System Security 2009 stops everything im doing and won't remove
Post by bobbby103 on Sat Jun 13, 2009 6:14 am
Hi I was burdened with this prgram "System Security 2009" and notice something funny with it so i tried removing it with add/remove programs, then after, i seen it was not gone i tried to restore my computer back to a earlier point but the restore wouldnt work. So I tried restarting my computer and then when it came back on nothing worked at all, I have tried downlaod the hijacks program and some other malware remover prgrams and they save onto the computer but wont open, and I get a message saying so and so file is infected and that it wont open. I use windows XP. So can u please help me remove this problem.
bobbby103
Posts Posts : 40
Joined Joined : 2009-06-13
Protection Protection : AVG 2013
Points Points : 27563
Re: System Security 2009 stops everything im doing and won't remove
Post by Belahzur on Sat Jun 13, 2009 1:23 pm
  3. Then look in the left hand bottom of the program and press "Registry"
  4. When the registry list opens, drag the line between the two windows so you can see which registry hive you need.
  5. Next, open the HKEY_LOCAL_MACHINE, and navigate to the following key:
  6. Now look in the right side pane for two run values that are just random numbers.
  7. Once you have found the value(s), right click it and press "Delete"
  8. Okay the prompt and close IceSword.
Reboot the machine.
Points Points : 245059
Post by bobbby103 on Sat Jun 13, 2009 5:45 pm
I tried downloading ice sword and it wont open, i manage to extract it to a folder on the desktop but that was it. After that it was blocked again, saying it was infected.
bobbby103
Posts Posts : 40
Post by Origin on Sat Jun 13, 2009 5:46 pm
What about HijackThis? Did you manage to run it?
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31473
Post by bobbby103 on Sat Jun 13, 2009 6:02 pm
tried doing hijackthis and nit wouldnt run either.
bobbby103
Posts Posts : 40
Post by Origin on Sat Jun 13, 2009 6:05 pm
Lets try to remove it in safe mode,
Can you do the following in Safe Mode with Networking, (as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode with Networking" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.) Once in the start up menu, select "Safe Mode with Networking", then do the following instructions:
  • See [You must be registered and logged in to see this link.] for how to disable your AV. (Mcafee)
Posts Posts : 2685
Post by bobbby103 on Sat Jun 13, 2009 6:52 pm
I'm doing that now, but i don't believe i have any anti virus programs on my computer, where it is old.
bobbby103
Posts Posts : 40
Post by Belahzur on Sat Jun 13, 2009 7:01 pm
Okay, just run Combofix as per Origins instructions anyway, skip the part about disabling the AV.
Post by bobbby103 on Sat Jun 13, 2009 7:04 pm
When i go to restart my computer and press F8 it brings to a boot menu with 4 options of network and a floppy drive and and 2 others that don't have anything to do with safe mode.
bobbby103
Posts Posts : 40
Post by bobbby103 on Sat Jun 13, 2009 7:07 pm
The options to be more precise, are to select a boot device, nothing with a safe mode option.
bobbby103
Posts Posts : 40
Post by Origin on Sat Jun 13, 2009 7:38 pm
What type of computer do you have? E.g Dell, Gateway, HP, etc..
Posts Posts : 2685
Post by bobbby103 on Sat Jun 13, 2009 8:04 pm
Nevermind i got it work and ran combo fix, i am gonna post the info up here in a second for you.
