Help! I need to remove System Security 2009 from XP
Post by sickels58 on 18th June 2009, 12:24 am
I've read a lot of posts and tried lots of things but nothing downloads properly because I keep getting "infected" prompts from the computer. Like everyone else I can't access any programs and the aggravating "warnings" keep popping up. I'm about to lose my mind because I have a letter due tomorrow and I can't use anything on my computer! Please help!
sickels58
Posts Posts : 5
Joined Joined : 2009-06-18
Points Points : 27327
Re: Help! I need to remove System Security 2009 from XP
Post by Belahzur on 18th June 2009, 12:28 am
  3. Will IceSword open?
Let me know if you cannot extract it and get the false alert again, and I will give you a unzipped copy.
Points Points : 245111
Post by sickels58 on 18th June 2009, 12:33 am
I'm getting a "Forbidden" message like you would from a filtered out website. Now what?
sickels58
Posts Posts : 5
Post by Belahzur on 18th June 2009, 12:40 am
Hmm, are you able to download Malwarebytes' Anti-Malware from [You must be registered and logged in to see this link.]?
Post by sickels58 on 18th June 2009, 12:51 am
When I click on "here" my internet link completely shuts down and I have to get it back up and go through the process to get back to here. I tried it three times and it kicked me off all 3 times! Any other suggestions?
sickels58
Posts Posts : 5
Post by Belahzur on 18th June 2009, 12:59 am
Yep. I know how to beat this, a new hole has been found it in, which we can use.
I have renamed and uploaded IceSword here for you. I have to rename it to a Windows filename, otherwise this infection will notice it and block it like the rest.
Let me know if that one will open.
Post by sickels58 on 18th June 2009, 1:14 am
Everything downloaded and then the alert came up and said the .exe was infected and nothing opened! You're a saint for trying to help me! Any other ideas?
sickels58
Posts Posts : 5
Post by sickels58 on 18th June 2009, 1:17 am
I just went back and tried it one more time and Ice Sword just came up!!!!! Now what do I do?
sickels58
Posts Posts : 5
Post by Belahzur on 18th June 2009, 10:22 am
  • Open IceSword again.
  • Then look in the left hand bottom of the program and press "Registry"
  • When the registry list opens, drag the line between the two windows so you can see which registry hive you need.
  • Next, open the HKEY_LOCAL_MACHINE, and navigate to the following key:
  • Now look in the right side pane for two run values that are just random numbers.
  • Once you have found the value(s), right click it and press "Delete"
  • Okay the prompt and close IceSword.
