Need help getting rid of System Security
Post by Repair Bay on 12th June 2009, 10:58 pm
It won't allow me to open anything. Gives a message:
"Application cannot be executed. The file "example.exe" is infected.
Please activate your antivirus software."
I can't open taskbar, Add or Remove Programs, etc. Please help!
I'm using Windows XP
Repair Bay
Posts Posts : 4
Joined Joined : 2009-06-12
Points Points : 27398
Re: Need help getting rid of System Security
Post by Belahzur on 12th June 2009, 11:04 pm
  3. IceSword.exe will randomly rename itself when opened, so let me know if it is able to bypass the malware and stays open.
Points Points : 245121
Post by Repair Bay on 12th June 2009, 11:15 pm
It stays open.
Repair Bay
Posts Posts : 4
Post by Belahzur on 12th June 2009, 11:23 pm
Hooray! Thanks, at last, I've found a hole in the malware.
  • Open the Ice Sword folder and then launch IceSword.exe.
  • Then look in the left hand bottom of the program and press "Registry"
  • When the registry list opens, drag the line between the two windows so you can see which registry hive you need.
  • Next, open the HKEY_LOCAL_MACHINE, and navigate to the following key:
  • Next, look in the right side pane, and there should be one or two values that are just random nummbers.
  • They points to random name numbered .exe inside a folder that is also random numbers.
  • Once you have found the value(s), right click it and press "Delete"
  • Okay the prompt and close IceSword.
Reboot the machine.
After reboot, the false alerts should have stopped.
Post by Repair Bay on 13th June 2009, 7:16 pm
Thank you SOSOSOSO much!
Repair Bay
Posts Posts : 4
Post by Belahzur on 13th June 2009, 7:46 pm
Please post a new Hijack This log.
