Help, done everything for winbluesoft
Re: Help, done everything for winbluesoft
Post by shaheen on 14th June 2009, 1:28 am
kk i did the fig.reg and selected yes, i rebooted my system, i tried to start Hijack but it woudn't load again
Still receiving fake alerts...unfortuantly
thanks for all this help
shaheen
Posts Posts : 33
Joined Joined : 2009-06-13
Points Points : 27377
Post by Belahzur on 14th June 2009, 1:30 am
  • Download combofix from here
  • See [You must be registered and logged in to see this link.] for how to disable your AV. (AVG8)
Points Points : 245079
Post by shaheen on 14th June 2009, 1:36 am
i Dont know wut Anti-Virus system im using, i have norton but it isnt on, think i have to renew...all my spyware protection is close, i think it might be just the windows firewall preventing it?
shaheen
Posts Posts : 33
Post by shaheen on 14th June 2009, 2:10 am
Combo Fix Log
ComboFix 09-06-13.03 - Shaheen 06/13/2009 18:51.1 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1022.590 [GMT -7:00]
Running from: c:\documents and settings\Shaheen.POURFALLAH\Desktop\Combo-Fix.exe
AV: AVG Anti-Virus Free *On-access scanning disabled* (Outdated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
c:\program files\Adware Professional
c:\program files\ecurit~1
c:\program files\Adware Professional\Adware Professional.exe
c:\program files\Adware Professional\noadware4_061309.na
c:\program files\Adware Professional\nutilities.dll
c:\program files\Adware Professional\unins000.dat
c:\program files\Adware Professional\unins000.exe
c:\program files\Adware Professional\UninstlDll.dll
c:\program files\Uninstall Fun Web Products.dll
c:\windows\105395iru9zf9.bin
c:\windows\10808wormz599.cpl
c:\windows\1083thre5tz3965.ocx
c:\windows\10998hazk5ool9c.bin
c:\windows\110asparz5793.cpl
c:\windows\11493hack9o5l6za.exe
c:\windows\11579h9cktzol587.cpl
c:\windows\117db5ckd9zr2261.ocx
c:\windows\1189th9eaz14450.bin
c:\windows\1248spz9se2549.exe
c:\windows\125ath9efz357.dll
c:\windows\12bes9azse2395.ocx
c:\windows\134zthi9f735.cpl
c:\windows\137215ackzool4f99.dll
c:\windows\1394795za5.ocx
c:\windows\13c5s9arze1106.ocx
c:\windows\14109parse21z85.dll
c:\windows\14132nzt-a-v9rus50a5.ocx
c:\windows\1429h5zf810.bin
c:\windows\14454troj139z.exe
c:\windows\146499i5uz247.bin
c:\windows\146615p9mbotz9e.dll
c:\windows\15076not-a-vir9s5cfz.ocx
c:\windows\1508359rm6zd.dll
c:\windows\15359hacztool59b.dll
c:\windows\155249ormz09.dll
c:\windows\15756ha5ktoo9zd7.bin
c:\windows\15z99worm659.cpl
c:\windows\16326hac9zool5f7.dll
c:\windows\16675virus5z79.exe
c:\windows\16855h5cktoolz1e9.cpl
c:\windows\1695sp59bot449z.dll
c:\windows\1729zv5ru96bd.exe
c:\windows\1759baczdoor2130.ocx
c:\windows\17656not-a5vzr9s406.dll
c:\windows\17994zot-a-9i5us149.cpl
c:\windows\1800downl9ad5z1465.exe
c:\windows\1841viru95z.bin
c:\windows\18987spzmb592f5.cpl
c:\windows\19143vzrus4225.bin
c:\windows\1918downloaderz569.dll
c:\windows\19273zirus655.dll
c:\windows\19493woz522a9.exe
c:\windows\1951vi5us2z2.exe
c:\windows\1953zspambot235.bin
c:\windows\196z3v9rus755.exe
c:\windows\19790ha9ktzol395.exe
c:\windows\19988tzo5440.ocx
c:\windows\19a45ir2552z.ocx
c:\windows\19b6ba5zdoor595.exe
c:\windows\19e9spar5z1559.exe
c:\windows\19fdspyw5ze9069.dll
c:\windows\1a39back5ozr515.exe
c:\windows\1bczdo9nloa5er2884.bin
c:\windows\1ce9spywarz5349.cpl
c:\windows\1dd7do5nloaze925.ocx
c:\windows\1ezaback5oor9344.ocx
c:\windows\1f5bspyw9re1829z.exe
c:\windows\1fc5sp9wa5e307z.ocx
c:\windows\1z294hackto9l6d5.cpl
c:\windows\1z4975irus759.ocx
c:\windows\2002859rmzc9.bin
c:\windows\20096spamb5tz79.cpl
c:\windows\201caddzare1959.exe
c:\windows\2045addwaze3239.cpl
c:\windows\205bsparse59z5.cpl
c:\windows\212499r5z71e.cpl
c:\windows\21262z952af.cpl
c:\windows\21499not-a-virus29z5.dll
c:\windows\2167zha9kt5ol7bc.dll
c:\windows\2233s9arsez512.bin
c:\windows\232359zoj85.cpl
c:\windows\23493hacktooz2cc5.dll
c:\windows\23538wor97zb.cpl
c:\windows\23552no5z9-virus52e.cpl
c:\windows\23719not5azvirus71f9.dll
c:\windows\23952ha5ktool6z99.cpl
c:\windows\2395backd9z53006.exe
c:\windows\23c5szy5are290.exe
c:\windows\2429z95y1df.ocx
c:\windows\24334sp9585z.ocx
c:\windows\24395szy5a2.ocx
c:\windows\24425wozm7ad9.cpl
c:\windows\24470noz5a-v9rus459.dll
c:\windows\245es9arze2122.dll
c:\windows\24661sp5559z.bin
c:\windows\2519zviru97e3.dll
c:\windows\25330szambot499.bin
c:\windows\25519trojz95.cpl
c:\windows\25564vzrus7cc9.ocx
c:\windows\25585spamzo5942.cpl
c:\windows\255fstzal2509.ocx
c:\windows\25620s5y2c9z.bin
c:\windows\25913not-a-viru9z52.ocx
c:\windows\25z9vir2057.ocx
c:\windows\26055not-a-virusz69.exe
c:\windows\26195s5ambzt541.cpl
c:\windows\262eth5e9t83z8.bin
c:\windows\26585sp9647z.cpl
c:\windows\266z9spy255.dll
c:\windows\2704down9oa5er77z.cpl
c:\windows\2739zh5cktool4bd.cpl
c:\windows\27757spazb9549d.dll
c:\windows\2779spa5ze1737.dll
c:\windows\27943spambot5bz5.ocx
c:\windows\27c8zownload9r2455.exe
c:\windows\281zthie91555.exe
c:\windows\28634trzj1195.ocx
c:\windows\28845ddwzr92820.bin
c:\windows\29165not9a-virus5ebz.cpl
c:\windows\29259virzs2ad.bin
c:\windows\29289sp57z0.ocx
c:\windows\29493not-9zvirus653.ocx
c:\windows\29545not-a9vir5z592.cpl
c:\windows\29575sp95z9.cpl
c:\windows\29699sp53z9.dll
c:\windows\29845szambot537.bin
c:\windows\29957spa5bot4a8z.ocx
c:\windows\29997viru5z.bin
c:\windows\29zdd5wnlo9der3194.cpl
c:\windows\2bffdowzlo9der18175.bin
c:\windows\2c23backd5o9280z.bin
c:\windows\2c25p9wzre514.exe
c:\windows\2cc49hreat16566z.exe
c:\windows\2e9dz5r119.bin
c:\windows\2f99bazkdoo5779.dll
c:\windows\2z521wor5953.bin
c:\windows\2z6bste5l19969.bin
c:\windows\2z756s5am9ot6f9.cpl
c:\windows\2z795ddware2964.cpl
c:\windows\2zd8d9wnloade52516.dll
c:\windows\30294not-a-virus5z9.cpl
c:\windows\305795dware997z.bin
c:\windows\305z8spamb59668.bin
c:\windows\306eaz95are1420.cpl
c:\windows\30733spamz5t459.bin
c:\windows\30859aczdoor2068.cpl
c:\windows\30949sp94zf5.ocx
c:\windows\3094st5al611z.bin
c:\windows\311945zckto9l253.exe
c:\windows\31194virusz59.exe
c:\windows\31z23s9a5bot75c.ocx
c:\windows\32025s9amzot2da.exe
c:\windows\32096nzt-5-virus7d6.exe
c:\windows\3238spa5bzt190.exe
c:\windows\32522wzr9495.exe
c:\windows\32939wor515fz.exe
c:\windows\34b9viz5757.dll
c:\windows\35119zr2939.cpl
c:\windows\351fbaz5door2793.ocx
c:\windows\3556szeal2967.bin
c:\windows\35zdvir924.ocx
c:\windows\362fspazse5919.cpl
c:\windows\36b0ba9zd5or154.bin
c:\windows\38685iz9s163.dll
c:\windows\3896wormz57.cpl
c:\windows\389bt5reat2z300.ocx
c:\windows\3952backzoor153.bin
c:\windows\395b5aczdoor2724.bin
c:\windows\3965zspy65b.cpl
c:\windows\39769zr2564.cpl
c:\windows\3ac6spywar950z1.exe
c:\windows\3ac8spar9e15z9.ocx
c:\windows\3d5a9ownlo5der243z.ocx
c:\windows\3z29download5r2699.cpl
c:\windows\3z35sp59are625.dll
shaheen
Posts Posts : 33
Combo Fix log cont..
