Need help
Solved Need help
Post by Ancilary on Tue Jun 09, 2009 3:59 pm
i need help to remove these program uninstalled from my pc..
i cant even install new one.
so plz guide me how to remove these i dint even got remove option
https://i86.servimg.com/u/f86/13/96/19/90/images10.jpg
Ancilary
Posts Posts : 23
Joined Joined : 2009-05-30
Points Points : 27508
Solved Re: Need help
Post by Doctor Inferno on Fri Jun 12, 2009 4:42 am
Click Start >> Run >> Type in regedit. Navigate to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\
Once you click the + sign in front Uninstall, you will see some {letters and numbers}, followed by a listing of your installed programs.
Click on one of the installed programs then on the right-pane, do the following:
Double-click NoRemove (REG_DWORD) and set it to 0
Double-click NoModify (REG_DWORD) and set it to 0
If NoRemove is set to 1, the Remove button will be unavailable
If NoModify is set to 1, the Change button will be unavailable
Points Points : 104600
