42 4,423 a------- c:\windows\e96vzr9605.exe
2008-03-08 21:20 0 a------- c:\docume~1\mitche~1\applic~1\Install.dat
2008-01-06 18:40 340,644 a--sh--- c:\windows\system32\gjjlm.bak1
2008-01-07 04:12 340,293 a--sh--- c:\windows\system32\gjjlm.bak2
2008-01-07 05:15 340,437 a--sh--- c:\windows\system32\gjjlm.ini2
============= FINISH: 13:49:40.45 ===============
philosophicalbass
Posts Posts : 34
Post by Origin on Sun Jun 21, 2009 9:24 pm
  • See [You must be registered and logged in to see this link.] for how to disable your AV. (Mcafee)
    Do not mouse click combofix's window whilst it's running. That may cause it to stall.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31473
Post by philosophicalbass on Sun Jun 21, 2009 10:58 pm
Holy crap, the problem seems to be fixed entirely - no more pop-ups, my internet isn't being attempted-redirected to other sites now, and the Windows Security Center which is running seems to be the real one.
I suspect there may be some lingering stuff in there, but I'd just like to thank you two who have helped me out, along with the rest of the people who run this wonderful site.
Anyway, here's my combo-fix .txt:
ComboFix 09-06-20.04 - mitchell kaplan 06/21/2009 15:24.1 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.510.97 [GMT -7:00]
Running from: c:\documents and settings\mitchell kaplan\Desktop\Combo-Fix.exe
AV: Symantec AntiVirus Corporate Edition *On-access scanning disabled* (Updated) {FB06448E-52B8-493A-90F3-E43226D3305C}
c:\recycler\S-1-5-21-1141404485-3055578623-1467224783-1005
c:\documents and settings\mitchell kaplan\Application Data\Install.dat
c:\documents and settings\mitchell kaplan\Favorites\Error Cleaner.url
c:\documents and settings\mitchell kaplan\Favorites\Privacy Protector.url
c:\documents and settings\mitchell kaplan\Favorites\Spyware&Malware Protection.url
c:\recycler\S-1-5-21-1141404485-3055578623-1467224783-1005\INFO2
c:\windows\10038h9cktozl25d.exe
c:\windows\10055viruz905.dll
c:\windows\10645no95azvirus32d.exe
c:\windows\108fazd5are32469.cpl
c:\windows\1098zsp9253.bin
c:\windows\109z9worm395.bin
c:\windows\12247v5rzs2b9.cpl
c:\windows\123925ozm9b9.exe
c:\windows\12522z95me8.exe
c:\windows\1294tzoj573.ocx
c:\windows\12e8sp9rs525z7.bin
c:\windows\137z3sp95cc.ocx
c:\windows\13z69hacktoo57d79.ocx
c:\windows\140145p9mbot6ez.ocx
c:\windows\1422down5oazer19919.bin
c:\windows\142685pambot99z.dll
c:\windows\14c95ir1z11.cpl
c:\windows\15117zpambo93a25.bin
c:\windows\15129not-a-zirus15b.cpl
c:\windows\15153viz9s750.bin
c:\windows\153z7hac95ool2f.ocx
c:\windows\15406spa9bz5158.exe
c:\windows\155365pa9bot200z.bin
c:\windows\155565zy59f.dll
c:\windows\15595troj1z5.ocx
c:\windows\15679virus2c6z.exe
c:\windows\159z2wor9355.exe
c:\windows\15c8backzo5r2294.ocx
c:\windows\162995pambot92z.ocx
c:\windows\163z9tro957a.cpl
c:\windows\164609zy2d05.ocx
c:\windows\16512zpy962.ocx
c:\windows\17925spy368z.exe
c:\windows\179bdow9zoader956.exe
c:\windows\17z59rojc3.cpl
c:\windows\17z95hacktool690.bin
c:\windows\1850stealz916.exe
c:\windows\18700spambo95b4z.bin
c:\windows\187805ot-9-vizus6c6.ocx
c:\windows\193fdownloaderz765.cpl
c:\windows\19527spyz56.exe
c:\windows\19555virus5z1.exe
c:\windows\1955ddzare1077.bin
c:\windows\195cspyware18z.dll
c:\windows\195fszarse1876.dll
c:\windows\196z9hackto5l434.cpl
c:\windows\19799zacktool6bd5.bin
c:\windows\19z135irus1b9.dll
c:\windows\1accthreaz9524.cpl
c:\windows\1cedthre5t942z.ocx
c:\windows\1d94threat22615z.exe
c:\windows\1dbesp5rse1z99.ocx
c:\windows\1dd0b9ckzoor18455.cpl
c:\windows\1dzf5ddware309.ocx
c:\windows\1ef95tea985z.bin
c:\windows\1f64spzrs51594.cpl
c:\windows\1f6cbackzoo95582.ocx
c:\windows\1z239v95us76b.dll
c:\windows\1z55troj79c.ocx
c:\windows\1z591spamb5t479.exe
c:\windows\1z599t5ojdc.ocx
c:\windows\1z953h9cktool2c3.bin
c:\windows\1z96hacktool559.cpl
c:\windows\1zdcb5c9door1576.dll
c:\windows\206559pamboz3b8.bin
c:\windows\2091haczto9534.exe
c:\windows\21009z9rm1105.dll
c:\windows\2194noz-a-v9rus3f25.cpl
c:\windows\21977nzt-a-9iru52f6.bin
c:\windows\21z81troj950.cpl
c:\windows\225549otza-virus75f.cpl
c:\windows\22688virus5z09.bin
c:\windows\22875spy9z.exe
c:\windows\23193wz5m494.dll
c:\windows\2358downl59derz171.ocx
c:\windows\23706viz5s4f39.dll
c:\windows\23z47ha95tool3af.exe
c:\windows\24009worz565.exe
c:\windows\24298spyzc5.ocx
c:\windows\2453spyz9re2725.dll
c:\windows\24759zorm957.dll
c:\windows\2479zw9rm357.cpl
c:\windows\2490zpa9bot115.dll
c:\windows\24f3dow9loadez75.bin
c:\windows\2505sparz9124.dll
c:\windows\251fbackdooz3939.exe
c:\windows\25335trz9760.ocx
c:\windows\254zvir982.exe
c:\windows\256zvir796.dll
c:\windows\2570w5zm739.ocx
c:\windows\25881zi5us910.ocx
c:\windows\2595wo9z1.bin
c:\windows\25csteaz9128.cpl
c:\windows\26349dzw5re1426.ocx
c:\windows\2657zhacktool509.cpl
c:\windows\27053zorm38e9.exe
c:\windows\27189s5amboz202.dll
c:\windows\27233hackt9oz1715.bin
c:\windows\272z9worm5bf.bin
c:\windows\2799z5py628.ocx
c:\windows\27ffdow9l5ader15z9.cpl
c:\windows\28439vizu96c75.exe
c:\windows\286sp96b5z.bin
c:\windows\2877z5roj719.cpl
c:\windows\28791tz59765.cpl
c:\windows\290075acktool64z.bin
c:\windows\292685irus5z5.bin
c:\windows\29364t5o9zff.cpl
c:\windows\29520troj24z.cpl
c:\windows\2971z5orm4a49.exe
c:\windows\29979not-5-viruz79b.bin
c:\windows\29favirz255.ocx
c:\windows\29z26virus3a5.exe
c:\windows\29z5thre5t13615.ocx
c:\windows\2a3bdow5z9ader3091.bin
c:\windows\2aeddownl5zder22899.ocx
c:\windows\2c3c5z9eat29623.exe
c:\windows\2cc95ackdzor2363.dll
c:\windows\2d54zac9door2857.dll
c:\windows\2z265hack5ool9c5.bin
c:\windows\2z515troj96.cpl
c:\windows\2z575virus90f.exe
c:\windows\2z899troj4b45.exe
c:\windows\30166spamz9t505.exe
c:\windows\30244sz5mbot89.cpl
c:\windows\30372s5amboz69a.bin
c:\windows\305545ormze29.cpl
c:\windows\3070addzar59516.bin
c:\windows\3074zviru53dc9.ocx
c:\windows\30a8sp95aze1561.bin
c:\windows\315c5hreat10249z.ocx
c:\windows\31953h9ckzool7dc.dll
c:\windows\31956vir9z71f.cpl
c:\windows\31z559py317.cpl
c:\windows\3214do59zoader108.ocx
c:\windows\32453tr9jz6.exe
c:\windows\32655vi9us315z.ocx
c:\windows\33z5st9al1281.exe
c:\windows\346faddwaze2995.dll
c:\windows\3489wozm2e05.bin
c:\windows\35871not-9-virus45ez.cpl
c:\windows\35921zot-a-virus255.ocx
c:\windows\37z2v951124.bin
c:\windows\39115no5-a-viruz3a.ocx
c:\windows\391fs5arze974.ocx
c:\windows\3950zteal2998.ocx
c:\windows\39595w5rm3zf.dll
c:\windows\3992downloazer2515.dll
c:\windows\39957spambotz25.exe
c:\windows\39c5vi913z.ocx
c:\windows\39ezthief9055.exe
c:\windows\3c59spyware2z70.exe
c:\windows\3da5vzr9559.cpl
c:\windows\3dz9backdoor5745.exe
c:\windows\3f59stea98z1.exe
c:\windows\3ze5ste9l1630.exe
c:\windows\40e9downloazer24425.dll
c:\windows\4142a9dwar51z77.bin
c:\windows\4228addwzr52947.ocx
c:\windows\42e3a5dwarz899.dll
c:\windows\4352wor57c9z.exe
c:\windows\43aespywz592236.bin
c:\windows\4459vir21z4.bin
c:\windows\4490zack5oor950.exe
c:\windows\4552dowzl9a5er37.exe
c:\windows\cookies.ini
c:\windows\Installer\{1de6c66a-b5cb-4e04-9611-f8d432658720}\zip.dll
c:\windows\Installer\{b861f83d-e23b-42fb-a387-a0a8245595bb}\MonAlrt.dll
c:\windows\kb913800.exe
c:\windows\rs.txt
c:\windows\system32\1AE5400c__.ini
c:\windows\system32\3DC3B00c__.ini
c:\windows\system32\83F900c__.ini
c:\windows\system32\9946400c__.ini