c:\windows\3za3vi54379.cpl
c:\windows\3zb0s5ywar91310.ocx
c:\windows\40195hreat974z.exe
c:\windows\4093a9dwzre5486.bin
c:\windows\4141zhr5at148139.ocx
c:\windows\414daddw95e3072z.dll
c:\windows\41eczteal1959.bin
c:\windows\42zs9ywar51514.ocx
c:\windows\4395s5ezl1908.cpl
c:\windows\4454vir1z09.exe
c:\windows\4495sparse1351z.bin
c:\windows\4519troj51z.dll
c:\windows\451zs9eal2478.cpl
c:\windows\452fszeal2912.ocx
c:\windows\458zstea91138.cpl
c:\windows\45d9vir135z9.bin
c:\windows\45dbaddwaze5829.dll
c:\windows\4719az5war92081.cpl
c:\windows\4775sparze8499.cpl
c:\windows\4819baczdoor657.cpl
c:\windows\4852h9cktool28z.bin
c:\windows\495csparsz902.bin
c:\windows\495d9tealz232.ocx
c:\windows\4999sparse18z5.dll
c:\windows\49dbzhief753.cpl
c:\windows\49z7stea5399.exe
c:\windows\4a95downloadez5494.bin
c:\windows\4ab1add5ar92z.dll
c:\windows\4adddownloazer9458.ocx
c:\windows\4b5a9pywzre23675.bin
c:\windows\4bc3thzeat532939.dll
c:\windows\4e95ste5l293z.cpl
c:\windows\4edca5dwar967z.ocx
c:\windows\4f49spyza5e2053.ocx
c:\windows\4fa5backdzo92075.bin
c:\windows\4z9steal3955.ocx
c:\windows\5010zvi9us5b8.ocx
c:\windows\50fcbackd9or315z.cpl
c:\windows\5156zi9u5617.ocx
c:\windows\51eetz9eat20257.bin
c:\windows\51zebackdoor5189.bin
c:\windows\5224a9dwaze1232.cpl
c:\windows\52509zirus185.exe
c:\windows\5256zsp948.ocx
c:\windows\52f5z9r817.exe
c:\windows\5437t9reat2528z5.dll
c:\windows\54593noz-a-virus293.ocx
c:\windows\5476thiz9568.ocx
c:\windows\551e5ackdoo91z91.dll
c:\windows\55348ha9ktool64z.exe
c:\windows\55440z9y7e8.dll
c:\windows\5567sp9654z.cpl
c:\windows\558639orm77z.ocx
c:\windows\5591spywzre2369.dll
c:\windows\55992spy5fdz.ocx
c:\windows\5614sp9w5rz603.cpl
c:\windows\5630s9yzc.ocx
c:\windows\56979spy2dz9.dll
c:\windows\56z5thie92771.exe
c:\windows\5715zir8689.dll
c:\windows\5788st9al2562z.cpl
c:\windows\57e5threz916776.exe
c:\windows\58495zwn9oader86.bin
c:\windows\587zs5yw9re2567.dll
c:\windows\59109ownloadzr502.bin
c:\windows\5925vi5110z.ocx
c:\windows\596fviz594.cpl
c:\windows\596z0not-a-virusdc9.cpl
c:\windows\599dspa5se2259z.cpl
c:\windows\59zad9ware892.ocx
c:\windows\5a6dzpywar9514.cpl
c:\windows\5b07zownloader91255.dll
c:\windows\5b0ds9arse2683z.exe
c:\windows\5b59addware150z.dll
c:\windows\5c6spy9are2740z.dll
c:\windows\5c8zs9arse1135.dll
c:\windows\5d0f5iz25389.bin
c:\windows\5e94thief555z.dll
c:\windows\5e99zddware3034.ocx
c:\windows\5eae5i91z8.cpl
c:\windows\5f51vzr9573.cpl
c:\windows\5fbaspz5are14949.cpl
c:\windows\5z094s9ambot5b0.ocx
c:\windows\5z395hacktool982.ocx
c:\windows\5zecs9yware10345.ocx
c:\windows\5zf5threat131199.bin
c:\windows\6109threat15850z.exe
c:\windows\613zs5arse398.dll
c:\windows\619abac9doo527z5.exe
c:\windows\6215s9eal302z.cpl
c:\windows\62zdownl5ader14609.ocx
c:\windows\639azhi5f1916.cpl
c:\windows\63b6zi59324.cpl
c:\windows\63z3t95j171.bin
c:\windows\6491bzckdo5r2964.exe
c:\windows\64dasp9rs59z8.dll
c:\windows\6578dzw9loader1350.bin
c:\windows\659threaz17443.bin
c:\windows\6608zpa9b5t4e.dll
c:\windows\669cd95zloader2989.exe
c:\windows\678zsteal956.ocx
c:\windows\6796t5reatz0449.bin
c:\windows\692ds9eal5z12.cpl
c:\windows\699fthr9at518z5.bin
c:\windows\69azste5l1571.ocx
c:\windows\6bb95ir38z.cpl
c:\windows\6c6zddw95e49.dll
c:\windows\6z42wo9m15b.exe
c:\windows\6zbcdownloader5794.dll
c:\windows\6ze6a5dware3902.dll
c:\windows\707bstz5l1199.dll
c:\windows\72e1bazkdoor7549.dll
c:\windows\72no9-a-zir5s55a.cpl
c:\windows\72zd9hreat29545.ocx
c:\windows\758ztr9524.cpl
c:\windows\75e9spywzre2217.exe
c:\windows\7847t9rea58048z.bin
c:\windows\7930spamb5tza1.dll
c:\windows\7936d5wnl9zder1305.dll
c:\windows\7a5et9iefz703.bin
c:\windows\7b0cd5wnlzader3914.dll
c:\windows\7b395ddwarz2620.cpl
c:\windows\7b7zpywa952760.dll
c:\windows\7c98th5zat7897.exe
c:\windows\7e65thzef9735.dll