bobbby103
Posts Posts : 40
Post by bobbby103 on Sat Jun 13, 2009 8:45 pm
ComboFix 09-06-13.02 - Ryan Fowler 06/13/2009 17:30.1 - FAT32x86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.511.261 [GMT -3:00]
Running from: c:\documents and settings\Ryan Fowler\Desktop\Combo-Fix.exe
c:\restore\S-1-5-21-1482476501-1644491937-682003330-1013
c:\restore\S-1-5-21-1482476501-1644491937-682003330-1013\Desktop.ini
c:\restore\S-1-5-21-1482476501-1644491937-682003330-1013\ise32.exe
((((((((((((((((((((((((( Files Created from 2009-05-13 to 2009-06-13 )))))))))))))))))))))))))))))))
2009-06-13 19:30 . 2009-06-13 19:30 -------- d-s---w- c:\documents and settings\Administrator\UserData
2009-06-12 18:46 . 2009-06-12 18:46 -------- d-----w- c:\documents and settings\NetworkService\Local Settings\Application Data\Google
2009-06-11 22:13 . 2009-06-11 22:13 -------- d-----w- c:\documents and settings\LocalService\Local Settings\Application Data\Google
2009-06-11 22:11 . 2009-06-11 22:11 -------- d-----w- c:\documents and settings\All Users\Application Data\Google Updater
2009-06-11 22:11 . 2009-06-11 22:11 -------- d-----w- c:\program files\Google
2009-06-09 23:23 . 2009-06-09 23:23 152576 ----a-w- c:\documents and settings\Ryan Fowler\Application Data\Sun\Java\jre1.6.0_14\lzma.dll
2009-06-09 22:37 . 2009-06-09 22:37 -------- d-----w- c:\windows\Sun
2009-06-09 12:01 . 2009-06-09 12:01 -------- d-sh--w- C:\FOUND.001
2009-06-06 07:46 . 2009-06-06 07:46 3701856 ----a-w- c:\documents and settings\Ryan Fowler\Application Data\Blitware\DriverRobot\updates\8659126fd6ff4db73e76b5252352132c\DriverRobot_Setup.exe
2009-06-05 02:25 . 2009-06-05 02:31 5 ----a-w- c:\windows\sbacknt.bin
2009-06-05 02:24 . 2009-06-05 02:24 -------- d-----w- c:\documents and settings\Ryan Fowler\Application Data\vghd
2009-06-03 01:14 . 2009-06-03 01:14 -------- d-----w- c:\windows\system32\wbem\Repository
2009-06-02 22:27 . 2009-06-02 22:27 -------- d-----w- c:\documents and settings\All Users\AVP 2009
2009-05-27 01:12 . 2009-06-12 23:24 1744 ----a-w- c:\windows\system32\d3d9caps.dat
2009-05-27 01:09 . 2009-05-21 14:33 410984 ----a-w- c:\windows\system32\deploytk.dll
2009-05-27 01:06 . 2009-05-27 01:06 152576 ----a-w- c:\documents and settings\Ryan Fowler\Application Data\Sun\Java\jre1.6.0_13\lzma.dll
2009-05-27 00:27 . 2008-04-14 08:42 221184 ----a-w- c:\windows\system32\wmpns.dll
2009-05-27 00:17 . 2009-05-27 00:17 -------- d-----w- c:\program files\Java
2009-05-26 23:25 . 2009-05-26 23:25 -------- d-sh--r- C:\RESTORE
2009-05-26 00:55 . 2009-05-26 00:55 -------- d-----w- c:\program files\Windows Media Connect 2
2009-05-26 00:52 . 2009-05-26 00:52 -------- d-----w- c:\windows\system32\LogFiles
2009-05-26 00:52 . 2009-05-26 00:52 -------- d-----w- c:\windows\system32\drivers\UMDF
2009-05-24 20:24 . 2009-05-24 20:24 -------- d-sh--w- C:\FOUND.000
2009-05-21 22:23 . 2009-05-21 22:23 -------- d-----w- c:\windows\system32\Adobe
2009-05-21 04:01 . 2009-05-21 04:01 -------- d-----w- c:\windows\system32\wbem\AutoRecover
2009-05-21 03:58 . 2007-10-23 12:22 3350528 ---h--w- c:\documents and settings\Ryan Fowler\Application Data\U3\temp\Launchpad Removal.exe
2009-05-21 03:58 . 2009-05-21 03:58 -------- d-----w- c:\documents and settings\Ryan Fowler\Application Data\U3
2009-05-21 03:50 . 2009-05-21 03:50 -------- d-----w- c:\windows\system32\NtmsData
2009-05-21 03:40 . 2008-04-14 08:40 102912 ------w- c:\windows\system32\dllcache\dpcdll.dll
2009-05-21 03:36 . 2008-04-14 08:41 33792 ------w- c:\windows\system32\dllcache\custsat.dll
