Help Removing Winbluesoft when antivirus won't work
Post by dlg2114 on 4th June 2009, 3:27 am
This winbluesoft recently installed itself onto my computer. I have tried several antivirus and none will work. I tried malwarebytes.org and once I install this program it won't allow me to run it. I'm not receiving any pop ups because I never opened Winbluesoft its just on my desktop. It won't allow me to remove it through Add/Remove programs. Please help
dlg2114
Posts Posts : 32
Joined Joined : 2009-06-04
Points Points : 27645
Re: Help Removing Winbluesoft when antivirus won't work
Post by Origin on 4th June 2009, 4:08 am
Hello can you doownload Hijackthis?
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31503
Post by dlg2114 on 4th June 2009, 4:27 am
I was able to download hijack this and do a system scan but no notepad opened. I don't know how to copy and paste it here.
dlg2114
Posts Posts : 32
Post by dlg2114 on 4th June 2009, 4:41 am
the information mage420 provided is not my info i'm still unable to copy my information from hijack this i'm able to open microsoft word but unable to even open notepad
dlg2114
Posts Posts : 32
Post by Belahzur on 4th June 2009, 10:51 am
mage420 has been split out of your topic.
We know the reason behind the block, we can use Hijack This to unlock the problem and then tools will work.
[LIST]
[*] Open HijackThis.
[*] When Hijack This opens, click "Open the Misc Tools section"
[*] Then select "Delete a file on reboot..."
[*] Then find and select this file: C:\windows\system32\blocker.dll
[*] Select okay and select yes to reboot.
[/LIST
Let us know once that is done, and then post the normal Hijack This log, because once that blocker.dll is gone, Notepad will work.
Points Points : 245091
Post by dlg2114 on 4th June 2009, 11:28 am
Scan saved at 6:26:00 AM, on 6/4/2009
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = [You must be registered and logged in to see this link.]
R3 - URLSearchHook: DefaultSearchHook Class - {C94E154B-1459-4A47-966B-4B843BEFC7DB} - C:\Program Files\AskSearch\bin\DefaultSearch.dll
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: AskBar BHO - {201f27d4-3704-41d6-89c1-aa35e39143ed} - C:\Program Files\AskBarDis\bar\bin\askBar.dll
O2 - BHO: AT&&T Toolbar - {4E7BD74F-2B8D-469E-94BE-FD60BB9AAE29} - C:\PROGRA~1\ATTTOO~1\ATTTOO~1.DLL
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O2 - BHO: NAV Helper - {A8F38D8D-E480-4D52-B7A2-731BB6995FDD} - c:\Program Files\Norton Internet Security\Norton AntiVirus\NavShExt.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar2.dll
O2 - BHO: HpWebHelper - {AAAE832A-5FFF-4661-9C8F-369692D1DCB9} - C:\WINDOWS\pchealth\helpctr\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\plugin\WebHelper.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\3.1.807.1746\swg.dll
O3 - Toolbar: Norton AntiVirus - {C4069E3A-68F1-403E-B40E-20066696354B} - c:\Program Files\Norton Internet Security\Norton AntiVirus\NavShExt.dll
O3 - Toolbar: AOL Toolbar - {4982D40A-C53B-4615-B15B-B5B5E98D167C} - C:\Program Files\AOL Toolbar\toolbar.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar2.dll
O3 - Toolbar: AT&&T Toolbar - {4E7BD74F-2B8D-469E-94BE-FD60BB9AAE29} - C:\PROGRA~1\ATTTOO~1\ATTTOO~1.DLL
O3 - Toolbar: Ask Toolbar - {3041d03e-fd4b-44e0-b742-2d9b88305f98} - C:\Program Files\AskBarDis\bar\bin\askBar.dll
O4 - HKLM\..\Run: [ehTray] C:\WINDOWS\ehome\ehtray.exe
O4 - HKLM\..\Run: [AlwaysReady Power Message APP] ARPWRMSG.EXE
O4 - HKLM\..\Run: [DISCover] C:\Program Files\DISC\DISCover.exe
O4 - HKLM\..\Run: [DiscUpdateManager] C:\Program Files\DISC\DiscUpdMgr.exe
O4 - HKLM\..\Run: [DMAScheduler] "c:\Program Files\HP DigitalMedia Archive\DMAScheduler.exe"
O4 - HKLM\..\Run: [Recguard] C:\WINDOWS\SMINST\RECGUARD.EXE
O4 - HKLM\..\Run: [ccApp] "c:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [HPBootOp] "C:\Program Files\Hewlett-Packard\HP Boot Optimizer\HPBootOp.exe" /run
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\HP\HP Software Update\HPwuSchd2.exe
O4 - HKLM\..\Run: [AOLDialer] C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
O4 - HKLM\..\Run: [HostManager] C:\Program Files\Common Files\AOL\1159822766\ee\AOLSoftware.exe
O4 - HKLM\..\Run: [Pure Networks Port Magic] "C:\PROGRA~1\PURENE~1\PORTMA~1\PortAOL.exe" -Run
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb12.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
O4 - HKLM\..\Run: [ATT-SST_McciTrayApp] "C:\Program Files\ATT-SST\McciTrayApp.exe"
O4 - HKLM\..\Run: [ISW.exe] "C:\Program Files\AT&T\Internet Security Wizard\ISW.exe" /AUTORUN
O4 - HKLM\..\Run: [WinBlueSoft] C:\Program Files\WinBlueSoft Software\WinBlueSoft\WinBlueSoft.exe -min
O4 - HKCU\..\Run: [Winstb] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [WinMedia] C:\3611010322575691656.exe
O4 - HKCU\..\Run: [Winstr] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstn] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winsts] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winsti] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstd] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstj] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winsty] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstz] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstp] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winste] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winsta] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstk] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstt] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winsto] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstu] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstf] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstv] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstx] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstg] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstl] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstm] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winsth] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstc] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstw] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Winstq] C:\3611010322575722234.exe
O4 - HKCU\..\Run: [Cognac] C:\DOCUME~1\HP_ADM~1\LOCALS~1\Temp\b.exe
O4 - HKCU\..\Run: [AROReminder] C:\Program Files\Advanced Registry Optimizer\ARO.exe -rem
O4 - HKUS\S-1-5-18\..\Run: [tempo-setup2.exe] C:\WINDOWS\system32\tempo-setup2.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [tempo-setup2.exe] C:\WINDOWS\system32\tempo-setup2.exe (User 'Default user')
O4 - .DEFAULT User Startup: Pin.lnk = C:\hp\bin\CLOAKER.EXE (User 'Default user')
O4 - Global Startup: Updates From HP.lnk = C:\Program Files\Updates from HP\9972322\Program\Updates from HP.exe
O8 - Extra context menu item: &AOL Toolbar search - [You must be registered and logged in to see this link.] Files\AOL Toolbar\toolbar.dll/SEARCH.HTML
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra button: AOL Toolbar - {4982D40A-C53B-4615-B15B-B5B5E98D167C} - C:\Program Files\AOL Toolbar\toolbar.dll
O9 - Extra 'Tools' menuitem: AOL Toolbar - {4982D40A-C53B-4615-B15B-B5B5E98D167C} - C:\Program Files\AOL Toolbar\toolbar.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~4\OFFICE11\REFIEBAR.DLL
O9 - Extra button: Internet Connection Help - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
O9 - Extra 'Tools' menuitem: Internet Connection Help - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
O15 - Trusted Zone: [You must be registered and logged in to see this link.] (HKLM)
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (Installation Support) - C:\Program Files\Yahoo!\Common\Yinsthelper.dll
O20 - AppInit_DLLs: blocker.dll
O23 - Service: AOL Connectivity Service (AOL ACS) - AOL LLC - C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
O23 - Service: AOL TopSpeed Monitor (AOL TopSpeedMonitor) - America Online, Inc - C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
O23 - Service: Symantec Internet Security Password Validation (ccISPwdSvc) - Symantec Corporation - c:\Program Files\Norton Internet Security\ccPwdSvc.exe
O23 - Service: Symantec Network Proxy (ccProxy) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\ccProxy.exe
O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
O23 - Service: COM Host (comHost) - Symantec Corporation - c:\Program Files\Norton Internet Security\comHost.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1150\Intel 32\IDriverT.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iTunes\iPod\bin\iPodService.exe
O23 - Service: McciCMService - Motive Communications, Inc. - C:\Program Files\Common Files\Motive\McciCMService.exe
O23 - Service: Norton AntiVirus Auto-Protect Service (navapsvc) - Symantec Corporation - c:\Program Files\Norton Internet Security\Norton AntiVirus\navapsvc.exe
O23 - Service: Norton Protection Center Service (NSCService) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\Security Console\NSCSRVCE.EXE
O23 - Service: Symantec AVScan (SAVScan) - Symantec Corporation - c:\Program Files\Norton Internet Security\Norton AntiVirus\SAVScan.exe
O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
O23 - Service: Symantec SPBBCSvc (SPBBCSvc) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
O23 - Service: Symantec Core LC - Unknown owner - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
End of file - 11992 bytes
dlg2114
Posts Posts : 32
Post by Belahzur on 4th June 2009, 2:48 pm
Your system is severly infected. Problem with these infections nowadays is, it causes a lot of damage. Even if we clean the malware off your system, I can't guarantee that your system will be clean afterwards, because these infections/bundles leave a lot of leftovers behind that most scanners won't even recognise and logs won't show.
