Help, done everything for winbluesoft
Post by shaheen on 13th June 2009, 10:44 pm
So i have purchased and downloaded spyhunter. When i scanned my pc it found some Dll and some rogue files of winbluesoft...but its still on my comp. I ran an adaware scan but errors keep occuring when i perform them.
I have removed winblusoft in "add/remove" i have also ran msconfig to stop it from starting up but still the virus has not subsided...wut else can i do
thanks
shaheen
Posts Posts : 33
Joined Joined : 2009-06-13
Points Points : 27377
Re: Help, done everything for winbluesoft
Post by Belahzur on 13th June 2009, 10:46 pm
Points Points : 245079
Post by shaheen on 13th June 2009, 10:56 pm
my Hijack This wont open up. I get the option of installing it...but after that nothing pops up. I click the desktop icon and still nothing occurs
i have the choice of either Run or Save when i click the link you gave me to download it
shaheen
Posts Posts : 33
Post by Belahzur on 13th June 2009, 11:02 pm
Guess the blocker.dll is present here. Lets try this out on it, see if it knows about IceSword yet. Goofy
  3. When IceSword opens, it will randomly rename itself, so the malware shouldn't notice it.
  4. Does it stay open? let me know. Don't do anything with it just yet.
Post by shaheen on 13th June 2009, 11:08 pm
god daym this winbluesoft is a little b****
i extracted it, when i did though it didnt change the name it stayed as iceswrd and when i opened it it gave a message
intialized failed, error code 3
shaheen
Posts Posts : 33
Post by Belahzur on 13th June 2009, 11:16 pm
I need to know what OS your running. There is two versions of IceSword. One for XP, another for Vista.
If your running Vista, I've given you the wrong link. LMBO or ROFL
Post by shaheen on 13th June 2009, 11:17 pm
I'm running windows xp
shaheen
Posts Posts : 33
Post by Belahzur on 13th June 2009, 11:23 pm
Darn.
Please download the Pocket Killbox from [You must be registered and logged in to see this link.]
1. Open the Killbox.
2. Does it stay open?
Post by shaheen on 13th June 2009, 11:32 pm
yes it stays open thank god lol
gives me and option to Full path of file to delete
shaheen
Posts Posts : 33
Post by Belahzur on 13th June 2009, 11:55 pm
I know.
2. Under "Full path of file to delete", copy and paste in the following:
C:\Windows\system32\blocker.dll
3. Then switch the option from "Standard file kill", to "Delete on reboot"
4. Press the Red X to delete the file.
5. It will ask if you want to make a backup of the file we deleted, select Yes to the prompt.
6. Now it will ask to reboot, so please do so.
Then after reboot, run Hijack This
Post by shaheen on 13th June 2009, 11:59 pm
Alrigh i'm able to do all of that except its not asking me to create a back up file. but i am able to delete on reboot and reboot my comp but i stopped the reboot before to make sure if i cant create a back up file is a problem
shaheen
Posts Posts : 33
Post by Belahzur on 14th June 2009, 12:12 am
Okay, doesn't matter anyway, I know the file is malicious.
Reboot the machine so Killbox can delete the file.
Post by shaheen on 14th June 2009, 12:15 am
kk i deleted on reboot, my compter didnt reboot it told me
"pendingFileRenameOperations Registery data has been removed by external process"
shaheen
Posts Posts : 33
Post by Belahzur on 14th June 2009, 12:17 am
Hmm.
Reboot anyway, see if you can run programs like normal now.
If not, re-run the Killbox, but don't stop the reboot this time.
Post by shaheen on 14th June 2009, 12:26 am
i Still have the security alerts for winbluesoft saying my comp is infected..i re-ran the kill box but again when i clikc the option delte on reboot and press the RED X button it gave me the same message as b4..kinda looks like an error msg saying PeningFileRename Operations Regiustry Data has been removed by external process. I have a choice in the kill box to do single files or all files? Again my PC didnt auto restart after pressing the RED X button
shaheen
Posts Posts : 33
Post by shaheen on 14th June 2009, 12:28 am
well fake security alert
shaheen
Posts Posts : 33
Post by Belahzur on 14th June 2009, 12:29 am
Lets see if this will run. Let me think
Post by shaheen on 14th June 2009, 12:32 am
This is what it gave me
"Silent Runners.vbs", revision 59, [You must be registered and logged in to see this link.]
Operating System: Windows XP
Output limited to non-default values, except where indicated by "{++}"
Startup items buried in registry:
HKCU\Software\Microsoft\Windows\CurrentVersion\Run\ {++}
"ctfmon.exe" = "C:\WINDOWS\system32\ctfmon.exe" [MS]
"Aim6" = ""C:\Program Files\AIM6\aim6.exe" /d locale=en-US [You must be registered and logged in to see this link.] ["AOL LLC"]
"swg" = "C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" ["Google Inc."]
"ares" = ""C:\Program Files\Ares\Ares.exe" -h" ["Ares Development Group"]
"ares vista" = ""C:\Program Files\Ares Vista\AresVista.exe" -h" ["Ares Vista"]
"setup2.exe" = "C:\WINDOWS\system32\setup2.exe" [null data]
"MSMSGS" = ""C:\Program Files\Messenger\msmsgs.exe" /background" [MS]
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\ {++}
"HPBootOp" = ""C:\Program Files\Hewlett-Packard\HP Boot Optimizer\HPBootOp.exe" /run" ["Hewlett-Packard Company"]
"HPHUPD08" = "c:\Program Files\HP\Digital Imaging\{33D6CC28-9F75-4d1b-A11D-98895B3A3729}\hphupd08.exe" ["Hewlett-Packard"]
"TkBellExe" = ""C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -osboot" ["RealNetworks, Inc."]
"Adobe Reader Speed Launcher" = ""C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"" ["Adobe Systems Incorporated"]
"AppleSyncNotifier" = "C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" ["Apple Inc."]
"QuickTime Task" = ""C:\Program Files\QuickTime\QTTask.exe" -atboottime" ["Apple Inc."]
"iTunesHelper" = ""C:\Program Files\iTunes\iTunesHelper.exe"" ["Apple Inc."]
"SunJavaUpdateSched" = ""C:\Program Files\Java\jre6\bin\jusched.exe"" ["Sun Microsystems, Inc."]
"SpyHunter Security Suite" = ""C:\Program Files\Enigma Software Group\SpyHunter\SpyHunter3.exe"" ["Enigma Software Group USA, LLC."]
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\
{06849E9F-C8D7-4D59-B87D-784B7D6BE0B3}\(Default) = (no title provided)
-> {HKLM...CLSID} = "Adobe PDF Reader Link Helper"
\InProcServer32\(Default) = "C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll" ["Adobe Systems Incorporated"]
{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}\(Default) = (no title provided)
-> {HKLM...CLSID} = "AVG Safe Search"
\InProcServer32\(Default) = "C:\Program Files\AVG\AVG8\avgssie.dll" ["AVG Technologies CZ, s.r.o."]
{AF69DE43-7D58-4638-B6FA-CE66B5AD205D}\(Default) = (no title provided)
-> {HKLM...CLSID} = "Google Toolbar Notifier BHO"
\InProcServer32\(Default) = "C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll" ["Google Inc."]
{DBC80044-A445-435b-BC74-9C25C1C588A9}\(Default) = (no title provided)
-> {HKLM...CLSID} = "Java(tm) Plug-In 2 SSV Helper"
\InProcServer32\(Default) = "C:\Program Files\Java\jre6\bin\jp2ssv.dll" ["Sun Microsystems, Inc."]
{E7E6F031-17CE-4C07-BC86-EABFE594F69C}\(Default) = "JQSIEStartDetectorImpl"
-> {HKLM...CLSID} = "JQSIEStartDetectorImpl Class"
\InProcServer32\(Default) = "C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll" ["Sun Microsystems, Inc."]
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved\
"{88895560-9AA2-1069-930E-00AA0030EBC8}" = "HyperTerminal Icon Ext"
-> {HKLM...CLSID} = "HyperTerminal Icon Ext"
\InProcServer32\(Default) = "C:\WINDOWS\system32\hticons.dll" ["Hilgraeve, Inc."]
shaheen
Posts Posts : 33
Post by shaheen on 14th June 2009, 12:37 am
heres the notepad info i get when i extract the files
"{DBFB267C-334F-4F19-A304-63B7130C20C7}" = "MediaCenter Property Page"
-> {HKLM...CLSID} = (no title provided)
\InProcServer32\(Default) = "arpower.dll" ["Microsoft"]
"{5E2121EE-0300-11D4-8D3B-444553540000}" = "Catalyst Context Menu extension"
-> {HKLM...CLSID} = "SimpleShlExt Class"
\InProcServer32\(Default) = "C:\Program Files\ATI Technologies\ATI.ACE\atiacmxx.dll" [empty string]
"{F0CB00CD-5A07-4D91-97F5-A8C92CDA93E4}" = "Shell Extensions for RealOne Player"
-> {HKLM...CLSID} = "RealOne Player Context Menu Class"
\InProcServer32\(Default) = "C:\Program Files\Real\RealPlayer\rpshell.dll" ["RealNetworks, Inc."]
"{7F67036B-66F1-411A-AD85-759FB9C5B0DB}" = "SampleView"
-> {HKLM...CLSID} = "SampleView"
\InProcServer32\(Default) = "C:\WINDOWS\system32\ShellvRTF.dll" ["XSS"]
"{00020D75-0000-0000-C000-000000000046}" = "Microsoft Office Outlook Desktop Icon Handler"
-> {HKLM...CLSID} = "Microsoft Office Outlook"
\InProcServer32\(Default) = "C:\PROGRA~1\MICROS~4\OFFICE11\MLSHEXT.DLL" [MS]
"{0006F045-0000-0000-C000-000000000046}" = "Microsoft Office Outlook Custom Icon Handler"
-> {HKLM...CLSID} = "Outlook File Icon Extension"
\InProcServer32\(Default) = "C:\PROGRA~1\MICROS~4\OFFICE11\OLKFSTUB.DLL" [MS]
"{42042206-2D85-11D3-8CFF-005004838597}" = "Microsoft Office HTML Icon Handler"
\InProcServer32\(Default) = "C:\Program Files\Microsoft Office\OFFICE11\msohev.dll" [MS]
"{9F97547E-4609-42C5-AE0C-81C61FFAEBC3}" = "AVG8 Shell Extension"
-> {HKLM...CLSID} = "AVG8 Shell Extension Class"
\InProcServer32\(Default) = "C:\Program Files\AVG\AVG8\avgse.dll" ["AVG Technologies CZ, s.r.o."]
"{B9E1D2CB-CCFF-4AA6-9579-D7A4754030EF}" = "iTunes"
-> {HKLM...CLSID} = "iTunes"
\InProcServer32\(Default) = "C:\Program Files\iTunes\iTunesMiniPlayer.dll" ["Apple Inc."]
"{11016101-E366-4D22-BC06-4ADA335C892B}" = "IE History and Feeds Shell Data Source for Windows Search"
-> {HKLM...CLSID} = "IE History and Feeds Shell Data Source for Windows Search"
\InProcServer32\(Default) = "C:\WINDOWS\system32\ieframe.dll" [MS]
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad\
"WPDShServiceObj" = "{AAA288BA-9A4C-45B0-95D7-94D524869DB5}"
-> {HKLM...CLSID} = "WPDShServiceObj Class"
\InProcServer32\(Default) = "C:\WINDOWS\system32\WPDShServiceObj.dll" [MS]
HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\
<> "BootExecute" = "autocheck autochk *"|"lsdelete" [null data]
HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\
<> AtiExtEvent\DLLName = "Ati2evxx.dll" ["ATI Technologies Inc."]
HKLM\SOFTWARE\Classes\PROTOCOLS\Filter\
<> text/xml\CLSID = "{807553E5-5146-11D5-A672-00B0D022E945}"
\InProcServer32\(Default) = "C:\Program Files\Common Files\Microsoft Shared\OFFICE11\MSOXMLMF.DLL" [MS]
HKLM\SOFTWARE\Classes\Folder\shellex\ColumnHandlers\
{F9DB5320-233E-11D1-9F84-707F02C10627}\(Default) = "PDF Column Info"
-> {HKLM...CLSID} = "PDF Shell Extension"
\InProcServer32\(Default) = "C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\PDFShell.dll" ["Adobe Systems, Inc."]
HKLM\SOFTWARE\Classes\*\shellex\ContextMenuHandlers\
AVG8 Shell Extension\(Default) = "{9F97547E-4609-42C5-AE0C-81C61FFAEBC3}"
HKLM\SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers\
shaheen
Posts Posts : 33
Post by shaheen on 14th June 2009, 12:38 am
NOTEPAD Cont..
Group Policies {GPedit.msc branch and setting}:
Note: detected settings may not have any effect.
HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\
"LinkResolveIgnoreLinkInfo" = (REG_DWORD) dword:0x00000000
{unrecognized setting}
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\
"NoResolveSearch" = (REG_DWORD) dword:0x00000001
"HonorAutoRunSetting" = (REG_DWORD) dword:0x00000001
"NoCDBurning" = (REG_DWORD) dword:0x00000000
HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer\Infodelivery\Restrictions\
"NoUpdateCheck" = (REG_DWORD) dword:0x00000001
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\
"shutdownwithoutlogon" = (REG_DWORD) dword:0x00000001
{Computer Configuration|Windows Settings|Security Settings|Local Policies|Security Options|
Shutdown: Allow system to be shut down without having to log on}
"undockwithoutlogon" = (REG_DWORD) dword:0x00000001
Devices: Allow undock without having to log on}
"InstallVisualStyle" = (REG_EXPAND_SZ) C:\WINDOWS\Resources\Themes\Royale\Royale.msstyles
"InstallTheme" = (REG_EXPAND_SZ) C:\WINDOWS\Resources\Themes\Royale.theme
Active Desktop and Wallpaper:
Active Desktop may be disabled at this entry:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellState
Displayed if Active Desktop enabled and wallpaper not set by Group Policy:
HKCU\Software\Microsoft\Internet Explorer\Desktop\General\
"Wallpaper" = "C:\WINDOWS\system32\config\systemprofile\Local Settings\Application Data\Microsoft\Wallpaper1.bmp"
Displayed if Active Desktop disabled and wallpaper not set by Group Policy:
HKCU\Control Panel\Desktop\
"Wallpaper" = "C:\Documents and Settings\Shaheen.POURFALLAH\Local Settings\Application Data\Microsoft\Wallpaper1.bmp"
Enabled Screen Saver:
"SCRNSAVE.EXE" = "C:\WINDOWS\system32\space.scr" [MS]
Autostart via AUTORUN.INF on local fixed drives:
D:\
<> D:\AUTORUN.INF -> "ShellExecute=Info.exe protect.ed 480 480" ["XSS"]
Windows Portable Device AutoPlay Handlers
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\AutoplayHandlers\Handlers\
EHomeMusicDropTarget\
"Provider" = "Media Center"
"InvokeProgID" = "EHomeDropTarget.EHomeMusicDropTarget"
"InvokeVerb" = "play"
HKLM\SOFTWARE\Classes\EHomeDropTarget.EHomeMusicDropTarget\shell\play\DropTarget\CLSID = "{ED87EFF3-FF22-404E-B2BD-BC3841BDCB2C}"
-> {HKLM...CLSID} = "EHomeMusicDropTarget Class"
\InProcServer32\(Default) = "C:\WINDOWS\eHome\ehdrop.dll" [MS]
EHomePhotosHandler\
"InvokeProgID" = "EHomeDropTarget.EHomePhotosHandler"
HKLM\SOFTWARE\Classes\EHomeDropTarget.EHomePhotosHandler\shell\play\DropTarget\CLSID = "{4b7601c1-d292-4902-89f4-583a5ce0c535}"
-> {HKLM...CLSID} = "EHomePhotosHandler Class"
EHomeVideoDropTarget\
"InvokeProgID" = "EHomeDropTarget.EHomeVideoDropTarget"
HKLM\SOFTWARE\Classes\EHomeDropTarget.EHomeVideoDropTarget\shell\play\DropTarget\CLSID = "{A48E70A4-8E15-4465-9D85-CCE9E63F8AAB}"
-> {HKLM...CLSID} = "EHomeVideoDropTarget Class"
EHomeVideosHandler\
"InvokeProgID" = "EHomeDropTarget.EHomeVideosHandler"
HKLM\SOFTWARE\Classes\EHomeDropTarget.EHomeVideosHandler\shell\play\DropTarget\CLSID = "{4f61ec50-acef-4ae7-b4c6-b19bddc0f745}"
-> {HKLM...CLSID} = "EHomeVideosHandler Class"
HPUnloadAutoplay\
"Provider" = "HP Transfer and Quick Print"
"InvokeProgID" = "HpqUnApl.Autoplay"
"InvokeVerb" = "Play"
HKLM\SOFTWARE\Classes\HpqUnApl.Autoplay\shell\Play\DropTarget\CLSID = "{E1A1C814-FD09-4c9d-BB4A-0394B836A1F0}"
\LocalServer32\(Default) = "c:\Program Files\HP\Digital Imaging\Unload\HpqUnApl.exe" ["Hewlett-Packard"]
iTunesBurnCDOnArrival\
"Provider" = "iTunes"
"InvokeProgID" = "iTunes.BurnCD"
"InvokeVerb" = "burn"
HKLM\SOFTWARE\Classes\iTunes.BurnCD\shell\burn\command\(Default) = ""C:\Program Files\iTunes\iTunes.exe" /AutoPlayBurn "%L"" ["Apple Inc."]
iTunesImportSongsOnArrival\
"InvokeProgID" = "iTunes.ImportSongsOnCD"
"InvokeVerb" = "import"
HKLM\SOFTWARE\Classes\iTunes.ImportSongsOnCD\shell\import\command\(Default) = ""C:\Program Files\iTunes\iTunes.exe" /AutoPlayImportSongs "%L"" ["Apple Inc."]
iTunesPlaySongsOnArrival\
"InvokeProgID" = "iTunes.PlaySongsOnCD"
HKLM\SOFTWARE\Classes\iTunes.PlaySongsOnCD\shell\play\command\(Default) = ""C:\Program Files\iTunes\iTunes.exe" /playCD "%L"" ["Apple Inc."]
iTunesShowSongsOnArrival\
"InvokeProgID" = "iTunes.ShowSongsOnCD"
"InvokeVerb" = "showsongs"
HKLM\SOFTWARE\Classes\iTunes.ShowSongsOnCD\shell\showsongs\command\(Default) = ""C:\Program Files\iTunes\iTunes.exe" /AutoPlayShowSongs "%L"" ["Apple Inc."]
IviDVDEventHandler\
"Provider" = "InterVideo WinDVD"
"InvokeProgID" = "Ivi.MediaFile"
"InvokeVerb" = "playDVD"
HKLM\SOFTWARE\Classes\Ivi.MediaFile\shell\playDVD\command\(Default) = ""C:\Program Files\InterVideo\WinDVD\WinDVD.exe" %1" ["InterVideo Inc."]
MSWPDShellNamespaceHandler\
"Provider" = "@%SystemRoot%\System32\WPDShextRes.dll,-501"
"CLSID" = "{A55803CC-4D53-404c-8557-FD63DBA95D24}"
"InitCmdLine" = " "
-> {HKLM...CLSID} = "WPDShextAutoplay"
\LocalServer32\(Default) = "C:\WINDOWS\system32\WPDShextAutoplay.exe" [MS]
muveeVideoCameraArrival\
"Provider" = "muvee autoProducer 4.0"
"ProgID" = "Shell.HWEventHandlerShellExecute"
"InitCmdLine" = ""C:\Program Files\muvee Technologies\muvee autoProducer 4.0 - HPD\muveeapp.exe" /RECORD"
HKLM\SOFTWARE\Classes\Shell.HWEventHandlerShellExecute\CLSID\(Default) = "{FFB8655F-81B9-4fce-B89C-9A6BA76D13E7}"
-> {HKLM...CLSID} = "ShellExecute HW Event Handler"
\LocalServer32\(Default) = "rundll32.exe shell32.dll,SHCreateLocalServerRunDll {FFB8655F-81B9-4fce-B89C-9A6BA76D13E7}" [MS]
RPCDBurningOnArrival\
"Provider" = "RealPlayer"
"InvokeProgID" = "RealPlayer.CDBurn.6"
"InvokeVerb" = "open"
HKLM\SOFTWARE\Classes\RealPlayer.CDBurn.6\shell\open\command\(Default) = ""C:\Program Files\Real\RealPlayer\RealPlay.exe" /burn "%1"" ["RealNetworks, Inc."]
RPDeviceOnArrival\
"ProgID" = "RealPlayer.HWEventHandler"
HKLM\SOFTWARE\Classes\RealPlayer.HWEventHandler\CLSID\(Default) = "{67E76F1D-BDE2-4052-913C-2752366192D2}"
-> {HKLM...CLSID} = "RealNetworks Scheduler"
\LocalServer32\(Default) = ""C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -autoplay" ["RealNetworks, Inc."]
RPPlayCDAudioOnArrival\
"InvokeProgID" = "RealPlayer.AudioCD.6"
HKLM\SOFTWARE\Classes\RealPlayer.AudioCD.6\shell\play\command\(Default) = ""C:\Program Files\Real\RealPlayer\RealPlay.exe" /play %1 " ["RealNetworks, Inc."]
RPPlayDVDMovieOnArrival\
"InvokeProgID" = "RealPlayer.DVD.6"
HKLM\SOFTWARE\Classes\RealPlayer.DVD.6\shell\play\command\(Default) = ""C:\Program Files\Real\RealPlayer\RealPlay.exe" /dvd %1 " ["RealNetworks, Inc."]
RPPlayMediaOnArrival\
"InvokeProgID" = "RealPlayer.AutoPlay.6"
HKLM\SOFTWARE\Classes\RealPlayer.AutoPlay.6\shell\open\command\(Default) = ""C:\Program Files\Real\RealPlayer\RealPlay.exe" /autoplay "%1"" ["RealNetworks, Inc."]
SonicMyCreateProject\
"Provider" = "Sonic MyDVD"
"InvokeProgID" = "Sonic.MyDVD"
"InvokeVerb" = "CreateProject"
HKLM\SOFTWARE\Classes\Sonic.MyDVD\shell\CreateProject\Command\(Default) = "c:\Program Files\Sonic\MyDVD\MyDVD.EXE /AutoPlayCreateProject %L" ["Sonic Solutions"]
SonicSCAudioCDTask\
"Provider" = "Sonic RecordNow Audio"
"InvokeProgID" = "Sonic.SonicCentral"
"InvokeVerb" = "AudioCDTask"
HKLM\SOFTWARE\Classes\Sonic.SonicCentral\shell\AudioCDTask\Command\(Default) = ""c:\Program Files\Common Files\Sonic Shared\Sonic Central\Main\Mediahub.exe" /Launch {EBD22732-1CC3-4CD7-9A45-B8D98DA0E784}" [null data]
SonicSCCopyCD\
"Provider" = "Sonic RecordNow Copy"
"InvokeVerb" = "ExactCopyJob"
HKLM\SOFTWARE\Classes\Sonic.SonicCentral\shell\ExactCopyJob\Command\(Default) = ""c:\Program Files\Common Files\Sonic Shared\Sonic Central\Main\Mediahub.exe" /Launch {49B235A3-1C3E-4802-9B5C-BAFBE69A3C85}" [null data]
SonicSCCopyDisc\
SonicSCDataProject\
"Provider" = "Sonic RecordNow Data"
"InvokeVerb" = "DataGuide"
HKLM\SOFTWARE\Classes\Sonic.SonicCentral\shell\DataGuide\Command\(Default) = ""c:\Program Files\Common Files\Sonic Shared\Sonic Central\Main\Mediahub.exe" /Launch Data" [null data]
SonicSCDataTask\
"InvokeVerb" = "DataTask"
HKLM\SOFTWARE\Classes\Sonic.SonicCentral\shell\DataTask\Command\(Default) = ""c:\Program Files\Common Files\Sonic Shared\Sonic Central\Main\Mediahub.exe" /Launch {0BAC5C34-DF45-4C0F-8D64-8E92DCCF007D}" [null data]
SonicVideoCameraArrival\
"Provider" = "Sonic Solutions"
"ProgID" = "MyDVD.MyDVDAPHandler"
"InitCmdLine" = "new"
HKLM\SOFTWARE\Classes\MyDVD.MyDVDAPHandler\CLSID\(Default) = "{3D5EF619-F606-4FAA-97C0-222B7DCA05EC}"
-> {HKLM...CLSID} = "MyDVDAPHandler Class"
\LocalServer32\(Default) = "c:\PROGRA~1\Sonic\MyDVD\MyDVD.EXE -autoplay" ["Sonic Solutions"]
SonicVideoCameraArrivalDirect\
"InitCmdLine" = ""c:\Program Files\Common Files\Sonic Shared\Sonic Central\Main\Mediahub.exe" /Launch {3563B7B4-E6D4-4360-8E38-64E008F52C5C}"
shaheen
Posts Posts : 33
Final Notepad Cont...
Enabled Scheduled Tasks:
"AppleSoftwareUpdate" -> launches: "C:\Program Files\Apple Software Update\SoftwareUpdate.exe -task" ["Apple Inc."]
"Google Software Updater" -> launches: "C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe scheduled_start" ["Google"]
"RegCure Program Check" -> launches: "C:\Program Files\RegCure\RegCure.exe ShowReminders" [null data]
"RegCure" -> launches: "C:\Program Files\RegCure\RegCure.exe -t" [null data]
"{5B57CF47-0BFA-43c6-ACF9-3B3653DCADBA}" -> launches: "C:\WINDOWS\TEMP\tempo-10626921.tmp" [null data]
Winsock2 Service Provider DLLs:
Namespace Service Providers
HKLM\SYSTEM\CurrentControlSet\Services\Winsock2\Parameters\NameSpace_Catalog5\Catalog_Entries\ {++}
000000000001\LibraryPath = "%SystemRoot%\System32\mswsock.dll" [MS]
000000000002\LibraryPath = "%SystemRoot%\System32\winrnr.dll" [MS]
000000000003\LibraryPath = "%SystemRoot%\System32\mswsock.dll" [MS]
000000000004\LibraryPath = "C:\Program Files\Bonjour\mdnsNSP.dll" ["Apple Inc."]