2009-05-21 03:34 . 2008-04-14 01:06 144384 ------w- c:\windows\system32\drivers\hdaudbus.sys
2009-05-21 03:34 . 2008-04-14 03:10 10240 ------w- c:\windows\system32\drivers\sffp_mmc.sys
2009-05-21 03:14 . 2008-10-15 16:34 337408 ------w- c:\windows\system32\dllcache\netapi32.dll
2009-05-21 03:11 . 2009-05-21 03:11 -------- d--h--w- c:\windows\$hf_mig$
2009-05-21 02:35 . 2008-04-14 02:09 2897920 ------w- c:\windows\system32\xpsp2res.dll
2009-05-21 02:32 . 2007-08-10 23:46 26488 ------w- c:\windows\system32\spupdsvc.exe
2009-05-21 02:12 . 2009-05-21 02:12 -------- d-----w- c:\windows\ServicePackFiles
2009-05-21 02:12 . 2009-05-21 02:12 -------- d-----w- c:\windows\ehome
2009-05-21 02:05 . 2008-04-14 08:42 270848 ------w- c:\windows\system32\sbe.dll
2009-05-21 02:04 . 2008-04-14 08:42 20992 ----a-w- c:\windows\system32\fontview.exe
2009-05-21 01:54 . 2009-03-09 18:27 453456 ------w- c:\windows\system32\d3dx10_41.dll
2009-05-21 01:49 . 2009-05-21 01:49 -------- d-----w- c:\windows\Logs
2009-05-21 01:25 . 2009-05-21 01:25 -------- d-----w- c:\program files\Spiceworks
2009-05-21 01:11 . 2009-05-21 01:11 -------- d-----w- c:\documents and settings\Ryan Fowler\Application Data\Blitware
2009-05-21 01:11 . 2009-05-21 01:11 -------- d-----w- c:\program files\Driver Robot
2009-05-21 00:04 . 2009-05-21 00:04 -------- d-----w- c:\documents and settings\Ryan Fowler\Local Settings\Application Data\Google
2009-05-20 23:02 . 2008-04-14 03:49 146048 ----a-w- c:\windows\system32\drivers\portcls.sys
2009-05-20 23:02 . 2008-04-14 03:15 60160 ----a-w- c:\windows\system32\drivers\drmk.sys
2009-05-20 22:50 . 2009-05-20 22:50 -------- d-----w- c:\windows\system32\bits
2009-05-20 22:49 . 2008-04-14 08:42 354304 ----a-w- c:\windows\system32\winhttp.dll
2009-05-20 22:49 . 2008-04-14 08:42 18944 ----a-w- c:\windows\system32\qmgrprxy.dll
2009-05-20 22:49 . 2008-04-14 08:41 8192 ------w- c:\windows\system32\bitsprx2.dll
2009-05-20 22:49 . 2008-04-14 08:41 7168 ------w- c:\windows\system32\bitsprx3.dll
2009-05-20 22:49 . 2008-04-14 02:09 438784 ------w- c:\windows\system32\xpob2res.dll
2009-05-20 22:30 . 2008-10-16 17:09 43544 ------w- c:\windows\system32\wups2.dll
2009-05-20 22:30 . 2008-10-16 17:08 34328 ----a-w- c:\windows\system32\wups.dll
2009-05-20 22:30 . 2008-10-16 17:12 323608 ----a-w- c:\windows\system32\wucltui.dll
2009-05-20 22:30 . 2008-10-16 17:12 561688 ----a-w- c:\windows\system32\wuapi.dll
2009-05-20 22:06 . 2009-05-27 21:28 1632 ----a-w- c:\windows\system32\d3d8caps.dat
2009-05-15 02:21 . 2009-05-15 02:22 -------- d-----w- c:\documents and settings\Ryan Fowler\Local Settings\Application Data\NOS
2009-05-15 02:21 . 2009-05-15 02:21 -------- d-----w- c:\documents and settings\All Users\Application Data\NOS
bobbby103
Posts Posts : 40
Post by bobbby103 on Sat Jun 13, 2009 8:46 pm
2009-06-13 20:06 . 2009-05-04 02:29 1428 ----a-w- c:\windows\system32\PerfStringBackup.TMP
2009-05-21 21:05 . 2009-05-21 21:05 -------- d-----w- c:\documents and settings\All Users\Application Data\WLInstaller
2009-05-21 21:05 . 2009-05-21 04:01 18504 ----a-w- c:\documents and settings\Ryan Fowler\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-05-21 21:04 . 2009-05-21 21:04 -------- d-----w- c:\program files\Microsoft Silverlight
2009-05-21 20:58 . 2009-05-21 20:58 -------- d-----w- c:\program files\Microsoft Sync Framework
2009-05-21 20:57 . 2009-05-21 20:57 -------- d-----w- c:\program files\Microsoft SQL Server Compact Edition