c:\windows\7ebfspa9sz2540.bin
c:\windows\7f89s9ywzre2154.ocx
c:\windows\7z579hief16505.ocx
c:\windows\8070spamzot5a79.bin
c:\windows\8348t59z33d.cpl
c:\windows\8359tz9j35e.exe
c:\windows\83z99roj1a65.dll
c:\windows\84bv95z714.exe
c:\windows\85z9troj92.cpl
c:\windows\90520spyzc5.exe
c:\windows\9062h59ktooz3fc.dll
c:\windows\91f2threa55z19.cpl
c:\windows\92842trzj35e.ocx
c:\windows\929asparze30985.dll
c:\windows\9355wzrm5b29.cpl
c:\windows\9357zhacktool57.bin
c:\windows\9376thizf525.exe
c:\windows\94085wo5mzdf.exe
c:\windows\94557hacztool530.ocx
c:\windows\951fszarse2484.bin
c:\windows\958thizf1425.dll
c:\windows\989zwo5m469.cpl
c:\windows\99dthrez518988.ocx
c:\windows\9a55dzwnloa5er997.bin
c:\windows\9a69z5wnloader2185.ocx
c:\windows\9ae7vi5z950.ocx
c:\windows\9d2zsteal5966.exe
c:\windows\9eb5threat11z79.cpl
c:\windows\9ez0sp5rse1552.bin
c:\windows\9fe9spa5ze1281.cpl
c:\windows\ab8zownl5ad9r1994.cpl
c:\windows\bd5v9rz552.dll
c:\windows\bef9pzw5re2009.dll
c:\windows\c9zs5yware1289.exe
c:\windows\cd5backdozr739.dll
c:\windows\d32s9arsz3055.dll
c:\windows\e56adzware1986.cpl
c:\windows\kb913800.exe
c:\windows\system32\10z905irus2a9.ocx
c:\windows\system32\1108spyw9rz2590.bin
c:\windows\system32\11093zp5mbot2d4.dll
c:\windows\system32\112159zambot725.ocx
c:\windows\system32\11404wo5m90z.dll
c:\windows\system32\11z39tr5j96.dll
c:\windows\system32\12551spz4a9.bin
c:\windows\system32\131695ormcz.exe
c:\windows\system32\132d9par5z3272.exe
c:\windows\system32\133z9hack5ool43d.cpl
c:\windows\system32\13993zirus511.dll
c:\windows\system32\140bsp5war9z641.cpl
c:\windows\system32\14594sp57z1.ocx
c:\windows\system32\15051spz9botec.ocx
c:\windows\system32\15293zot-a-9irus5c3.exe
c:\windows\system32\1530hackzool956.exe
c:\windows\system32\15359hacztoo5e2.bin
c:\windows\system32\153z25r9j299.dll
c:\windows\system32\1552szyware9048.bin
c:\windows\system32\1559threat2z216.ocx
c:\windows\system32\1564sp97z4.ocx
c:\windows\system32\157359ot-a-ziru54cf.cpl
c:\windows\system32\15863spamboz569.ocx
c:\windows\system32\1592addwarz3270.ocx
c:\windows\system32\15933virus514z.ocx
c:\windows\system32\15957spamboz378.bin
c:\windows\system32\15z529py295.exe
c:\windows\system32\15z97not-a-9irus25c.bin
c:\windows\system32\1631zp5rse9740.exe
c:\windows\system32\164bvirz59.exe
c:\windows\system32\16591spyz6d.cpl
c:\windows\system32\1667859t-a-virus117z.cpl
c:\windows\system32\16966t5o91bz.bin
c:\windows\system32\17256h5ck9ool2z6.bin
c:\windows\system32\18389trz598c.ocx
c:\windows\system32\18927t95j6z1.cpl
c:\windows\system32\189635acztoo959b.exe
c:\windows\system32\19197s5y71az.exe
c:\windows\system32\194789aczto5l1b6.bin
c:\windows\system32\19549hacktool715z.bin
c:\windows\system32\1956downloader129z.exe
c:\windows\system32\19806zroj5e3.bin
c:\windows\system32\1995sparse15z1.ocx
c:\windows\system32\1adbbaz9door26925.bin
c:\windows\system32\1ae1b5ck9oor3125z.bin
c:\windows\system32\1b37dow9loaze52656.cpl
c:\windows\system32\1c21zownload5r2779.bin
c:\windows\system32\1c25d9wnzoader1632.exe
c:\windows\system32\1c5zthreat9942.dll
c:\windows\system32\1d5adown59azer525.exe
c:\windows\system32\1d7f5ac9zoor2360.ocx
c:\windows\system32\1de1spyw9re85z5.dll
c:\windows\system32\1f85doznlo5de9441.ocx
c:\windows\system32\1z349virus55c9.ocx
c:\windows\system32\1z8125o9m5da.dll
c:\windows\system32\1z95add9a5e1556.dll
c:\windows\system32\20420v5rusz269.bin
c:\windows\system32\20520no5-a-vizus198.exe
c:\windows\system32\205abackdzo92123.bin
c:\windows\system32\207zro5199.exe
c:\windows\system32\2095tro5z5.cpl
c:\windows\system32\20979not-a-zirus6925.exe
c:\windows\system32\20z92wor52c4.cpl
c:\windows\system32\215215z94b9.ocx
c:\windows\system32\22197virzs595.ocx
shaheen
Posts Posts : 33
Post by shaheen on 14th June 2009, 2:11 am
Combo Fix Log cont....