c:\windows\system32\A64C600c__.ini
c:\windows\system32\amqgpiqy.ini
c:\windows\system32\aocthwji.ini
c:\windows\system32\aoikmwnd.ini
c:\windows\system32\asdpnxil.ini
c:\windows\system32\asmageqp.ini
c:\windows\system32\B162500c__.ini
c:\windows\system32\bprfpkov.ini
c:\windows\system32\bucupnyq.ini
c:\windows\system32\ceevjhnc.ini
c:\windows\system32\chamgfup.ini
c:\windows\system32\ciatvsfa.ini
c:\windows\system32\cjivcsmr.ini
c:\windows\system32\cnhtvbpm.ini
c:\windows\system32\cxuicjgs.ini
c:\windows\system32\delullhu.ini
c:\windows\system32\dilykoel.ini
c:\windows\system32\drivers\MSIVXyqjopxjnqtepxgsqnoewqologiuxdulr.sys
c:\windows\system32\ebaaeipq.ini
c:\windows\system32\eedeyfle.ini
c:\windows\system32\eguhpixt.ini
c:\windows\system32\ekarvynk.ini
c:\windows\system32\esfpggqi.ini
c:\windows\system32\exhykcaj.ini
c:\windows\system32\fdfdbxgc.ini
c:\windows\system32\furkjofu.ini
c:\windows\system32\gjjlm.tmp
c:\windows\system32\grevomnt.ini
c:\windows\system32\gttwjgse.ini
c:\windows\system32\gufubwot.ini
c:\windows\system32\gunlcumd.ini
c:\windows\system32\gxxpfkff.ini
c:\windows\system32\hirbqtyg.ini
c:\windows\system32\hmwyornv.ini
c:\windows\system32\hoorfunr.ini
c:\windows\system32\hpsegqoh.ini
c:\windows\system32\hrsarloy.ini
c:\windows\system32\hsspyoak.ini
c:\windows\system32\hykuayeg.ini
c:\windows\system32\iivgikhe.ini
c:\windows\system32\imolhvwl.ini
c:\windows\system32\inualsvj.ini
c:\windows\system32\iucdabyj.ini
c:\windows\system32\jbdaccgu.ini
c:\windows\system32\joqxtfri.ini
c:\windows\system32\jqeowddm.ini
c:\windows\system32\jwqnpkhx.ini
c:\windows\system32\jxdxmbki.ini
c:\windows\system32\kbgwxoyd.ini
c:\windows\system32\kfaefmdt.ini
c:\windows\system32\kjrlcbnh.ini
c:\windows\system32\kowxtwus.ini
c:\windows\system32\kqayijra.ini
c:\windows\system32\lccilhjg.ini
c:\windows\system32\lnckwebm.ini
c:\windows\system32\mcrh.tmp
c:\windows\system32\mfc45.dll
c:\windows\system32\mifjlffd.ini
c:\windows\system32\miwnhnkc.ini
c:\windows\system32\mmcqlhea.ini
c:\windows\system32\mqhhnyoh.ini
c:\windows\system32\mrubapoq.ini
c:\windows\system32\mrxuuoie.ini
c:\windows\system32\msfxtqlg.ini
c:\windows\system32\MSIVXcevvkbdymytqctfmhbowryhmkhdplpxd.dll
c:\windows\system32\MSIVXcount
c:\windows\system32\MSIVXulhrpcghqvrjsttmuktpuylgibarjtmp.dll
c:\windows\system32\mvbxvhja.ini
c:\windows\system32\nbxkrecv.ini
c:\windows\system32\njkvlvjo.ini
c:\windows\system32\nkpjtgay.ini
c:\windows\system32\nnurwmoc.ini
c:\windows\system32\nodggvji.ini
c:\windows\system32\nwehvxgw.ini
c:\windows\system32\oiabaxlq.ini
c:\windows\system32\ovgsjtlk.ini
c:\windows\system32\pblsbtcc.ini
c:\windows\system32\phmbkgqp.ini
c:\windows\system32\pisrptvv.ini
c:\windows\system32\pmqladjb.ini
c:\windows\system32\pojmpnhy.ini
c:\windows\system32\qdebyxrp.ini
c:\windows\system32\qggdowxb.ini
c:\windows\system32\qptduedh.ini
c:\windows\system32\radmquly.ini
c:\windows\system32\rdwdmmpw.ini
c:\windows\system32\rkytiyww.ini
c:\windows\system32\rlnoppmb.ini
c:\windows\system32\rtuwyogp.ini
c:\windows\system32\sclrsfam.ini
c:\windows\system32\swuetbym.ini
c:\windows\system32\tclfwjvu.ini
c:\windows\system32\tkamlwuy.ini
c:\windows\system32\trlypkdq.ini
c:\windows\system32\tvblexmi.ini
c:\windows\system32\uawyljwo.ini
c:\windows\system32\uchrytll.ini
c:\windows\system32\umrgvbjt.ini
c:\windows\system32\uubdfnat.ini
c:\windows\system32\uvvnfgpx.ini
c:\windows\system32\veftpttb.ini
c:\windows\system32\vjpurqhs.ini
c:\windows\system32\vkngrmbo.ini
c:\windows\system32\vxexkxaq.ini
c:\windows\system32\wbwiodpt.ini
c:\windows\system32\wdnrtrgq.ini
c:\windows\system32\wgralrtj.ini
c:\windows\system32\wjgksbxt.ini
c:\windows\system32\wqcjpkbp.ini
c:\windows\system32\wsvcfyih.ini
c:\windows\system32\wygxlmbm.ini
c:\windows\system32\xcacsjxs.ini
c:\windows\system32\xgjmojqf.ini
c:\windows\system32\xiqqrsrc.ini
c:\windows\system32\xnsyffmx.ini
c:\windows\system32\yqjckykb.ini
c:\windows\Tasks\{5B57CF47-0BFA-43c6-ACF9-3B3653DCADBA}.job
C:\xcrashdump.dat
D:\Autorun.inf
D:\Desktop.ini
philosophicalbass
Posts Posts : 34
Post by philosophicalbass on Sun Jun 21, 2009 10:59 pm
-------\Service_MSIVXserv.sys
((((((((((((((((((((((((( Files Created from 2009-05-21 to 2009-06-21 )))))))))))))))))))))))))))))))
2009-12-26 22:46 . 2009-12-26 22:46 16158 ----a-w- c:\windows\system32\22250vizus595.dll
2009-12-26 04:57 . 2009-12-26 04:57 12646 ----a-w- c:\windows\system32\556fth9zf2612.exe
2009-12-24 07:40 . 2009-12-24 07:40 11635 ----a-w- c:\windows\system32\6bd5zpy59re2586.bin
2009-12-16 01:28 . 2009-12-16 01:28 15678 ----a-w- c:\windows\5c53downloaz9r13985.exe
2009-12-14 15:52 . 2009-12-14 15:52 7632 ----a-w- c:\windows\system32\5551tr5z609.bin
2009-12-13 21:23 . 2009-12-13 21:23 12393 ----a-w- c:\windows\system32\430edo9nzoad5r138.bin
2009-12-11 12:44 . 2009-12-11 12:44 12577 ----a-w- c:\windows\5286spamz59126.exe
2009-12-10 19:47 . 2009-12-10 19:47 2721 ----a-w- c:\windows\system32\26492vi5us24z.exe
2009-12-06 07:21 . 2009-12-06 07:21 9510 ----a-w- c:\windows\system32\56az9hie51808.exe
2009-12-05 02:59 . 2009-12-05 02:59 6873 ----a-w- c:\windows\4ed0th5ef85z9.exe
2009-12-01 20:59 . 2009-12-01 20:59 5251 ----a-w- c:\windows\8816v95usz4a.bin
2009-12-01 08:02 . 2009-12-01 08:02 2667 ----a-w- c:\windows\system32\5zd8vir5389.bin
2009-11-19 17:14 . 2009-11-19 17:14 8303 ----a-w- c:\windows\system32\76645pywarez899.exe
2009-11-19 13:01 . 2009-11-19 13:01 17489 ----a-w- c:\windows\system32\25575ha9ztool478.bin
2009-11-18 22:35 . 2009-11-18 22:35 13543 ----a-w- c:\windows\6zbab5ckdoor1967.dll
2009-11-13 00:15 . 2009-11-13 00:15 17087 ----a-w- c:\windows\system32\25094not-9-virusza5.dll
2009-11-11 03:03 . 2009-11-11 03:03 16723 ----a-w- c:\windows\system32\6597zhi5f2808.dll
2009-11-06 17:49 . 2009-11-06 17:49 3371 ----a-w- c:\windows\94fvzr536.exe
2009-11-05 15:25 . 2009-11-05 15:25 3320 ----a-w- c:\windows\759thzea9345.dll
2009-11-03 23:44 . 2009-11-03 23:44 13245 ----a-w- c:\windows\system32\54799tealz537.exe
2009-11-01 06:42 . 2009-11-01 06:42 3945 ----a-w- c:\windows\880zhackto5l952.exe
2009-10-28 13:55 . 2009-10-28 13:55 3059 ----a-w- c:\windows\6979spar5e1z9.dll
2009-10-27 07:59 . 2009-10-27 07:59 6220 ----a-w- c:\windows\system32\2b9ethie5488z.dll
2009-10-24 09:22 . 2009-10-24 09:22 13908 ----a-w- c:\windows\system32\6611bzckdoor9574.bin
2009-10-23 11:15 . 2009-10-23 11:15 14460 ----a-w- c:\windows\system32\17965not-a-5zrus5759.exe
2009-10-22 09:19 . 2009-10-22 09:19 16114 ----a-w- c:\windows\system32\7965spz5se1876.bin
2009-10-20 18:39 . 2009-10-20 18:39 2816 ----a-w- c:\windows\system32\528e5par9z898.exe
2009-10-17 17:34 . 2009-10-17 17:34 4889 ----a-w- c:\windows\8445virz9579.bin
2009-10-16 18:52 . 2009-10-16 18:52 4798 ----a-w- c:\windows\system32\19689s9ambzt6fa5.bin
2009-10-10 01:34 . 2009-10-10 01:34 6737 ----a-w- c:\windows\5c31tz9ef2570.bin
2009-10-06 08:10 . 2009-10-06 08:10 14493 ----a-w- c:\windows\system32\21zcdownloa5er3097.bin
2009-10-03 18:00 . 2009-10-03 18:00 8424 ----a-w- c:\windows\system32\11threat967z5.bin
2009-09-20 22:41 . 2009-09-20 22:41 12546 ----a-w- c:\windows\system32\25884spzmbot89.dll
2009-09-19 12:31 . 2009-09-19 12:31 16488 ----a-w- c:\windows\9a88steal265z.dll
2009-09-18 17:49 . 2009-09-18 17:49 14576 ----a-w- c:\windows\system32\3d7za9dware569.exe