2009-05-21 20:56 . 2009-05-21 20:56 -------- d-----w- c:\program files\Microsoft
2009-05-21 20:56 . 2009-05-21 20:56 -------- d-----w- c:\program files\Windows Live SkyDrive
2009-05-21 20:55 . 2009-05-21 20:55 -------- d-----w- c:\program files\Windows Live
2009-05-21 20:53 . 2009-05-21 20:53 -------- d-----w- c:\program files\Common Files\Windows Live
2009-05-21 03:45 . 2009-05-04 02:11 86327 ------w- c:\windows\PCHEALTH\HELPCTR\OfflineCache\index.dat
2009-05-06 23:04 . 2009-05-06 23:04 -------- d-----w- c:\documents and settings\Ryan Fowler\Application Data\FrostWire
2009-05-06 23:03 . 2009-05-06 23:03 -------- d-----w- c:\program files\Common Files\Java
2009-05-06 23:02 . 2009-05-06 23:02 -------- d-----w- c:\program files\FrostWire
2009-05-06 23:01 . 2009-05-06 23:01 -------- d-----w- c:\program files\AskBarDis
2009-05-04 03:08 . 2009-05-04 03:08 -------- d-----w- c:\documents and settings\Ryan Fowler\Application Data\MSN6
2009-05-04 02:15 . 2009-05-04 02:15 -------- d-----w- c:\documents and settings\Ryan Fowler\Application Data\Symantec
2009-05-04 02:15 . 2009-05-04 02:15 -------- d-----w- c:\documents and settings\Ryan Fowler\Application Data\RegTool
2009-05-04 02:15 . 2009-05-04 02:15 -------- d-----w- c:\documents and settings\Ryan Fowler\Application Data\TouchStoneSoftware
2009-05-04 02:15 . 2009-05-04 02:15 -------- d-----w- c:\documents and settings\Ryan Fowler\Application Data\Microsoft Web Folders
2009-05-04 02:15 . 2009-05-04 02:15 -------- d-----w- c:\documents and settings\Ryan Fowler\Application Data\QN74SR7K
2009-05-04 02:15 . 2009-05-04 02:15 -------- d-----w- c:\documents and settings\All Users\Application Data\Symantec
2009-05-04 02:12 . 2009-05-04 02:12 504832 ------w- c:\windows\system32\migicons.exe
2009-05-04 02:08 . 2009-05-04 02:08 21640 ------w- c:\windows\system32\emptyregdb.dat
2009-05-04 01:36 . 2009-05-04 01:36 -------- d-----w- c:\program files\Microsoft SQL Server
2009-05-04 00:41 . 2009-05-04 00:40 122 ------w- c:\windows\tmpdelis.bat
2009-05-04 00:15 . 2009-05-04 00:15 15120 ------w- c:\windows\system32\icfg95.dll
2009-05-03 23:51 . 2009-05-03 23:51 315424 ---h--r- c:\windows\HWINFO.DAT
2009-05-03 23:51 . 2008-10-17 03:09 11079 ---h--w- c:\program files\folder.htt
2009-05-03 23:39 . 2009-05-03 23:38 132418775 ---h--r- C:\W98UNDO.DAT
2009-04-30 21:57 . 2009-04-30 21:57 -------- d-----w- c:\program files\Mob Wars Toolbar
2009-04-28 09:47 . 2009-04-28 09:47 499712 ----a-w- c:\windows\system32\msvcp71.dll
2009-04-28 09:47 . 2009-04-28 09:47 348160 ----a-w- c:\windows\system32\msvcr71.dll
2009-04-18 06:09 . 2009-04-18 06:09 -------- d-----w- c:\program files\Common Files\Wise Installation Wizard
2009-03-16 17:18 . 2009-05-21 01:54 69448 ------w- c:\windows\system32\XAPOFX1_3.dll
2009-03-16 17:18 . 2009-05-21 01:54 517448 ------w- c:\windows\system32\XAudio2_4.dll
2009-03-16 17:18 . 2009-05-21 01:54 235352 ------w- c:\windows\system32\xactengine3_4.dll
2009-03-16 17:18 . 2009-05-21 01:54 22360 ------w- c:\windows\system32\X3DAudio1_6.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{201f27d4-3704-41d6-89c1-aa35e39143ed}]
2008-09-09 01:08 279944 ----a-w- c:\program files\AskBarDis\bar\bin\askBar.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\SlowFile Icon Overlay]
@="{7D688A77-C613-11D0-999B-00C04FD655E1}"
[HKEY_CLASSES_ROOT\CLSID\{7D688A77-C613-11D0-999B-00C04FD655E1}]
2008-04-14 08:42 8461312 ----a-w- c:\windows\SYSTEM32\shell32.dll
"msnmsgr"="c:\program files\Windows Live\Messenger\msnmsgr.exe" [2009-02-06 3885408]