Also, I can't promise you we can repair all the damage it caused... Even after cleaning the malware, you can still get errors afterwards because of the damage. Solving these is not always possible since it will be searching for a needle in a haystack to find the right cause and solution.
So, we can try to clean this up and do what we can, but keep in mind that we can't solve ALL problems this malware already caused.
In light of this it would be wise for you to back up any files and folders that you don't want to lose before we start. Reason I am telling this is because when a system is so terribly infected and we try to clean this up manually, the damage that is already present may interfere with our removal attempts.
  • Open HijackThis.
  • Then select "Delete a file on reboot..."
  • Then find and select this file: C:\windows\system32\blocker.dll
  • Select okay and select yes to reboot.
Let me know once you've done that.
Post by dlg2114 on 4th June 2009, 3:00 pm
I'm unable to find blocker.dll, I believe you had me to delete it early because I was unable to open notepad. I looked to see if there was another blocker but was unable to find one.
dlg2114
Posts Posts : 32
Post by Belahzur on 4th June 2009, 3:03 pm
Oh, sorry. I help so many people per day to try and stop it building up on me that I forget who I've asked to do what.
I want to get an uninstall list, because there's some old/un-needed software I want to get rid of before doing any malwarew removal, it will be less stress on the machine.
  • Open HijackThis.
Post by dlg2114 on 4th June 2009, 3:06 pm
Adobe Flash Player 10 ActiveX
Adobe Reader 7.0.5
Alien Outbreak 2
Ancient Sudoku
AOL Coach Version 2.0(Build:20041026.5 en)
AOL Deskbar
AOL Toolbar
AOL Uninstaller (Choose which Products to Remove)
AOL You've Got Pictures Screensaver
Apple Mobile Device Support
Apple Software Update
Ask Toolbar
AT&T Internet Security Wizard 1.5.11
AT&T Self Support Tool
AT&T Toolbar
AT&T Yahoo! Internet Mail
ATI Control Panel
ATI Display Driver
Bejeweled 2 Deluxe
Big Kahuna Reef
Blackhawk Striker 2
Blasterball 2 Remix
Blasterball 2 Revolution
Bonjour
Bookworm Deluxe
Bounce Symphony
CC_ccProxyExt
ccCommon
ccPxyCore
Chuzzle Deluxe
Customer Experience Enhancement
Data Fax SoftModem with SmartCP
Diner Dash
DISCover
DivxFree
Easy Internet Sign-up
Enhanced Multimedia Keyboard Solution
Fairies
Family Feud
FATE
Flip Words
GemMaster Mystic
High Definition Audio Driver Package - KB888111
HijackThis 2.0.2
Hotfix for Windows Media Player 10 (KB910393)
Hotfix for Windows XP (KB893357)
Hotfix for Windows XP (KB906569)
Hotfix for Windows XP (KB912024)
Hotfix for Windows XP (KB935448)
HP Boot Optimizer
HP Deskjet Printer Preload
HP Document Viewer 6.1
HP DVD Play 2.1
HP Extended Capabilities 5.3
HP Game Console
HP Image Zone Express
HP Imaging Device Functions 7.0
HP Photosmart Cameras 6.0
HP Photosmart for Media Center PC
HP Photosmart Premier Software 6.5
HP PSC & OfficeJet 5.3.B
HP PSC & OfficeJet 6.1.A
HP Rhapsody
HP Software Update
HP Solution Center and Imaging Support Tools 6.1
HP Web Helper
Insaniquarium Deluxe
iPod for Windows 2006-01-10
iTunes
Jewel Quest
LiveUpdate 2.7 (Symantec Corporation)
Mah Jong Quest
Microsoft .NET Framework 1.0 Hotfix (KB887998)
Microsoft .NET Framework 1.0 Hotfix (KB930494)
Microsoft .NET Framework 1.1
Microsoft Money 2006
Microsoft Office 2003 Edition 60 Days Trial Welcome Tour
Microsoft Office Standard Edition 2003
Microsoft Works
MSN
MSRedist
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
muvee autoProducer 5.0
muvee autoProducer unPlugged 2.0
Mystery Case Files
Netscape Browser (remove only)
Norton AntiSpam
Norton AntiVirus 2006
Norton Internet Security 2006 (Symantec Corporation)
Norton WMI Update
Norton WMI Update
Otto
PC-Doctor 5 for Windows
Poker Superstars
Polar Bowler
Polar Golfer
Python 2.2 pywin32 extensions (build 203)
Python 2.2.3
Quicken 2006
QuickTime
RealPlayer
Ricochet Lost Worlds
SCRABBLE
Security Update for Windows XP (KB890046)
Security Update for Windows XP (KB893756)
Security Update for Windows XP (KB896358)
Security Update for Windows XP (KB896422)
Security Update for Windows XP (KB896423)
Security Update for Windows XP (KB896424)
Security Update for Windows XP (KB896428)
Security Update for Windows XP (KB899587)
Security Update for Windows XP (KB899589)
Security Update for Windows XP (KB899591)
Security Update for Windows XP (KB900725)
Security Update for Windows XP (KB901017)
Security Update for Windows XP (KB901214)
Security Update for Windows XP (KB902400)
Security Update for Windows XP (KB904706)
Security Update for Windows XP (KB905414)
Security Update for Windows XP (KB905749)
Security Update for Windows XP (KB905915)
Security Update for Windows XP (KB908519)
Security Update for Windows XP (KB911562)
Security Update for Windows XP (KB911567)
Security Update for Windows XP (KB911927)
Security Update for Windows XP (KB912919)
Security Update for Windows XP (KB913580)
Security Update for Windows XP (KB914388)
Security Update for Windows XP (KB914389)
Security Update for Windows XP (KB917344)
Security Update for Windows XP (KB917422)
Security Update for Windows XP (KB917953)
Security Update for Windows XP (KB918118)
Security Update for Windows XP (KB918439)
Security Update for Windows XP (KB918899)
Security Update for Windows XP (KB919007)
Security Update for Windows XP (KB920213)
Security Update for Windows XP (KB920214)
Security Update for Windows XP (KB920670)
Security Update for Windows XP (KB920683)
Security Update for Windows XP (KB920685)
Security Update for Windows XP (KB921398)
Security Update for Windows XP (KB921503)
Security Update for Windows XP (KB921883)
Security Update for Windows XP (KB922616)
Security Update for Windows XP (KB922760)
Security Update for Windows XP (KB922819)
Security Update for Windows XP (KB923191)
Security Update for Windows XP (KB923414)
Security Update for Windows XP (KB923694)
Security Update for Windows XP (KB923980)
Security Update for Windows XP (KB924191)
Security Update for Windows XP (KB924270)
Security Update for Windows XP (KB924496)
Security Update for Windows XP (KB924667)
Security Update for Windows XP (KB925454)
Security Update for Windows XP (KB925486)
Security Update for Windows XP (KB925902)