c:\windows\system32\2269z5rse2381.exe
c:\windows\system32\229z9tro5203.dll
c:\windows\system32\22e9t5i9f1z69.cpl
c:\windows\system32\22eeth95atz9775.cpl
c:\windows\system32\23099not-a-zirus553.ocx
c:\windows\system32\23197troz2895.ocx
c:\windows\system32\23288n9t-azv5rus7e7.cpl
c:\windows\system32\233cd5wn9oaderz7.exe
c:\windows\system32\23539t9zj623.dll
c:\windows\system32\239285pzmbota49.ocx
c:\windows\system32\24205wor9z28.dll
c:\windows\system32\24471notza-virus90a5.ocx
c:\windows\system32\2469s5z598.exe
c:\windows\system32\24798nzt-a-virus5975.ocx
c:\windows\system32\24896not-5zvirus493.dll
c:\windows\system32\248z2ha9kt5ol201.ocx
c:\windows\system32\24957zirus978.cpl
c:\windows\system32\24z98v5ru95d0.ocx
c:\windows\system32\2552stzal2569.dll
c:\windows\system32\2552zhie93156.bin
c:\windows\system32\25534sp51z9.ocx
c:\windows\system32\2556zhacktool98a.ocx
c:\windows\system32\25745virus93z.ocx
c:\windows\system32\25793spamb5t629z.cpl
c:\windows\system32\2587dzwnload9r3031.bin
c:\windows\system32\25898spamzot5895.ocx
c:\windows\system32\25955spy1az.bin
c:\windows\system32\25azadd9are1123.dll
c:\windows\system32\25b1sp9warez450.cpl
c:\windows\system32\26022viruz91a5.exe
c:\windows\system32\26226spa9bot54z.dll
c:\windows\system32\275559irus5z5.dll
c:\windows\system32\2783znot-a-v9r5s434.bin
c:\windows\system32\2796t5iefz998.dll
c:\windows\system32\28785not-5-vzrus391.exe
c:\windows\system32\2891s5arze356.ocx
c:\windows\system32\28z5pambo9357.dll
c:\windows\system32\29017vi5usz59.bin
c:\windows\system32\2902thre5t22z46.dll
c:\windows\system32\29156troj7zf.bin
c:\windows\system32\29157spz2c9.ocx
c:\windows\system32\29428troj4b5z.bin
c:\windows\system32\29504ha9kzool1b5.bin
c:\windows\system32\2985st95l108z.bin
c:\windows\system32\29901spy5z5.ocx
c:\windows\system32\29dzsteal2954.exe
c:\windows\system32\2a49addwaze5089.dll
c:\windows\system32\2a759pzrse165.exe
c:\windows\system32\2e05bazkdo5r2209.ocx
c:\windows\system32\2f09zown5oader559.dll
c:\windows\system32\2f69dow5loadez1954.exe
c:\windows\system32\2fbzdo9nloader5999.cpl
c:\windows\system32\2fecspywa5ez1689.bin
c:\windows\system32\2z16wo953a4.dll
c:\windows\system32\2z5519roj169.bin
c:\windows\system32\2z55thie93077.bin
c:\windows\system32\2z580tro95af.cpl
c:\windows\system32\2zfstea51928.bin
c:\windows\system32\30959trojz9c.dll
c:\windows\system32\30969hac5tool5za.ocx
c:\windows\system32\30z23viru53b9.bin
c:\windows\system32\31196zot-a-vi5us379.bin
c:\windows\system32\31556szy599.cpl
c:\windows\system32\31z41not-a9v5rus7f6.cpl
c:\windows\system32\3212zspy5c39.exe
c:\windows\system32\322595ruz3f2.ocx
c:\windows\system32\3249zwo9m4c55.dll
c:\windows\system32\327159zoj9d.cpl
c:\windows\system32\32924wor51az.ocx
c:\windows\system32\33155ac9tozl35b.ocx
c:\windows\system32\332dsp5rz91946.cpl
c:\windows\system32\3395parse2925z.cpl
c:\windows\system32\33zb9ownl5ader2774.ocx
c:\windows\system32\3469hac5tool55z.exe
c:\windows\system32\3592spzmbot4bd.ocx
c:\windows\system32\35945acktzol97.exe
c:\windows\system32\3595spamboz1a8.cpl
c:\windows\system32\359cth5ef2z389.dll
c:\windows\system32\35c95ackzoor930.exe
c:\windows\system32\35z84spam9ot5bb.ocx
c:\windows\system32\367t95z5d0.bin
c:\windows\system32\3708b5ckdozr9009.bin
c:\windows\system32\37535ack9ooz34e.ocx
c:\windows\system32\375dspywarz3905.bin
c:\windows\system32\37zfvir51269.cpl
c:\windows\system32\38509parze2526.ocx
c:\windows\system32\389fd5wnloazer819.dll
c:\windows\system32\390not-a-5irus3ze.bin
c:\windows\system32\39866hacktoo56fez.cpl
c:\windows\system32\39aa9py5arz1774.exe
c:\windows\system32\39dfaddwar53z39.dll
c:\windows\system32\3ad2backzoor29025.exe
c:\windows\system32\3bf5thz9a53907.exe
c:\windows\system32\3bz6s9a5se1444.exe
c:\windows\system32\3ec8szeal4159.ocx
c:\windows\system32\3fz9steal14045.bin
c:\windows\system32\3z9dvi52834.dll
c:\windows\system32\4006do5nload9z1498.exe
c:\windows\system32\4056addz9re552.exe
c:\windows\system32\41fas9za52628.exe
c:\windows\system32\4222hazkto5l595.ocx
c:\windows\system32\4534z9dware1581.dll
c:\windows\system32\454bsp5warez997.cpl
c:\windows\system32\470zad59are2304.cpl
c:\windows\system32\477zdow9loader2175.exe
c:\windows\system32\47885iruz7de9.exe
c:\windows\system32\479d5ddzar92531.exe
c:\windows\system32\4838spzrse3905.bin
c:\windows\system32\4924szy55b9.ocx
c:\windows\system32\49az5ddware2747.ocx
c:\windows\system32\4ac75ze9l235.cpl
c:\windows\system32\4az9sp5rse2621.dll
c:\windows\system32\4b8ct9ie511z3.bin
c:\windows\system32\4c2cspyzare55669.cpl
c:\windows\system32\4d95bzck5oor1560.cpl
c:\windows\system32\4dadadd5ar9327z.cpl
c:\windows\system32\4e525ownloadez949.dll
c:\windows\system32\4e5spyware188z9.bin
c:\windows\system32\4ebb95rz933.exe
c:\windows\system32\4f909ownlozd5r1518.exe
c:\windows\system32\4fd9sze5l16929.cpl
c:\windows\system32\4fe59zreat25928.exe
c:\windows\system32\4z07addwa59687.cpl
c:\windows\system32\4z20ha9ktoo5464.cpl
c:\windows\system32\4z2eaddw9re20025.bin
c:\windows\system32\5051sp9rse737z.ocx
c:\windows\system32\50b9z5r362.bin
c:\windows\system32\5101troz379.cpl
c:\windows\system32\5105spy59z.cpl
c:\windows\system32\512669ormdz.cpl
c:\windows\system32\513csp9warez165.ocx
c:\windows\system32\51f3ba9kdooz15305.bin
c:\windows\system32\520etzief599.ocx
c:\windows\system32\5247hzck5ool809.bin
c:\windows\system32\524tz5ef1396.dll
c:\windows\system32\529z5virus3af.ocx
c:\windows\system32\53270spa9bzt205.bin
c:\windows\system32\53440spa9boz3cd.exe
c:\windows\system32\5364thrzat93789.exe
c:\windows\system32\53a4bac95ozr1108.cpl
c:\windows\system32\5422zddwar91579.dll
c:\windows\system32\5459s9arse1z35.cpl
c:\windows\system32\548fspa9se266z.ocx
c:\windows\system32\5530sparse392z.dll
c:\windows\system32\5534addw95e37z.cpl
c:\windows\system32\5573baczdoor2952.ocx
c:\windows\system32\5583zack9oor3176.ocx
c:\windows\system32\55eesparsez929.bin
c:\windows\system32\55z0ad5wa9e2394.bin
c:\windows\system32\55z2troj2509.dll
