system security help
Post by jblack803 on 14th June 2009, 5:33 pm
so i follow all the steps and keep in mind i'm not up on all this computer stuff help me get rid of this damn system security please on my brand new laptop
jblack803
Joined Joined : 2009-06-14
Points Points : 27374
Re: system security help
Post by Origin on 14th June 2009, 5:38 pm
  3. Then look in the left hand bottom of the program and press "Registry"
  4. When the registry list opens, drag the line between the two windows so you can see which registry hive you need.
  5. Next, open the HKEY_LOCAL_MACHINE, and navigate to the following key:
  6. Now look in the right side pane for two run values that are just random numbers.
  7. Once you have found the value(s), right click it and press "Delete"
  8. Okay the prompt and close IceSword.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31533
thank you for answering
Post by jblack803 on 14th June 2009, 8:20 pm
yo when i downloaded it i took it to the desk top then i tried to open it this shit tells m the file is infected cant open help and i keep going to blue screen
jblack803
Post by Belahzur on 14th June 2009, 8:31 pm
You can't extract it?
Let me know.
Points Points : 245121