Transport Service Providers
HKLM\SYSTEM\CurrentControlSet\Services\Winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\ {++}
0000000000##\PackedCatalogItem (contains) DLL [Company Name], (at) ## range:
%SystemRoot%\system32\mswsock.dll [MS], 01 - 03, 06 - 19
%SystemRoot%\system32\rsvpsp.dll [MS], 04 - 05
Toolbars, Explorer Bars, Extensions:
Explorer Bars
HKLM\SOFTWARE\Microsoft\Internet Explorer\Explorer Bars\
HKLM\SOFTWARE\Classes\CLSID\{FF059E31-CC5A-4E2E-BF3B-96E929D65503}\(Default) = "&Research"
Implemented Categories\{00021493-0000-0000-C000-000000000046}\ [vertical bar]
InProcServer32\(Default) = "C:\PROGRA~1\MICROS~4\OFFICE11\REFIEBAR.DLL" [MS]
Extensions (Tools menu items, main toolbar menu buttons)
HKLM\SOFTWARE\Microsoft\Internet Explorer\Extensions\
{92780B25-18CC-41C8-B9BE-3C9C571A8263}\
"ButtonText" = "Research"
{E2D4D26B-0180-43A4-B05F-462D6D54C789}\
"ButtonText" = "Connection Help"
"MenuText" = "Connection Help"
{E2E2DD38-D088-4134-82B7-F2BA38496583}\
"MenuText" = "@xpsp3res.dll,-20001"
"Exec" = "%windir%\Network Diagnostic\xpnetdiag.exe" [MS]
{FB5F1910-F110-11D2-BB9E-00C04F795683}\
"ButtonText" = "Messenger"
"MenuText" = "Windows Messenger"
"Exec" = "C:\Program Files\Messenger\msmsgs.exe" [MS]
Miscellaneous IE Hijack Points
C:\WINDOWS\INF\IERESET.INF (used to "Reset Web Settings")
Added lines (compared with English-language version):
[Strings]: START_PAGE_URL=http://www.microsoft.com/isapi/redir.dll?prd=ie&pver=6&ar=msnhome
[Strings]: MS_START_PAGE_URL="http://www.microsoft.com/isapi/redir.dll?prd=ie&pver=6&ar=msnhome"
Missing lines (compared with English-language version):
[Strings]: 2 lines
HKLM\SOFTWARE\Microsoft\Internet Explorer\AboutURLs\
<> "InPrivate" = "res://ieframe.dll/inprivate.htm" [MS]
Running Services (Display Name, Service Name, Path {Service DLL}Crying
Ad-Aware 2007 Service, aawservice, ""C:\Program Files\Lavasoft\Ad-Aware 2007\aawservice.exe"" ["Lavasoft"]
Apple Mobile Device, Apple Mobile Device, ""C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe"" ["Apple Inc."]
ARSVC, ARSVC, "C:\WINDOWS\arservice.exe" ["Microsoft"]
Ati HotKey Poller, Ati HotKey Poller, "C:\WINDOWS\system32\Ati2evxx.exe" ["ATI Technologies Inc."]
AVG8 E-mail Scanner, avg8emc, "C:\PROGRA~1\AVG\AVG8\avgemc.exe" ["AVG Technologies CZ, s.r.o."]
AVG8 WatchDog, avg8wd, "C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe" ["AVG Technologies CZ, s.r.o."]
Bonjour Service, Bonjour Service, ""C:\Program Files\Bonjour\mDNSResponder.exe"" ["Apple Inc."]
iPod Service, iPod Service, ""C:\Program Files\iPod\bin\iPodService.exe"" ["Apple Inc."]
Java Quick Starter, JavaQuickStarterService, ""C:\Program Files\Java\jre6\bin\jqs.exe" -service -config "C:\Program Files\Java\jre6\lib\deploy\jqs\jqs.conf"" ["Sun Microsystems, Inc."]
Juniper Network Connect Service, dsNcService, "C:\Program Files\Juniper Networks\Common Files\dsNcService.exe" ["Juniper Networks"]
LightScribeService Direct Disc Labeling Service, LightScribeService, ""C:\Program Files\Common Files\LightScribe\LSSrvc.exe"" ["Hewlett-Packard Company"]
Machine Debug Manager, MDM, ""C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE"" [MS]
Media Center Extender Service, McrdSvc, "C:\WINDOWS\ehome\mcrdsvc.exe" [MS]
Media Center Receiver Service, ehRecvr, "C:\WINDOWS\eHome\ehRecvr.exe" [MS]
Media Center Scheduler Service, ehSched, "C:\WINDOWS\eHome\ehSched.exe" [MS]
Pml Driver HPZ12, Pml Driver HPZ12, "C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\HPZIPM12.EXE" ["HP"]
Keyboard Driver Filters:
HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E96B-E325-11CE-BFC1-08002BE10318}\
"UpperFilters" = <> "arkbcfltr" [MS]
Print Monitors:
HKLM\SYSTEM\CurrentControlSet\Control\Print\Monitors\
HP Standard TCP/IP Port\Driver = "HpTcpMon.dll" [file not found]
Microsoft Document Imaging Writer Monitor\Driver = "mdimon.dll" [MS]
Microsoft Shared Fax Monitor\Driver = "FXSMON.DLL" [MS]
---------- (launch time: 2009-06-13 17:31:03)
<>: Suspicious data at a malware launch point.
<>: Suspicious data at a browser hijack point.
+ This report excludes default entries except where indicated.
+ To see *everywhere* the script checks and *everything* it finds,
launch it from a command prompt or a shortcut with the -all parameter.
+ To search all directories of local fixed drives for DESKTOP.INI
DLL launch points, use the -supp parameter or answer "No" at the
first message box and "Yes" at the second message box.
---------- (total run time: 94 seconds, including 44 seconds for message boxes)
shaheen
Posts Posts : 33
Post by Belahzur on 14th June 2009, 1:06 am
Hmm, not enough information really. Lets see if this will run.
Post by shaheen on 14th June 2009, 1:11 am
DDS Notepad 1
DDS (Ver_09-05-14.01) - NTFSx86
Run by Shaheen at 18:09:29.23 on Sat 06/13/2009
Internet Explorer: 8.0.6001.18702 BrowserJavaVersion: 1.6.0_13
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1022.425 [GMT -7:00]
AV: AVG Anti-Virus Free *On-access scanning enabled* (Outdated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
C:\WINDOWS\system32\svchost -k rpcss
C:\WINDOWS\system32\svchost.exe -k LocalService
C:\PROGRA~1\AVG\AVG8\avgrsx.exe
C:\WINDOWS\system32\dllhost.exe
C:\WINDOWS\System32\alg.exe
C:\WINDOWS\system32\ps2.exe
c:\windows\system\hpsysdrv.exe
C:\Program Files\mIRC\mirc.exe
C:\Program Files\Ventrilo\Ventrilo.exe
C:\Documents and Settings\Shaheen.POURFALLAH\Local Settings\Temporary Internet Files\Content.IE5\10Y38H41\dds[1].scr
C:\WINDOWS\system32\wbem\wmiprvse.exe
uLocal Page = \blank.htm
uURLSearchHooks: H - No File
BHO: {02478D38-C3F9-4efb-9B51-7695ECA05670} - No File
BHO: AVG Safe Search: {3ca2f312-6f6e-4b53-a66e-4e65e497c8c0} - c:\program files\avg\avg8\avgssie.dll
BHO: Google Toolbar Notifier BHO: {af69de43-7d58-4638-b6fa-ce66b5ad205d} - c:\program files\google\googletoolbarnotifier\5.1.1309.3572\swg.dll
TB: {2318C2B1-4965-11D4-9B18-009027A5CD4F} - No File
TB: {DE9C389F-3316-41A7-809B-AA305ED9D922} - No File
TB: {61539ECD-CC67-4437-A03C-9AACCBD14326} - No File
uRun: [Aim6] "c:\program files\aim6\aim6.exe" /d locale=en-US [You must be registered and logged in to see this link.]
uRun: [swg] c:\program files\google\googletoolbarnotifier\GoogleToolbarNotifier.exe
uRun: [ares] "c:\program files\ares\Ares.exe" -h
uRun: [ares vista] "c:\program files\ares vista\AresVista.exe" -h
uRun: [setup2.exe] c:\windows\system32\setup2.exe
mRun: [HPBootOp] "c:\program files\hewlett-packard\hp boot optimizer\HPBootOp.exe" /run
mRun: [HPHUPD08] c:\program files\hp\digital imaging\{33d6cc28-9f75-4d1b-a11d-98895b3a3729}\hphupd08.exe
mRun: [Adobe Reader Speed Launcher] "c:\program files\adobe\reader 8.0\reader\Reader_sl.exe"
mRun: [SunJavaUpdateSched] "c:\program files\java\jre6\bin\jusched.exe"
mRun: [SpyHunter Security Suite] "c:\program files\enigma software group\spyhunter\SpyHunter3.exe"
IE: &AIM Search - c:\program files\aol\aim toolbar 5.0\resources\en-us\local\search.html
IE: &AIM Toolbar Search - c:\documents and settings\all users\application data\aim toolbar\ietoolbar\resources\en-us\local\search.html
IE: &Google Search - c:\program files\google\GoogleToolbar1.dll/cmsearch.html
IE: Backward Links - c:\program files\google\GoogleToolbar1.dll/cmbacklinks.html
IE: Cached Snapshot of Page - c:\program files\google\GoogleToolbar1.dll/cmcache.html
IE: E&xport to Microsoft Excel - c:\progra~1\micros~4\office11\EXCEL.EXE/3000
IE: Similar Pages - c:\program files\google\GoogleToolbar1.dll/cmsimilar.html
IE: Translate into English - c:\program files\google\GoogleToolbar1.dll/cmtrans.html
IE: {E2D4D26B-0180-43a4-B05F-462D6D54C789}
IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~1\micros~4\office11\REFIEBAR.DLL
DPF: {CAFEEFAC-0015-0000-0000-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {E5F5D008-DD2C-4D32-977D-1A0ADF03058B} - [You must be registered and logged in to see this link.]
TCP: NameServer = 85.255.112.173,85.255.112.122
TCP: {8DC0BAB8-C0E1-425A-8007-1388C8E230D9} = 85.255.112.173,85.255.112.122
TCP: {FEF010B8-4F30-436C-B497-30DA2D8770C3} = 85.255.112.173,85.255.112.122
Handler: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - c:\program files\avg\avg8\avgpp.dll
Handler: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - c:\progra~1\common~1\skype\Skype4COM.dll
Notify: AtiExtEvent - Ati2evxx.dll
AppInit_DLLs: avgrsstx.dll
shaheen
Posts Posts : 33
Post by shaheen on 14th June 2009, 1:12 am
DDS Notepad cont...