"Google Update"="c:\documents and settings\Ryan Fowler\Local Settings\Application Data\Google\Update\GoogleUpdate.exe" [2009-05-21 133104]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2009-06-11 39408]
"Spiceworks"="c:\program files\Spiceworks\bin\spicetray_silent.exe" [2009-04-04 66840]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-05-21 148888]
"15268874"="c:\documents and settings\All Users\Application Data\15268874\15268874.exe" [BU]
True Internet Color Icon.lnk - c:\program files\E-Color\True Internet Color\TICIcon.exe [2008-10-18 221184]
Microsoft Office.lnk - c:\program files\Microsoft Office\Office\Osa9.exe [2000-1-21 65588]
Service Manager.lnk - c:\program files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe [2000-8-6 69632]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\setup\disabledrunkeys]
"Tweak UI"=RUNDLL32.EXE c:\windows\SYSTEM32\TWEAKUI.CPL,TweakMeUp
"LoadQM"=loadqm.exe
"LoadPowerProfile"=Rundll32.exe powrprof.dll,LoadCurrentPwrScheme
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\Windows Live\\Sync\\WindowsLiveSync.exe"=
"c:\\Program Files\\Spiceworks\\bin\\spiceworks.exe"=
"c:\\Program Files\\FrostWire\\FrostWire.exe"=
"c:\\WINDOWS\\Network Diagnostic\\xpnetdiag.exe"=
R2 fssfltr;FssFltr;c:\windows\SYSTEM32\DRIVERS\fssfltr_tdi.sys [5/21/2009 6:04 PM 55152]
S2 gupdate1c9eae1d64e61d0;Google Update Service (gupdate1c9eae1d64e61d0);c:\program files\Google\Update\GoogleUpdate.exe [6/11/2009 7:13 PM 133104]
S3 fsssvc;Windows Live Family Safety;c:\program files\Windows Live\Family Safety\fsssvc.exe [2/6/2009 6:08 PM 533360]
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{44BBA840-CC51-11CF-AAFA-00AA00B6015C}]
"c:\progra~1\OUTLOO~1\setup50.exe" /APP:OE /CALLER:WIN9X /user /install
"c:\progra~1\OUTLOO~1\setup50.exe" /APP:OE /CALLER:IE50 /user /install
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{7790769C-0471-11d2-AF11-00C04FA35D02}]
"c:\progra~1\OUTLOO~1\setup50.exe" /APP:WAB /CALLER:WIN9X /user /install
"c:\progra~1\OUTLOO~1\setup50.exe" /APP:WAB /CALLER:IE50 /user /install
2009-03-03 c:\windows\Tasks\Symantec NetDetect.job
- c:\program files\SYMANTEC\LIVEUPDATE\NDETECT.EXE [2008-11-12 15:23]
2009-06-13 c:\windows\Tasks\Driver Robot.job
- c:\program files\Driver Robot\1.0.5.17\DriverRobot.exe [2009-05-21 20:59]
2009-06-13 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-527237240-789336058-1202660629-1003.job
- c:\documents and settings\Ryan Fowler\Local Settings\Application Data\Google\Update\GoogleUpdate.exe [2009-05-21 20:32]
2009-06-13 c:\windows\Tasks\GoogleUpdateTaskMachine.job
- c:\program files\Google\Update\GoogleUpdate.exe [2009-06-11 22:13]
2009-06-13 c:\windows\Tasks\Google Software Updater.job
- c:\program files\Google\Common\Google Updater\GoogleUpdaterService.exe [2009-06-11 22:11]
bobbby103
Posts Posts : 40
mLocal Page = c:\windows\SYSTEM\blank.htm
DPF: DirectAnimation Java Classes - [You must be registered and logged in to see this link.]
DPF: Internet Explorer Classes for Java - [You must be registered and logged in to see this link.]
DPF: Win32 Classes
Rootkit scan 2009-06-13 17:35
Windows 5.1.2600 Service Pack 3 FAT NTAPI
- - - - - - - > 'winlogon.exe'(372)
c:\windows\system32\COMRes.dll
Completion time: 2009-06-13 17:36
ComboFix-quarantined-files.txt 2009-06-13 20:36
ComboFix2.txt 2009-06-13 19:54
Pre-Run: 26,585,006,080 bytes free
Post-Run: 26,573,209,600 bytes free
211
bobbby103
Posts Posts : 40
Post by Belahzur on Sat Jun 13, 2009 9:26 pm
Lets get an uninstall list.