2009-09-18 03:51 . 2009-09-18 03:51 5877 ----a-w- c:\windows\system32\5ac9spyware55z.bin
2009-09-17 12:23 . 2009-09-17 12:23 12504 ----a-w- c:\windows\system32\13673spa5bo933z.dll
2009-09-16 09:44 . 2009-09-16 09:44 17248 ----a-w- c:\windows\9054wozm556.bin
2009-09-16 05:20 . 2009-09-16 05:20 11512 ----a-w- c:\windows\752ddownl9adzr1256.bin
2009-09-14 02:11 . 2009-09-14 02:11 17676 ----a-w- c:\windows\system32\1z559hacktool9f3.dll
2009-09-12 13:49 . 2009-09-12 13:49 10170 ----a-w- c:\windows\system32\5ac1s9yw5re2z11.exe
2009-09-10 18:12 . 2009-09-10 18:12 16205 ----a-w- c:\windows\9963down5zader2185.bin
2009-09-10 04:48 . 2009-09-10 04:48 13428 ----a-w- c:\windows\b5bs5zal899.bin
2009-09-03 20:59 . 2009-09-03 20:59 16168 ----a-w- c:\windows\5z796worm213.bin
2009-09-02 09:41 . 2009-09-02 09:41 7442 ----a-w- c:\windows\b90threaz319995.dll
2009-09-01 14:55 . 2009-09-01 14:55 11796 ----a-w- c:\windows\system32\6ec1downloa9er5z29.exe
2009-08-27 08:56 . 2009-08-27 08:56 10260 ----a-w- c:\windows\system32\91548not-a-vi5uz45.bin
2009-08-26 12:00 . 2009-08-26 12:00 10527 ----a-w- c:\windows\fb0azdwa9e5990.exe
2009-08-23 19:58 . 2009-08-23 19:58 8462 ----a-w- c:\windows\5azathi5f194.dll
2009-08-19 16:47 . 2009-08-19 16:47 5987 ----a-w- c:\windows\system32\5cb1bzckd9or2672.exe
2009-08-17 21:14 . 2009-08-17 21:14 15972 ----a-w- c:\windows\system32\3z98sparse2158.bin
2009-08-13 19:17 . 2009-08-13 19:17 8107 ----a-w- c:\windows\9dz1backdoo53140.bin
2009-08-12 18:52 . 2009-08-12 18:52 15927 ----a-w- c:\windows\system32\1ebzsteal9056.bin
2009-08-11 22:58 . 2009-08-11 22:58 3144 ----a-w- c:\windows\4b205parsez897.dll
2009-08-11 11:01 . 2009-08-11 11:01 2960 ----a-w- c:\windows\system32\15453tr5jz869.exe
2009-08-10 09:53 . 2009-08-10 09:53 10531 ----a-w- c:\windows\system32\6ab9backdoo51z41.exe
2009-08-09 06:45 . 2009-08-09 06:45 13147 ----a-w- c:\windows\system32\15765viru9z5f.bin
2009-08-07 20:24 . 2009-08-07 20:24 12171 ----a-w- c:\windows\system32\245spy9az.bin
2009-08-07 11:15 . 2009-08-07 11:15 13670 ----a-w- c:\windows\5146ha9ktool5z5.bin
2009-08-05 08:07 . 2009-08-05 08:07 16037 ----a-w- c:\windows\system32\5301sp5mb9z740.bin
2009-08-03 18:17 . 2009-08-03 18:17 11072 ----a-w- c:\windows\system32\9338spy596z.exe
2009-07-22 05:49 . 2009-07-22 05:49 8827 ----a-w- c:\windows\system32\29215hac9tool1c6z.exe
2009-07-16 22:44 . 2009-07-16 22:44 3108 ----a-w- c:\windows\system32\265255py9bz.dll
2009-07-15 01:23 . 2009-07-15 01:23 4024 ----a-w- c:\windows\52aethizf5469.dll
2009-07-11 20:23 . 2009-07-11 20:23 17455 ----a-w- c:\windows\5182spy9zre2585.exe
2009-07-08 21:28 . 2009-07-08 21:28 4037 ----a-w- c:\windows\6912hzckto5l59d.bin
2009-07-04 23:48 . 2009-07-04 23:48 7501 ----a-w- c:\windows\system32\11951spz959.dll
2009-07-04 07:48 . 2009-07-04 07:48 17737 ----a-w- c:\windows\6a10tz9ef1945.exe
2009-06-24 15:12 . 2009-06-24 15:12 2857 ----a-w- c:\windows\system32\92600zpambo5b7.dll
2009-06-24 06:11 . 2009-06-24 06:11 13891 ----a-w- c:\windows\system32\z4ees9yw5re1021.dll
2009-06-21 10:58 . 2009-06-21 10:58 -------- d-----w- c:\program files\Creative
2009-06-21 10:58 . 2005-08-16 19:23 38422 ----a-w- c:\windows\system32\drivers\StMp3Rec.sys
2009-06-20 11:37 . 2009-06-20 11:37 -------- d-----w- C:\!KillBox
2009-06-20 10:47 . 2008-12-11 15:38 159600 ----a-w- c:\windows\system32\drivers\pctgntdi.sys
2009-06-20 10:47 . 2009-04-03 18:18 130936 ----a-w- c:\windows\system32\drivers\PCTCore.sys
2009-06-20 10:47 . 2008-12-18 19:16 73840 ----a-w- c:\windows\system32\drivers\PCTAppEvent.sys
2009-06-20 10:47 . 2009-06-21 22:22 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2009-06-20 10:47 . 2009-06-20 10:47 -------- d-----w- c:\program files\Common Files\PC Tools
2009-06-20 10:47 . 2008-12-10 18:36 64392 ----a-w- c:\windows\system32\drivers\pctplsg.sys
2009-06-20 10:47 . 2009-06-20 10:50 -------- d-----w- c:\program files\Spyware Doctor
2009-06-20 10:47 . 2009-06-20 10:47 -------- d-----w- c:\documents and settings\mitchell kaplan\Application Data\PC Tools
2009-06-20 10:47 . 2009-06-20 10:47 -------- d-----w- c:\documents and settings\All Users\Application Data\PC Tools
2009-06-20 10:35 . 2009-06-17 18:27 38160 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-06-20 10:35 . 2009-06-20 10:35 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-06-20 10:35 . 2009-06-17 18:27 19096 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-06-20 10:35 . 2009-06-20 10:41 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-06-20 10:28 . 2009-06-20 10:38 -------- d-----w- c:\program files\Enigma Software Group
2009-06-18 08:51 . 2009-06-18 08:51 -------- d-----w- c:\windows\system32\Adobe
2009-06-17 09:42 . 2009-06-17 09:42 -------- d-sh--w- c:\documents and settings\LocalService\PrivacIE
2009-06-17 09:42 . 2009-06-17 09:42 -------- d-sh--w- c:\documents and settings\LocalService\IECompatCache
2009-06-10 05:21 . 2009-04-30 21:22 12800 ------w- c:\windows\system32\dllcache\xpshims.dll
2009-06-10 05:21 . 2009-04-30 21:22 1985024 ------w- c:\windows\system32\dllcache\iertutil.dll
2009-06-10 05:21 . 2009-04-30 21:22 246272 ------w- c:\windows\system32\dllcache\ieproxy.dll
2009-06-10 05:21 . 2009-04-30 21:22 11064832 ------w- c:\windows\system32\dllcache\ieframe.dll
2009-06-09 21:36 . 2009-06-09 21:36 4546 ----a-w- c:\windows\905z3worm6aa.exe
2009-06-06 11:30 . 2009-06-06 11:30 10077 ----a-w- c:\windows\system32\714z9pa5se451.dll
2009-06-04 07:56 . 2009-06-04 07:56 18401 ----a-w- c:\windows\73725irzs9e8.dll
2009-05-23 21:20 . 2009-05-23 21:20 390664 ----a-w- c:\documents and settings\mitchell kaplan\Application Data\Real\RealPlayer\Update\RealPlayer11.exe
2009-06-21 22:20 . 2008-03-20 23:32 40 ----a-w- c:\windows\system32\profile.dat
2009-06-21 22:19 . 2008-06-20 23:01 -------- d-----w- c:\documents and settings\mitchell kaplan\Application Data\DNA
2009-06-21 21:56 . 2006-04-14 04:33 -------- d-----w- c:\program files\Common Files\Symantec Shared
2009-06-21 20:04 . 2008-06-20 23:01 -------- d-----w- c:\program files\DNA
2009-06-21 02:08 . 2008-03-17 08:47 -------- d-----w- c:\program files\Trend Micro
2009-06-20 11:00 . 2008-06-20 23:05 -------- d-----w- c:\documents and settings\mitchell kaplan\Application Data\BitTorrent
2009-06-20 09:37 . 2006-04-14 04:00 -------- d-----w- c:\program files\HP
2009-06-20 09:36 . 2006-04-14 04:06 -------- d-----w- c:\program files\Hewlett-Packard
2009-05-21 03:55 . 2009-05-21 03:55 7404 ----a-w- c:\windows\system32\67569hreat19z32.bin
2009-05-19 22:22 . 2009-05-19 22:22 4970 ----a-w- c:\windows\5aedthr9at154z4.bin
2009-05-13 05:15 . 2004-08-10 15:00 915456 ----a-w- c:\windows\system32\wininet.dll
2009-05-10 09:54 . 2009-05-10 09:54 -------- d-----w- c:\program files\Microsoft CAPICOM 2.1.0.2
2009-05-10 09:26 . 2008-07-08 02:07 -------- d-----w- c:\program files\Diablo II
2009-05-10 03:51 . 2008-02-14 08:20 -------- d-----w- c:\program files\AIMTunes
2009-05-09 07:26 . 2009-05-09 07:26 -------- d-----w- c:\program files\Microsoft Silverlight
2009-05-07 15:32 . 2004-08-10 15:00 345600 ----a-w- c:\windows\system32\localspl.dll
2009-05-05 02:55 . 2009-05-05 02:55 3109 ----a-w- c:\windows\system32\z5293worm57b.bin
2009-05-03 16:19 . 2009-05-03 16:19 3216 ----a-w- c:\windows\system32\304225iz9s4d8.exe