FF - ProfilePath - c:\docume~1\shahee~1.pou\applic~1\mozilla\firefox\profiles\cjxdeobm.default\
FF - prefs.js: browser.search.selectedEngine - AIM Search
FF - component: c:\program files\avg\avg8\firefox\components\avgssff.dll
FF - plugin: c:\program files\google\google updater\2.4.1536.6592\npCIDetect13.dll
FF - plugin: c:\program files\mozilla firefox\plugins\npCID.dll
FF - plugin: c:\program files\mozilla firefox\plugins\npdnu.dll
FF - plugin: c:\program files\mozilla firefox\plugins\npunagi2.dll
FF - plugin: c:\program files\mozilla firefox\plugins\npViewpoint.dll
FF - plugin: c:\program files\viewpoint\viewpoint media player\npViewpoint.dll
---- FIREFOX POLICIES ----
FF - user.js: browser.sessionstore.resume_from_crash - false
R0 PCTCore;PCTools KDS;c:\windows\system32\drivers\PCTCore.sys [2009-6-13 130936]
R1 AvgLdx86;AVG AVI Loader Driver x86;c:\windows\system32\drivers\avgldx86.sys [2008-5-1 97928]
R1 AvgMfx86;AVG On-access Scanner Minifilter Driver x86;c:\windows\system32\drivers\avgmfx86.sys [2008-4-14 26824]
R2 avg8emc;AVG8 E-mail Scanner;c:\progra~1\avg\avg8\avgemc.exe [2008-7-6 875288]
R2 avg8wd;AVG8 WatchDog;c:\progra~1\avg\avg8\avgwdsvc.exe [2008-7-6 231704]
R2 AvgTdiX;AVG8 Network Redirector;c:\windows\system32\drivers\avgtdix.sys [2008-5-1 76040]
R2 McrdSvc;Media Center Extender Service;c:\windows\ehome\mcrdsvc.exe [2005-8-5 99328]
R3 DAdderFltr;DeathAdder Mouse;c:\windows\system32\drivers\dadder.sys [2008-7-13 22784]
S2 aawservice;Ad-Aware 2007 Service;c:\program files\lavasoft\ad-aware 2007\aawservice.exe [2008-3-19 607576]
S3 LachesisFltr;Lachesis Mouse Driver;c:\windows\system32\drivers\Lachesis.sys [2008-7-22 12032]
S3 sdAuxService;PC Tools Auxiliary Service;c:\program files\spyware doctor\pctsAuxs.exe [2009-6-13 348752]
S3 sdCoreService;PC Tools Security Service;c:\program files\spyware doctor\pctsSvc.exe [2009-6-13 1096584]
S4 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\viewpoint\common\ViewpointService.exe [2008-12-20 24652]
2009-06-13 16:31 --d----- C:\!KillBox
2009-06-13 15:52 --d----- c:\program files\Trend Micro
2009-06-13 15:08 --d----- c:\program files\Adware Professional
2009-06-13 14:16 335 a------- C:\spyhunter.fix
2009-06-13 14:16 --d----- c:\program files\Enigma Software Group
2009-06-13 13:44 159,600 a------- c:\windows\system32\drivers\pctgntdi.sys
2009-06-13 13:44 130,936 a------- c:\windows\system32\drivers\PCTCore.sys
2009-06-13 13:44 73,840 a------- c:\windows\system32\drivers\PCTAppEvent.sys
2009-06-13 13:44 64,392 a------- c:\windows\system32\drivers\pctplsg.sys
2009-06-13 13:44 --d----- c:\program files\common files\PC Tools
2009-06-13 13:44 --d----- c:\program files\Spyware Doctor
2009-06-13 13:44 --d----- c:\docume~1\shahee~1.pou\applic~1\PC Tools
2009-06-13 13:44 --d----- c:\docume~1\alluse~1\applic~1\PC Tools
2009-06-13 03:40 16,780 a------- c:\windows\16675virus5z79.exe
2009-06-12 15:34 17,170 a------- c:\windows\17656not-a5vzr9s406.dll
2009-06-11 06:22 --dsh--- c:\documents and settings\shaheen.pourfallah\PrivacIE
2009-06-10 15:16 --dsh--- c:\documents and settings\shaheen.pourfallah\IETldCache
2009-06-10 13:30 -cd-h--- c:\windows\ie8
2009-06-10 00:46 10,898 a------- c:\windows\57e5threz916776.exe
2009-06-09 15:58 16,063 a------- c:\windows\15076not-a-vir9s5cfz.ocx
2009-06-09 15:37 15,777 a------- c:\windows\system32\1667859t-a-virus117z.cpl
2009-06-09 15:14 12,581 a------- c:\windows\system32\7195sp9rsz10.ocx
2009-06-09 02:21 6,484 a------- c:\windows\255fstzal2509.ocx
2009-06-09 01:12 6,797 a------- c:\windows\system32\989zth5ef2699.cpl
2009-06-08 14:47 16,443 a------- c:\windows\1841viru95z.bin
2009-06-05 19:27 16,292 a------- c:\windows\9357zhacktool57.bin
2009-06-05 18:42 3,705 a------- c:\windows\system32\248z2ha9kt5ol201.ocx
2009-06-05 13:26 10,346 a------- c:\windows\5156zi9u5617.ocx
2009-06-05 02:58 14,800 a------- c:\windows\system32\1995sparse15z1.ocx
2009-06-04 12:32 17,478 a------- c:\windows\5224a9dwaze1232.cpl
2009-06-03 14:39 15,982 a------- c:\windows\4519troj51z.dll
2009-06-02 12:36 8,190 a------- c:\windows\system32\5583zack9oor3176.ocx
2009-06-02 07:52 9,696 a------- c:\windows\2002859rmzc9.bin
2009-06-01 18:30 4,391 a------- c:\windows\14132nzt-a-v9rus50a5.ocx
2009-06-01 07:52 15,691 a------- c:\windows\25620s5y2c9z.bin
2009-06-01 07:10 17,453 a------- c:\windows\system32\743bthr9at30z265.cpl
2009-05-27 08:07 14,858 a------- c:\windows\266z9spy255.dll
2009-05-26 17:43 --d----- c:\docume~1\shahee~1.pou\applic~1\GARMIN
2009-05-26 17:42 --d----- c:\program files\Garmin GPS Plugin
2009-05-26 16:09 --d----- c:\program files\Ares Vista
2009-05-24 09:20 11,447 a------- c:\windows\4999sparse18z5.dll
2009-05-22 12:20 3,635 a------- c:\windows\30733spamz5t459.bin
2009-05-21 22:02 10,072 a------- c:\windows\system32\75ea9hie532z5.exe
2009-05-20 05:29 17,415 a------- c:\windows\49dbzhief753.cpl
2009-05-20 03:43 17,840 a------- c:\windows\system32\9a1zackdoor5502.ocx
2009-05-19 15:05 8,752 a------- c:\windows\7b0cd5wnlzader3914.dll
2009-05-19 13:00 11,400 a------- c:\windows\system32\1c25d9wnzoader1632.exe
2009-05-17 10:08 14,317 a------- c:\windows\9a55dzwnloa5er997.bin
2009-05-16 20:03 12,376 a------- c:\windows\8070spamzot5a79.bin
2009-05-14 23:36 9,433 a------- c:\windows\9062h59ktooz3fc.dll
2009-06-13 03:40 16,069 a------- c:\windows\3ac6spywar950z1.exe
2009-06-13 03:38 1,262,080 a------- c:\windows\system32\setup2.exe
2009-05-12 13:31 12,297 a------- c:\windows\1f5bspyw9re1829z.exe
2009-05-11 09:57 5,398 a------- c:\windows\z0ath9e5529.dll
2009-05-10 18:09 12,218 a------- c:\windows\613zs5arse398.dll
2009-05-07 00:05 9,491 a------- c:\windows\system32\4e525ownloadez949.dll
2009-05-06 23:14 7,452 a------- c:\windows\55348ha9ktool64z.exe
2009-05-06 17:40 9,266 a------- c:\windows\21499not-a-virus29z5.dll
2009-05-04 13:30 6,772 a------- c:\windows\system32\25azadd9are1123.dll
2009-05-02 02:37 6,543 a------- c:\windows\699fthr9at518z5.bin
2009-05-01 09:55 10,216 a------- c:\windows\system32\2a49addwaze5089.dll
2009-04-27 05:49 18,314 a------- c:\windows\6109threat15850z.exe
2009-04-27 01:26 16,586 a------- c:\windows\2233s9arsez512.bin
2009-04-26 18:14 16,026 a------- c:\windows\cd5backdozr739.dll
2009-04-26 06:08 13,629 a------- c:\windows\system32\7334downzoad5r27369.exe
2009-04-24 15:47 8,411 a------- c:\windows\14109parse21z85.dll
2009-04-24 06:47 2,610 a------- c:\windows\z560n5t-9-virus76.dll
2009-04-23 11:40 5,558 a------- c:\windows\system32\15z97not-a-9irus25c.bin
2009-04-21 11:03 7,397 a------- c:\windows\4454vir1z09.exe
2009-04-18 22:51 14,724 a------- c:\windows\system32\29017vi5usz59.bin
2009-04-14 14:36 15,390 a------- c:\windows\system32\66z79hrea53569.dll
2009-04-12 23:32 9,982 a------- c:\windows\5b59addware150z.dll
2009-04-12 07:45 6,654 a------- c:\windows\system32\4az9sp5rse2621.dll
2009-04-08 01:06 5,455 a------- c:\windows\system32\6ff5bazkdoor579.bin
2009-04-07 09:56 3,604 a------- c:\windows\system32\5a0ethizf1924.dll
2009-03-28 15:50 14,991 a------- c:\windows\system32\4056addz9re552.exe
2009-03-28 13:40 2,620 a------- c:\windows\system32\189635acztoo959b.exe
2009-03-26 19:21 13,510 a------- c:\windows\system32\28z5pambo9357.dll
2009-03-25 20:30 3,302 a------- c:\windows\1918downloaderz569.dll
2009-03-25 06:58 12,106 a------- c:\windows\146499i5uz247.bin
2009-03-21 07:06 989,696 -------- c:\windows\system32\dllcache\kernel32.dll
2009-03-18 10:25 6,846 a------- c:\windows\2f99bazkdoo5779.dll
2008-12-01 00:47 168 a------- c:\docume~1\shahee~1.pou\applic~1\wklnhst.dat
2008-09-18 23:45 409,695 ac------ c:\program files\Uninstall Fun Web Products.dll
2008-04-14 09:30 20 -c--h--- c:\docume~1\alluse~1\applic~1\PKP_DLec.DAT
============= FINISH: 18:10:35.67 ===============
shaheen
Posts Posts : 33
Post by Belahzur on 14th June 2009, 1:17 am
No blocker file, only the fake alert setup.exe file.
    "ares"=-
    "ares vista"=-
    "setup2.exe"=-
Then reboot.
Try running Hijack This after reboot.
Post by shaheen on 14th June 2009, 1:28 am
kk i did the fig.reg and selected yes, i rebooted my system, i tried to start Hijack but it woudn't load again
Still receiving fake alerts...unfortuantly
thanks for all this help
shaheen
Posts Posts : 33
Post by Belahzur on 14th June 2009, 1:30 am
  • Download combofix from here
  • See [You must be registered and logged in to see this link.] for how to disable your AV. (AVG8)
Post by shaheen on 14th June 2009, 1:36 am
i Dont know wut Anti-Virus system im using, i have norton but it isnt on, think i have to renew...all my spyware protection is close, i think it might be just the windows firewall preventing it?
