Increase DSL Speed in XP
Solved Increase DSL Speed in XP
Post by blackgalaxy on Thu Jun 11, 2009 3:44 am
I need to know how to increase my DSL speed by tweeking XP.
blackgalaxy
Posts Posts : 4
Joined Joined : 2009-06-11
Points Points : 27358
Solved Re: Increase DSL Speed in XP
Post by Doctor Inferno on Fri Jun 12, 2009 4:35 am
You could use 'Open DNS'. They allow you to go through their DNS servers and many have reported a noticeable increase in speed.
They have configuration pages for your OS or hardware router.
http://www.opendns.com/
Secondly, If you’re on Windows, install 'FastCache'.
AnalogX FastCache is a caching DNS server that runs on your local machine and handles any DNS request that your computer makes, from Internet Explorer to your favorite FTP client. Once a query is made, FastCache will override the normal timeout for the item with one that you specify, so instead of saving a query for a couple of seconds, it can save it for a couple of days. Now every time you ask for it again while it's in the cache, it gives it to you instantly.
http://www.analogx.com/CONTENTS/download/network/fc.htm
Download AnalogX FastCache From Here
Download Firefox
http://download.mozilla.org/?product=firefox-3.5.6&os=win&lang=en-US
When you have installed Firefox;
In the address bar type in about:config >> in the filter bar type in pipe under network.http.pipelining >> right click toogle >> under network.http.pipelining.maxrequests >> right click >> Modify and change the value to 30.
This makes firefox use 30 connections instead of just 4. Making your surfing speed slightly faster.
Download and install this Firefox add-on called: Fasterfox:
https://addons.mozilla.org/en-US/firefox/downloads/file/63337/fasterfox_lite-3.8.2lite-fx.xpi?confirmed
Last edited by Doctor Inferno on Fri Dec 25, 2009 9:44 am; edited 2 times in total
Points Points : 104600
Post by blackgalaxy on Fri Jun 12, 2009 5:08 am
Thanks for your assistance DOC. I have downloaded one of the applications and I will test to see how it works out.
blackgalaxy
Posts Posts : 4
Solved Thanks for internet tips.
Post by gunwantk on Fri Mar 05, 2010 4:12 pm
Well thanks for internet speed tips
I found it very usefull.And expecting some more about DAP.
gunwantk
Joined Joined : 2010-03-05
OS OS : windows xp
Points Points : 24690