2009-04-23 09:41 . 2008-07-17 02:43 -------- d-----w- c:\documents and settings\mitchell kaplan\Application Data\Apple Computer
2009-04-21 06:58 . 2009-04-21 06:58 17650 ----a-w- c:\windows\system32\5b14thi59z008.exe
2009-04-17 12:26 . 2004-08-10 15:00 1847168 ----a-w- c:\windows\system32\win32k.sys
2009-04-15 14:51 . 2004-08-10 15:00 585216 ----a-w- c:\windows\system32\rpcrt4.dll
2009-04-11 10:29 . 2009-04-11 10:29 13712 ----a-w- c:\windows\system32\78e2spar9e529z.exe
2009-04-09 13:39 . 2009-04-09 13:39 4700 ----a-w- c:\windows\system32\4470addwzre59309.bin
2009-04-07 22:41 . 2009-04-07 22:41 10570 ----a-w- c:\windows\system32\699zt5ief819.bin
2009-04-06 17:55 . 2009-04-06 17:55 152576 ----a-w- c:\documents and settings\mitchell kaplan\Application Data\Sun\Java\jre1.6.0_13\lzma.dll
2009-04-06 00:22 . 2009-04-06 00:22 17248 ----a-w- c:\windows\system32\135z1troj3195.dll
2009-04-01 03:48 . 2009-04-01 03:48 8394 ----a-w- c:\windows\system32\19095worm79z.bin
2009-03-28 07:58 . 2009-03-28 07:58 3481 ----a-w- c:\windows\9z535a9ktool4c.exe
2009-03-25 20:42 . 2009-03-25 20:42 4423 ----a-w- c:\windows\e96vzr9605.exe
2007-11-04 17:09 . 2007-11-04 17:09 577025 --sha-w- c:\windows\system32\tclfwjvu.tmp
philosophicalbass
Posts Posts : 34
Post by philosophicalbass on Sun Jun 21, 2009 11:00 pm
"SpybotSD TeaTimer"="c:\program files\Spybot - Search & Destroy\TeaTimer.exe" [2008-01-28 2097488]
"BitTorrent DNA"="c:\program files\DNA\btdna.exe" [2009-01-20 342848]
"ATIPTA"="c:\program files\ATI Technologies\ATI Control Panel\atiptaxx.exe" [2005-12-02 344064]
"SynTPEnh"="c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2006-11-14 815104]
"RecGuard"="c:\windows\SMINST\RecGuard.exe" [2005-10-11 1187840]
"QPService"="c:\program files\HP\QuickPlay\QPService.exe" [2005-12-12 94208]
"hpWirelessAssistant"="c:\program files\hpq\HP Wireless Assistant\HP Wireless Assistant.exe" [2005-12-13 507904]
"ehTray"="c:\windows\ehome\ehtray.exe" [2005-08-06 64512]
"eabconfg.cpl"="c:\program files\HPQ\Quick Launch Buttons\EabServr.exe" [2005-12-22 405504]
"Cpqset"="c:\program files\HPQ\Default Settings\cpqset.exe" [2005-08-01 233534]
"LogitechCommunicationsManager"="c:\program files\Common Files\LogiShrd\LComMgr\Communications_Helper.exe" [2007-07-26 563984]
"LogitechQuickCamRibbon"="c:\program files\Logitech\QuickCam\Quickcam.exe" [2007-07-26 2027792]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2008-03-15 185896]
"ccApp"="c:\program files\Common Files\Symantec Shared\ccApp.exe" [2006-03-07 53408]
"vptray"="c:\progra~1\BESECU~1\SYMANT~2\VPTray.exe" [2006-03-17 124656]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2008-05-27 413696]
"AppleSyncNotifier"="c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2008-07-10 116040]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2008-07-30 289064]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-10-15 39792]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-03-09 148888]
"HP Software Update"="c:\program files\Hp\HP Software Update\HPWuSchd2.exe" [2007-05-08 54840]
"ISTray"="c:\program files\Spyware Doctor\pctsTray.exe" [2009-06-12 1181576]
"swg"="c:\program files\Google\GoogleToolbarNotifier\1.2.1128.5462\GoogleToolbarNotifier.exe" [2007-02-19 171448]
HotSync Manager.lnk - c:\program files\palmOne\Hotsync.exe [2008-1-3 1392640]
Microsoft Office.lnk - c:\program files\Microsoft Office\Office10\OSA.EXE [2001-2-12 83360]
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^America Online 9.0 Tray Icon.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\America Online 9.0 Tray Icon.lnk
backup=c:\windows\pss\America Online 9.0 Tray Icon.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Photosmart Premier Fast Start.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\HP Photosmart Premier Fast Start.lnk
backup=c:\windows\pss\HP Photosmart Premier Fast Start.lnkCommon Startup
"EnableFirewall"= 0 (0x0)
"c:\\StubInstaller.exe"=
"c:\\Program Files\\Common Files\\AOL\\ACS\\AOLDial.exe"=
"c:\\Program Files\\Common Files\\AOL\\ACS\\AOLacsd.exe"=
"c:\\Program Files\\America Online 9.0\\waol.exe"=
"c:\\Program Files\\Common Files\\AOL\\1167714396\\ee\\aolsoftware.exe"=
"c:\\Program Files\\DNA\\btdna.exe"=
"c:\\Program Files\\BitTorrent\\bittorrent.exe"=
R0 PCTCore;PCTools KDS;c:\windows\system32\drivers\PCTCore.sys [6/20/2009 3:47 AM 130936]
R2 ioloFileInfoList;iolo FileInfoList Service;c:\program files\iolo\Common\Lib\ioloServiceManager.exe [1/6/2008 8:59 AM 572776]
R2 ioloSystemService;iolo System Service;c:\program files\iolo\Common\Lib\ioloServiceManager.exe [1/6/2008 8:59 AM 572776]
R2 sdAuxService;PC Tools Auxiliary Service;c:\program files\Spyware Doctor\pctsAuxs.exe [6/20/2009 3:47 AM 348752]
R2 UacFlt;Philips Composite Class Filter Driver;c:\windows\system32\drivers\uacbflt.sys [6/13/2002 10:40 PM 21276]
R2 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\Viewpoint\Common\ViewpointService.exe [11/16/2008 2:09 PM 24652]
R3 EraserUtilRebootDrv;EraserUtilRebootDrv;c:\program files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys [2/28/2009 1:12 PM 101936]
R3 HSFHWATI;HSFHWATI;c:\windows\system32\drivers\HSFHWATI.sys [8/22/2005 2:06 AM 231424]
S3 SavRoam;SAVRoam;c:\program files\Be Secure 2007\Symantec AntiVirus\SavRoam.exe [3/17/2006 6:34 AM 115952]
*Deregistered* - mchInjDrv
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\>{60B49E34-C7CC-11D0-8953-00A0C90347FF}]
"c:\windows\system32\rundll32.exe" "c:\windows\system32\iedkcs32.dll",BrandIEActiveSetup SIGNUP
2009-06-10 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 19:34]
BHO-{371EBD01-4415-4F57-A786-73328AEFBF58} - c:\windows\system32\mljjg.dll
HKCU-Run-Aim6 - (no file)
HKLM-Run-HotSync - c:\program files\PalmSource\Desktop\HotSync.exe
HKLM-Run-WinBlueSoft - c:\program files\WinBlueSoft Software\WinBlueSoft\WinBlueSoft.exe
SSODL-bokpkov-{E7B35CA8-0996-49FD-9651-2D114F09E1F4} - c:\windows\bokpkov.dll
SSODL-altvxvm-{FD5CA636-51C7-4349-9F02-717A53E3AA48} - c:\windows\altvxvm.dll
IE: &Google Search - c:\program files\Google\GoogleToolbar1.dll/cmsearch.html
IE: &Translate English Word - c:\program files\Google\GoogleToolbar1.dll/cmwordtrans.html
IE: Backward Links - c:\program files\Google\GoogleToolbar1.dll/cmbacklinks.html
IE: Cached Snapshot of Page - c:\program files\Google\GoogleToolbar1.dll/cmcache.html
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~4\Office10\EXCEL.EXE/3000
IE: Similar Pages - c:\program files\Google\GoogleToolbar1.dll/cmsimilar.html
IE: Translate Page into English - c:\program files\Google\GoogleToolbar1.dll/cmtrans.html
FF - ProfilePath -
Rootkit scan 2009-06-21 15:46
detected NTDLL code modification:
ZwClose
Cpqset = c:\program files\HPQ\Default Settings\cpqset.exe????????????n??|?????? ???B?????????????hLC? ??????
- - - - - - - > 'winlogon.exe'(912)
Completion time: 2009-06-21 15:51
ComboFix-quarantined-files.txt 2009-06-21 22:51
Pre-Run: 32,315,588,608 bytes free
Post-Run: 32,917,938,176 bytes free
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Media Center Edition" /noexecute=optin /fastdetect
601 --- E O F --- 2009-06-10 09:39
philosophicalbass
Posts Posts : 34
Post by Origin on Mon Jun 22, 2009 1:44 am
Now open a new notepad file.