  • Open HijackThis.
Post by bobbby103 on Sat Jun 13, 2009 9:31 pm
here it is
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Shockwave Player 11.5
Ask Toolbar
Choice Guard
Driver Robot 1.0.6.0
FrostWire 4.18.0
Google Earth
Google Update Helper
Google Updater
HijackThis 2.0.2
Hotfix for Windows XP (KB954708)
Java(TM) 6 Update 14
Java(TM) 6 Update 7
Junk Mail filter update
LiveReg (Symantec Corporation)
LiveUpdate 1.6 (Symantec Corporation)
Microsoft .NET Framework 1.1
Microsoft .NET Framework 2.0
Microsoft Office 2000 SR-1 Premium
Microsoft Search Enhancement Pack
Microsoft SQL Server 2005 Compact Edition [ENU]
Microsoft SQL Server Desktop Engine
Microsoft Sync Framework Runtime Native v1.0 (x86)
Microsoft Sync Framework Services Native v1.0 (x86)
MSVCRT
Security Update for Windows 98 (KB913433)
Segoe UI
Spiceworks
True Internet Color
VIA Rhine-Family Fast-Ethernet Adapter
Westwood Shared Internet Components
Windows Live Call
Windows Live Essentials
Windows Live Mail
Windows Live Messenger
Windows Live Photo Gallery
Windows Live Sync
Windows Live Toolbar
Windows Live Upload Tool
Windows Live Writer
Windows XP Service Pack 3
Windows XP Uninstall
WinRAR archiver
WinZip
bobbby103
Posts Posts : 40
Post by Belahzur on Sat Jun 13, 2009 9:36 pm
    Ask Toolbar
    FrostWire 4.18.0
    Java(TM) 6 Update 7
Now open a new notepad file.
Folder::
C:\FOUND.000
C:\FOUND.001
Registry::
"15268874"=-
"AntiVirusOverride"=-
[-HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{44BBA840-CC51-11CF-AAFA-00AA00B6015C}]
[-HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{7790769C-0471-11d2-AF11-00C04FA35D02}]
Post by bobbby103 on Sat Jun 13, 2009 10:05 pm
Here is the log.
ComboFix 09-06-13.03 - Ryan Fowler 06/13/2009 18:48.2 - FAT32x86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.511.252 [GMT -3:00]
Command switches used :: c:\documents and settings\Ryan Fowler\Desktop\CFScript.txt
C:\FOUND.000
C:\FOUND.001
c:\found.000\FILE0000.CHK
c:\found.000\FILE0001.CHK
c:\found.000\FILE0002.CHK
c:\found.000\FILE0003.CHK
c:\found.000\FILE0004.CHK
c:\found.000\FILE0005.CHK
c:\found.001\FILE0000.CHK
bobbby103
Posts Posts : 40
Post by bobbby103 on Sat Jun 13, 2009 10:06 pm
bobbby103
Posts Posts : 40
"LoadQM"=loadqm.exe
DPF: Win32 Classes
Rootkit scan 2009-06-13 18:53
Completion time: 2009-06-13 18:54
ComboFix-quarantined-files.txt 2009-06-13 21:54
ComboFix2.txt 2009-06-13 20:36
ComboFix3.txt 2009-06-13 19:54
Pre-Run: 26,660,864,000 bytes free
Post-Run: 26,656,145,408 bytes free
199
bobbby103
Posts Posts : 40
Post by Belahzur on Sat Jun 13, 2009 10:24 pm
ComboFix /u
Post by bobbby103 on Sat Jun 13, 2009 10:49 pm
everything seem to be back to normal. Thanks. Also was wondering, why remove combo fix after? and how do i prevent stuff like this from happening again. And las t but not least do u know or can u recommend a good anti-virus download thats free or store bought.
bobbby103
Posts Posts : 40
Post by Belahzur on Sat Jun 13, 2009 10:58 pm
Combofix is far too powerful to be used without trained staff members watching over you.
Post by bobbby103 on Sun Jun 14, 2009 2:01 am
Thank you very much for your help and recommendations.
bobbby103
Posts Posts : 40
Post by bobbby103 on Sun Jun 14, 2009 2:51 am
one last thing, would AVG be the better anti-virus or avira?
bobbby103
Posts Posts : 40
Post by Belahzur on Sun Jun 14, 2009 12:10 pm
Avira is better.