Security Update for Windows XP (KB926255)
Security Update for Windows XP (KB926436)
Security Update for Windows XP (KB927779)
Security Update for Windows XP (KB927802)
Security Update for Windows XP (KB928255)
Security Update for Windows XP (KB928843)
Security Update for Windows XP (KB929123)
Security Update for Windows XP (KB929969)
Security Update for Windows XP (KB930178)
Security Update for Windows XP (KB931261)
Security Update for Windows XP (KB931768)
Security Update for Windows XP (KB931784)
Security Update for Windows XP (KB932168)
Security Update for Windows XP (KB933566)
Security Update for Windows XP (KB933729)
Security Update for Windows XP (KB935839)
Security Update for Windows XP (KB935840)
Security Update for Windows XP (KB936021)
Security Update for Windows XP (KB937143)
Security Update for Windows XP (KB937894)
Security Update for Windows XP (KB938127)
Security Update for Windows XP (KB938829)
Security Update for Windows XP (KB939653)
Security Update for Windows XP (KB941202)
Security Update for Windows XP (KB941568)
Security Update for Windows XP (KB941644)
Security Update for Windows XP (KB941693)
Security Update for Windows XP (KB943055)
Security Update for Windows XP (KB943460)
Security Update for Windows XP (KB943485)
Security Update for Windows XP (KB944338)
Security Update for Windows XP (KB944653)
Security Update for Windows XP (KB945553)
Security Update for Windows XP (KB946026)
Security Update for Windows XP (KB947864)
Security Update for Windows XP (KB948590)
Security Update for Windows XP (KB948881)
Security Update for Windows XP (KB950749)
Security Update for Windows XP (KB950759)
Security Update for Windows XP (KB956390)
Security Update for Windows XP (KB958215)
Security Update for Windows XP (KB960714)
Security Update for Windows XP (KB963027)
Slingo Deluxe
Snowy The Bears Adventure
Sonic Express Labeler
Sonic MyDVD Plus
Sonic RecordNow Audio
Sonic RecordNow Copy
Sonic RecordNow Data
Sonic Update Manager
SPBBC
Super Granny
SymNet
Tennis Titans
Tornado Jockey
Tradewinds
Update for Windows Media Player 10 (KB913800)
Update for Windows Media Player 10 (KB926251)
Update for Windows XP (KB900485)
Update for Windows XP (KB908531)
Update for Windows XP (KB910437)
Update for Windows XP (KB911280)
Update for Windows XP (KB912945)
Update for Windows XP (KB916595)
Update for Windows XP (KB920872)
Update for Windows XP (KB922582)
Update for Windows XP (KB927891)
Update for Windows XP (KB930916)
Update for Windows XP (KB931836)
Update for Windows XP (KB933360)
Update for Windows XP (KB936357)
Update for Windows XP (KB938828)
Update for Windows XP (KB942763)
Update for Windows XP (KB942840)
Updates from HP (remove only)
Viewpoint Media Player
WildTangent Web Driver
WinBlueSoft
Windows Media Format Runtime
Windows XP Hotfix - KB873339
Windows XP Hotfix - KB883667
Windows XP Hotfix - KB885250
Windows XP Hotfix - KB885835
Windows XP Hotfix - KB885836
Windows XP Hotfix - KB886185
Windows XP Hotfix - KB887472
Windows XP Hotfix - KB887742
Windows XP Hotfix - KB888113
Windows XP Hotfix - KB888302
Windows XP Hotfix - KB890175
Windows XP Hotfix - KB890859
Windows XP Hotfix - KB891781
Windows XP Hotfix - KB892050
Windows XP Hotfix - KB893066
Windows XP Media Center Edition 2005 KB908246
Windows XP Media Center Edition 2005 KB912067
Yahoo! Install Manager
dlg2114
Posts Posts : 32
Post by Belahzur on 4th June 2009, 3:09 pm
    Ask Toolbar
    WinBlueSoft
Next,
  • Open HijackThis.
Post by dlg2114 on 4th June 2009, 3:26 pm
I was unable to remove J2SE Runtime Environment 5.0 Update 6. I did everything else.
dlg2114
Posts Posts : 32
Post by Belahzur on 4th June 2009, 3:50 pm
Now lets see about this infection and kick it out.
  • Download combofix from here
  • See [You must be registered and logged in to see this link.] for how to disable your AV. (Norton)
Post by dlg2114 on 4th June 2009, 4:41 pm
ComboFix 09-06-03.04 - HP_Administrator 06/04/2009 11:16.1 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.2.1252.1.1033.18.447.69 [GMT -5:00]
Running from: c:\documents and settings\HP_Administrator\Desktop\Combo-Fix.exe
AV: Norton Internet Security 2006 *On-access scanning disabled* (Outdated) {E10A9785-9598-4754-B552-92431C1C35F8}
FW: Norton Internet Security 2006 *disabled* {7C21A4C9-F61F-4AC4-B722-A6E19C16F220}
FW: Norton Internet Worm Protection *disabled* {990F9400-4CEE-43EA-A83A-D013ADD8EA6E}
* Created a new restore point
C:\3611010322575722671.exe
C:\3611010322575723578.exe
C:\autorun.inf
c:\docume~1\HP_ADM~1\LOCALS~1\Temp\IadHide5.dll
c:\documents and settings\HP_Administrator\Local Settings\Temp\IadHide5.dll
c:\windows\10044zro968a5.bin
c:\windows\103z45py2c89.dll
c:\windows\10565z9ckto5l441.exe
c:\windows\1089woz9255.cpl
c:\windows\117z5t5o9eb.bin
c:\windows\12119hacktooz459.bin
c:\windows\13335h5cktooz5939.bin
c:\windows\13429spyz2d5.dll
c:\windows\1351azdw9re2030.dll
c:\windows\13692wzrm558.ocx
c:\windows\13869zirus1925.exe
c:\windows\14199h5cktool5z9.dll
c:\windows\1433spywa59603z.cpl
c:\windows\14555parse2983z.ocx
c:\windows\1456zhackt9ol30c.ocx
c:\windows\14765spamzo92b5.exe
c:\windows\14829ro57z0.bin
c:\windows\14fathief9659z.bin
c:\windows\14z99t5oj2c5.cpl
c:\windows\1527wor93zb.ocx
c:\windows\15318sp9zbo518a.exe
c:\windows\15384ha9kzool5c5.bin
c:\windows\153zvir9395.bin
c:\windows\1549viz3189.bin
c:\windows\158395py57z.exe
c:\windows\15a8dowzloade91813.ocx
c:\windows\15d9threzt19894.ocx
c:\windows\16253w9rmz80.bin
c:\windows\1652szy926.bin
c:\windows\172965ot-azvir9s55d.ocx
c:\windows\1799zt9oj551.cpl
c:\windows\182z9spamb5t75d.ocx
c:\windows\18555not5a-zirus94e.exe
c:\windows\18bz9ir5435.cpl
c:\windows\1909vzr2531.exe
c:\windows\19255viru919z.bin
c:\windows\19411ha9kzool54b.dll
c:\windows\1956wozm23b.cpl
c:\windows\195z9wo5m7ef.ocx
c:\windows\19635tro55bez.exe
c:\windows\19740not-z-viru52eb.dll
c:\windows\197z0troj355.cpl
c:\windows\1987addzar51314.cpl
c:\windows\198979izus1a5.bin
c:\windows\19953not-a-virz5592.bin
c:\windows\19d3bazkd9or653.bin
c:\windows\19z5vir2729.cpl
c:\windows\19z959ro5288.dll
c:\windows\19z99s5ambot193.bin
c:\windows\1b5ct9iefz70.bin
c:\windows\1f36d5wnloz9er1554.bin
c:\windows\1f75s5zware2909.dll
c:\windows\1z569tro9556.cpl
c:\windows\1z83sp59se1304.dll