File::
C:\windows\system32\528e5par9z898.exe
Folder::
Registry::
"BitTorrent DNA"=-
"c:\\Program Files\\LimeWire\\LimeWire.exe"=-
"c:\\Program Files\\DNA\\btdna.exe"=-
"c:\\Program Files\\BitTorrent\\bittorrent.exe"=-
Posts Posts : 2685
Post by philosophicalbass on Mon Jun 22, 2009 5:26 am
ComboFix 09-06-21.01 - mitchell kaplan 06/21/2009 20:35.2 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.510.141 [GMT -7:00]
Command switches used :: c:\documents and settings\mitchell kaplan\Desktop\CFScript.txt
* Created a new restore point
FILE ::
"c:\windows\4b205parsez897.dll"
"c:\windows\4ed0th5ef85z9.exe"
"c:\windows\5146ha9ktool5z5.bin"
"c:\windows\5182spy9zre2585.exe"
"c:\windows\5286spamz59126.exe"
"c:\windows\52aethizf5469.dll"
"c:\windows\5aedthr9at154z4.bin"
"c:\windows\5azathi5f194.dll"
"c:\windows\5c31tz9ef2570.bin"
"c:\windows\5c53downloaz9r13985.exe"
"c:\windows\5z796worm213.bin"
"c:\windows\6912hzckto5l59d.bin"
"c:\windows\6979spar5e1z9.dll"
"c:\windows\6a10tz9ef1945.exe"
"c:\windows\6zbab5ckdoor1967.dll"
"c:\windows\73725irzs9e8.dll"
"c:\windows\752ddownl9adzr1256.bin"
"c:\windows\759thzea9345.dll"
"c:\windows\8445virz9579.bin"
"c:\windows\880zhackto5l952.exe"
"c:\windows\8816v95usz4a.bin"
"c:\windows\9054wozm556.bin"
"c:\windows\905z3worm6aa.exe"
"c:\windows\94fvzr536.exe"
"c:\windows\9963down5zader2185.bin"
"c:\windows\9a88steal265z.dll"
"c:\windows\9dz1backdoo53140.bin"
"c:\windows\9z535a9ktool4c.exe"
"c:\windows\b5bs5zal899.bin"
"c:\windows\b90threaz319995.dll"
"c:\windows\e96vzr9605.exe"
"c:\windows\fb0azdwa9e5990.exe"
"c:\windows\system32\11951spz959.dll"
"c:\windows\system32\11threat967z5.bin"
"c:\windows\system32\135z1troj3195.dll"
"c:\windows\system32\13673spa5bo933z.dll"
"c:\windows\system32\15453tr5jz869.exe"
"c:\windows\system32\15765viru9z5f.bin"
"c:\windows\system32\17965not-a-5zrus5759.exe"
"c:\windows\system32\19095worm79z.bin"
"c:\windows\system32\19689s9ambzt6fa5.bin"
"c:\windows\system32\1ebzsteal9056.bin"
"c:\windows\system32\1z559hacktool9f3.dll"
"c:\windows\system32\21zcdownloa5er3097.bin"
"c:\windows\system32\22250vizus595.dll"
"c:\windows\system32\245spy9az.bin"
"c:\windows\system32\25094not-9-virusza5.dll"
"c:\windows\system32\25575ha9ztool478.bin"
"c:\windows\system32\25884spzmbot89.dll"
"c:\windows\system32\26492vi5us24z.exe"
"c:\windows\system32\265255py9bz.dll"
"c:\windows\system32\29215hac9tool1c6z.exe"
"c:\windows\system32\2b9ethie5488z.dll"
"c:\windows\system32\304225iz9s4d8.exe"
"c:\windows\system32\3d7za9dware569.exe"
"c:\windows\system32\3z98sparse2158.bin"
"c:\windows\system32\430edo9nzoad5r138.bin"
"c:\windows\system32\4470addwzre59309.bin"
"c:\windows\system32\528e5par9z898.exe"
"c:\windows\system32\5301sp5mb9z740.bin"
"c:\windows\system32\54799tealz537.exe"
"c:\windows\system32\5551tr5z609.bin"
"c:\windows\system32\556fth9zf2612.exe"
"c:\windows\system32\56az9hie51808.exe"
"c:\windows\system32\5ac1s9yw5re2z11.exe"
"c:\windows\system32\5ac9spyware55z.bin"
"c:\windows\system32\5b14thi59z008.exe"
"c:\windows\system32\5cb1bzckd9or2672.exe"
"c:\windows\system32\5zd8vir5389.bin"
"c:\windows\system32\6597zhi5f2808.dll"
"c:\windows\system32\6611bzckdoor9574.bin"
"c:\windows\system32\67569hreat19z32.bin"
"c:\windows\system32\699zt5ief819.bin"
"c:\windows\system32\6ab9backdoo51z41.exe"
"c:\windows\system32\6bd5zpy59re2586.bin"
"c:\windows\system32\6ec1downloa9er5z29.exe"
"c:\windows\system32\714z9pa5se451.dll"
"c:\windows\system32\76645pywarez899.exe"
"c:\windows\system32\78e2spar9e529z.exe"
"c:\windows\system32\7965spz5se1876.bin"
"c:\windows\system32\91548not-a-vi5uz45.bin"
"c:\windows\system32\92600zpambo5b7.dll"
"c:\windows\system32\9338spy596z.exe"
"c:\windows\system32\tclfwjvu.tmp"
"c:\windows\system32\z4ees9yw5re1021.dll"
"c:\windows\system32\z5293worm57b.bin"
philosophicalbass
Posts Posts : 34
Post by philosophicalbass on Mon Jun 22, 2009 5:30 am
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Amateur 18yo flexible girl stretches on BIG cock.wmv.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\babe takes a huge cock in her pussy.wmv.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Big Cock Teen Adiction - Cameron Love.rar.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\bittorrent.lng
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\bobs-f***-movie-collection01.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Cicciolina and Peter North.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Cute teen f*** a huge cock.wmv.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\dht.dat
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\dht.dat.old
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\DOOM 1&2.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Facial Abuse - Hannah.avi.1.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Facial Abuse - Hannah.avi.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Filthy_First_Timers_22_Teen_Sex_Porn.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Gag Slut Getting a Forced Face f***.zip.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Girl with Tight smooth shaved pussy getting a big one [ggbabes.com] .avi.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\holly- dog collar- face f***.wmv.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Hot babe gets big cock in her pussy.flv.rar.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\ID.Software.Classics.Collection.30+.Games.(1990-1997).DOOM.Commander.Keen.Heretic.Hexen.Quake.iso.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\mileyann-wmvFullHigh-1.wmv.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Mysongbook.Guitar.Pro.January.2006(55294.tabs).zip.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\OMG Wut a Brutal Face f***.rar.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Peter north cumsh0ts complete compilation.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Poolside Cheating Pussy.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\resume.dat
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\resume.dat.old
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\rss.dat
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\rss.dat.old
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Sara Stone.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\settings.dat
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\settings.dat.old
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Teen Sex - Teenie f*** by huge cock.wmv.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Tight 19yo Pussy gets Annihilated.wmv.1.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Tight 19yo Pussy gets Annihilated.wmv.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Tight asian pussy riding a BIG dick.wmv.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\Youngthroats - Keri.wmv.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\YoungThroats - Laura.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\YoungThroats.Bailey.XXX.[SiteRip][GoldenPirates].torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\YoungThroats.Cassie.XXX.[SiteRip][GoldenPirates].torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\youngthroats.com Whitney.torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\YoungThroats.DianeXXX.[SiteRip][GoldenPirates].torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\YoungThroats.Drew.XXX.[SiteRip][GoldenPirates].torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\YoungThroats.Geri.XXX.[SiteRip][GoldenPirates].torrent
c:\documents and settings\mitchell kaplan\Application Data\BitTorrent\YoungThroatsCollection.torrent
c:\documents and settings\mitchell kaplan\Application Data\DNA\dht.dat
c:\documents and settings\mitchell kaplan\Application Data\DNA\dht.dat.old
c:\documents and settings\mitchell kaplan\Application Data\DNA\dna.lng
c:\documents and settings\mitchell kaplan\Application Data\DNA\resume.dat
c:\documents and settings\mitchell kaplan\Application Data\DNA\resume.dat.old
c:\documents and settings\mitchell kaplan\Application Data\DNA\rss.dat
c:\documents and settings\mitchell kaplan\Application Data\DNA\rss.dat.old
c:\documents and settings\mitchell kaplan\Application Data\DNA\settings.dat
c:\documents and settings\mitchell kaplan\Application Data\DNA\settings.dat.old
c:\program files\DNA\DNAcpl.cpl
c:\program files\DNA\plugins\npbtdna.dll
c:\windows\45e8sp9rse292z.exe
c:\windows\46b5downlo5de9z406.dll
c:\windows\47ecz5eal9935.exe
c:\windows\4962baczdoor9959.cpl
c:\windows\4975szy193.ocx
c:\windows\49eczackdo5r2627.ocx
c:\windows\4a72add9are3z52.dll
c:\windows\4a8stza515259.cpl
c:\windows\4bdadd95ze2937.cpl
c:\windows\4c92zpa5se1493.bin
c:\windows\4db0t5rez93585.exe
c:\windows\4e96th5ez409.cpl
c:\windows\4f0et9reat12257z.ocx
c:\windows\4fbds5ezl9254.cpl
c:\windows\4ff5addwzre2911.bin
c:\windows\4z0dspy5a9e82.ocx
c:\windows\4z375ownl9ader522.exe
c:\windows\4z459ir435.ocx
c:\windows\4zf0downlo5de9317.exe
c:\windows\508eadzw9re1939.dll
c:\windows\516eaddzare97675.exe
c:\windows\51f6downlo9derz845.dll
