help with port forwarding...no clue!!
Post by PatriciaRose on 7th June 2009, 3:11 am
I am using Azureus/Vuze is shows me a NAT problem...I have recently hooked up a router..I read i should use port forwarding...i have nooo clue how this is done.. like i can get to my routers 'web page' thinger, and i know the listening port on azureus..i just dont know how to add that all together...
i am clueless...please be as descriptive as possible! thank you
PatriciaRose
Posts Posts : 18
Joined Joined : 2009-03-08
OS OS : windows xp home
Points Points : 28333
Re: help with port forwarding...no clue!!
Post by PatriciaRose on 8th June 2009, 12:47 am
ok so i found port forwarding.com and added the port i use in azureus to my routers web page thing etc. ...and created a static ip address for azureus.. but then i realized that the actual modem has its own set of ip address and stuff like that... the smiley's in azureus have been either yellow or red since hooking up my router...
PatriciaRose
Posts Posts : 18
Post by PatriciaRose on 22nd June 2009, 4:23 pm
please can anyone help me out! thanks
PatriciaRose
Posts Posts : 18