c:\windows\1ze19hief1135.cpl
c:\windows\2008bac5doz9664.cpl
c:\windows\2016azdwar597.ocx
c:\windows\2035spambz91f4.cpl
c:\windows\2050tzie92185.dll
c:\windows\20519zackt5ol4c7.dll
c:\windows\20619zpa9bo5285.bin
c:\windows\20z39h5ef2459.bin
c:\windows\212215acktzol69e.cpl
c:\windows\214z7spamb5t79d9.exe
c:\windows\2193downloader2z865.exe
c:\windows\2195sparze962.exe
c:\windows\22148not-a9virzs658.exe
c:\windows\224z9virus4b5.exe
c:\windows\225195aczt9ol674.dll
c:\windows\22625t95j1d1z.dll
c:\windows\226dthr9at4885z.cpl
c:\windows\229039ot-a-v5ruz31f.ocx
c:\windows\22939hackt5zl40a.bin
c:\windows\22a4zhief58179.cpl
c:\windows\22z52w9rm46c.ocx
c:\windows\23046not-9-v5rus6z1.dll
c:\windows\24221w9zm153.ocx
c:\windows\24692woz5d59.bin
c:\windows\255279ot-azvirus619.cpl
c:\windows\25763hazktoo99c.exe
c:\windows\2588th95at2740z.dll
c:\windows\25972n5t-a-virzs268.exe
c:\windows\25992not-a-vzruseb.dll
c:\windows\259bsp9ware31z4.ocx
c:\windows\25z51troj982.cpl
c:\windows\265869a5ktool2ze.cpl
c:\windows\2666zhacktool965.ocx
c:\windows\26884tro53zf9.cpl
c:\windows\26999spy2z85.dll
c:\windows\2705z5orm49f.bin
c:\windows\27248zackto5l902.cpl
c:\windows\27285ackdzo91110.exe
c:\windows\2833s5y4z9.exe
c:\windows\286z3sp95bot7a4.ocx
c:\windows\28937zr5j6ee.bin
c:\windows\28966h5cztool7c2.dll
c:\windows\29345spyzf3.cpl
c:\windows\2942h5cktozla4.bin
c:\windows\29597not-5zvirus32d.cpl
c:\windows\29822wozm4c5.exe
c:\windows\29938not-a-viru5375z.exe
c:\windows\29fcdow5loader1z41.dll
c:\windows\29z325orm2aa.exe
c:\windows\2bf3thrz9524795.bin
c:\windows\2c0c95r582z.dll
c:\windows\2c6cthizf15259.cpl
c:\windows\2dabackz5or2779.ocx
c:\windows\2e3zdownlo9der5141.ocx
c:\windows\2f069i5418z.ocx
c:\windows\2z095virus5dc.bin
c:\windows\2z25th9ef1553.ocx
c:\windows\2z6esteal9156.dll
c:\windows\302aaddware1z59.ocx
c:\windows\3034worz69f5.dll
c:\windows\30596not-azvirus49b.cpl
c:\windows\30650spamboz9a.cpl
c:\windows\30659zirus1f75.ocx
c:\windows\30948szambot5495.exe
c:\windows\30988z95mbot235.ocx
c:\windows\30c0adzware8549.cpl
c:\windows\30f95ddware482z.ocx
c:\windows\310705ro97za.exe
c:\windows\31559virzs3fa.dll
c:\windows\31576wzrm5229.exe
c:\windows\3199sp5rsez543.bin
c:\windows\3216sp9rsez508.dll
c:\windows\32479wzrm3495.exe
c:\windows\32d6thie5z097.bin
c:\windows\332bad9warez155.bin
c:\windows\3357viruz4449.cpl
c:\windows\3391steal15z1.ocx
c:\windows\342dsteaz97815.cpl
c:\windows\347espy5zre9215.exe
c:\windows\3489noz-a-viru94715.bin
c:\windows\3539backdozr9940.dll
c:\windows\353z59y501.ocx
c:\windows\3559addwarz1890.dll
c:\windows\35e3downloz9er1825.exe
c:\windows\36559pamboz58a.dll
c:\windows\366zroj659.cpl
c:\windows\3904th9eat253z6.ocx
c:\windows\3932w5rmz62.ocx
c:\windows\3ac3spy9are3z58.ocx
c:\windows\3c15zack9oor1793.exe
c:\windows\3cedzdd9ar5458.cpl
c:\windows\3d1dspa9ze1854.exe
c:\windows\3d95addwaze9305.exe
c:\windows\3ec9d5warez564.ocx
c:\windows\3z3fbackdo9r1576.exe
c:\windows\406cszar9e5075.ocx
c:\windows\4103s9z55f.exe
c:\windows\42zadd9ar51627.cpl
c:\windows\42zwo5m6b29.dll
c:\windows\448et9iez495.dll
c:\windows\4589szeal953.bin
c:\windows\459dspywa5e29z0.exe
c:\windows\459zvi53250.ocx
c:\windows\45z4worm3959.bin
c:\windows\4662not-9-virzs5a.bin
c:\windows\469threaz5251.bin
c:\windows\46z85ddw9re790.exe
c:\windows\4719download5r29z6.cpl
c:\windows\4750vir5399z.ocx
c:\windows\4996vi5z39.bin
c:\windows\49daste5l17z6.bin
c:\windows\49z3ad59are1638.ocx
c:\windows\49z8s9yware519.cpl
c:\windows\4a3dt5reat494z.cpl
c:\windows\4b0z5yware32589.cpl
c:\windows\4b52downlo9d5rz376.ocx
c:\windows\4be4t5reat7z09.exe
c:\windows\4bed5ackdo9z1469.dll
c:\windows\4c1ethr9at5066z.cpl
c:\windows\4c985tealz9.cpl
c:\windows\4cffthrea91537z.exe
c:\windows\4e09stzal1395.exe
c:\windows\4ezcdo9n5oader2223.cpl
c:\windows\4f96downloaz9r10555.ocx
c:\windows\4fabzt5al1918.dll
c:\windows\4z03thief9531.dll
c:\windows\4zcet9reat2570.cpl
c:\windows\4zd2sparse9559.exe
c:\windows\50fzvir2592.cpl
c:\windows\5104thzef10219.cpl
c:\windows\5114spzw5re5139.bin
c:\windows\51291zpambot586.exe
c:\windows\52244no9-a-virus3z8.ocx
c:\windows\52bz9hief5199.dll
c:\windows\5351spy49z9.bin
c:\windows\535espyware29z4.ocx
c:\windows\54146noz-9-virus776.exe
c:\windows\5419z5y9c.ocx
c:\windows\545ethrzat79379.dll
c:\windows\5592thief258z.ocx
c:\windows\5593z9yware1530.ocx
c:\windows\559zdown5o9der165.exe
c:\windows\55ebazkdo9r345.bin
c:\windows\55f5d5wnloader279z.exe
c:\windows\55f9spzware2618.ocx
c:\windows\56361z9oj327.exe
c:\windows\5651thre9z660.bin
c:\windows\56f5s95alz43.cpl
c:\windows\57435ot-a-v9rus472z.ocx
c:\windows\577719ozm572.bin
c:\windows\57z0thief5699.exe
c:\windows\5800tro5zc19.bin
c:\windows\5808virus179z.dll
c:\windows\58195wnloader158z.exe
c:\windows\58493worz24b.exe
c:\windows\58z95virus149.exe
c:\windows\58z9teal2112.ocx
c:\windows\5904zackt59l27b.exe
c:\windows\59279spy69z.exe
c:\windows\592wzr525c.dll
c:\windows\59345owzloader22579.dll
c:\windows\599z9worm5ae9.exe
c:\windows\59eeaddw9re2203z.bin
c:\windows\5a5as9yware635z.cpl
c:\windows\5abdzteal91765.dll
c:\windows\5af29ir27z5.exe
c:\windows\5b35backzoor2590.cpl
c:\windows\5c1ethief238z9.ocx
c:\windows\5cbezpywar53993.exe
c:\windows\5d3dsparse198z.bin
c:\windows\5d59sparse255z.dll
c:\windows\5d81tzreat57149.exe
c:\windows\5dzb9parse1652.ocx
c:\windows\5e51backdzo9750.exe
c:\windows\5ea75ackdoo9z545.cpl
c:\windows\5ed4zhief15629.ocx
c:\windows\5f91v9z5772.dll
c:\windows\5fcz9ir2192.exe
c:\windows\5fz4spyw9re2411.bin
c:\windows\5zc3vir3994.exe
c:\windows\5zca9dware1891.bin
c:\windows\5zf85te9l1866.exe
c:\windows\6399vir5s39az.ocx
c:\windows\63a6down5oa9er1z57.bin
c:\windows\63d9zhr5at10599.cpl
c:\windows\655fzhre9t12336.bin
c:\windows\65d19pars5z260.exe
c:\windows\65z6t9reat390.dll
c:\windows\6692z5am9ot4ed.cpl
c:\windows\6739viruz6a5.bin
c:\windows\6795addware115z.bin
c:\windows\6858virz3895.dll
c:\windows\68z7no5-a-viru94b5.cpl
c:\windows\6925szar9e2530.bin
c:\windows\692as5ywzre1449.dll
c:\windows\69595pzmbotf4.bin
c:\windows\695fspywa9e114z.ocx
c:\windows\698adownloadzr5595.cpl
c:\windows\6a7dzownl5ade91436.bin
c:\windows\6af0add5zr92601.dll
c:\windows\6c965parse5z2.cpl
c:\windows\6cb7sz9ware5.exe
c:\windows\6dadtzreat45359.bin
c:\windows\6efza5dware9777.dll
c:\windows\6f8zd5wnloader16139.bin
c:\windows\6z69s5eal3095.bin