c:\windows\system32\55z59rm127.bin
c:\windows\system32\5654thiefz7059.cpl
c:\windows\system32\5676wo9z76.cpl
c:\windows\system32\5692s9z207.exe
c:\windows\system32\57519troz1ce.exe
c:\windows\system32\5752tzoj4dc9.exe
c:\windows\system32\57eabackdo9r35z9.cpl
c:\windows\system32\57fevzr9066.bin
c:\windows\system32\5891backzoor555.cpl
c:\windows\system32\59010tzojca.ocx
c:\windows\system32\5915spyz7a9.exe
c:\windows\system32\5920zhie52873.cpl
c:\windows\system32\593es95ware3z6.dll
c:\windows\system32\5972hacztool49f.exe
c:\windows\system32\5990vir23z6.dll
c:\windows\system32\59d4a9dware4z0.ocx
c:\windows\system32\59z1sparse3259.dll
c:\windows\system32\59z3t9reat1501.cpl
c:\windows\system32\59z64virus7b.ocx
c:\windows\system32\59z70virus3ce.cpl
c:\windows\system32\59z85ownloader1242.cpl
c:\windows\system32\5a0ethizf1924.dll
c:\windows\system32\5a4zth9ef1810.ocx
c:\windows\system32\5a8abackdzo9578.bin
c:\windows\system32\5ab9sparse1z2.cpl
c:\windows\system32\5b2est9alz192.cpl
c:\windows\system32\5b9zba5kdoor661.exe
c:\windows\system32\5b9zspyware1496.bin
c:\windows\system32\5baat5ie9z997.exe
c:\windows\system32\5bc9teaz5062.cpl
c:\windows\system32\5c06thze95611.cpl
c:\windows\system32\5d1ed5wnl9ader18z3.dll
c:\windows\system32\5d45vir969z.bin
c:\windows\system32\5dc99pywarez5805.cpl
c:\windows\system32\5e7cthre9516082z.bin
c:\windows\system32\5ef0s9ar5ez082.ocx
c:\windows\system32\5f54b5ck9oorz258.ocx
c:\windows\system32\5z5dsteal9045.dll
c:\windows\system32\5za3spa9se3218.dll
c:\windows\system32\5zd0s9ea52093.cpl
c:\windows\system32\61569irus146z.cpl
c:\windows\system32\621ct5iez17639.cpl
c:\windows\system32\62715ddware9z89.ocx
c:\windows\system32\6334wo5m9f8z.ocx
c:\windows\system32\6390dowzloader5094.dll
c:\windows\system32\645z5roj9b.bin
c:\windows\system32\6482ziru9895.bin
c:\windows\system32\6497a95ware1z95.ocx
c:\windows\system32\6556s9arze2283.exe
c:\windows\system32\659znot-a-virus9865.dll
c:\windows\system32\65d1spywaze9824.exe
c:\windows\system32\66z79hrea53569.dll
c:\windows\system32\6815thizf1965.dll
c:\windows\system32\69375ackdozr2378.dll
c:\windows\system32\6951not-z-5irus1aa.dll
c:\windows\system32\6965v9z3136.ocx
c:\windows\system32\6d95th9ez269.ocx
c:\windows\system32\6eebba9kdozr3145.dll
c:\windows\system32\6ff5bazkdoor579.bin
c:\windows\system32\709759zj7e7.dll
c:\windows\system32\710zsp96b05.exe
c:\windows\system32\7195sp9rsz10.ocx
c:\windows\system32\72f49hie52z91.exe
c:\windows\system32\7334downzoad5r27369.exe
c:\windows\system32\73599ackdozr1555.exe
c:\windows\system32\743bthr9at30z265.cpl
c:\windows\system32\749csteal2752z.dll
c:\windows\system32\74do95lzader814.cpl
c:\windows\system32\7594downlo9zer1593.bin
c:\windows\system32\75ea9hie532z5.exe
c:\windows\system32\76z1spy395.ocx
c:\windows\system32\7724not-a-virzs3995.cpl
c:\windows\system32\7739viz9s454.bin
c:\windows\system32\77za5ddware619.bin
c:\windows\system32\7930tzi951732.dll
c:\windows\system32\7969t5reat14z46.dll
c:\windows\system32\79f7spzrse5937.cpl
c:\windows\system32\7a9caddwar9z635.dll
c:\windows\system32\7b74bz5kdoor898.bin
c:\windows\system32\7b7cs9arsez925.bin
c:\windows\system32\7d9bthz9f5904.exe
c:\windows\system32\7f9caddwarz2859.bin
c:\windows\system32\8667worm5z19.dll
c:\windows\system32\8z25i9697.exe
c:\windows\system32\9008z5y44e.ocx
c:\windows\system32\906cv5r2z44.ocx
c:\windows\system32\90919spyzb5.bin
c:\windows\system32\913925azktool571.bin
c:\windows\system32\91970wor5548z.exe
c:\windows\system32\91985ir22z0.bin
c:\windows\system32\92344spamboz5a15.bin
c:\windows\system32\9245teal1z789.ocx
c:\windows\system32\9248tzo5315.bin
c:\windows\system32\92617vzrus50d.dll
c:\windows\system32\9281thizf5859.ocx
c:\windows\system32\9295noz-a-virus452.bin
c:\windows\system32\9465spzware2972.exe
c:\windows\system32\95036spambotz75.bin
c:\windows\system32\956fthzef11495.exe
c:\windows\system32\9594stzal1312.ocx
c:\windows\system32\95a5spzware243.exe
c:\windows\system32\95z4sparse3507.cpl
c:\windows\system32\9605iruszbd.ocx
c:\windows\system32\961vi5uz4499.dll
c:\windows\system32\9671h9cktz5l1c8.dll
c:\windows\system32\96aspywa5e690z.dll
c:\windows\system32\975fdownlozder608.exe
c:\windows\system32\975zspy5are513.exe
c:\windows\system32\97f4thzeat15170.ocx
c:\windows\system32\989zth5ef2699.cpl
c:\windows\system32\9935troj25bz.exe
c:\windows\system32\9954hackto9l5z5.cpl
c:\windows\system32\9959vir5s6z4.ocx
c:\windows\system32\99a4downloader555z.cpl
c:\windows\system32\99azv5r333.ocx
c:\windows\system32\9a1zackdoor5502.ocx
c:\windows\system32\9a61do5nloader255z.exe
c:\windows\system32\9b5addwaze1894.cpl
c:\windows\system32\9czddownlo5der869.bin
c:\windows\system32\9e8a5hzeat5260.cpl
c:\windows\system32\9zc7thief570.ocx
c:\windows\system32\a8e5i95z.dll
c:\windows\system32\af6bac5dzor2989.cpl
c:\windows\system32\bd1addwaze25189.cpl
c:\windows\system32\c59vir902z.bin
c:\windows\system32\drivers\MSIVXujnmhctvdlftiqmelxbwqpulvvjtmxel.sys
c:\windows\system32\ecazpa59e698.ocx
c:\windows\system32\fb29pyware30z5.bin
c:\windows\system32\fb7za9kd5or241.exe
c:\windows\system32\MSIVXcount
c:\windows\system32\MSIVXkmkvjimenrphyyosivrjbapaerlrdfay.dll
c:\windows\system32\MSIVXvypuhrgxoyobqnyjskdsxwntjxfujoym.dll
c:\windows\system32\setup2.exe
c:\windows\system32\z0706spa9bot758.bin
c:\windows\system32\z141995y332.bin
c:\windows\system32\z141spam5ot598.dll
c:\windows\system32\z16t59ef1950.exe
c:\windows\system32\z17ba5kdoor20589.bin
c:\windows\system32\z2c2ba5kdoor3981.ocx
c:\windows\system32\z3812no5-9-virus748.cpl
c:\windows\system32\z428hack5o9l8b.ocx
c:\windows\system32\z481s5ambot449.ocx
c:\windows\system32\z543vir8999.bin
c:\windows\system32\z549spy745.ocx
c:\windows\system32\z55addwar92255.ocx
c:\windows\system32\z5821spambot4389.exe
c:\windows\system32\z659teal31605.cpl
c:\windows\system32\z8259t9oj29d.ocx
c:\windows\system32\z988spyw5re502.cpl
c:\windows\system32\z996backdoor5073.cpl