shaheen
Posts Posts : 33
Post by shaheen on 14th June 2009, 2:10 am
Combo Fix Log
ComboFix 09-06-13.03 - Shaheen 06/13/2009 18:51.1 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1022.590 [GMT -7:00]
Running from: c:\documents and settings\Shaheen.POURFALLAH\Desktop\Combo-Fix.exe
AV: AVG Anti-Virus Free *On-access scanning disabled* (Outdated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
c:\program files\ecurit~1
c:\program files\Adware Professional\Adware Professional.exe
c:\program files\Adware Professional\noadware4_061309.na
c:\program files\Adware Professional\nutilities.dll
c:\program files\Adware Professional\unins000.dat
c:\program files\Adware Professional\unins000.exe
c:\program files\Adware Professional\UninstlDll.dll
c:\windows\105395iru9zf9.bin
c:\windows\10808wormz599.cpl
c:\windows\1083thre5tz3965.ocx
c:\windows\10998hazk5ool9c.bin
c:\windows\110asparz5793.cpl
c:\windows\11493hack9o5l6za.exe
c:\windows\11579h9cktzol587.cpl
c:\windows\117db5ckd9zr2261.ocx
c:\windows\1189th9eaz14450.bin
c:\windows\1248spz9se2549.exe
c:\windows\125ath9efz357.dll
c:\windows\12bes9azse2395.ocx
c:\windows\134zthi9f735.cpl
c:\windows\137215ackzool4f99.dll
c:\windows\1394795za5.ocx
c:\windows\13c5s9arze1106.ocx
c:\windows\1429h5zf810.bin
c:\windows\14454troj139z.exe
c:\windows\146615p9mbotz9e.dll
c:\windows\1508359rm6zd.dll
c:\windows\15359hacztool59b.dll
c:\windows\155249ormz09.dll
c:\windows\15756ha5ktoo9zd7.bin
c:\windows\15z99worm659.cpl
c:\windows\16326hac9zool5f7.dll
c:\windows\16855h5cktoolz1e9.cpl
c:\windows\1695sp59bot449z.dll
c:\windows\1729zv5ru96bd.exe
c:\windows\1759baczdoor2130.ocx
c:\windows\17994zot-a-9i5us149.cpl
c:\windows\1800downl9ad5z1465.exe
c:\windows\18987spzmb592f5.cpl
c:\windows\19143vzrus4225.bin
c:\windows\19273zirus655.dll
c:\windows\19493woz522a9.exe
c:\windows\1951vi5us2z2.exe
c:\windows\1953zspambot235.bin
c:\windows\196z3v9rus755.exe
c:\windows\19790ha9ktzol395.exe
c:\windows\19988tzo5440.ocx
c:\windows\19a45ir2552z.ocx
c:\windows\19b6ba5zdoor595.exe
c:\windows\19e9spar5z1559.exe
c:\windows\19fdspyw5ze9069.dll
c:\windows\1a39back5ozr515.exe
c:\windows\1bczdo9nloa5er2884.bin
c:\windows\1ce9spywarz5349.cpl
c:\windows\1dd7do5nloaze925.ocx
c:\windows\1ezaback5oor9344.ocx
c:\windows\1fc5sp9wa5e307z.ocx
c:\windows\1z294hackto9l6d5.cpl
c:\windows\1z4975irus759.ocx
c:\windows\20096spamb5tz79.cpl
c:\windows\201caddzare1959.exe
c:\windows\2045addwaze3239.cpl
c:\windows\205bsparse59z5.cpl
c:\windows\212499r5z71e.cpl
c:\windows\21262z952af.cpl
c:\windows\2167zha9kt5ol7bc.dll
c:\windows\232359zoj85.cpl
c:\windows\23493hacktooz2cc5.dll
c:\windows\23538wor97zb.cpl
c:\windows\23552no5z9-virus52e.cpl
c:\windows\23719not5azvirus71f9.dll
c:\windows\23952ha5ktool6z99.cpl
c:\windows\2395backd9z53006.exe
c:\windows\23c5szy5are290.exe
c:\windows\2429z95y1df.ocx
c:\windows\24334sp9585z.ocx
c:\windows\24395szy5a2.ocx
c:\windows\24425wozm7ad9.cpl
c:\windows\24470noz5a-v9rus459.dll
c:\windows\245es9arze2122.dll
c:\windows\24661sp5559z.bin
c:\windows\2519zviru97e3.dll
c:\windows\25330szambot499.bin
c:\windows\25519trojz95.cpl
c:\windows\25564vzrus7cc9.ocx
c:\windows\25585spamzo5942.cpl
c:\windows\25913not-a-viru9z52.ocx
c:\windows\25z9vir2057.ocx
c:\windows\26055not-a-virusz69.exe
c:\windows\26195s5ambzt541.cpl
c:\windows\262eth5e9t83z8.bin
c:\windows\26585sp9647z.cpl
c:\windows\2704down9oa5er77z.cpl
c:\windows\2739zh5cktool4bd.cpl
c:\windows\27757spazb9549d.dll
c:\windows\2779spa5ze1737.dll
c:\windows\27943spambot5bz5.ocx
c:\windows\27c8zownload9r2455.exe
c:\windows\281zthie91555.exe
c:\windows\28634trzj1195.ocx
c:\windows\28845ddwzr92820.bin
c:\windows\29165not9a-virus5ebz.cpl
c:\windows\29259virzs2ad.bin
c:\windows\29289sp57z0.ocx
c:\windows\29493not-9zvirus653.ocx
c:\windows\29545not-a9vir5z592.cpl
c:\windows\29575sp95z9.cpl
c:\windows\29699sp53z9.dll
c:\windows\29845szambot537.bin
c:\windows\29957spa5bot4a8z.ocx
c:\windows\29997viru5z.bin
c:\windows\29zdd5wnlo9der3194.cpl
c:\windows\2bffdowzlo9der18175.bin
c:\windows\2c23backd5o9280z.bin
c:\windows\2c25p9wzre514.exe
c:\windows\2cc49hreat16566z.exe
c:\windows\2e9dz5r119.bin
c:\windows\2z521wor5953.bin
c:\windows\2z6bste5l19969.bin
c:\windows\2z756s5am9ot6f9.cpl
c:\windows\2z795ddware2964.cpl
c:\windows\2zd8d9wnloade52516.dll
c:\windows\30294not-a-virus5z9.cpl
c:\windows\305795dware997z.bin
c:\windows\305z8spamb59668.bin
c:\windows\306eaz95are1420.cpl
c:\windows\30859aczdoor2068.cpl
c:\windows\30949sp94zf5.ocx
c:\windows\3094st5al611z.bin
c:\windows\311945zckto9l253.exe
c:\windows\31194virusz59.exe
c:\windows\31z23s9a5bot75c.ocx
c:\windows\32025s9amzot2da.exe
c:\windows\32096nzt-5-virus7d6.exe
c:\windows\3238spa5bzt190.exe
c:\windows\32522wzr9495.exe
c:\windows\32939wor515fz.exe
c:\windows\34b9viz5757.dll
c:\windows\35119zr2939.cpl
c:\windows\351fbaz5door2793.ocx
c:\windows\3556szeal2967.bin
c:\windows\35zdvir924.ocx
c:\windows\362fspazse5919.cpl
c:\windows\36b0ba9zd5or154.bin
c:\windows\38685iz9s163.dll
c:\windows\3896wormz57.cpl
c:\windows\389bt5reat2z300.ocx
c:\windows\3952backzoor153.bin
c:\windows\395b5aczdoor2724.bin
c:\windows\3965zspy65b.cpl
c:\windows\39769zr2564.cpl
c:\windows\3ac8spar9e15z9.ocx
c:\windows\3d5a9ownlo5der243z.ocx
c:\windows\3z29download5r2699.cpl
c:\windows\3z35sp59are625.dll
shaheen
Posts Posts : 33
Combo Fix log cont..
c:\windows\3za3vi54379.cpl
c:\windows\3zb0s5ywar91310.ocx
c:\windows\40195hreat974z.exe
c:\windows\4093a9dwzre5486.bin
c:\windows\4141zhr5at148139.ocx
c:\windows\414daddw95e3072z.dll
c:\windows\41eczteal1959.bin
c:\windows\42zs9ywar51514.ocx
c:\windows\4395s5ezl1908.cpl
c:\windows\4495sparse1351z.bin
c:\windows\451zs9eal2478.cpl
c:\windows\452fszeal2912.ocx
c:\windows\458zstea91138.cpl
c:\windows\45d9vir135z9.bin
c:\windows\45dbaddwaze5829.dll
c:\windows\4719az5war92081.cpl
c:\windows\4775sparze8499.cpl
c:\windows\4819baczdoor657.cpl
c:\windows\4852h9cktool28z.bin
c:\windows\495csparsz902.bin
c:\windows\495d9tealz232.ocx
c:\windows\49z7stea5399.exe
c:\windows\4a95downloadez5494.bin
c:\windows\4ab1add5ar92z.dll
c:\windows\4adddownloazer9458.ocx
c:\windows\4b5a9pywzre23675.bin
c:\windows\4bc3thzeat532939.dll
c:\windows\4e95ste5l293z.cpl
c:\windows\4edca5dwar967z.ocx
c:\windows\4f49spyza5e2053.ocx
c:\windows\4fa5backdzo92075.bin
c:\windows\4z9steal3955.ocx
c:\windows\5010zvi9us5b8.ocx
c:\windows\50fcbackd9or315z.cpl
c:\windows\51eetz9eat20257.bin
c:\windows\51zebackdoor5189.bin
c:\windows\52509zirus185.exe
c:\windows\5256zsp948.ocx
c:\windows\52f5z9r817.exe
c:\windows\5437t9reat2528z5.dll
c:\windows\54593noz-a-virus293.ocx
c:\windows\5476thiz9568.ocx
c:\windows\551e5ackdoo91z91.dll
c:\windows\55440z9y7e8.dll
c:\windows\5567sp9654z.cpl
c:\windows\558639orm77z.ocx
c:\windows\5591spywzre2369.dll
c:\windows\55992spy5fdz.ocx
c:\windows\5614sp9w5rz603.cpl
c:\windows\5630s9yzc.ocx
c:\windows\56979spy2dz9.dll
c:\windows\56z5thie92771.exe
c:\windows\5715zir8689.dll
c:\windows\5788st9al2562z.cpl
c:\windows\58495zwn9oader86.bin
c:\windows\587zs5yw9re2567.dll
c:\windows\59109ownloadzr502.bin
c:\windows\5925vi5110z.ocx
c:\windows\596fviz594.cpl
c:\windows\596z0not-a-virusdc9.cpl
c:\windows\599dspa5se2259z.cpl
c:\windows\59zad9ware892.ocx
c:\windows\5a6dzpywar9514.cpl
c:\windows\5b07zownloader91255.dll
c:\windows\5b0ds9arse2683z.exe
c:\windows\5c6spy9are2740z.dll
c:\windows\5c8zs9arse1135.dll
c:\windows\5d0f5iz25389.bin
c:\windows\5e94thief555z.dll
c:\windows\5e99zddware3034.ocx
c:\windows\5eae5i91z8.cpl
c:\windows\5f51vzr9573.cpl
c:\windows\5fbaspz5are14949.cpl
c:\windows\5z094s9ambot5b0.ocx
c:\windows\5z395hacktool982.ocx
c:\windows\5zecs9yware10345.ocx
c:\windows\5zf5threat131199.bin
c:\windows\619abac9doo527z5.exe
c:\windows\6215s9eal302z.cpl
c:\windows\62zdownl5ader14609.ocx
c:\windows\639azhi5f1916.cpl
c:\windows\63b6zi59324.cpl
c:\windows\63z3t95j171.bin
c:\windows\6491bzckdo5r2964.exe
c:\windows\64dasp9rs59z8.dll
c:\windows\6578dzw9loader1350.bin
c:\windows\659threaz17443.bin
c:\windows\6608zpa9b5t4e.dll
c:\windows\669cd95zloader2989.exe
c:\windows\678zsteal956.ocx
c:\windows\6796t5reatz0449.bin
c:\windows\692ds9eal5z12.cpl
c:\windows\69azste5l1571.ocx
c:\windows\6bb95ir38z.cpl
c:\windows\6c6zddw95e49.dll
c:\windows\6z42wo9m15b.exe
c:\windows\6zbcdownloader5794.dll
c:\windows\6ze6a5dware3902.dll
c:\windows\707bstz5l1199.dll
c:\windows\72e1bazkdoor7549.dll
c:\windows\72no9-a-zir5s55a.cpl
c:\windows\72zd9hreat29545.ocx
c:\windows\758ztr9524.cpl
c:\windows\75e9spywzre2217.exe
c:\windows\7847t9rea58048z.bin
c:\windows\7930spamb5tza1.dll
c:\windows\7936d5wnl9zder1305.dll
c:\windows\7a5et9iefz703.bin
c:\windows\7b395ddwarz2620.cpl
c:\windows\7b7zpywa952760.dll
c:\windows\7c98th5zat7897.exe
c:\windows\7e65thzef9735.dll
c:\windows\7ebfspa9sz2540.bin
c:\windows\7f89s9ywzre2154.ocx
c:\windows\7z579hief16505.ocx
c:\windows\8348t59z33d.cpl
c:\windows\8359tz9j35e.exe
c:\windows\83z99roj1a65.dll
c:\windows\84bv95z714.exe
c:\windows\85z9troj92.cpl
c:\windows\90520spyzc5.exe
c:\windows\91f2threa55z19.cpl
c:\windows\92842trzj35e.ocx
c:\windows\929asparze30985.dll
c:\windows\9355wzrm5b29.cpl
c:\windows\9376thizf525.exe
c:\windows\94085wo5mzdf.exe
c:\windows\94557hacztool530.ocx
c:\windows\951fszarse2484.bin
c:\windows\958thizf1425.dll
c:\windows\989zwo5m469.cpl
c:\windows\99dthrez518988.ocx
c:\windows\9a69z5wnloader2185.ocx
c:\windows\9ae7vi5z950.ocx
c:\windows\9d2zsteal5966.exe
c:\windows\9eb5threat11z79.cpl
c:\windows\9ez0sp5rse1552.bin
c:\windows\9fe9spa5ze1281.cpl
c:\windows\ab8zownl5ad9r1994.cpl
c:\windows\bd5v9rz552.dll
c:\windows\bef9pzw5re2009.dll
c:\windows\c9zs5yware1289.exe
c:\windows\d32s9arsz3055.dll
c:\windows\e56adzware1986.cpl
c:\windows\kb913800.exe
c:\windows\system32\10z905irus2a9.ocx
c:\windows\system32\1108spyw9rz2590.bin
c:\windows\system32\11093zp5mbot2d4.dll
c:\windows\system32\112159zambot725.ocx
c:\windows\system32\11404wo5m90z.dll
c:\windows\system32\11z39tr5j96.dll
c:\windows\system32\12551spz4a9.bin
c:\windows\system32\131695ormcz.exe
c:\windows\system32\132d9par5z3272.exe
c:\windows\system32\133z9hack5ool43d.cpl
c:\windows\system32\13993zirus511.dll
c:\windows\system32\140bsp5war9z641.cpl
c:\windows\system32\14594sp57z1.ocx
c:\windows\system32\15051spz9botec.ocx
c:\windows\system32\15293zot-a-9irus5c3.exe
c:\windows\system32\1530hackzool956.exe
c:\windows\system32\15359hacztoo5e2.bin
c:\windows\system32\153z25r9j299.dll
c:\windows\system32\1552szyware9048.bin
c:\windows\system32\1559threat2z216.ocx
c:\windows\system32\1564sp97z4.ocx
c:\windows\system32\157359ot-a-ziru54cf.cpl
c:\windows\system32\15863spamboz569.ocx
c:\windows\system32\1592addwarz3270.ocx
c:\windows\system32\15933virus514z.ocx
c:\windows\system32\15957spamboz378.bin
c:\windows\system32\15z529py295.exe
c:\windows\system32\1631zp5rse9740.exe
c:\windows\system32\164bvirz59.exe
c:\windows\system32\16591spyz6d.cpl
c:\windows\system32\16966t5o91bz.bin
c:\windows\system32\17256h5ck9ool2z6.bin
c:\windows\system32\18389trz598c.ocx
c:\windows\system32\18927t95j6z1.cpl
c:\windows\system32\19197s5y71az.exe
c:\windows\system32\194789aczto5l1b6.bin
c:\windows\system32\19549hacktool715z.bin
c:\windows\system32\1956downloader129z.exe
c:\windows\system32\19806zroj5e3.bin
c:\windows\system32\1adbbaz9door26925.bin
c:\windows\system32\1ae1b5ck9oor3125z.bin
c:\windows\system32\1b37dow9loaze52656.cpl
c:\windows\system32\1c21zownload5r2779.bin
c:\windows\system32\1c5zthreat9942.dll
c:\windows\system32\1d5adown59azer525.exe
c:\windows\system32\1d7f5ac9zoor2360.ocx
c:\windows\system32\1de1spyw9re85z5.dll
c:\windows\system32\1f85doznlo5de9441.ocx
c:\windows\system32\1z349virus55c9.ocx
c:\windows\system32\1z8125o9m5da.dll
c:\windows\system32\1z95add9a5e1556.dll
c:\windows\system32\20420v5rusz269.bin
c:\windows\system32\20520no5-a-vizus198.exe
c:\windows\system32\205abackdzo92123.bin
c:\windows\system32\207zro5199.exe
c:\windows\system32\2095tro5z5.cpl
c:\windows\system32\20979not-a-zirus6925.exe
c:\windows\system32\20z92wor52c4.cpl
c:\windows\system32\215215z94b9.ocx
c:\windows\system32\22197virzs595.ocx
shaheen
Posts Posts : 33
Post by shaheen on 14th June 2009, 2:11 am
Combo Fix Log cont....