c:\windows\6za4backdoo57039.ocx
c:\windows\7017addw9re5513z.exe
c:\windows\705zvir2094.cpl
c:\windows\7075trojz9.ocx
c:\windows\72d1doz95oader1255.dll
c:\windows\7387no9-a-vir5s7z9.cpl
c:\windows\738zthi5f20019.ocx
c:\windows\73a9spywarz1059.ocx
c:\windows\744z5ro9602.cpl
c:\windows\749zt9reat1563.exe
c:\windows\7542ba5kdo9z449.bin
c:\windows\7569spyz9re2896.dll
c:\windows\75casp95sez06.dll
c:\windows\7659spy95bz.exe
c:\windows\7993st5alz274.exe
c:\windows\7b9t5zef655.ocx
c:\windows\7c5bad9warz2759.ocx
c:\windows\7c965pyware9076z.dll
c:\windows\7f28a5dwa9e2z66.dll
c:\windows\7z4cspar9e5812.dll
c:\windows\83735ot-a-virus98az.ocx
c:\windows\83789zrus25e.dll
c:\windows\84395roz7e0.ocx
c:\windows\8542trojz49.ocx
c:\windows\8870hackzoo5719.exe
c:\windows\90059zj20a.ocx
c:\windows\90dzad5ware1916.dll
c:\windows\916535acktooz2e0.dll
c:\windows\9179znot-5-virus88.dll
c:\windows\919135rojz82.bin
c:\windows\91z45worm2415.exe
c:\windows\92559pyze5.ocx
c:\windows\92719spy55z.bin
c:\windows\9339zworm67f5.ocx
c:\windows\95012spambotzbf5.dll
c:\windows\95598spy48dz.ocx
c:\windows\9585vi5us3z29.cpl
c:\windows\95950virusfz.exe
c:\windows\9595zworm675.exe
c:\windows\95e7szarse1327.exe
c:\windows\95z00tro5568.ocx
c:\windows\95z9troj555.cpl
c:\windows\962z75py41f.exe
c:\windows\9695hackzoo51a3.dll
c:\windows\9754zorm5f8.dll
c:\windows\980downloadez2556.bin
c:\windows\98998vizus7aa5.exe
c:\windows\9927spam5ot13z.dll
c:\windows\9939s5ambztc1.exe
c:\windows\99589zrus357.exe
c:\windows\995zvir2243.cpl
c:\windows\9d4zpar5e1226.dll
c:\windows\9dcedowzlo5der948.bin
c:\windows\9de5zir53.cpl
c:\windows\9dz5v5r1407.exe
c:\windows\9ea5vir1937z.exe
c:\windows\9edavz53079.cpl
c:\windows\9z354not-a-vir5s1c9.cpl
c:\windows\b59threzt22030.dll
c:\windows\d2cazdw95e3238.cpl
c:\windows\d3spzware57379.exe
c:\windows\IE4 Error Log.txt
c:\windows\msa.exe
dlg2114
Posts Posts : 32
Post by dlg2114 on 4th June 2009, 4:42 pm
c:\windows\system32\11670vzrus5589.bin
c:\windows\system32\119zspywar5690.ocx
c:\windows\system32\124z45ac9tool45c.ocx
c:\windows\system32\12551wo9mz44.dll
c:\windows\system32\12584tz9j65.bin
c:\windows\system32\12935worz4d5.dll
c:\windows\system32\13699hacktool590z.ocx
c:\windows\system32\13e6b5czdoo9128.cpl
c:\windows\system32\14189no9-a-5irus7bdz.dll
c:\windows\system32\1419hackto5l57az.dll
c:\windows\system32\145zd9wnloader2295.dll
c:\windows\system32\14913sp596z.dll
c:\windows\system32\14978ha5ktozl515.bin
c:\windows\system32\1519w9zm255.cpl
c:\windows\system32\152659acztool6e2.dll
c:\windows\system32\153athreaz985.cpl
c:\windows\system32\15524szambot590.exe
c:\windows\system32\1555z9orm410.bin
c:\windows\system32\15572vi5us6z9.cpl
c:\windows\system32\155899acktoolzb2.cpl
c:\windows\system32\1595baczdoor2462.dll
c:\windows\system32\1595zvirus5ce.cpl
c:\windows\system32\1597zh9cktool1d0.cpl
c:\windows\system32\1599zpyware1929.bin
c:\windows\system32\15bazdware23539.cpl
c:\windows\system32\1613zspambot99a5.cpl
c:\windows\system32\162z5not-a-virus639.bin
c:\windows\system32\16305worz7985.cpl
c:\windows\system32\16527h5c9tool9bz.dll
c:\windows\system32\16821hacktozl955.cpl
c:\windows\system32\16967tz5j520.ocx
c:\windows\system32\16968not-a-5irzs86.cpl
c:\windows\system32\16979zambot50c.exe
c:\windows\system32\16989hacktool33z5.dll
c:\windows\system32\171z959rm173.exe
c:\windows\system32\17299nzt-a5v9rus66f.ocx
c:\windows\system32\17695ha5ktoolz9f.exe
c:\windows\system32\17zfth5ef26959.bin
c:\windows\system32\180759izus559.exe
c:\windows\system32\1808ba5kdzor1090.dll
c:\windows\system32\1836zs9amb5t7b7.cpl
c:\windows\system32\19260vi5zs7e9.exe
c:\windows\system32\194759r5j4z6.ocx
c:\windows\system32\19634s9y7z5.bin
c:\windows\system32\19812zacktool575.exe
c:\windows\system32\19920trz95c1.ocx
c:\windows\system32\19z075pa9bot7c.exe
c:\windows\system32\1a775zr10399.exe
c:\windows\system32\1az15ackdoor2988.cpl
c:\windows\system32\1cd4zddw9re2556.exe
c:\windows\system32\1d59spyware1924z.bin
c:\windows\system32\1e325ackdo9rz260.bin
c:\windows\system32\1f55sparse162z9.dll
c:\windows\system32\1z345h9cktool52d.bin
c:\windows\system32\1z353sp9747.dll
c:\windows\system32\1z548troj4d9.ocx
c:\windows\system32\1z890v5rus994.cpl
c:\windows\system32\1z9asparse2965.cpl
c:\windows\system32\20564s5z4ef9.dll
c:\windows\system32\20695virus9z45.bin
c:\windows\system32\2069ownloa5erz981.cpl
c:\windows\system32\20z42tr596c5.dll
c:\windows\system32\20z57s955dc.ocx
c:\windows\system32\20z68spam5ot2c9.dll
c:\windows\system32\21345h9ef1z.exe
c:\windows\system32\21809not9a5zirus79a.exe
c:\windows\system32\2251z9ot-a-virus255.exe
c:\windows\system32\22534tz9555.cpl
c:\windows\system32\22566wor95c1z.ocx
c:\windows\system32\229bazkd5or3232.dll
c:\windows\system32\22z7spywar93256.bin
c:\windows\system32\23006vir95z0b.bin
c:\windows\system32\238z05roj39b.ocx
c:\windows\system32\23z06spam9ot552.exe
c:\windows\system32\2466zt9oj195.exe
c:\windows\system32\24894vzru5793.exe
c:\windows\system32\24z745o9m514.dll
c:\windows\system32\24zcvir24529.dll
c:\windows\system32\25403not-a-v9rzsff.cpl
c:\windows\system32\25681wormz7b9.bin
c:\windows\system32\25715vzrus759.cpl
c:\windows\system32\25839spyz91.exe
c:\windows\system32\2599zte5l1463.exe
c:\windows\system32\25d9spywarz1925.cpl
c:\windows\system32\267z5not9a5virus5f5.ocx
c:\windows\system32\27600spy359z.cpl
c:\windows\system32\27693spyz15.bin
c:\windows\system32\27984tr9j75z.exe
c:\windows\system32\280b9pyware153z5.bin
c:\windows\system32\28321hacktz95597.ocx
c:\windows\system32\2853szy9b5.ocx
c:\windows\system32\28558trojz79.bin
c:\windows\system32\28589pzmbotfb.ocx
c:\windows\system32\285z9not-a-vi9u5403.cpl
c:\windows\system32\28870ha5k9oolz7d.exe
c:\windows\system32\2887zno9-a-vir5s5a7.ocx
c:\windows\system32\28885szambot988.dll
c:\windows\system32\2888995cktool4ez.bin
c:\windows\system32\28a0s9arze1605.dll
c:\windows\system32\28z51hackto9l279.bin
c:\windows\system32\2900thr9a5472z.bin
c:\windows\system32\2907zspambot55a.exe
c:\windows\system32\2915add5are1152z.exe
c:\windows\system32\291adzware22925.dll
c:\windows\system32\29259szy555.dll
c:\windows\system32\29268t5ojfz.ocx
c:\windows\system32\29401not-a-virus359z.exe
c:\windows\system32\29529troz581.exe
c:\windows\system32\29569vi5uz14a.bin
c:\windows\system32\29z2sp5mbot544.cpl