c:\windows\system32\z9aeba5kdoor593.cpl
c:\windows\system32\z9f5thief2592.cpl
c:\windows\system32\za8thi9f952.cpl
c:\windows\system32\zfb5v9r5915.exe
c:\windows\Tasks\{5B57CF47-0BFA-43c6-ACF9-3B3653DCADBA}.job
c:\windows\z046sp5mbot5419.ocx
c:\windows\z097sp5rse3169.exe
c:\windows\z0ath9e5529.dll
c:\windows\z1e5t9reat54989.ocx
c:\windows\z2f5thief945.cpl
shaheen
Posts Posts : 33
Post by shaheen on 14th June 2009, 2:12 am
c:\windows\z560n5t-9-virus76.dll
c:\windows\z5972not5a-virus59c.cpl
c:\windows\z6245spambota59.cpl
c:\windows\z624wor950.dll
c:\windows\z6279not-a-vir5s696.exe
c:\windows\z638st9a569.exe
c:\windows\z6d8do9nlo5der3.dll
c:\windows\z759spars51410.ocx
c:\windows\z792vi9us755.ocx
c:\windows\z8565worm99.ocx
c:\windows\z92dspar5e18939.exe
c:\windows\z9811viru5619.ocx
c:\windows\zb9cthreat70245.ocx
c:\windows\zcd9backd5or9172.ocx
c:\windows\ze5b5py9are2645.bin
c:\windows\zf5bt9reat13846.exe
D:\Autorun.inf
D:\Desktop.ini
-------\Service_MSIVXserv.sys
((((((((((((((((((((((((( Files Created from 2009-05-14 to 2009-06-14 )))))))))))))))))))))))))))))))
2009-09-04 06:52 . 2009-09-04 06:52 10587 ----a-w- c:\windows\system32\51034szy9.bin
2009-06-13 23:31 . 2009-06-13 23:31 -------- d-----w- C:\!KillBox
2009-06-13 22:52 . 2009-06-13 22:52 -------- d-----w- c:\program files\Trend Micro
2009-06-13 21:16 . 2009-06-13 21:16 -------- d-----w- c:\program files\Enigma Software Group
2009-06-13 20:44 . 2008-12-11 15:38 159600 ----a-w- c:\windows\system32\drivers\pctgntdi.sys
2009-06-13 20:44 . 2009-04-03 18:18 130936 ----a-w- c:\windows\system32\drivers\PCTCore.sys
2009-06-13 20:44 . 2008-12-18 19:16 73840 ----a-w- c:\windows\system32\drivers\PCTAppEvent.sys
2009-06-13 20:44 . 2009-06-13 20:45 -------- d-----w- c:\program files\Common Files\PC Tools
2009-06-13 20:44 . 2008-12-10 18:36 64392 ----a-w- c:\windows\system32\drivers\pctplsg.sys
2009-06-13 20:44 . 2009-06-13 20:45 -------- d-----w- c:\program files\Spyware Doctor
2009-06-13 20:44 . 2009-06-13 20:44 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\PC Tools
2009-06-13 20:44 . 2009-06-13 20:44 -------- d-----w- c:\documents and settings\All Users\Application Data\PC Tools
2009-06-13 08:21 . 2009-06-13 08:21 -------- d-sh--w- c:\documents and settings\Tammie.POURFALLAH\PrivacIE
2009-06-13 08:21 . 2009-06-13 08:21 -------- d-sh--w- c:\documents and settings\Tammie.POURFALLAH\IETldCache
2009-06-13 03:34 . 2009-06-13 03:34 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Local Settings\Application Data\MicroVision Applications
2009-06-11 13:22 . 2009-06-11 13:22 -------- d-sh--w- c:\documents and settings\Shaheen.POURFALLAH\PrivacIE
2009-06-10 22:16 . 2009-06-10 22:16 -------- d-sh--w- c:\documents and settings\Shaheen.POURFALLAH\IETldCache
2009-06-10 21:29 . 2009-06-10 21:29 -------- d-sh--w- c:\windows\system32\config\systemprofile\IETldCache
2009-06-10 20:30 . 2009-06-10 20:33 -------- dc-h--w- c:\windows\ie8
2009-06-08 19:34 . 2009-06-08 19:34 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\Sonic
2009-06-08 19:34 . 2009-06-08 19:34 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\Leadertech
2009-06-08 18:54 . 2009-06-08 18:54 152576 ----a-w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\Sun\Java\jre1.6.0_13\lzma.dll
2009-05-27 00:43 . 2009-05-27 00:43 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\GARMIN
2009-05-27 00:42 . 2009-05-27 00:42 -------- d-----w- c:\program files\Garmin GPS Plugin
2009-05-26 23:09 . 2009-05-26 23:09 -------- d-----w- c:\program files\Ares Vista
2009-06-14 01:22 . 2009-01-11 02:04 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\mIRC
2009-06-14 00:34 . 2009-01-11 02:04 -------- d-----w- c:\program files\mIRC
2009-06-13 23:52 . 2007-04-10 02:42 -------- d-----w- c:\program files\Steam
2009-06-13 22:16 . 2005-10-19 23:34 -------- d-----w- c:\program files\GemMaster
2009-06-13 21:57 . 2006-12-23 18:24 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2009-06-13 19:54 . 2008-12-20 09:59 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\Skype
2009-06-13 10:59 . 2008-12-31 22:19 -------- d-----w- c:\documents and settings\All Users\Application Data\Google Updater
2009-06-13 08:56 . 2008-05-01 07:13 -------- d-----w- c:\documents and settings\Tammie.POURFALLAH\Application Data\Juniper Networks
2009-06-12 23:13 . 2008-12-20 10:01 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\skypePM
2009-06-10 19:00 . 2008-05-02 01:33 -------- d-----w- c:\documents and settings\All Users\Application Data\avg8
2009-06-08 18:55 . 2005-10-19 23:40 -------- d-----w- c:\program files\Java
2009-05-27 00:42 . 2008-07-14 00:18 -------- d-----w- c:\program files\DIFX
2009-03-22 23:44 . 2009-03-22 23:44 51056 ----a-w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-03-22 23:23 . 2009-03-22 23:23 75048 ----a-w- c:\documents and settings\All Users\Application Data\Apple Computer\Installer Cache\iTunes 8.1.0.52\SetupAdmin.exe
2009-03-22 00:36 . 2009-03-22 00:36 503808 ----a-w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\Sun\Java\Deployment\cache\6.0\38\39ba6e6-582ddd6c-n\msvcp71.dll
2009-03-22 00:36 . 2009-03-22 00:36 499712 ----a-w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\Sun\Java\Deployment\cache\6.0\38\39ba6e6-582ddd6c-n\jmc.dll
2009-03-22 00:36 . 2009-03-22 00:36 348160 ----a-w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\Sun\Java\Deployment\cache\6.0\38\39ba6e6-582ddd6c-n\msvcr71.dll
2009-03-17 12:29 . 2009-03-17 12:29 503808 ----a-w- c:\documents and settings\Bardia.POURFALLAH\Application Data\Sun\Java\Deployment\cache\6.0\38\39ba6e6-1d54f57b-n\msvcp71.dll
2009-03-17 12:29 . 2009-03-17 12:29 499712 ----a-w- c:\documents and settings\Bardia.POURFALLAH\Application Data\Sun\Java\Deployment\cache\6.0\38\39ba6e6-1d54f57b-n\jmc.dll
2009-03-17 12:29 . 2009-03-17 12:29 348160 ----a-w- c:\documents and settings\Bardia.POURFALLAH\Application Data\Sun\Java\Deployment\cache\6.0\38\39ba6e6-1d54f57b-n\msvcr71.dll