c:\windows\5203s5ea931z7.cpl
c:\windows\5216tro59az.exe
c:\windows\52425zief1399.cpl
c:\windows\529fzir925.exe
c:\windows\532hzckt5ol29e.cpl
c:\windows\53957spambot19ez.cpl
c:\windows\5418spam9ot3z5.exe
c:\windows\54915sp9zdd.ocx
c:\windows\556backdoor2795z.exe
c:\windows\55935pywarez194.dll
c:\windows\5769v9zus5d9.bin
c:\windows\57e8add9are2515z.bin
c:\windows\585fsp9rsz1566.dll
c:\windows\58993hacktzol198.exe
c:\windows\58dethzef5009.dll
c:\windows\591zspambot9c45.cpl
c:\windows\59209spy26z.dll
c:\windows\59461z9t-a-virus62d.cpl
c:\windows\5977troj2z5.bin
c:\windows\5988zhreat237065.cpl
c:\windows\59a4steaz3879.ocx
c:\windows\59ccadd5aze1235.ocx
c:\windows\5a3dspywzre159.cpl
c:\windows\5a6ft9zea526870.cpl
c:\windows\5b63thrzat19918.cpl
c:\windows\5b69tealz011.dll
c:\windows\5c629ir2683z.cpl
c:\windows\5c86threa9z653.cpl
c:\windows\5cedszyware592.cpl
c:\windows\5ddbtzre956955.bin
c:\windows\5decsp5rsz9228.cpl
c:\windows\5df9vzr1559.bin
c:\windows\5dst9al2372z.exe
c:\windows\5e48sp5warz926.cpl
c:\windows\5fa5s9arsez018.bin
c:\windows\5z235ackdo9r1694.ocx
c:\windows\5za1a95ware1280.dll
c:\windows\5zb7stea92507.dll
c:\windows\6119worz5b29.exe
c:\windows\6265t59ef97z.ocx
c:\windows\62b1adzw95e2587.exe
c:\windows\6357downloz5er2219.bin
c:\windows\636a9pywa5e1z55.exe
c:\windows\63zfa5dw9re1193.ocx
c:\windows\6532szea91500.exe
c:\windows\6543vizu59ee.bin
c:\windows\6547bac9dozr1519.ocx
c:\windows\663espzrse2598.ocx
c:\windows\673asparsz1659.ocx
c:\windows\67579pzrse1352.bin
c:\windows\68049pazse3058.cpl
c:\windows\69205izus7d4.dll
c:\windows\69385pamboz92.exe
c:\windows\6995sp95bot2z4.ocx
c:\windows\6d9cz9r2965.exe
c:\windows\6e09threatz5657.dll
c:\windows\6e7espyware5z9.cpl
c:\windows\6eea5pywa9e47z.ocx
c:\windows\71b1download5r92z2.dll
c:\windows\73c95dzware2937.exe
c:\windows\7535virzs985.cpl
c:\windows\7563tro5z9f.exe
c:\windows\7586n5z-a-9irus7a2.ocx
c:\windows\7593zparse3080.ocx
c:\windows\75bbbackdoo9219z.ocx
c:\windows\75e0thzeat307975.exe
c:\windows\7755ot-az9irus512.cpl
c:\windows\789zp5rse1900.ocx
c:\windows\79135zarse3024.bin
c:\windows\7bf9ir2z55.ocx
c:\windows\7d12vi9z156.cpl
c:\windows\7z3e5pywa9e766.bin
c:\windows\7zb659arse236.ocx
c:\windows\7zd4backd5or1699.cpl
c:\windows\8559zacktool1b5.cpl
c:\windows\85z8v9rusfb.ocx
c:\windows\8600spy9z75.exe
c:\windows\8814not-a-virus6z59.dll
c:\windows\8859vi5uz548.ocx
c:\windows\904th9ef5z9.exe
c:\windows\9085backdoor5z2.dll
c:\windows\925threaz17531.bin
c:\windows\93733zirusd5.dll
c:\windows\952backdooz2127.bin
c:\windows\95801zpambot3b.cpl
c:\windows\95z69worm508.bin
c:\windows\9645spamzot69.exe
c:\windows\96797w5rz2a6.ocx
c:\windows\9709wor5770z.ocx
c:\windows\983athrzat15719.dll
c:\windows\995zspye5.dll
c:\windows\99880virus3z5.exe
c:\windows\9993vi51482z.bin
c:\windows\9999zot-a-vir5s7af.cpl
c:\windows\99d1spa5se173z.ocx
c:\windows\9a73spyzare59.exe
c:\windows\9aa2addwzre3252.bin
c:\windows\9dbzpyw5re1378.bin
c:\windows\9dc4thzef2545.exe
c:\windows\9fb2vzr1527.dll
c:\windows\9z225pambot295.ocx
c:\windows\9z657worm64b.exe
c:\windows\9z9steal3596.ocx
c:\windows\a19v9r1z52.bin
c:\windows\a56stezl9782.cpl
c:\windows\az1bac5d9or9.bin
c:\windows\b50dow5loa9zr953.bin
c:\windows\b53t9rezt12696.exe
c:\windows\c56vz91461.cpl
c:\windows\d95virz736.ocx
c:\windows\e5b9ddware1507z.cpl
c:\windows\fd1b5ckdo9r29z3.ocx
c:\windows\system32\10009ac5tzol336.ocx
c:\windows\system32\1033v5rz917.ocx
c:\windows\system32\10435vzr5s951.ocx
c:\windows\system32\105895wzloader2977.bin
c:\windows\system32\105959orm96z.cpl
c:\windows\system32\1190s5z16c.bin
c:\windows\system32\11939ha5kzool3cc.ocx
c:\windows\system32\119z3tro9504.exe
c:\windows\system32\11z15t95jf5.dll
c:\windows\system32\12706ha9ktzol3995.exe
c:\windows\system32\12z859oj2d5.dll
c:\windows\system32\14494szy9a5.bin
c:\windows\system32\14706w5rm9a3z.exe
c:\windows\system32\14855spa9zot113.bin
c:\windows\system32\14931n9tza-virus458.exe
c:\windows\system32\149529acktzol595.ocx
c:\windows\system32\15022worz3489.bin
c:\windows\system32\1505zn5t9a-virus37.cpl
c:\windows\system32\15091troj55ez.cpl
c:\windows\system32\15392tr9jza4.dll
c:\windows\system32\159665pz569.dll
c:\windows\system32\1597sp9mbot6z0.exe
c:\windows\system32\16103ziru51e19.dll
c:\windows\system32\1632zac9d5or556.exe
c:\windows\system32\1659zv9rus424.dll
c:\windows\system32\17950troj72az.ocx
c:\windows\system32\187619iruz35c.bin
c:\windows\system32\19250z5y29e.cpl
c:\windows\system32\19570sz52ca.cpl
c:\windows\system32\19b9z9i5f711.cpl
c:\windows\system32\19baviz2552.bin
c:\windows\system32\1azcst5al24019.ocx
c:\windows\system32\1c07downlozder17859.cpl
c:\windows\system32\1c64zte5l2229.ocx
c:\windows\system32\1d5fspyw9re3z4.ocx
c:\windows\system32\1e0esparz52397.exe
c:\windows\system32\1ez5backdoor993.dll
c:\windows\system32\1fe9szyware4195.dll
c:\windows\system32\1fze5ackdoor21129.exe
c:\windows\system32\1z03t9o5532.cpl
c:\windows\system32\1z143tr5j4d79.ocx
c:\windows\system32\1z851ha9kt5ol4d4.dll
c:\windows\system32\1z995spamb5t62f.cpl
philosophicalbass
Posts Posts : 34
Joined Joined : 2009-06-20
Points Points : 27358
Re: WinBlueSoft problems
c:\windows\system32\205z1s9ambot18b.ocx
c:\windows\system32\209175orm6zd9.ocx
c:\windows\system32\2102dowzloa95r575.exe
c:\windows\system32\21895reatz400.ocx
c:\windows\system32\22z0steal958.cpl
c:\windows\system32\23349not-a9vizus55.bin
c:\windows\system32\2355spamzot796.ocx
c:\windows\system32\23992spam5oz325.exe
c:\windows\system32\24479virz57f7.exe
c:\windows\system32\24685tro956bz.cpl
c:\windows\system32\24dcazdw5re1397.cpl
c:\windows\system32\250555ackt9zl712.dll
c:\windows\system32\25155ac9door31z1.bin
c:\windows\system32\25277not-a-zi9u557f.ocx
c:\windows\system32\25446sp59botza3.cpl
c:\windows\system32\25z5backdoor3209.exe
c:\windows\system32\25z99hief649.exe
c:\windows\system32\262759roj7z95.ocx
c:\windows\system32\26592h5c9tool551z.exe
c:\windows\system32\2692495z-a-virus487.ocx
c:\windows\system32\26959viruz26f.ocx
c:\windows\system32\271z5p99f.ocx
c:\windows\system32\27227haczt5ol31f9.cpl
c:\windows\system32\2743ad9warez995.dll
c:\windows\system32\27518spy5z9.cpl
c:\windows\system32\27666sp9mb5z5d6.exe
c:\windows\system32\28085t5z9253.dll
c:\windows\system32\28540not-9zvirus228.cpl
c:\windows\system32\2869spyware3051z.exe
c:\windows\system32\286ezp9rse1357.ocx
c:\windows\system32\29051spambot65bz.cpl
c:\windows\system32\29254zro515f.ocx
c:\windows\system32\2945thiez2548.ocx
c:\windows\system32\296dbazkdoor8605.bin
c:\windows\system32\296z6virus6945.cpl
c:\windows\system32\29929worm4z5.dll
c:\windows\system32\29despyw5re29z2.dll
c:\windows\system32\2a3zad5ware296.dll
c:\windows\system32\2ca25pywa9ez114.bin
c:\windows\system32\2d59sparse3z85.ocx
c:\windows\system32\2e15zi92036.bin
c:\windows\system32\2e23d5wzloader5149.ocx
c:\windows\system32\2e43spzwa9e5607.exe
c:\windows\system32\2z17backdoor4559.bin
c:\windows\system32\2z819tro95ec.ocx
c:\windows\system32\304159i5us38z.ocx
c:\windows\system32\30576v9zus45a.cpl
c:\windows\system32\309ownloadzr23365.ocx
c:\windows\system32\30csp9rse559z.dll
c:\windows\system32\31143n5t-9-virzs71f.cpl
c:\windows\system32\31970trzj45a.exe
c:\windows\system32\330bbackdoo511z9.exe
c:\windows\system32\3355addwzre994.ocx
c:\windows\system32\3365downloader565z9.exe
c:\windows\system32\34z95hief27169.ocx
c:\windows\system32\353atzie92800.dll
c:\windows\system32\355down9oadez2725.ocx
c:\windows\system32\35729ddwarez176.ocx
c:\windows\system32\35eas9ywzre2368.dll
c:\windows\system32\36bbdownloaderz9365.ocx
c:\windows\system32\37179i5us5z8.exe
c:\windows\system32\375azownload9r2559.dll
c:\windows\system32\37f4stezl9952.ocx
c:\windows\system32\38d9ad5waze26119.bin
c:\windows\system32\39209parse5114z.dll
c:\windows\system32\39887troj55az.bin
c:\windows\system32\398945py7z0.ocx
c:\windows\system32\3991threat26995z.ocx
c:\windows\system32\3d439ddw5re27z3.dll
c:\windows\system32\3d4et9i5f2z70.ocx
c:\windows\system32\3d6faddwa5e269z.bin
c:\windows\system32\3eezspy5are1930.dll
c:\windows\system32\3f84zddwar9635.cpl
c:\windows\system32\3f96v5r285z9.dll
c:\windows\system32\3fczsteal28915.exe
c:\windows\system32\3z5dvir2869.exe
c:\windows\system32\3z925ir253.cpl
c:\windows\system32\4029zac9tool85.bin
c:\windows\system32\40685hiez9905.ocx
c:\windows\system32\4123spy159z.exe
c:\windows\system32\4359tzreat17530.cpl
c:\windows\system32\452at9rzat256055.exe
c:\windows\system32\4569d9wnloader1z96.ocx
c:\windows\system32\459dzi91578.cpl
c:\windows\system32\459t9zj46e.bin
c:\windows\system32\492atzrea53769.bin
c:\windows\system32\49fstea5811z.ocx
c:\windows\system32\4a5s5azse769.cpl
c:\windows\system32\4a91thie53z53.ocx
c:\windows\system32\4cdzdownload9r752.exe
c:\windows\system32\4ce59hi5f294z.exe
c:\windows\system32\4dc9spzware9554.bin
c:\windows\system32\4e5dzir3923.dll
c:\windows\system32\4e7z5ir3199.cpl
c:\windows\system32\505dspyware99z.ocx
c:\windows\system32\50897hazktool3319.ocx
c:\windows\system32\50z5spyware2098.ocx
c:\windows\system32\514thiz9692.dll
c:\windows\system32\51610hackto9z651.exe
c:\windows\system32\5175sp59are2z90.cpl