c:\windows\system32\2ac0backzoor8959.ocx
c:\windows\system32\2d1aste951391z.ocx
c:\windows\system32\2dcfb59kzoor480.cpl
c:\windows\system32\2e3ezpar5e9106.exe
c:\windows\system32\2eaf5zeal28599.bin
c:\windows\system32\2z189no9-a-vir5s531.exe
c:\windows\system32\2z758troj29a.ocx
c:\windows\system32\2z957v5rus53f.exe
c:\windows\system32\2zb0th9eat20375.dll
c:\windows\system32\3067zwo9m556.ocx
c:\windows\system32\30z129irus5c.exe
c:\windows\system32\30z92s95259.exe
c:\windows\system32\312z4spambo9250.exe
c:\windows\system32\31441wozm549.bin
c:\windows\system32\31529orm28z.cpl
c:\windows\system32\31584not5a-v9rzs5b1.cpl
c:\windows\system32\3159zvirus5d59.cpl
c:\windows\system32\31959vzrus58d.cpl
c:\windows\system32\321e59dware115z.cpl
c:\windows\system32\322z25roj7b99.bin
c:\windows\system32\32474wozm93c5.cpl
c:\windows\system32\327et9z5f1097.cpl
c:\windows\system32\3294sparsz52329.cpl
c:\windows\system32\3357spa9boz2a4.ocx
c:\windows\system32\33b1st59l1605z.dll
c:\windows\system32\3437not-a9zir5s7da.exe
c:\windows\system32\3459threaz225885.dll
c:\windows\system32\350vir146z9.dll
c:\windows\system32\3525z9r364.bin
c:\windows\system32\369bzi5186.ocx
c:\windows\system32\381zspywar91532.dll
c:\windows\system32\3869t5oj4zd.bin
c:\windows\system32\39399z5m19a.exe
c:\windows\system32\39923hac5tool2z.cpl
c:\windows\system32\3a20addware97z55.exe
c:\windows\system32\3ba0thz591688.bin
c:\windows\system32\3d0zvir1599.cpl
c:\windows\system32\3d45a9dw5re125z.ocx
c:\windows\system32\3e2zs5yware18999.cpl
c:\windows\system32\3f6z5h9eat1651.bin
c:\windows\system32\3f97spar5e83z.exe
c:\windows\system32\3z591virus17d9.dll
c:\windows\system32\3z599t9oj5b4.exe
c:\windows\system32\3zb395arse1604.exe
c:\windows\system32\403eba5kdooz1699.exe
c:\windows\system32\425dz9arse1320.exe
c:\windows\system32\42z95ownloader1543.cpl
c:\windows\system32\439d9ackdozr2558.bin
c:\windows\system32\44445hi9fz5.bin
c:\windows\system32\4518wor935z.cpl
c:\windows\system32\4596zir2010.cpl
c:\windows\system32\45f5addware29z3.cpl
c:\windows\system32\4696bacz5oor1202.ocx
c:\windows\system32\4755vir3938z.ocx
c:\windows\system32\4909spa5sez516.bin
c:\windows\system32\4a9f5azkdoor1868.exe
c:\windows\system32\4afzt5ief10129.cpl
c:\windows\system32\4b4dspyw5rz955.exe
c:\windows\system32\4b65addwa5e1098z.bin
c:\windows\system32\4c4zteal16539.ocx
c:\windows\system32\4c89spywarz27935.bin
c:\windows\system32\4cafzpyware24509.bin
c:\windows\system32\4e5b9parse2586z.bin
c:\windows\system32\4fb9thzef1582.bin
c:\windows\system32\4z50v59us255.cpl
c:\windows\system32\4z6edownlo9der3625.exe
c:\windows\system32\4z93not-a-v5rus64a.bin
c:\windows\system32\4z99spy5d4.ocx
c:\windows\system32\5021zwor92c4.dll
c:\windows\system32\5053wzrm99d.exe
c:\windows\system32\50670zackto9l12.dll
c:\windows\system32\5100dow9z5ader1271.dll
c:\windows\system32\5155v9r318z.exe
c:\windows\system32\51869haczt9ol55f.dll
c:\windows\system32\51a9szeal1527.cpl
c:\windows\system32\5209zackdoo52876.dll
c:\windows\system32\529zaddwa5e2064.cpl
c:\windows\system32\53045zdwar9594.exe
c:\windows\system32\53545pywaz91043.ocx
c:\windows\system32\535cadzwar924.dll
c:\windows\system32\5360threat297z59.ocx
c:\windows\system32\5369stzal2998.ocx
c:\windows\system32\536dstz592505.cpl
c:\windows\system32\53716notza-vir9s5e9.dll
c:\windows\system32\53z0bac5door799.dll
c:\windows\system32\53zab5ckdo9r2455.cpl
c:\windows\system32\540b5te9l8z8.ocx
c:\windows\system32\54224virus94z.ocx
c:\windows\system32\542edow9zoader18965.exe
c:\windows\system32\549szy475.dll
c:\windows\system32\55099vz9us49d.bin
c:\windows\system32\5509st9alz296.exe
c:\windows\system32\5566zvirus9c1.bin
c:\windows\system32\5569threat3749z.ocx
c:\windows\system32\557z59dware2715.ocx
c:\windows\system32\55f5addwz9e959.ocx
c:\windows\system32\55z09tro91d6.ocx
c:\windows\system32\5600zpy169.ocx
c:\windows\system32\56107z9oj505.dll
c:\windows\system32\564ethi5f1z29.cpl
c:\windows\system32\5663w59m1fz.exe
c:\windows\system32\56931hacktool5bz.exe
c:\windows\system32\569d9ownz5ader91.dll
c:\windows\system32\56bzv5r9534.exe
c:\windows\system32\56e2st9az1598.bin
c:\windows\system32\57958spy5fz.bin
c:\windows\system32\579backdo5r131z9.cpl
c:\windows\system32\58369orz1d4.dll
c:\windows\system32\583ethrzat93341.dll
c:\windows\system32\5854bac9zoor2888.cpl
c:\windows\system32\58ez9ownloader7305.ocx
c:\windows\system32\58f0tzief3951.dll
c:\windows\system32\5906n9t-z-5irus1d8.exe
c:\windows\system32\59206s9z2b.cpl
c:\windows\system32\59532t9oz794.cpl
c:\windows\system32\59595not-a-virus5z4.bin
c:\windows\system32\5995thief544z.bin
c:\windows\system32\59ecsp9rsz5892.bin
c:\windows\system32\5a9zdownlo5der1729.dll
c:\windows\system32\5b5dthrezt549.bin
c:\windows\system32\5ba2vz9597.bin
c:\windows\system32\5c1dbaczdoor1916.dll
c:\windows\system32\5d71addwar5589z.cpl
c:\windows\system32\5dc9zief975.bin
c:\windows\system32\5dzfvir26369.exe
c:\windows\system32\5f09threat4725z.dll
c:\windows\system32\5f95ad5w9re11z5.bin
c:\windows\system32\5fa8backdzo9579.bin
c:\windows\system32\5ff1download5r98z0.exe
c:\windows\system32\5z069pyware1781.exe
c:\windows\system32\5z145pam9ote8.ocx
c:\windows\system32\5z26down9oad5r2723.cpl
c:\windows\system32\5z7dvir1329.dll
c:\windows\system32\5zb35ir2991.dll
c:\windows\system32\6069tzreat238855.exe
c:\windows\system32\6145zparse977.bin
c:\windows\system32\659badd9arz1405.ocx
c:\windows\system32\65abthiz91635.dll
c:\windows\system32\65c3backdooz895.exe
c:\windows\system32\6618ste5l95z9.ocx
c:\windows\system32\6694zpambota95.ocx
c:\windows\system32\67995ot-a-virus4zf.bin
c:\windows\system32\67e4zparse9504.bin
c:\windows\system32\6829back9zor5359.exe
c:\windows\system32\684e9ownloadez5555.cpl
c:\windows\system32\68z0spa5se3219.exe
c:\windows\system32\6965notz5-virus1969.bin
c:\windows\system32\69829pamb5t61z.ocx
c:\windows\system32\6997v5r2209z.cpl
c:\windows\system32\69c4thrzat502709.ocx
c:\windows\system32\69z45acktool260.cpl
c:\windows\system32\6b295pyware89z.ocx
c:\windows\system32\6d71th5eat7z879.cpl
c:\windows\system32\6d88spy5aze390.ocx
c:\windows\system32\6z62hackto5l399.exe
c:\windows\system32\6z89thief19495.bin
c:\windows\system32\7159t5oj2d2z.cpl
dlg2114
Posts Posts : 32
Post by dlg2114 on 4th June 2009, 4:43 pm
c:\windows\system32\7179down5ozde91322.ocx
