Computer infected with Antivirus System Pro
Post by rockne1932 on Sun 07 Jun 2009, 12:22 am
Someone please help. My laptop is infected with Antivirus System Pro. I have windows that keep popping up and I can't access the internet or my itunes. What can I do???
Operating System : XP
Re: Computer infected with Antivirus System Pro
Post by Belahzur on Sun 07 Jun 2009, 12:32 am
  • Restart your computer
  • Select the second option, to run Windows in Safe Mode WITH NETWORKING, then press Enter.
  • Choose your usual account.
Please download the current version of HijackThis from HERE
Manager | Tech Officer