c:\windows\system32\2269z5rse2381.exe
c:\windows\system32\229z9tro5203.dll
c:\windows\system32\22e9t5i9f1z69.cpl
c:\windows\system32\22eeth95atz9775.cpl
c:\windows\system32\23099not-a-zirus553.ocx
c:\windows\system32\23197troz2895.ocx
c:\windows\system32\23288n9t-azv5rus7e7.cpl
c:\windows\system32\233cd5wn9oaderz7.exe
c:\windows\system32\23539t9zj623.dll
c:\windows\system32\239285pzmbota49.ocx
c:\windows\system32\24205wor9z28.dll
c:\windows\system32\24471notza-virus90a5.ocx
c:\windows\system32\2469s5z598.exe
c:\windows\system32\24798nzt-a-virus5975.ocx
c:\windows\system32\24896not-5zvirus493.dll
c:\windows\system32\24957zirus978.cpl
c:\windows\system32\24z98v5ru95d0.ocx
c:\windows\system32\2552stzal2569.dll
c:\windows\system32\2552zhie93156.bin
c:\windows\system32\25534sp51z9.ocx
c:\windows\system32\2556zhacktool98a.ocx
c:\windows\system32\25745virus93z.ocx
c:\windows\system32\25793spamb5t629z.cpl
c:\windows\system32\2587dzwnload9r3031.bin
c:\windows\system32\25898spamzot5895.ocx
c:\windows\system32\25955spy1az.bin
c:\windows\system32\25b1sp9warez450.cpl
c:\windows\system32\26022viruz91a5.exe
c:\windows\system32\26226spa9bot54z.dll
c:\windows\system32\275559irus5z5.dll
c:\windows\system32\2783znot-a-v9r5s434.bin
c:\windows\system32\2796t5iefz998.dll
c:\windows\system32\28785not-5-vzrus391.exe
c:\windows\system32\2891s5arze356.ocx
c:\windows\system32\2902thre5t22z46.dll
c:\windows\system32\29156troj7zf.bin
c:\windows\system32\29157spz2c9.ocx
c:\windows\system32\29428troj4b5z.bin
c:\windows\system32\29504ha9kzool1b5.bin
c:\windows\system32\2985st95l108z.bin
c:\windows\system32\29901spy5z5.ocx
c:\windows\system32\29dzsteal2954.exe
c:\windows\system32\2a759pzrse165.exe
c:\windows\system32\2e05bazkdo5r2209.ocx
c:\windows\system32\2f09zown5oader559.dll
c:\windows\system32\2f69dow5loadez1954.exe
c:\windows\system32\2fbzdo9nloader5999.cpl
c:\windows\system32\2fecspywa5ez1689.bin
c:\windows\system32\2z16wo953a4.dll
c:\windows\system32\2z5519roj169.bin
c:\windows\system32\2z55thie93077.bin
c:\windows\system32\2z580tro95af.cpl
c:\windows\system32\2zfstea51928.bin
c:\windows\system32\30959trojz9c.dll
c:\windows\system32\30969hac5tool5za.ocx
c:\windows\system32\30z23viru53b9.bin
c:\windows\system32\31196zot-a-vi5us379.bin
c:\windows\system32\31556szy599.cpl
c:\windows\system32\31z41not-a9v5rus7f6.cpl
c:\windows\system32\3212zspy5c39.exe
c:\windows\system32\322595ruz3f2.ocx
c:\windows\system32\3249zwo9m4c55.dll
c:\windows\system32\327159zoj9d.cpl
c:\windows\system32\32924wor51az.ocx
c:\windows\system32\33155ac9tozl35b.ocx
c:\windows\system32\332dsp5rz91946.cpl
c:\windows\system32\3395parse2925z.cpl
c:\windows\system32\33zb9ownl5ader2774.ocx
c:\windows\system32\3469hac5tool55z.exe
c:\windows\system32\3592spzmbot4bd.ocx
c:\windows\system32\35945acktzol97.exe
c:\windows\system32\3595spamboz1a8.cpl
c:\windows\system32\359cth5ef2z389.dll
c:\windows\system32\35c95ackzoor930.exe
c:\windows\system32\35z84spam9ot5bb.ocx
c:\windows\system32\367t95z5d0.bin
c:\windows\system32\3708b5ckdozr9009.bin
c:\windows\system32\37535ack9ooz34e.ocx
c:\windows\system32\375dspywarz3905.bin
c:\windows\system32\37zfvir51269.cpl
c:\windows\system32\38509parze2526.ocx
c:\windows\system32\389fd5wnloazer819.dll
c:\windows\system32\390not-a-5irus3ze.bin
c:\windows\system32\39866hacktoo56fez.cpl
c:\windows\system32\39aa9py5arz1774.exe
c:\windows\system32\39dfaddwar53z39.dll
c:\windows\system32\3ad2backzoor29025.exe
c:\windows\system32\3bf5thz9a53907.exe
c:\windows\system32\3bz6s9a5se1444.exe
c:\windows\system32\3ec8szeal4159.ocx
c:\windows\system32\3fz9steal14045.bin
c:\windows\system32\3z9dvi52834.dll
c:\windows\system32\4006do5nload9z1498.exe
c:\windows\system32\41fas9za52628.exe
c:\windows\system32\4222hazkto5l595.ocx
c:\windows\system32\4534z9dware1581.dll
c:\windows\system32\454bsp5warez997.cpl
c:\windows\system32\470zad59are2304.cpl
c:\windows\system32\477zdow9loader2175.exe
c:\windows\system32\47885iruz7de9.exe
c:\windows\system32\479d5ddzar92531.exe
c:\windows\system32\4838spzrse3905.bin
c:\windows\system32\4924szy55b9.ocx
c:\windows\system32\49az5ddware2747.ocx
c:\windows\system32\4ac75ze9l235.cpl
c:\windows\system32\4b8ct9ie511z3.bin
c:\windows\system32\4c2cspyzare55669.cpl
c:\windows\system32\4d95bzck5oor1560.cpl
c:\windows\system32\4dadadd5ar9327z.cpl
c:\windows\system32\4e5spyware188z9.bin
c:\windows\system32\4ebb95rz933.exe
c:\windows\system32\4f909ownlozd5r1518.exe
c:\windows\system32\4fd9sze5l16929.cpl
c:\windows\system32\4fe59zreat25928.exe
c:\windows\system32\4z07addwa59687.cpl
c:\windows\system32\4z20ha9ktoo5464.cpl
c:\windows\system32\4z2eaddw9re20025.bin
c:\windows\system32\5051sp9rse737z.ocx
c:\windows\system32\50b9z5r362.bin
c:\windows\system32\5101troz379.cpl
c:\windows\system32\5105spy59z.cpl
c:\windows\system32\512669ormdz.cpl
c:\windows\system32\513csp9warez165.ocx
c:\windows\system32\51f3ba9kdooz15305.bin
c:\windows\system32\520etzief599.ocx
c:\windows\system32\5247hzck5ool809.bin
c:\windows\system32\524tz5ef1396.dll
c:\windows\system32\529z5virus3af.ocx
c:\windows\system32\53270spa9bzt205.bin
c:\windows\system32\53440spa9boz3cd.exe
c:\windows\system32\5364thrzat93789.exe
c:\windows\system32\53a4bac95ozr1108.cpl
c:\windows\system32\5422zddwar91579.dll
c:\windows\system32\5459s9arse1z35.cpl
c:\windows\system32\548fspa9se266z.ocx
c:\windows\system32\5530sparse392z.dll
c:\windows\system32\5534addw95e37z.cpl
c:\windows\system32\5573baczdoor2952.ocx
c:\windows\system32\55eesparsez929.bin
c:\windows\system32\55z0ad5wa9e2394.bin
c:\windows\system32\55z2troj2509.dll
c:\windows\system32\55z59rm127.bin
c:\windows\system32\5654thiefz7059.cpl
c:\windows\system32\5676wo9z76.cpl
c:\windows\system32\5692s9z207.exe
c:\windows\system32\57519troz1ce.exe
c:\windows\system32\5752tzoj4dc9.exe
c:\windows\system32\57eabackdo9r35z9.cpl
c:\windows\system32\57fevzr9066.bin
c:\windows\system32\5891backzoor555.cpl
c:\windows\system32\59010tzojca.ocx
c:\windows\system32\5915spyz7a9.exe
c:\windows\system32\5920zhie52873.cpl
c:\windows\system32\593es95ware3z6.dll
c:\windows\system32\5972hacztool49f.exe
c:\windows\system32\5990vir23z6.dll
c:\windows\system32\59d4a9dware4z0.ocx
c:\windows\system32\59z1sparse3259.dll
c:\windows\system32\59z3t9reat1501.cpl
c:\windows\system32\59z64virus7b.ocx
c:\windows\system32\59z70virus3ce.cpl
c:\windows\system32\59z85ownloader1242.cpl
c:\windows\system32\5a4zth9ef1810.ocx
c:\windows\system32\5a8abackdzo9578.bin
c:\windows\system32\5ab9sparse1z2.cpl
c:\windows\system32\5b2est9alz192.cpl
c:\windows\system32\5b9zba5kdoor661.exe
c:\windows\system32\5b9zspyware1496.bin
c:\windows\system32\5baat5ie9z997.exe
c:\windows\system32\5bc9teaz5062.cpl
c:\windows\system32\5c06thze95611.cpl
c:\windows\system32\5d1ed5wnl9ader18z3.dll
c:\windows\system32\5d45vir969z.bin
c:\windows\system32\5dc99pywarez5805.cpl
c:\windows\system32\5e7cthre9516082z.bin
c:\windows\system32\5ef0s9ar5ez082.ocx
c:\windows\system32\5f54b5ck9oorz258.ocx
c:\windows\system32\5z5dsteal9045.dll
c:\windows\system32\5za3spa9se3218.dll
c:\windows\system32\5zd0s9ea52093.cpl
c:\windows\system32\61569irus146z.cpl
c:\windows\system32\621ct5iez17639.cpl
c:\windows\system32\62715ddware9z89.ocx
c:\windows\system32\6334wo5m9f8z.ocx
c:\windows\system32\6390dowzloader5094.dll
c:\windows\system32\645z5roj9b.bin
c:\windows\system32\6482ziru9895.bin
c:\windows\system32\6497a95ware1z95.ocx
c:\windows\system32\6556s9arze2283.exe
c:\windows\system32\659znot-a-virus9865.dll
c:\windows\system32\65d1spywaze9824.exe
c:\windows\system32\6815thizf1965.dll
c:\windows\system32\69375ackdozr2378.dll
c:\windows\system32\6951not-z-5irus1aa.dll
c:\windows\system32\6965v9z3136.ocx
c:\windows\system32\6d95th9ez269.ocx
c:\windows\system32\6eebba9kdozr3145.dll
c:\windows\system32\709759zj7e7.dll
c:\windows\system32\710zsp96b05.exe
c:\windows\system32\72f49hie52z91.exe
c:\windows\system32\73599ackdozr1555.exe
c:\windows\system32\749csteal2752z.dll
c:\windows\system32\74do95lzader814.cpl
c:\windows\system32\7594downlo9zer1593.bin
c:\windows\system32\76z1spy395.ocx
c:\windows\system32\7724not-a-virzs3995.cpl
c:\windows\system32\7739viz9s454.bin
c:\windows\system32\77za5ddware619.bin
c:\windows\system32\7930tzi951732.dll
c:\windows\system32\7969t5reat14z46.dll
c:\windows\system32\79f7spzrse5937.cpl
c:\windows\system32\7a9caddwar9z635.dll
c:\windows\system32\7b74bz5kdoor898.bin
c:\windows\system32\7b7cs9arsez925.bin
c:\windows\system32\7d9bthz9f5904.exe
c:\windows\system32\7f9caddwarz2859.bin
c:\windows\system32\8667worm5z19.dll
c:\windows\system32\8z25i9697.exe
c:\windows\system32\9008z5y44e.ocx
c:\windows\system32\906cv5r2z44.ocx
c:\windows\system32\90919spyzb5.bin
c:\windows\system32\913925azktool571.bin
c:\windows\system32\91970wor5548z.exe
c:\windows\system32\91985ir22z0.bin
c:\windows\system32\92344spamboz5a15.bin
c:\windows\system32\9245teal1z789.ocx
c:\windows\system32\9248tzo5315.bin
c:\windows\system32\92617vzrus50d.dll
c:\windows\system32\9281thizf5859.ocx
c:\windows\system32\9295noz-a-virus452.bin
c:\windows\system32\9465spzware2972.exe
c:\windows\system32\95036spambotz75.bin
c:\windows\system32\956fthzef11495.exe
c:\windows\system32\9594stzal1312.ocx
c:\windows\system32\95a5spzware243.exe
c:\windows\system32\95z4sparse3507.cpl
c:\windows\system32\9605iruszbd.ocx
c:\windows\system32\961vi5uz4499.dll
c:\windows\system32\9671h9cktz5l1c8.dll
c:\windows\system32\96aspywa5e690z.dll
c:\windows\system32\975fdownlozder608.exe
c:\windows\system32\975zspy5are513.exe
c:\windows\system32\97f4thzeat15170.ocx
c:\windows\system32\9935troj25bz.exe
c:\windows\system32\9954hackto9l5z5.cpl
c:\windows\system32\9959vir5s6z4.ocx
c:\windows\system32\99a4downloader555z.cpl
c:\windows\system32\99azv5r333.ocx
c:\windows\system32\9a61do5nloader255z.exe
c:\windows\system32\9b5addwaze1894.cpl
c:\windows\system32\9czddownlo5der869.bin
c:\windows\system32\9e8a5hzeat5260.cpl
c:\windows\system32\9zc7thief570.ocx
c:\windows\system32\a8e5i95z.dll
c:\windows\system32\af6bac5dzor2989.cpl
c:\windows\system32\bd1addwaze25189.cpl
c:\windows\system32\c59vir902z.bin
c:\windows\system32\drivers\MSIVXujnmhctvdlftiqmelxbwqpulvvjtmxel.sys
c:\windows\system32\ecazpa59e698.ocx
c:\windows\system32\fb29pyware30z5.bin
c:\windows\system32\fb7za9kd5or241.exe
c:\windows\system32\MSIVXcount
c:\windows\system32\MSIVXkmkvjimenrphyyosivrjbapaerlrdfay.dll
c:\windows\system32\MSIVXvypuhrgxoyobqnyjskdsxwntjxfujoym.dll
