"personal antivirus" problem
Post by ggpriya17 on 14th June 2009, 9:17 pm
i actually have no idea whats goin on with my computer there is this personal antivirus thing i can't get rid of like it keeps coming up and i can't delete that crap and since its appearence my security center has beeen down like i can't get it to start thats all my problem is so some out there can u help me please ............
ggpriya17
Joined Joined : 2009-06-14
OS OS : vista
Points Points : 27363
Re: "personal antivirus" problem
Post by Belahzur on 14th June 2009, 9:28 pm
Points Points : 245111
Post by laginglucky on 14th June 2009, 11:08 pm
did you solve the issue on this?
laginglucky
Points Points : 27362
Post by Belahzur on 14th June 2009, 11:13 pm
Not yet, but I know this malware, killed it before, it's quite easy to kill.
Do you need help yourself laginglucky?
Post by laginglucky on 15th June 2009, 1:27 am
Please help me on this.
laginglucky
Post by Belahzur on 15th June 2009, 1:49 pm
Please use my above post and download Hijack This, post me a log in your own topic.