c:\windows\system32\71e9zddware531.dll
c:\windows\system32\7215a9zwa5e2092.ocx
c:\windows\system32\7242zt5al2619.exe
c:\windows\system32\7247z9t-a-v5rus124.dll
c:\windows\system32\72799py352z.dll
c:\windows\system32\759azp9rse1303.bin
c:\windows\system32\7700sp5war9985z.exe
c:\windows\system32\77z99ir1552.dll
c:\windows\system32\784bbackdozr9528.ocx
c:\windows\system32\7888not-a-vizu53849.exe
c:\windows\system32\790dspars51494z.cpl
c:\windows\system32\7922v9zu56e2.bin
c:\windows\system32\79z29hief2584.exe
c:\windows\system32\7ac5sp95sz2384.dll
c:\windows\system32\7b43spa5s9z965.cpl
c:\windows\system32\7b52s9azse2195.bin
c:\windows\system32\7f5dowzloader25499.cpl
c:\windows\system32\7z0dt9ie511.bin
c:\windows\system32\7z34s5eal23259.cpl
c:\windows\system32\7z5athi9f584.cpl
c:\windows\system32\7zd8add5a9e1457.ocx
c:\windows\system32\87065pamzot91.dll
c:\windows\system32\8939zir5s54a.cpl
c:\windows\system32\900thi5fz826.bin
c:\windows\system32\9056hacktozl65.cpl
c:\windows\system32\90596spazbot3cd.exe
c:\windows\system32\90ztr5j369.ocx
c:\windows\system32\91777w5zm1dd.exe
c:\windows\system32\92223sp569z.bin
c:\windows\system32\92314z5rus209.exe
c:\windows\system32\92z59vi5us529.cpl
c:\windows\system32\94bdown5oa9zr2714.bin
c:\windows\system32\94cad5warez789.cpl
c:\windows\system32\95000not-a-viruszce.dll
c:\windows\system32\959tzreat25701.ocx
c:\windows\system32\95z4vir20995.exe
c:\windows\system32\97579roj405z.exe
c:\windows\system32\97dcs5zrse610.dll
c:\windows\system32\98439vi5usz3f.ocx
c:\windows\system32\98839wo5m35cz.exe
c:\windows\system32\98zspy573.exe
c:\windows\system32\99ct5rzat31838.dll
c:\windows\system32\9ab4virz895.cpl
c:\windows\system32\9bczbackd5or3184.bin
c:\windows\system32\9cc6spzrse5779.cpl
c:\windows\system32\9cz9addware25115.bin
c:\windows\system32\9edzste5l2352.exe
c:\windows\system32\9z11v5r2491.ocx
c:\windows\system32\a91z9i5f154.cpl
c:\windows\system32\b9bsz5rse1598.exe
c:\windows\system32\bz6a5dware1792.cpl
c:\windows\system32\cb8zownload951222.dll
c:\windows\system32\e929t5al7z.exe
c:\windows\system32\f59th9e5tz1419.exe
c:\windows\system32\fc4addwa9e765z.exe
c:\windows\system32\z2145tr9540b.cpl
c:\windows\system32\z2205tro9c9.bin
c:\windows\system32\z2379tr5j5ba.exe
c:\windows\system32\z2596v95us2d2.ocx
c:\windows\system32\z2965teal2069.exe
c:\windows\system32\z2a5threa922380.ocx
c:\windows\system32\z2fethie918025.cpl
c:\windows\system32\z4549r5j24d.bin
c:\windows\system32\z4882viru9115.dll
c:\windows\system32\z5094sp5409.exe
c:\windows\system32\z5579ir630.cpl
c:\windows\system32\z561worm459.ocx
c:\windows\system32\z590s5y269.dll
c:\windows\system32\z591threat24349.ocx
c:\windows\system32\z5924not-a-virusc4.ocx
c:\windows\system32\z5a5ownlo9der2223.cpl
c:\windows\system32\z5f7thie91705.ocx
c:\windows\system32\z6098virus456.cpl
c:\windows\system32\z6741n9t-a-v5rus733.dll
c:\windows\system32\z72e95eal398.exe
c:\windows\system32\z810spyw59e3117.bin
c:\windows\system32\z885spy499.bin
c:\windows\system32\z9256v5rus50e.exe
c:\windows\system32\z94399orm458.cpl
c:\windows\system32\z94755py9e4.exe
c:\windows\system32\z9645hreat324.bin
c:\windows\system32\z97cthief26095.ocx
c:\windows\system32\z9bste9l2595.ocx
c:\windows\system32\z9csp9rs5943.exe
c:\windows\system32\z9d5steal8525.exe
c:\windows\system32\z9desparse865.exe
c:\windows\system32\zaabs9eal1955.exe
c:\windows\system32\ze15thre9t395.cpl
c:\windows\system32\ze70thief3059.bin
c:\windows\system32\zefdsteal2159.cpl
c:\windows\system32\zf68spa59e1456.cpl
c:\windows\system32\zf94a9dware4785.cpl
c:\windows\Tasks\{5B57CF47-0BFA-43c6-ACF9-3B3653DCADBA}.job
c:\windows\z0247ha59tool203.bin
c:\windows\z0943virus7f5.dll
c:\windows\z11backd5o9200.cpl
c:\windows\z1802hack9ool457.exe
c:\windows\z1809tr5j19f9.cpl
c:\windows\z1a3addwar91525.exe
c:\windows\z2986spy4d95.exe
c:\windows\z298sp59bot2a3.cpl
c:\windows\z318ha9k5ool5ad.exe
c:\windows\z3423troj95e.cpl
c:\windows\z411spar9e2305.bin
c:\windows\z4719hie576.exe
c:\windows\z5349hacktool31.exe
c:\windows\z599spambot732.exe
c:\windows\z5bvir16439.bin
c:\windows\z6434spambot951.exe
c:\windows\z66dt5reat29599.cpl
c:\windows\z75b9ownloader5373.ocx
c:\windows\z95fst9al794.exe
c:\windows\z969sparse1564.ocx
c:\windows\z9ebv5r1093.dll
c:\windows\zcd9ir5381.dll
c:\windows\zce75ddware2699.exe
D:\Autorun.inf
D:\Desktop.ini
dlg2114
Posts Posts : 32
Post by dlg2114 on 4th June 2009, 4:44 pm
((((((((((((((((((((((((( Files Created from 2009-05-04 to 2009-06-04 )))))))))))))))))))))))))))))))
2009-06-04 04:51 . 2009-06-04 04:51 -------- d-s---w- c:\documents and settings\Administrator\UserData
2009-06-04 03:33 . 2009-06-04 03:33 -------- d-----w- c:\program files\Trend Micro
2009-06-02 23:24 . 2009-06-02 23:31 -------- d-----w- c:\program files\VS Revo Group
2009-06-02 04:32 . 2009-06-02 22:09 -------- d-----w- C:\Spyware Cleaner 2009
2009-06-02 03:48 . 2009-06-02 03:56 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2009-06-02 03:22 . 2009-06-02 03:22 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Sammsoft
2009-06-02 03:22 . 2009-06-02 03:22 -------- d-----w- c:\program files\Advanced Registry Optimizer
2009-06-02 02:25 . 2009-06-02 02:23 1164288 ----a-w- c:\windows\system32\tempo-setup2.exe
2009-06-02 02:23 . 2009-06-02 02:23 -------- d-----w- c:\program files\WinBlueSoft Software
2009-06-02 02:22 . 2009-06-02 02:22 -------- d-----w- c:\program files\DivxFree
2009-05-19 21:32 . 2009-05-19 21:32 -------- d-----w- c:\program files\AskSearch
2009-05-18 04:02 . 2009-05-18 04:08 112384 ----a-w- c:\windows\hpoins07.dat
2009-05-18 04:02 . 2005-05-24 06:52 21124 ------w- c:\windows\hpomdl07.dat
2009-05-14 02:42 . 2009-05-14 02:42 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\AT&T
2009-05-14 02:42 . 2009-05-14 02:42 -------- d-----w- c:\program files\AT&T
2009-05-14 02:42 . 2009-05-14 02:42 -------- d-----w- c:\documents and settings\All Users\Application Data\AT&T
2009-05-14 02:42 . 2009-06-04 06:06 -------- d-----w- c:\documents and settings\All Users\Application Data\ATTToolbar
2009-05-14 02:41 . 2009-05-23 04:57 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\ATTToolbar
2009-05-14 02:41 . 2009-05-14 02:41 -------- d-----w- c:\program files\ATTToolbar
2009-05-14 02:41 . 2009-05-14 02:41 -------- d-----w- c:\program files\Yahoo!