shaheen
Posts Posts : 33
Post by shaheen on 14th June 2009, 2:13 am
Combo Fix Log cont... Final part
"Aim6"="c:\program files\AIM6\aim6.exe" [2008-10-31 50480]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2008-12-31 39408]
"HPBootOp"="c:\program files\Hewlett-Packard\HP Boot Optimizer\HPBootOp.exe" [2005-02-26 245760]
"HPHUPD08"="c:\program files\HP\Digital Imaging\{33D6CC28-9F75-4d1b-A11D-98895B3A3729}\hphupd08.exe" [2005-06-02 49152]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2005-10-20 180269]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-10-15 39792]
"AppleSyncNotifier"="c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2009-03-06 177472]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-01-05 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-03-13 342312]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-03-09 148888]
"SpyHunter Security Suite"="c:\program files\Enigma Software Group\SpyHunter\SpyHunter3.exe" [2008-09-03 864256]
"AppInit_DLLs"=c:\windows\system32\avgrsstx.dll
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\aawservice]
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^ATI CATALYST System Tray.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\ATI CATALYST System Tray.lnk
backup=c:\windows\pss\ATI CATALYST System Tray.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Digital Imaging Monitor.lnk]
backup=c:\windows\pss\HP Digital Imaging Monitor.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HPAiODevice(hp officejet g series) - 2.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\HPAiODevice(hp officejet g series) - 2.lnk
backup=c:\windows\pss\HPAiODevice(hp officejet g series) - 2.lnkCommon Startup
"Viewpoint Manager Service"=2 (0x2)
"IDriverT"=3 (0x3)
"gusvc"=2 (0x2)
"AntiVirusDisableNotify"=dword:00000001
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpofxm08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hposfx08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqCopy.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpfccopy.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpzwiz01.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqPhUnl.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqDIA.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpoews01.exe"=
"c:\\Program Files\\Updates from HP\\9972322\\Program\\Updates from HP.exe"=
"c:\\Program Files\\Ares\\Ares.exe"=
"c:\\Program Files\\AVG\\AVG8\\avgupd.exe"=
"c:\\Program Files\\AVG\\AVG8\\avgemc.exe"=
"c:\\Program Files\\Steam\\steamapps\\atbs495\\counter-strike\\hl.exe"=
"c:\\WINDOWS\\system32\\dpvsetup.exe"=
"c:\\Program Files\\Ventrilo\\Ventrilo.exe"=
"c:\\Documents and Settings\\Tammie.POURFALLAH\\Application Data\\Juniper Networks\\Juniper Terminal Services Client\\dsTermServ.exe"=
"c:\\Program Files\\Microsoft Games\\Age of Empires III\\age3x.exe"=
"c:\\Program Files\\Microsoft Games\\Age of Empires III\\age3y.exe"=
"c:\\Program Files\\Ares Vista\\AresVista.exe"=
"c:\\Program Files\\mIRC\\mirc.exe"=
"c:\\Program Files\\Steam\\steamapps\\atbs495\\counter-strike source\\hl2.exe"=
"1723:TCP"= 1723:TCP:@xpsp2res.dll,-22015
"1701:UDP"= 1701:UDP:@xpsp2res.dll,-22016
"500:UDP"= 500:UDP:@xpsp2res.dll,-22017
R0 PCTCore;PCTools KDS;c:\windows\system32\drivers\PCTCore.sys [6/13/2009 1:44 PM 130936]
R1 AvgLdx86;AVG AVI Loader Driver x86;c:\windows\system32\drivers\avgldx86.sys [5/1/2008 6:33 PM 97928]
R2 avg8emc;AVG8 E-mail Scanner;c:\progra~1\AVG\AVG8\avgemc.exe [7/6/2008 9:23 PM 875288]
R2 avg8wd;AVG8 WatchDog;c:\progra~1\AVG\AVG8\avgwdsvc.exe [7/6/2008 9:23 PM 231704]
R2 AvgTdiX;AVG8 Network Redirector;c:\windows\system32\drivers\avgtdix.sys [5/1/2008 6:33 PM 76040]
R3 DAdderFltr;DeathAdder Mouse;c:\windows\system32\drivers\dadder.sys [7/13/2008 5:17 PM 22784]
S3 LachesisFltr;Lachesis Mouse Driver;c:\windows\system32\drivers\Lachesis.sys [7/22/2008 4:59 PM 12032]
S3 sdAuxService;PC Tools Auxiliary Service;c:\program files\Spyware Doctor\pctsAuxs.exe [6/13/2009 1:44 PM 348752]
S4 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\Viewpoint\Common\ViewpointService.exe [12/20/2008 3:16 AM 24652]
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\>{60B49E34-C7CC-11D0-8953-00A0C90347FF}]
"c:\windows\system32\rundll32.exe" "c:\windows\system32\iedkcs32.dll",BrandIEActiveSetup SIGNUP
2009-05-17 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 20:34]
2009-06-13 c:\windows\Tasks\Google Software Updater.job
- c:\program files\Google\Common\Google Updater\GoogleUpdaterService.exe [2008-12-31 16:40]
2009-06-14 c:\windows\Tasks\RegCure Program Check.job
- c:\program files\RegCure\RegCure.exe [2008-04-21 21:21]
2009-06-11 c:\windows\Tasks\RegCure.job
uLocal Page = \blank.htm
IE: &AIM Search - c:\program files\aol\aim toolbar 5.0\resources\en-US\local\search.html
IE: &AIM Toolbar Search - c:\documents and settings\All Users\Application Data\AIM Toolbar\ieToolbar\resources\en-US\local\search.html
IE: &Google Search - c:\program files\Google\GoogleToolbar1.dll/cmsearch.html
IE: Backward Links - c:\program files\Google\GoogleToolbar1.dll/cmbacklinks.html
IE: Cached Snapshot of Page - c:\program files\Google\GoogleToolbar1.dll/cmcache.html
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~4\OFFICE11\EXCEL.EXE/3000
IE: Similar Pages - c:\program files\Google\GoogleToolbar1.dll/cmsimilar.html
IE: Translate into English - c:\program files\Google\GoogleToolbar1.dll/cmtrans.html
FF - ProfilePath -
Rootkit scan 2009-06-13 19:06
- - - - - - - > 'winlogon.exe'(864)
Completion time: 2009-06-14 19:09
ComboFix-quarantined-files.txt 2009-06-14 02:09
Pre-Run: 215,159,259,136 bytes free
Post-Run: 217,214,717,952 bytes free
940 --- E O F --- 2009-06-10 20:33
shaheen
Posts Posts : 33
Post by Belahzur on 14th June 2009, 12:05 pm
Before we remove the leftovers, I want to get an uninstall list.
  • Open HijackThis.
