Antivirus System Pro
Post by sonobaby on Wed Jun 10, 2009 5:17 pm
Help! I got the crap on my computer and now I can't even get on the Internet to download the program to fix it. I tried removing it under add and remove programs but no luck. How can I get on the Internet to load a fix?
sonobaby
OS : XP? not sure
Re: Antivirus System Pro
Post by Belahzur on Wed Jun 10, 2009 5:39 pm
Do you have a USB stick/external hardrive we can use?
Post by sonobaby on Wed Jun 10, 2009 5:46 pm
Thanks but I can't get on the computer at all. It won't let me get on the Internet. I'm writing this from work. Is there some way to download the fix onto a floppy or disc and then try to run that on my computer at home?
sonobaby
OS : XP? not sure
Post by Belahzur on Wed Jun 10, 2009 5:57 pm
Yes, that's why I asked if you had a USB stick/external hardrive in my post.
You can use the CD method if you want to as well.
Post by sonobaby on Wed Jun 10, 2009 6:17 pm
Thanks. I will try the CD. I'm sort of computer illiterate so I didn't know what a USB stick/external hardrive were.
sonobaby
OS : XP? not sure
Post by sonobaby on Mon Jun 15, 2009 10:29 pm
OK I have the log file scanned - is there some email address that i can send it to as an attachment? I can't get it to copy and paste here...
sonobaby
OS : XP? not sure
Post by Belahzur on Tue Jun 16, 2009 12:00 am
It says it's too big?
Split it up into more than one post, or upload it at rapidshare.com.
Post by sonobaby on Sat Jun 20, 2009 4:04 pm
I scanned it and emailed it to myself. It won't let me copy and paste. Can I forward my email to you? Email address? If I upload it to rapidshare I still don't have anywhere to send it.
sonobaby
OS : XP? not sure
Post by Belahzur on Sat Jun 20, 2009 6:03 pm
You can paste the rapidshare link here.