c:\windows\system32\51f9dowzloader735.cpl
c:\windows\system32\52948viru97a9z.dll
c:\windows\system32\5298thief59z.bin
c:\windows\system32\5369not-az5iru94f4.cpl
c:\windows\system32\53baazd9a5e2350.ocx
c:\windows\system32\53z4d9wnloader1971.dll
c:\windows\system32\548495rz080.exe
c:\windows\system32\54875acktool9z5.bin
c:\windows\system32\54d8thr5at2599z.ocx
c:\windows\system32\553bdo9nlzader2145.cpl
c:\windows\system32\5544download9r4z1.bin
c:\windows\system32\5557z9ambot51.bin
c:\windows\system32\5593vir162z.bin
c:\windows\system32\5597virzs70d9.exe
c:\windows\system32\55ecthie918z8.cpl
c:\windows\system32\55f2bazkdo9r1338.dll
c:\windows\system32\56czba9kdoor411.dll
c:\windows\system32\56z2spywar92135.bin
c:\windows\system32\56z4h9ckto5l2e5.cpl
c:\windows\system32\578db9zkd5or2076.ocx
c:\windows\system32\5794not-a-5iruz35a.cpl
c:\windows\system32\57z8tro944.exe
c:\windows\system32\5833zpy3559.dll
c:\windows\system32\59155hzcktool929.cpl
c:\windows\system32\593c5ownzoader3031.bin
c:\windows\system32\597cvi527z5.bin
c:\windows\system32\59819pywaze2354.ocx
c:\windows\system32\5989hack9ool6a3z.dll
c:\windows\system32\5ac0spywar911z8.dll
c:\windows\system32\5ac8threat19954z.bin
c:\windows\system32\5adf9hreaz53298.bin
c:\windows\system32\5az6addwa9e1308.ocx
c:\windows\system32\5b0zthi5f9353.cpl
c:\windows\system32\5b56spzrse1951.ocx
c:\windows\system32\5beds5ea9z775.cpl
c:\windows\system32\5c6zthief1935.ocx
c:\windows\system32\5c915ddware311z.cpl
c:\windows\system32\5cbstea91z2.ocx
c:\windows\system32\5cdzs5ar9e1176.dll
c:\windows\system32\5f0zvir1569.cpl
c:\windows\system32\5f1cbz5kdo9r3019.exe
c:\windows\system32\5f5as5yware2910z.ocx
c:\windows\system32\5fcfsp5warez971.cpl
c:\windows\system32\5fd9thi5f2940z.exe
c:\windows\system32\5ff8dowzl5ader32589.bin
c:\windows\system32\5z43wor9465.cpl
c:\windows\system32\5z6ev9r22945.cpl
c:\windows\system32\5z932worm5cd.exe
c:\windows\system32\6005hack9ozl59d.cpl
c:\windows\system32\61055ot-a-zir9s46f.ocx
c:\windows\system32\620z9pambot57.exe
c:\windows\system32\6387sz9al2055.bin
c:\windows\system32\63e99i5z12.ocx
c:\windows\system32\649ct9r5zt3918.cpl
c:\windows\system32\65c8zpy9are653.ocx
c:\windows\system32\6657spzw9re1802.dll
c:\windows\system32\66a8spa5se192z.exe
c:\windows\system32\66c795r27z3.exe
c:\windows\system32\675zdownload591276.bin
c:\windows\system32\6959spz5se191.exe
c:\windows\system32\695wozm476.ocx
c:\windows\system32\6968downl5ader296z.cpl
c:\windows\system32\6c02download59z912.ocx
c:\windows\system32\6d50thi9f1z26.cpl
c:\windows\system32\6f435pyw9rz481.bin
c:\windows\system32\7030add9are355z.cpl
c:\windows\system32\71e3dozn5oad9r1962.bin
c:\windows\system32\71z8vir9525.bin
c:\windows\system32\71zcthi5f7449.cpl
c:\windows\system32\7225nzt-a-vir9s709.exe
c:\windows\system32\7269sp5war9z19.cpl
c:\windows\system32\7276zot-a-virus5559.dll
c:\windows\system32\7299d5wnloaderz363.exe
c:\windows\system32\73979irzs6685.cpl
c:\windows\system32\73ath9z5t7324.ocx
c:\windows\system32\7525stez9992.cpl
c:\windows\system32\7595vzru9454.cpl
c:\windows\system32\75c5th9ez755.exe
c:\windows\system32\75cspyw9rz2559.cpl
c:\windows\system32\7634zte9l16225.exe
c:\windows\system32\7651back5oo9138z.dll
c:\windows\system32\76d1zddwa5e199.exe
c:\windows\system32\76z5vir3629.ocx
c:\windows\system32\772zs5ar9e2879.cpl
c:\windows\system32\7749s9ywzre5529.ocx
c:\windows\system32\7784threaz51990.bin
c:\windows\system32\78c4do5nloader909z.cpl
c:\windows\system32\7913zot-a-virus5cc.cpl
c:\windows\system32\795bdowzloader1476.cpl
c:\windows\system32\7969szeal5793.cpl
c:\windows\system32\7986s5yware2096z.cpl
c:\windows\system32\79a5bac5zoor9735.exe
c:\windows\system32\79a9z5r62.ocx
c:\windows\system32\79bcspzwa5e2589.cpl
c:\windows\system32\7a169ownzoader24695.bin
c:\windows\system32\7bb1dow9loade55z7.cpl
c:\windows\system32\7c65vzr28919.ocx
c:\windows\system32\7dac5pywa9z1731.dll
c:\windows\system32\805bac9dzor2974.dll
c:\windows\system32\87285p9mbot51cz.dll
c:\windows\system32\8839spazbot454.dll
c:\windows\system32\891haczto9l5d5.bin
c:\windows\system32\9053ztroj555.dll
c:\windows\system32\90837tzoj4845.dll
c:\windows\system32\9284tr5jze29.exe
c:\windows\system32\94839zam5ot5dc.exe
c:\windows\system32\9514thzef175.ocx
c:\windows\system32\951z5py584.exe
c:\windows\system32\9553z9rusc0.dll
c:\windows\system32\955esteaz522.bin
c:\windows\system32\957downloade5z4089.exe
c:\windows\system32\95829viruz425.dll
c:\windows\system32\95904vzrus5e3.exe
c:\windows\system32\95z81tro5378.ocx
c:\windows\system32\9779hackto5lze5.exe
c:\windows\system32\9872spambot4z85.dll
c:\windows\system32\98753wzrm101.bin
c:\windows\system32\996backd5zr893.bin
c:\windows\system32\9aa5v5r86z.ocx
c:\windows\system32\9acbspywzre3425.cpl
c:\windows\system32\9c79spa5se1024z.cpl
c:\windows\system32\9f5addware1697z.cpl
c:\windows\system32\9z511spambo5183.cpl
c:\windows\system32\af05tealz394.cpl
c:\windows\system32\b52downzo9der2728.bin
c:\windows\system32\dd5s59warz1577.cpl
c:\windows\system32\eb95zyware459.dll
c:\windows\system32\z0217not-5-virusc9.cpl
c:\windows\system32\z0656s9y3c9.ocx
c:\windows\system32\z089ad59are2578.cpl
c:\windows\system32\z271thi5f2449.cpl
c:\windows\system32\z4319p521a.dll
c:\windows\system32\z4977hacktool5f39.dll
c:\windows\system32\z5351spambot959.bin
c:\windows\system32\z5819spy5e.exe
c:\windows\system32\z5aca9dware83.exe
c:\windows\system32\z715vir491.cpl
c:\windows\system32\z8669pamb5t2f8.ocx
c:\windows\system32\ze075pyw9re2548.exe
c:\windows\z055spa9bot512.cpl
c:\windows\z057not-a9virus3c4.ocx
c:\windows\z05cbackdoor1923.ocx
c:\windows\z096tr5j7a1.ocx
c:\windows\z0e7steal5595.bin
c:\windows\z1428not9a-vir5s7f3.cpl
c:\windows\z1472s5amb9t2a.ocx
c:\windows\z155addw9re1169.cpl
c:\windows\z21sp5war92695.bin
c:\windows\z2252h9cktool86.exe
c:\windows\z235steal9550.dll
c:\windows\z23e9hreat20865.ocx
c:\windows\z2416sp5m9ot2c1.cpl
c:\windows\z2875spamb9t75.exe
c:\windows\z33259ckdoor2445.bin
c:\windows\z4134hac9tool509.exe
c:\windows\z421spyware12059.dll
c:\windows\z4925spy703.dll
c:\windows\z4bf5i913.ocx
c:\windows\z54519irus475.cpl
c:\windows\z598steal58549.exe
c:\windows\z5dev9r1984.dll
c:\windows\z615troj7b09.bin
c:\windows\z684t5ief1925.ocx
c:\windows\z9dvir3250.ocx
c:\windows\zacaddwa5e692.ocx
c:\windows\zc5fadd9are332.dll
c:\windows\zc9dvir2445.exe
c:\windows\zdcds9arse1554.exe
c:\windows\ze925teal209.exe
c:\windows\zec4sp5wa9e824.cpl
c:\windows\zef6thief9655.exe
c:\windows\zfabaddware13539.exe
philosophicalbass
Posts Posts : 34
Post by philosophicalbass on Mon Jun 22, 2009 5:31 am
((((((((((((((((((((((((( Files Created from 2009-05-22 to 2009-06-22 )))))))))))))))))))))))))))))))
2009-06-20 10:47 . 2009-06-21 22:54 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
BHO-{371EBD01-4415-4F57-A786-73328AEFBF58} - (no file)
mWindow Title = Microsoft Internet Explorer presented by Comcast
uInternet Connection Wizard,ShellNext = [You must be registered and logged in to see this link.]
IE: &AOL Toolbar Search - c:\program files\aol\aol toolbar 2.0\aoltbhtml.dll/search.html
IE: &Search - ?p=ZCfox000
FF - ProfilePath -
Rootkit scan 2009-06-21 20:51
ZwClose
Completion time: 2009-06-22 20:55
ComboFix-quarantined-files.txt 2009-06-22 03:55
ComboFix2.txt 2009-06-21 22:51
Pre-Run: 32,896,319,488 bytes free
Post-Run: 32,875,868,160 bytes free
875 --- E O F --- 2009-06-10 09:39
philosophicalbass
Posts Posts : 34
Post by Origin on Mon Jun 22, 2009 2:55 pm
Posts Posts : 2685
Post by philosophicalbass on Mon Jul 06, 2009 2:53 am
Malwarebytes' Anti-Malware 1.38
Database version: 2378
7/5/2009 10:26:16 PM
mbam-log-2009-07-05 (22-26-16).txt
Objects scanned: 103010
Time elapsed: 13 minute(s), 55 second(s)
Registry Keys Infected: 12
HKEY_CLASSES_ROOT\etlrlws.bodx (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\etlrlws.toolbar.1 (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{49a93d1e-5c81-4074-89e2-dcfa48cea1de} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{a698f335-43de-4d83-aa95-dd8847b955d5} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{f8153af9-06fe-435a-84c7-b7fb066fe597} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{6572c831-4eed-4e74-865e-2cfc7693f1ca} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{fb180da7-1acd-4b7b-8d47-57e0ecea2767} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{cc721bba-7958-4b7e-8f88-81bc0b6dfa73} (Rogue.Installer) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{a6573479-9075-4a65-98a6-19fd29cf7374} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Installer\Products\568267acfc5644dab06f058006ddbae3 (Adware.Zango) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Installer\Features\9ee2330ae5f4470cac801baac83818c9 (Adware.Zango) -> Quarantined and deleted successfully.
philosophicalbass
Posts Posts : 34
Post by Belahzur on Mon Jul 06, 2009 2:13 pm
ComboFix /u
Points Points : 245059
Post by philosophicalbass on Sun Jul 19, 2009 1:42 am
It's still running a bit slowly. I suspect that more malware may have gotten on my computer recently; how, I'm not sure.