c:\windows\system32\z0706spa9bot758.bin
c:\windows\system32\z141995y332.bin
c:\windows\system32\z141spam5ot598.dll
c:\windows\system32\z16t59ef1950.exe
c:\windows\system32\z17ba5kdoor20589.bin
c:\windows\system32\z2c2ba5kdoor3981.ocx
c:\windows\system32\z3812no5-9-virus748.cpl
c:\windows\system32\z428hack5o9l8b.ocx
c:\windows\system32\z481s5ambot449.ocx
c:\windows\system32\z543vir8999.bin
c:\windows\system32\z549spy745.ocx
c:\windows\system32\z55addwar92255.ocx
c:\windows\system32\z5821spambot4389.exe
c:\windows\system32\z659teal31605.cpl
c:\windows\system32\z8259t9oj29d.ocx
c:\windows\system32\z988spyw5re502.cpl
c:\windows\system32\z996backdoor5073.cpl
c:\windows\system32\z9aeba5kdoor593.cpl
c:\windows\system32\z9f5thief2592.cpl
c:\windows\system32\za8thi9f952.cpl
c:\windows\system32\zfb5v9r5915.exe
c:\windows\Tasks\{5B57CF47-0BFA-43c6-ACF9-3B3653DCADBA}.job
c:\windows\z046sp5mbot5419.ocx
c:\windows\z097sp5rse3169.exe
c:\windows\z1e5t9reat54989.ocx
c:\windows\z2f5thief945.cpl
shaheen
Posts Posts : 33
Joined Joined : 2009-06-13
Points Points : 27377
Re: Help, done everything for winbluesoft
Post by shaheen on 14th June 2009, 2:12 am
c:\windows\z5972not5a-virus59c.cpl
c:\windows\z6245spambota59.cpl
c:\windows\z624wor950.dll
c:\windows\z6279not-a-vir5s696.exe
c:\windows\z638st9a569.exe
c:\windows\z6d8do9nlo5der3.dll
c:\windows\z759spars51410.ocx
c:\windows\z792vi9us755.ocx
c:\windows\z8565worm99.ocx
c:\windows\z92dspar5e18939.exe
c:\windows\z9811viru5619.ocx
c:\windows\zb9cthreat70245.ocx
c:\windows\zcd9backd5or9172.ocx
c:\windows\ze5b5py9are2645.bin
c:\windows\zf5bt9reat13846.exe
D:\Autorun.inf
D:\Desktop.ini
-------\Service_MSIVXserv.sys
((((((((((((((((((((((((( Files Created from 2009-05-14 to 2009-06-14 )))))))))))))))))))))))))))))))
2009-09-04 06:52 . 2009-09-04 06:52 10587 ----a-w- c:\windows\system32\51034szy9.bin
2009-06-13 23:31 . 2009-06-13 23:31 -------- d-----w- C:\!KillBox
2009-06-13 22:52 . 2009-06-13 22:52 -------- d-----w- c:\program files\Trend Micro
2009-06-13 21:16 . 2009-06-13 21:16 -------- d-----w- c:\program files\Enigma Software Group
2009-06-13 20:44 . 2008-12-11 15:38 159600 ----a-w- c:\windows\system32\drivers\pctgntdi.sys
2009-06-13 20:44 . 2009-04-03 18:18 130936 ----a-w- c:\windows\system32\drivers\PCTCore.sys
2009-06-13 20:44 . 2008-12-18 19:16 73840 ----a-w- c:\windows\system32\drivers\PCTAppEvent.sys
2009-06-13 20:44 . 2009-06-13 20:45 -------- d-----w- c:\program files\Common Files\PC Tools
2009-06-13 20:44 . 2008-12-10 18:36 64392 ----a-w- c:\windows\system32\drivers\pctplsg.sys
2009-06-13 20:44 . 2009-06-13 20:45 -------- d-----w- c:\program files\Spyware Doctor
2009-06-13 20:44 . 2009-06-13 20:44 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\PC Tools
2009-06-13 20:44 . 2009-06-13 20:44 -------- d-----w- c:\documents and settings\All Users\Application Data\PC Tools
2009-06-13 08:21 . 2009-06-13 08:21 -------- d-sh--w- c:\documents and settings\Tammie.POURFALLAH\PrivacIE
2009-06-13 08:21 . 2009-06-13 08:21 -------- d-sh--w- c:\documents and settings\Tammie.POURFALLAH\IETldCache
2009-06-13 03:34 . 2009-06-13 03:34 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Local Settings\Application Data\MicroVision Applications
2009-06-11 13:22 . 2009-06-11 13:22 -------- d-sh--w- c:\documents and settings\Shaheen.POURFALLAH\PrivacIE
2009-06-10 22:16 . 2009-06-10 22:16 -------- d-sh--w- c:\documents and settings\Shaheen.POURFALLAH\IETldCache
2009-06-10 21:29 . 2009-06-10 21:29 -------- d-sh--w- c:\windows\system32\config\systemprofile\IETldCache
2009-06-10 20:30 . 2009-06-10 20:33 -------- dc-h--w- c:\windows\ie8
2009-06-08 19:34 . 2009-06-08 19:34 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\Sonic
2009-06-08 19:34 . 2009-06-08 19:34 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\Leadertech
2009-06-08 18:54 . 2009-06-08 18:54 152576 ----a-w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\Sun\Java\jre1.6.0_13\lzma.dll
2009-05-27 00:43 . 2009-05-27 00:43 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\GARMIN
2009-05-27 00:42 . 2009-05-27 00:42 -------- d-----w- c:\program files\Garmin GPS Plugin
2009-05-26 23:09 . 2009-05-26 23:09 -------- d-----w- c:\program files\Ares Vista
2009-06-14 01:22 . 2009-01-11 02:04 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\mIRC
2009-06-14 00:34 . 2009-01-11 02:04 -------- d-----w- c:\program files\mIRC
2009-06-13 23:52 . 2007-04-10 02:42 -------- d-----w- c:\program files\Steam
2009-06-13 22:16 . 2005-10-19 23:34 -------- d-----w- c:\program files\GemMaster
2009-06-13 21:57 . 2006-12-23 18:24 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2009-06-13 19:54 . 2008-12-20 09:59 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\Skype
2009-06-13 10:59 . 2008-12-31 22:19 -------- d-----w- c:\documents and settings\All Users\Application Data\Google Updater
2009-06-13 08:56 . 2008-05-01 07:13 -------- d-----w- c:\documents and settings\Tammie.POURFALLAH\Application Data\Juniper Networks
2009-06-12 23:13 . 2008-12-20 10:01 -------- d-----w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\skypePM
2009-06-10 19:00 . 2008-05-02 01:33 -------- d-----w- c:\documents and settings\All Users\Application Data\avg8
2009-06-08 18:55 . 2005-10-19 23:40 -------- d-----w- c:\program files\Java
2009-05-27 00:42 . 2008-07-14 00:18 -------- d-----w- c:\program files\DIFX
2009-03-22 23:44 . 2009-03-22 23:44 51056 ----a-w- c:\documents and settings\HP_Administrator\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-03-22 23:23 . 2009-03-22 23:23 75048 ----a-w- c:\documents and settings\All Users\Application Data\Apple Computer\Installer Cache\iTunes 8.1.0.52\SetupAdmin.exe
2009-03-22 00:36 . 2009-03-22 00:36 503808 ----a-w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\Sun\Java\Deployment\cache\6.0\38\39ba6e6-582ddd6c-n\msvcp71.dll
2009-03-22 00:36 . 2009-03-22 00:36 499712 ----a-w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\Sun\Java\Deployment\cache\6.0\38\39ba6e6-582ddd6c-n\jmc.dll
2009-03-22 00:36 . 2009-03-22 00:36 348160 ----a-w- c:\documents and settings\Shaheen.POURFALLAH\Application Data\Sun\Java\Deployment\cache\6.0\38\39ba6e6-582ddd6c-n\msvcr71.dll
2009-03-17 12:29 . 2009-03-17 12:29 503808 ----a-w- c:\documents and settings\Bardia.POURFALLAH\Application Data\Sun\Java\Deployment\cache\6.0\38\39ba6e6-1d54f57b-n\msvcp71.dll
2009-03-17 12:29 . 2009-03-17 12:29 499712 ----a-w- c:\documents and settings\Bardia.POURFALLAH\Application Data\Sun\Java\Deployment\cache\6.0\38\39ba6e6-1d54f57b-n\jmc.dll
2009-03-17 12:29 . 2009-03-17 12:29 348160 ----a-w- c:\documents and settings\Bardia.POURFALLAH\Application Data\Sun\Java\Deployment\cache\6.0\38\39ba6e6-1d54f57b-n\msvcr71.dll
shaheen
Posts Posts : 33
Post by shaheen on 14th June 2009, 2:13 am
Combo Fix Log cont... Final part
"Aim6"="c:\program files\AIM6\aim6.exe" [2008-10-31 50480]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2008-12-31 39408]
"HPBootOp"="c:\program files\Hewlett-Packard\HP Boot Optimizer\HPBootOp.exe" [2005-02-26 245760]
"HPHUPD08"="c:\program files\HP\Digital Imaging\{33D6CC28-9F75-4d1b-A11D-98895B3A3729}\hphupd08.exe" [2005-06-02 49152]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2005-10-20 180269]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-10-15 39792]
"AppleSyncNotifier"="c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2009-03-06 177472]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-01-05 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-03-13 342312]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-03-09 148888]
"SpyHunter Security Suite"="c:\program files\Enigma Software Group\SpyHunter\SpyHunter3.exe" [2008-09-03 864256]
"AppInit_DLLs"=c:\windows\system32\avgrsstx.dll
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\aawservice]
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^ATI CATALYST System Tray.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\ATI CATALYST System Tray.lnk
backup=c:\windows\pss\ATI CATALYST System Tray.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Digital Imaging Monitor.lnk]
backup=c:\windows\pss\HP Digital Imaging Monitor.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HPAiODevice(hp officejet g series) - 2.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\HPAiODevice(hp officejet g series) - 2.lnk
backup=c:\windows\pss\HPAiODevice(hp officejet g series) - 2.lnkCommon Startup
"Viewpoint Manager Service"=2 (0x2)
"IDriverT"=3 (0x3)
"gusvc"=2 (0x2)
"AntiVirusDisableNotify"=dword:00000001
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpofxm08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hposfx08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqCopy.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpfccopy.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpzwiz01.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqPhUnl.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqDIA.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpoews01.exe"=
"c:\\Program Files\\Updates from HP\\9972322\\Program\\Updates from HP.exe"=
"c:\\Program Files\\Ares\\Ares.exe"=
"c:\\Program Files\\AVG\\AVG8\\avgupd.exe"=
"c:\\Program Files\\AVG\\AVG8\\avgemc.exe"=
"c:\\Program Files\\Steam\\steamapps\\atbs495\\counter-strike\\hl.exe"=
"c:\\WINDOWS\\system32\\dpvsetup.exe"=
"c:\\Program Files\\Ventrilo\\Ventrilo.exe"=
"c:\\Documents and Settings\\Tammie.POURFALLAH\\Application Data\\Juniper Networks\\Juniper Terminal Services Client\\dsTermServ.exe"=
"c:\\Program Files\\Microsoft Games\\Age of Empires III\\age3x.exe"=
"c:\\Program Files\\Microsoft Games\\Age of Empires III\\age3y.exe"=
"c:\\Program Files\\Ares Vista\\AresVista.exe"=
"c:\\Program Files\\mIRC\\mirc.exe"=
"c:\\Program Files\\Steam\\steamapps\\atbs495\\counter-strike source\\hl2.exe"=
"1723:TCP"= 1723:TCP:@xpsp2res.dll,-22015
"1701:UDP"= 1701:UDP:@xpsp2res.dll,-22016
"500:UDP"= 500:UDP:@xpsp2res.dll,-22017
R0 PCTCore;PCTools KDS;c:\windows\system32\drivers\PCTCore.sys [6/13/2009 1:44 PM 130936]
R1 AvgLdx86;AVG AVI Loader Driver x86;c:\windows\system32\drivers\avgldx86.sys [5/1/2008 6:33 PM 97928]
R2 avg8emc;AVG8 E-mail Scanner;c:\progra~1\AVG\AVG8\avgemc.exe [7/6/2008 9:23 PM 875288]
R2 avg8wd;AVG8 WatchDog;c:\progra~1\AVG\AVG8\avgwdsvc.exe [7/6/2008 9:23 PM 231704]
R2 AvgTdiX;AVG8 Network Redirector;c:\windows\system32\drivers\avgtdix.sys [5/1/2008 6:33 PM 76040]
