antivirus system pro
Re: antivirus system pro
Post by Belahzur on 6th June 2009, 9:18 pm
The log was cut off, please post rest.
Points Points : 245121
Post by bleedbolts on 6th June 2009, 9:24 pm
So since this is all of it that means that when i x'd out of the screen yesterday it must have cut out the remaining parts....should i run combo-fix again?
bleedbolts
Posts Posts : 26
Joined Joined : 2009-06-05
Points Points : 27589
Post by Belahzur on 6th June 2009, 9:26 pm
No, there was no leftover malware showing, I just thought the board limit cut it off, this should be fine now.
ComboFix /u
Post by bleedbolts on 6th June 2009, 9:32 pm
i just completed the above and at the end it said combofix is uninstalled.
bleedbolts
Posts Posts : 26
Post by Origin on 6th June 2009, 10:13 pm
Yes it was suppose to uninstall ComboFix, how is the computer running?
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31533
Post by bleedbolts on 6th June 2009, 11:09 pm
Computer is running great! You guys are awesome. Hope i don't have to revisit the site but i feel comfortable knowing that you guys are here just in case...
bleedbolts
Posts Posts : 26