I want to thank you all SO MUCH for your help; you are truly angels.
Should I run HijackThis! or something to check for any current malware?
philosophicalbass
Posts Posts : 34
Post by Origin on Sun Jul 19, 2009 3:30 pm
Please post a new HijackThis log.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31473
Post by philosophicalbass on Sun Jul 19, 2009 7:44 pm
Scan saved at 3:39:39 PM, on 7/19/2009
C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
C:\Program Files\Be Secure 2007\Symantec Client Firewall\ISSVC.exe
C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe
C:\PROGRA~1\COMMON~1\AOL\ACS\AOLacsd.exe
C:\Program Files\Be Secure 2007\Symantec AntiVirus\DefWatch.exe
C:\Program Files\iolo\common\lib\ioloServiceManager.exe
C:\Program Files\Common Files\LogiShrd\LVCOMSER\LVComSer.exe
C:\Program Files\Be Secure 2007\Symantec AntiVirus\Rtvscan.exe
C:\Program Files\Be Secure 2007\Symantec Client Firewall\SymSPort.exe
C:\Program Files\Viewpoint\Common\ViewpointService.exe
C:\WINDOWS\wanmpsvc.exe
C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
C:\Program Files\HP\QuickPlay\QPService.exe
C:\Program Files\hpq\HP Wireless Assistant\HP Wireless Assistant.exe
C:\WINDOWS\ehome\ehtray.exe
C:\Program Files\HPQ\Quick Launch Buttons\EabServr.exe
C:\Program Files\Common Files\LogiShrd\LComMgr\Communications_Helper.exe
C:\Program Files\Logitech\QuickCam\Quickcam.exe
C:\PROGRA~1\hpq\Shared\HPQTOA~1.EXE
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\PROGRA~1\BESECU~1\SYMANT~2\VPTray.exe
C:\Program Files\Hp\HP Software Update\HPWuSchd2.exe
C:\Program Files\Be Secure 2007\Symantec AntiVirus\DoScan.exe
C:\PROGRA~1\FDF\FAST2.EXE
C:\Program Files\palmOne\Hotsync.exe
C:\Program Files\Common Files\Logishrd\LQCVFX\COCIManager.exe
O2 - BHO: Skype add-on (mastermind) - {22BF413B-C6D2-4d91-82A9-A0F997BA588C} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\Program Files\Real\RealPlayer\rpbrowserrecordplugin.dll
O2 - BHO: (no name) - {371EBD01-4415-4F57-A786-73328AEFBF58} - (no file)
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O2 - BHO: AOL Toolbar Launcher - {7C554162-8CB7-45A4-B8F4-8EA1C75885F9} - C:\Program Files\AOL\AOL Toolbar 2.0\aoltb.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\2.0.301.7164\swg.dll
O3 - Toolbar: AOLToolBand Class - {DE9C389F-3316-41A7-809B-AA305ED9D922} - C:\Program Files\AOL\AOL Toolbar 2.0\aoltb.dll
O4 - HKLM\..\Run: [ATIPTA] "C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe"
O4 - HKLM\..\Run: [RecGuard] C:\Windows\SMINST\RecGuard.exe
O4 - HKLM\..\Run: [QPService] "C:\Program Files\HP\QuickPlay\QPService.exe"
O4 - HKLM\..\Run: [hpWirelessAssistant] "C:\Program Files\hpq\HP Wireless Assistant\HP Wireless Assistant.exe"
O4 - HKLM\..\Run: [ehTray] C:\WINDOWS\ehome\ehtray.exe
O4 - HKLM\..\Run: [eabconfg.cpl] "C:\Program Files\HPQ\Quick Launch Buttons\EabServr.exe" /Start
O4 - HKLM\..\Run: [Cpqset] C:\Program Files\HPQ\Default Settings\cpqset.exe
O4 - HKLM\..\Run: [LogitechCommunicationsManager] "C:\Program Files\Common Files\LogiShrd\LComMgr\Communications_Helper.exe"
O4 - HKLM\..\Run: [LogitechQuickCamRibbon] "C:\Program Files\Logitech\QuickCam\Quickcam.exe" /hide
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [vptray] C:\PROGRA~1\BESECU~1\SYMANT~2\VPTray.exe
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\Hp\HP Software Update\HPWuSchd2.exe
O4 - HKCU\..\Run: [FAST Defrag] C:\PROGRA~1\FDF\FAST2.EXE -tray
O4 - HKUS\S-1-5-18\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\1.2.1128.5462\GoogleToolbarNotifier.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\1.2.1128.5462\GoogleToolbarNotifier.exe (User 'Default user')
O4 - Global Startup: HotSync Manager.lnk = C:\Program Files\palmOne\Hotsync.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O8 - Extra context menu item: &AOL Toolbar Search - [You must be registered and logged in to see this link.] files\aol\aol toolbar 2.0\aoltbhtml.dll/search.html
O8 - Extra context menu item: &Google Search - [You must be registered and logged in to see this link.] Files\Google\GoogleToolbar1.dll/cmsearch.html
O8 - Extra context menu item: &Search - ?p=ZCfox000
O8 - Extra context menu item: &Translate English Word - [You must be registered and logged in to see this link.] Files\Google\GoogleToolbar1.dll/cmwordtrans.html
O8 - Extra context menu item: Backward Links - [You must be registered and logged in to see this link.] Files\Google\GoogleToolbar1.dll/cmbacklinks.html
O8 - Extra context menu item: Cached Snapshot of Page - [You must be registered and logged in to see this link.] Files\Google\GoogleToolbar1.dll/cmcache.html
O8 - Extra context menu item: Similar Pages - [You must be registered and logged in to see this link.] Files\Google\GoogleToolbar1.dll/cmsimilar.html
O8 - Extra context menu item: Translate Page into English - [You must be registered and logged in to see this link.] Files\Google\GoogleToolbar1.dll/cmtrans.html
O9 - Extra button: (no name) - {5067A26B-1337-4436-8AFE-EE169C2DA79F} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra 'Tools' menuitem: Skype add-on for Internet Explorer - {5067A26B-1337-4436-8AFE-EE169C2DA79F} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra button: Skype - {77BF5300-1474-4EC7-9980-D32B190E9B07} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search && Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O14 - IERESET.INF: START_PAGE_URL=http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=Q106&bd=pavilion&pf=laptop
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (Installation Support) - C:\Program Files\Yahoo!\Common\Yinsthelper.dll
O16 - DPF: {F58E1CEF-A068-4C15-BA5E-587CAF3EE8C6} (MSN Chat Control 4.5) - [You must be registered and logged in to see this link.]
O18 - Protocol: x-cnote - {8D32BA61-D15B-11D4-894B-000000000000} - C:\Program Files\Common Files\EzTools\hsppp.dll
O23 - Service: AOL Connectivity Service (AOL ACS) - AOL LLC - C:\PROGRA~1\COMMON~1\AOL\ACS\AOLacsd.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
O23 - Service: Symantec Network Proxy (ccProxy) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
O23 - Service: Symantec AntiVirus Definition Watcher (DefWatch) - Symantec Corporation - C:\Program Files\Be Secure 2007\Symantec AntiVirus\DefWatch.exe
O23 - Service: iolo FileInfoList Service (ioloFileInfoList) - Unknown owner - C:\Program Files\iolo\common\lib\ioloServiceManager.exe
O23 - Service: iolo System Service (ioloSystemService) - Unknown owner - C:\Program Files\iolo\common\lib\ioloServiceManager.exe
O23 - Service: IS Service (ISSVC) - Symantec Corporation - C:\Program Files\Be Secure 2007\Symantec Client Firewall\ISSVC.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
O23 - Service: LVCOMSer - Logitech Inc. - C:\Program Files\Common Files\LogiShrd\LVCOMSER\LVComSer.exe
O23 - Service: Process Monitor (LVPrcSrv) - Logitech Inc. - C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe
O23 - Service: LVSrvLauncher - Logitech Inc. - C:\Program Files\Common Files\LogiShrd\SrvLnch\SrvLnch.exe
O23 - Service: SAVRoam (SavRoam) - symantec - C:\Program Files\Be Secure 2007\Symantec AntiVirus\SavRoam.exe
O23 - Service: PC Tools Auxiliary Service (sdAuxService) - PC Tools - C:\Program Files\Spyware Doctor\pctsAuxs.exe
O23 - Service: PC Tools Security Service (sdCoreService) - PC Tools - C:\Program Files\Spyware Doctor\pctsSvc.exe
O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
O23 - Service: Symantec SPBBCSvc (SPBBCSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
O23 - Service: Symantec AntiVirus - Symantec Corporation - C:\Program Files\Be Secure 2007\Symantec AntiVirus\Rtvscan.exe
O23 - Service: Symantec SecurePort (SymSecurePort) - Symantec Corporation - C:\Program Files\Be Secure 2007\Symantec Client Firewall\SymSPort.exe
O23 - Service: WAN Miniport (ATW) Service (WANMiniportService) - America Online, Inc. - C:\WINDOWS\wanmpsvc.exe
End of file - 14420 bytes
philosophicalbass
Posts Posts : 34
Post by philosophicalbass on Sun Jul 19, 2009 7:45 pm
I should also mention that my memory is almost completely being used up...I have a little ticker that shows me how much is being used and right now I'm using up all but 86 mb of my 512 mb of RAM...
philosophicalbass
Posts Posts : 34
Post by Origin on Mon Jul 20, 2009 3:33 pm
Lets remove some start up items to see if it was those that were slowing it down:
  • Open HijackThis.
Posts Posts : 2685
Post by philosophicalbass on Mon Jul 20, 2009 10:40 pm
Hey, well, the computer seems to be running much faster now. The only complaint I have is that now my antivirus software doesn't run at startup...I imagine I can just change that in the settings for the antivirus program, right?
Thanks so much for all your help, everyone. :-)
philosophicalbass
Posts Posts : 34
Post by Origin on Tue Jul 21, 2009 6:41 pm
Which anti virus? Do you mean RecGuard? If so that's not a anti virus.
Posts Posts : 2685
Post by philosophicalbass on Thu Aug 06, 2009 10:15 pm
Symantec, I mean. Didn't that show up in there?
philosophicalbass
Posts Posts : 34
Post by Belahzur on Fri Aug 07, 2009 11:21 pm
No problem, just need to restore two items.
  • Open HijackThis.
  • Choose "View list of backups"
  • Press "Restore"
Now reboot normally.
Symantec will be back after reboot.
Post by philosophicalbass on Sat Aug 08, 2009 12:48 am
Okay cool. Thanks so much! You guys are the best...
philosophicalbass
Posts Posts : 34