R3 DAdderFltr;DeathAdder Mouse;c:\windows\system32\drivers\dadder.sys [7/13/2008 5:17 PM 22784]
S3 LachesisFltr;Lachesis Mouse Driver;c:\windows\system32\drivers\Lachesis.sys [7/22/2008 4:59 PM 12032]
S3 sdAuxService;PC Tools Auxiliary Service;c:\program files\Spyware Doctor\pctsAuxs.exe [6/13/2009 1:44 PM 348752]
S4 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\Viewpoint\Common\ViewpointService.exe [12/20/2008 3:16 AM 24652]
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\>{60B49E34-C7CC-11D0-8953-00A0C90347FF}]
"c:\windows\system32\rundll32.exe" "c:\windows\system32\iedkcs32.dll",BrandIEActiveSetup SIGNUP
2009-05-17 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 20:34]
2009-06-13 c:\windows\Tasks\Google Software Updater.job
- c:\program files\Google\Common\Google Updater\GoogleUpdaterService.exe [2008-12-31 16:40]
2009-06-14 c:\windows\Tasks\RegCure Program Check.job
- c:\program files\RegCure\RegCure.exe [2008-04-21 21:21]
2009-06-11 c:\windows\Tasks\RegCure.job
IE: &AIM Search - c:\program files\aol\aim toolbar 5.0\resources\en-US\local\search.html
IE: &AIM Toolbar Search - c:\documents and settings\All Users\Application Data\AIM Toolbar\ieToolbar\resources\en-US\local\search.html
IE: &Google Search - c:\program files\Google\GoogleToolbar1.dll/cmsearch.html
IE: Backward Links - c:\program files\Google\GoogleToolbar1.dll/cmbacklinks.html
IE: Cached Snapshot of Page - c:\program files\Google\GoogleToolbar1.dll/cmcache.html
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~4\OFFICE11\EXCEL.EXE/3000
IE: Similar Pages - c:\program files\Google\GoogleToolbar1.dll/cmsimilar.html
IE: Translate into English - c:\program files\Google\GoogleToolbar1.dll/cmtrans.html
FF - ProfilePath -
Rootkit scan 2009-06-13 19:06
- - - - - - - > 'winlogon.exe'(864)
Completion time: 2009-06-14 19:09
ComboFix-quarantined-files.txt 2009-06-14 02:09
Pre-Run: 215,159,259,136 bytes free
Post-Run: 217,214,717,952 bytes free
940 --- E O F --- 2009-06-10 20:33
shaheen
Posts Posts : 33
Post by Belahzur on 14th June 2009, 12:05 pm
Before we remove the leftovers, I want to get an uninstall list.
  • Open HijackThis.
Points Points : 245079
Post by shaheen on 14th June 2009, 4:02 pm
The uninstall list from Hijack
Ad-Aware 2007
Adobe AIR
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Media Player
Adobe Media Player
Adobe Reader 8.1.3
Advanced WindowsCare Personal
Adware Professional v5.0
Age of Empires III
Age of Empires III - The Asian Dynasties
Age of Empires III - The WarChiefs
AIM 6
Apple Mobile Device Support
Ares Vista 3.0.9.9002
ATI Catalyst Control Center
ATI Display Driver
Atomic Clock Sync
AVG Free 8.0
Barnyard Invasion from HP Media Center (remove only)
Bejeweled 2 Deluxe from HP Media Center (remove only)
Big Kahuna Reef from HP Media Center (remove only)
Blackhawk Striker 2 from HP Media Center (remove only)
Blasterball 2 from HP Media Center (remove only)
Blasterball 2 Holidays from HP Media Center (remove only)
Boggle Supreme from HP Media Center (remove only)
Bonjour
Bookworm Deluxe from HP Media Center (remove only)
Bounce Symphony from HP Media Center (remove only)
CCleaner (remove only)
CMN3
Counter-Strike: Source
Crystal Maze from HP Media Center (remove only)
Digby's Donuts from HP Media Center (remove only)
Download Updater (AOL LLC)
Easy Internet Sign-up
FATE Demo from HP Media Center (remove only)
ffdshow [rev 1928] [2008-04-10]
Flip Words from HP Media Center (remove only)
Garmin Communicator Plugin
Garmin USB Drivers
GemMaster Mystic
Google Earth
Google Updater
HijackThis 2.0.2
HP Boot Optimizer
HP Deskjet Printer Preload
HP DigitalMedia Archive
HP Game Console and games
HP Image Zone for Media Center PC
hp officejet g series - 2
HP Software Update
HP Tunes
HPTunesAddIn
Insaniquarium Deluxe from HP Media Center (remove only)
Intel(R) PRO Network Connections Drivers
IntelliMover Data Transfer Demo
InterVideo WinDVD Player
iTunes
J2SE Runtime Environment 5.0
Java(TM) 6 Update 13
Java(TM) 6 Update 5
Java(TM) 6 Update 7
Jewel Quest from HP Media Center (remove only)
Juniper Networks Network Connect 6.2.0
Mah Jong Quest from HP Media Center (remove only)
Microsoft .NET Framework 1.1
Microsoft Money 2005
Microsoft Office Standard Edition 2003
Microsoft Works
mIRC
MobileMe Control Panel
Mozilla Firefox (3.0.10)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
MSXML 6.0 Parser (KB933579)
muvee autoProducer 4.0
muvee autoProducer unPlugged 1.1 - HPD
Office 2003 Tour
Otto
PC-Doctor 5 for Windows
Polar Bowler from HP Media Center (remove only)
Polar Golfer from HP Media Center (remove only)
PS2
Puzzle Express from HP Media Center (remove only)
Python 2.2 pywin32 extensions (build 203)
Python 2.2.3
Quicken 2005
QuickTime
Razer DeathAdder(TM) Mouse
RealPlayer
RegCure 1.5.0.1
RegistryFix v6.1
Ricochet Lost Worlds from HP Media Center (remove only)
SCRABBLE Blast from HP Media Center (remove only)
SCRABBLE from HP Media Center (remove only)
SCRABBLE Rack Attack from HP Media Center (remove only)
Security Update for Windows Internet Explorer 8 (KB969897)
Shrek 2 Ogre Bowler from HP Media Center (remove only)
Skype™ 3.8
Slingo Deluxe from HP Media Center (remove only)
Slyder from HP Media Center (remove only)
Sonic Encoders
Sonic Express Labeler
Sonic MyDVD Plus
Sonic RecordNow Audio
Sonic RecordNow Copy
Sonic RecordNow Data
Sonic Update Manager
SpyHunter
Spyware Doctor 6.0
Steam
Super Granny from HP Media Center (remove only)
Swarm from HP Media Center (remove only)
Tradewinds from HP Media Center (remove only)
Updates from HP (remove only)
Ventrilo Client
Viewpoint Media Player
WildTangent Web Driver
Windows Driver Package - Cypress (CyUsb) USB
Windows Driver Package - Garmin (grmnusb) GARMIN Devices (03/08/2007 2.2.1.0)
Windows Driver Package - MOTOROLA (uisp) USB (09/08/2006 1.2.0.0)
Windows Driver Package - Razer (HidUsb) HIDClass (02/02/2007 1.0.5.0)
Windows Driver Package - Razer (HidUsb) HIDClass (05/10/2007 1.00)
Windows XP Service Pack 3
Yahoo! Messenger
shaheen
Posts Posts : 33
Post by Belahzur on 14th June 2009, 4:25 pm
    Java(TM) 6 Update 5
    Java(TM) 6 Update 7
File::
Folder::
C:\!KillBox
c:\Program Files\Ares
Registry::
"AntiVirusDisableNotify"=-
Post by shaheen on 14th June 2009, 4:53 pm
Alrigh i perform all things in that last msg you left me...still have the notes if you want
my internet explorer now though is telling me its running wit addons disbaled
shaheen
Posts Posts : 33
Post by shaheen on 14th June 2009, 5:05 pm
When i open up I.E it gives me a window staing this
[b]This is an add-on that can cause I.E to stop responding or crash
The safe search for I.E add-on vertion 8.0.0.152 published by AVG tech is not compatible w/ I.E 8
I can either check online for updates
or
i can always open I.E w/o this add-on ...
shaheen
Posts Posts : 33
Post by Origin on 14th June 2009, 5:09 pm
If the add on is not compatible with that version of IE then its is recommended that you remove it so it can prevent IE from crashing.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31493
Post by shaheen on 14th June 2009, 5:17 pm
kk ty
so belahzur, im i good wit everything? should i remove all the programs from my comp or?
shaheen
Posts Posts : 33
Post by Origin on 14th June 2009, 5:20 pm
Couple of things left to do,
Posts Posts : 2685
Post by shaheen on 14th June 2009, 9:44 pm
Update Quick scan MBAM log file
Malwarebytes' Anti-Malware 1.37
Database version: 2279
6/14/2009 2:44:04 PM
mbam-log-2009-06-14 (14-44-04).txt
Objects scanned: 165223
Time elapsed: 12 minute(s), 11 second(s)
Registry Keys Infected: 14
Folders Infected: 5
Files Infected: 9
HKEY_CLASSES_ROOT\Interface\{2e9937fc-cf2f-4f56-af54-5a6a3dd375cc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{cf54be1c-9359-4395-8533-1657cf209cfe} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{d518921a-4a03-425e-9873-b9a71756821e} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{59c7fc09-1c83-4648-b3e6-003d2bbc7481} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{68af847f-6e91-45dd-9b68-d6a12c30e5d7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{9170b96c-28d4-4626-8358-27e6caeef907} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{d1a71fa0-ff48-48dd-9b6d-7a13a3e42127} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{ddb1968e-ead6-40fd-8dae-ff14757f60c7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{f138d901-86f0-4383-99b6-9cdd406036da} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\WinBlueSoft (Rogue.WinBlue) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\RunDll32Policy\f3ScrCtr.dll (Adware.MyWay) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Fun Web Products (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\AdwareAlert (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Log (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Quarantine (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Registry Backups (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Settings (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\DataBaseNew.ref (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Log\log_2006_05_09_23_46_29.log (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Log\log_2006_05_09_23_46_30.log (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Settings\CustomScan.stg (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Settings\IgnoreList.stg (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Settings\ScanInfo.stg (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Settings\ScanResults.stg (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Settings\SelectedFolders.stg (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
c:\program files\adwarealert\Settings\Settings.stg (Rogue.AdwareAlert) -> Quarantined and deleted successfully.
shaheen
Posts Posts : 33
Post by shaheen on 15th June 2009, 12:21 am
so am i all set?
shaheen
Posts Posts : 33
Post by Belahzur on 15th June 2009, 12:23 am
I'd say so, MBAM only found a rogue scanner.
How's the machine running?
Post by shaheen on 15th June 2009, 2:38 am
Seems like its all running good.
Thanks for your help i coudn't find ny other thing to do to get that crap off my PC
All the programs i downloaded..is it safe just to uninstill/remove from the comp?
shaheen
Posts Posts : 33
Post by Belahzur on 15th June 2009, 1:53 pm
Yep. Smile
