antivirus system pro
Post by daja7 on Tue 09 Jun 2009, 1:55 am
I cannot remove antivirus system pro.
It will not let me download the malwarebytes.
When I download it from another comuter and put it on the effected one it call for a registration number and to get that it says that I must purchase the program. Am I doing something wrong?
Operating System : xp pro
Re: antivirus system pro
Post by Belahzur on Tue 09 Jun 2009, 4:17 am
  • Download combofix from here
    Link 1
    Link 2
  • See HERE for how to disable your AV.
Manager | Tech Officer
