Please help with winsoftblue!
Post by EllisG342 on 7th June 2009, 2:05 pm
Please help!
C:\WINDOWS\TEMP\tempo-89875.tmp
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\Program Files\MSN Messenger\usnsvc.exe
C:\Program Files\iTunes\iTunes.exe
C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll (file missing)
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [RelevantKnowledge] C:\program files\relevantknowledge\rlvknlg.exe -boot
O4 - HKLM\..\Run: [WinBlueSoft] C:\Program Files\WinBlueSoft Software\WinBlueSoft\WinBlueSoft.exe -min
O4 - HKLM\..\RunOnce: [Malwarebytes' Anti-Malware] C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe /install /silent
O4 - HKCU\..\Run: [BitTorrent DNA] "C:\Program Files\DNA\btdna.exe"
O4 - HKCU\..\Run: [setup2.exe] C:\WINDOWS\system32\setup2.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
O4 - Global Startup: Wireless Configuration Utility HW.15.lnk = C:\Program Files\TRENDnet\TRENDnet TEW-421PC_TEW-423PI\WlanCU.exe
O16 - DPF: {5D6F45B3-9043-443D-A792-115447494D24} (UnoCtrl Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - [You must be registered and logged in to see this link.]
O17 - HKLM\System\CCS\Services\Tcpip\..\{45BE97D3-2B71-4645-97AE-C5C4036E5D7C}: NameServer = 85.255.112.102,85.255.112.186
O17 - HKLM\System\CCS\Services\Tcpip\..\{FB7C2CF8-E663-4B8D-943E-8EFA8C717499}: NameServer = 85.255.112.102,85.255.112.186
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: NameServer = 85.255.112.102,85.255.112.186
O17 - HKLM\System\CS1\Services\Tcpip\..\{45BE97D3-2B71-4645-97AE-C5C4036E5D7C}: NameServer = 85.255.112.102,85.255.112.186
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: NameServer = 85.255.112.102,85.255.112.186
O23 - Service: ForceWare Intelligent Application Manager (IAM) - Unknown owner - C:\Program Files\NVIDIA Corporation\NetworkAccessManager\bin\nSvcAppFlt.exe
O23 - Service: Forceware Web Interface (ForcewareWebInterface) - Apache Software Foundation - C:\Program Files\NVIDIA Corporation\NetworkAccessManager\Apache Group\Apache2\bin\apache.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1150\Intel 32\IDriverT.exe
O23 - Service: ForceWare IP service (nSvcIp) - NVIDIA - C:\Program Files\NVIDIA Corporation\NetworkAccessManager\bin\nSvcIp.exe
O23 - Service: ForceWare user log service (nSvcLog) - NVIDIA - C:\Program Files\NVIDIA Corporation\NetworkAccessManager\bin\nSvcLog.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\System32\nvsvc32.exe
End of file - 6604 bytes
EllisG342
Posts Posts : 4
Joined Joined : 2009-06-07
Points Points : 27426
Re: Please help with winsoftblue!
Post by Belahzur on 7th June 2009, 6:56 pm
Points Points : 245101
Post by EllisG342 on 8th June 2009, 3:19 am
I've just closed HiJackThis and have installed Malwarebytes' Anti-Malware.
However, when I try to run the program, nothing happens. Is there any way I could resolve this problem?
EllisG342
Posts Posts : 4
Post by Belahzur on 8th June 2009, 5:10 pm
Post by EllisG342 on 8th June 2009, 8:12 pm
I've successfully run Malwarebytes.
Malwarebytes' Anti-Malware 1.37
Database version: 2182
6/8/2009 4:11:45 PM
mbam-log-2009-06-08 (16-11-42).txt
Objects scanned: 79099
Time elapsed: 3 minute(s), 58 second(s)
Registry Keys Infected: 2
Folders Infected: 2
Files Infected: 6
HKEY_CURRENT_USER\SOFTWARE\{NSINAME} (Trojan.Agent) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{d08d9f98-1c78-4704-87e6-368b0023d831} (Adware.RelevantKnowledge) -> No action taken.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\Tcpip\Parameters\Interfaces\{fb7c2cf8-e663-4b8d-943e-8efa8c717499}\DhcpNameServer (Trojan.DNSChanger) -> Data: 85.255.112.102,85.255.112.186 -> No action taken.
c:\documents and settings\All Users\Start Menu\Programs\RelevantKnowledge (Spyware.Marketscore) -> No action taken.
c:\documents and settings\Ellis\Start Menu\Programs\UltraVideo (Trojan.DNSChanger) -> No action taken.
c:\documents and settings\all users\start menu\Programs\relevantknowledge\About RelevantKnowledge.lnk (Spyware.Marketscore) -> No action taken.
c:\documents and settings\all users\start menu\Programs\relevantknowledge\Privacy Policy and User License Agreement.lnk (Spyware.Marketscore) -> No action taken.
c:\documents and settings\all users\start menu\Programs\relevantknowledge\Support.lnk (Spyware.Marketscore) -> No action taken.
c:\documents and settings\all users\start menu\Programs\relevantknowledge\Uninstall Instructions.lnk (Spyware.Marketscore) -> No action taken.
C:\WINDOWS\rundll32.exe (Backdoor.Bot) -> No action taken.
C:\WINDOWS\rundll.exe (Trojan.Agent) -> No action taken.
EllisG342
Posts Posts : 4
Post by Belahzur on 8th June 2009, 8:34 pm
Did you set it to remove everything before getting the log?
Post by EllisG342 on 9th June 2009, 1:32 am
Yes
EllisG342
Posts Posts : 4
Post by Belahzur on 9th June 2009, 5:43 pm
Okay, see if you can run Combofix anyhow.