Post by shaheen on 14th June 2009, 4:02 pm
The uninstall list from Hijack
Ad-Aware 2007
Adobe AIR
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Media Player
Adobe Media Player
Adobe Reader 8.1.3
Advanced WindowsCare Personal
Adware Professional v5.0
Age of Empires III
Age of Empires III - The Asian Dynasties
Age of Empires III - The WarChiefs
AIM 6
Apple Mobile Device Support
Ares Vista 3.0.9.9002
ATI Catalyst Control Center
ATI Display Driver
Atomic Clock Sync
AVG Free 8.0
Barnyard Invasion from HP Media Center (remove only)
Bejeweled 2 Deluxe from HP Media Center (remove only)
Big Kahuna Reef from HP Media Center (remove only)
Blackhawk Striker 2 from HP Media Center (remove only)
Blasterball 2 from HP Media Center (remove only)
Blasterball 2 Holidays from HP Media Center (remove only)
Boggle Supreme from HP Media Center (remove only)
Bonjour
Bookworm Deluxe from HP Media Center (remove only)
Bounce Symphony from HP Media Center (remove only)
CCleaner (remove only)
CMN3
Counter-Strike: Source
Crystal Maze from HP Media Center (remove only)
Digby's Donuts from HP Media Center (remove only)
Download Updater (AOL LLC)
Easy Internet Sign-up
FATE Demo from HP Media Center (remove only)
ffdshow [rev 1928] [2008-04-10]
Flip Words from HP Media Center (remove only)
Garmin Communicator Plugin
Garmin USB Drivers
GemMaster Mystic
Google Earth
Google Updater
HijackThis 2.0.2
HP Boot Optimizer
HP Deskjet Printer Preload
HP DigitalMedia Archive
HP Game Console and games
HP Image Zone for Media Center PC
hp officejet g series - 2
HP Software Update
HP Tunes
HPTunesAddIn
Insaniquarium Deluxe from HP Media Center (remove only)
Intel(R) PRO Network Connections Drivers
IntelliMover Data Transfer Demo
InterVideo WinDVD Player
iTunes
J2SE Runtime Environment 5.0
Java(TM) 6 Update 13
Java(TM) 6 Update 5
Java(TM) 6 Update 7
Jewel Quest from HP Media Center (remove only)
Juniper Networks Network Connect 6.2.0
Mah Jong Quest from HP Media Center (remove only)
Microsoft .NET Framework 1.1
Microsoft Money 2005
Microsoft Office Standard Edition 2003
Microsoft Works
mIRC
MobileMe Control Panel
Mozilla Firefox (3.0.10)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
MSXML 6.0 Parser (KB933579)
muvee autoProducer 4.0
muvee autoProducer unPlugged 1.1 - HPD
Office 2003 Tour
Otto
PC-Doctor 5 for Windows
Polar Bowler from HP Media Center (remove only)
Polar Golfer from HP Media Center (remove only)
PS2
Puzzle Express from HP Media Center (remove only)
Python 2.2 pywin32 extensions (build 203)
Python 2.2.3
Quicken 2005
QuickTime
Razer DeathAdder(TM) Mouse
RealPlayer
RegCure 1.5.0.1
RegistryFix v6.1
Ricochet Lost Worlds from HP Media Center (remove only)
SCRABBLE Blast from HP Media Center (remove only)
SCRABBLE from HP Media Center (remove only)
SCRABBLE Rack Attack from HP Media Center (remove only)
Security Update for Windows Internet Explorer 8 (KB969897)
Shrek 2 Ogre Bowler from HP Media Center (remove only)
Skype™ 3.8
Slingo Deluxe from HP Media Center (remove only)
Slyder from HP Media Center (remove only)
Sonic Encoders
Sonic Express Labeler
Sonic MyDVD Plus
Sonic RecordNow Audio
Sonic RecordNow Copy
Sonic RecordNow Data
Sonic Update Manager
SpyHunter
Spyware Doctor 6.0
Steam
Super Granny from HP Media Center (remove only)
Swarm from HP Media Center (remove only)
Tradewinds from HP Media Center (remove only)
Updates from HP (remove only)
Ventrilo Client
Viewpoint Media Player
WildTangent Web Driver
Windows Driver Package - Cypress (CyUsb) USB
Windows Driver Package - Garmin (grmnusb) GARMIN Devices (03/08/2007 2.2.1.0)
Windows Driver Package - MOTOROLA (uisp) USB (09/08/2006 1.2.0.0)
Windows Driver Package - Razer (HidUsb) HIDClass (02/02/2007 1.0.5.0)
Windows Driver Package - Razer (HidUsb) HIDClass (05/10/2007 1.00)
Windows XP Service Pack 3
Yahoo! Messenger
shaheen
Posts Posts : 33
Post by Belahzur on 14th June 2009, 4:25 pm
    Java(TM) 6 Update 5
    Java(TM) 6 Update 7
Now open a new notepad file.
File::
Folder::
C:\!KillBox
c:\Program Files\Ares
Registry::
"AntiVirusDisableNotify"=-
Post by shaheen on 14th June 2009, 4:53 pm
Alrigh i perform all things in that last msg you left me...still have the notes if you want
my internet explorer now though is telling me its running wit addons disbaled
shaheen
Posts Posts : 33
Post by shaheen on 14th June 2009, 5:05 pm
When i open up I.E it gives me a window staing this
[b]This is an add-on that can cause I.E to stop responding or crash
The safe search for I.E add-on vertion 8.0.0.152 published by AVG tech is not compatible w/ I.E 8
I can either check online for updates
or
i can always open I.E w/o this add-on ...
shaheen
Posts Posts : 33
Post by Origin on 14th June 2009, 5:09 pm
If the add on is not compatible with that version of IE then its is recommended that you remove it so it can prevent IE from crashing.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31493
Post by shaheen on 14th June 2009, 5:17 pm
kk ty
so belahzur, im i good wit everything? should i remove all the programs from my comp or?
shaheen
Posts Posts : 33
Post by Origin on 14th June 2009, 5:20 pm
Couple of things left to do,
Posts Posts : 2685
Post by shaheen on 14th June 2009, 9:44 pm
Update Quick scan MBAM log file
Malwarebytes' Anti-Malware 1.37
Database version: 2279
6/14/2009 2:44:04 PM
mbam-log-2009-06-14 (14-44-04).txt
Objects scanned: 165223
Time elapsed: 12 minute(s), 11 second(s)
Registry Keys Infected: 14
Folders Infected: 5
Files Infected: 9
HKEY_CLASSES_ROOT\Interface\{2e9937fc-cf2f-4f56-af54-5a6a3dd375cc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{cf54be1c-9359-4395-8533-1657cf209cfe} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{d518921a-4a03-425e-9873-b9a71756821e} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{59c7fc09-1c83-4648-b3e6-003d2bbc7481} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{68af847f-6e91-45dd-9b68-d6a12c30e5d7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{9170b96c-28d4-4626-8358-27e6caeef907} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{d1a71fa0-ff48-48dd-9b6d-7a13a3e42127} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{ddb1968e-ead6-40fd-8dae-ff14757f60c7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{f138d901-86f0-4383-99b6-9cdd406036da} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\WinBlueSoft (Rogue.WinBlue) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\RunDll32Policy\f3ScrCtr.dll (Adware.MyWay) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Fun Web Products (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\AdwareAlert (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Log (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Quarantine (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Registry Backups (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Settings (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\DataBaseNew.ref (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Log\log_2006_05_09_23_46_29.log (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Log\log_2006_05_09_23_46_30.log (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Settings\CustomScan.stg (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Settings\IgnoreList.stg (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Settings\ScanInfo.stg (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Settings\ScanResults.stg (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Settings\SelectedFolders.stg (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Settings\Settings.stg (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
shaheen
Posts Posts : 33
Post by shaheen on 15th June 2009, 12:21 am
so am i all set?
shaheen
Posts Posts : 33
Post by Belahzur on 15th June 2009, 12:23 am
I'd say so, MBAM only found a rogue scanner.
How's the machine running?
Post by shaheen on 15th June 2009, 2:38 am
Seems like its all running good.
Thanks for your help i coudn't find ny other thing to do to get that crap off my PC
All the programs i downloaded..is it safe just to uninstill/remove from the comp?
shaheen
Posts Posts : 33
Post by Belahzur on 15th June 2009, 1:53 pm
Yep. Smile