2009-05-14 02:39 . 2009-05-14 02:40 -------- d-----w- c:\program files\ATT-SST
2009-05-14 01:59 . 2009-05-14 02:40 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\Motive
2009-05-14 01:58 . 2009-05-14 01:58 -------- d-----w- c:\program files\ATT-HSI
2009-05-14 01:58 . 2009-05-14 03:11 -------- d-----w- c:\program files\Common Files\Motive
2009-05-14 01:56 . 2009-05-14 02:45 -------- d-----w- c:\documents and settings\All Users\Application Data\Motive
2009-06-04 16:30 . 2006-05-14 09:20 -------- d-----w- c:\program files\Common Files\Symantec Shared
2009-05-27 04:26 . 2006-10-10 04:05 676 ----a-w- c:\documents and settings\HP_Administrator\Application Data\wklnhst.dat
2009-05-19 21:43 . 2006-10-03 00:10 -------- d-----w- c:\program files\LimeWire
2009-05-15 02:38 . 2009-04-09 01:19 -------- d-----w- c:\documents and settings\HP_Administrator\Application Data\U3
2009-05-14 03:09 . 2006-10-02 21:00 -------- d-----w- c:\program files\AOL Deskbar
"ctfmon.exe"="c:\windows\system32\ctfmon.exe" [2004-08-09 15360]
"MSMSGS"="c:\program files\Messenger\msmsgs.exe" [2004-10-13 1694208]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-09-06 68856]
"ehTray"="c:\windows\ehome\ehtray.exe" [2005-09-29 67584]
"DISCover"="c:\program files\DISC\DISCover.exe" [2006-03-16 1077248]
"DiscUpdateManager"="c:\program files\DISC\DiscUpdMgr.exe" [2006-03-16 61440]
"DMAScheduler"="c:\program files\HP DigitalMedia Archive\DMAScheduler.exe" [2006-03-20 90112]
"Recguard"="c:\windows\SMINST\RECGUARD.EXE" [2005-07-22 237568]
"ccApp"="c:\program files\Common Files\Symantec Shared\ccApp.exe" [2005-09-17 52848]
"HPBootOp"="c:\program files\Hewlett-Packard\HP Boot Optimizer\HPBootOp.exe" [2006-02-15 249856]
"HP Software Update"="c:\program files\HP\HP Software Update\HPwuSchd2.exe" [2005-12-15 49152]
"AOLDialer"="c:\program files\Common Files\AOL\ACS\AOLDial.exe" [2006-10-23 71216]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2006-05-14 180269]
"HostManager"="c:\program files\Common Files\AOL\1159822766\ee\AOLSoftware.exe" [2006-09-26 50736]
"Pure Networks Port Magic"="c:\progra~1\PURENE~1\PORTMA~1\PortAOL.exe" [2004-04-05 99480]
"HPDJ Taskbar Utility"="c:\windows\system32\spool\drivers\w32x86\3\hpztsb12.exe" [2005-03-08 176128]
"SunJavaUpdateSched"="c:\program files\Java\jre1.5.0_06\bin\jusched.exe" [2005-11-10 36975]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2008-11-04 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2008-11-20 290088]
"ATT-SST_McciTrayApp"="c:\program files\ATT-SST\McciTrayApp.exe" [2008-09-19 1529856]
"ISW.exe"="c:\program files\AT&T\Internet Security Wizard\ISW.exe" [2007-05-03 2061816]
"RTHDCPL"="RTHDCPL.EXE" - c:\windows\RTHDCPL.EXE [2006-03-08 16010240]
"AlwaysReady Power Message APP"="ARPWRMSG.EXE" - c:\windows\arpwrmsg.exe [2005-08-02 77312]
HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2005-12-15 282624]
Updates From HP.lnk - c:\program files\Updates from HP\9972322\Program\Updates from HP.exe [2006-5-14 36903]
"NoDispBackgroundPage"= 1 (0x1)
"AntiVirusDisableNotify"=dword:00000001
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqnrs08.exe"=
"c:\\Program Files\\DISC\\DISCover.exe"=
"c:\\Program Files\\DISC\\DiscStreamHub.exe"=
"c:\\Program Files\\DISC\\myFTP.exe"=
"c:\\Program Files\\Updates from HP\\9972322\\Program\\Updates from HP.exe"=
"c:\\Program Files\\Common Files\\AOL\\ACS\\AOLDial.exe"=
"c:\\Program Files\\Common Files\\AOL\\ACS\\AOLacsd.exe"=
"c:\\Program Files\\America Online 9.0\\waol.exe"=
"c:\\Program Files\\Common Files\\AOL\\TopSpeed\\2.0\\aoltsmon.exe"=
"c:\\Program Files\\Common Files\\AOL\\TopSpeed\\2.0\\aoltpspd.exe"=
"c:\\Program Files\\Common Files\\AOL\\1159822766\\EE\\AOLServiceHost.exe"=
"c:\\Program Files\\Common Files\\AOL\\System Information\\sinf.exe"=
"c:\\Program Files\\Common Files\\AolCoach\\en_en\\player\\AOLNySEV.exe"=
"c:\\Program Files\\America Online 9.0a\\waol.exe"=
"c:\\Program Files\\ATT-HSI\\McciBrowser.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpofxm08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hposfx08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqCopy.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpfccopy.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpzwiz01.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqPhUnl.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqDIA.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpoews01.exe"=
dlg2114
Posts Posts : 32
Joined Joined : 2009-06-04
Points Points : 27645
Re: Help Removing Winbluesoft when antivirus won't work
*NewlyCreated* - ATWPKT2
*NewlyCreated* - COMHOST
*Deregistered* - ATWPKT2
2009-05-29 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 18:34]
2009-05-30 c:\windows\Tasks\Norton AntiVirus - Run Full System Scan - HP_Administrator.job
- c:\progra~1\NORTON~1\NORTON~1\Navw32.exe [2005-12-30 22:42]
2009-06-01 c:\windows\Tasks\Symantec NetDetect.job
- c:\program files\Symantec\LiveUpdate\NDETECT.EXE [2006-05-14 21:21]
HKLM-Run-PCDrProfiler - (no file)
SafeBoot-procexp90.Sys
IE: &AOL Toolbar search - c:\program files\AOL Toolbar\toolbar.dll/SEARCH.HTML
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~4\OFFICE11\EXCEL.EXE/3000
Trusted Zone: 0.0.0.0
Trusted Zone: motive.com\patttbc.att
Trusted Zone: trymedia.com
Rootkit scan 2009-06-04 11:29
- - - - - - - > 'winlogon.exe'(644)
- - - - - - - > 'explorer.exe'(2076)
c:\program files\AOL Deskbar\deskbar.dll
c:\program files\Common Files\AOL\AOL Toolbar\AOLHelper.dll
c:\windows\system32\ati2evxx.exe
c:\program files\Common Files\Symantec Shared\ccSetMgr.exe
c:\program files\Common Files\Symantec Shared\ccEvtMgr.exe
c:\program files\Common Files\Symantec Shared\ccProxy.exe
c:\program files\Common Files\Symantec Shared\SNDSrvc.exe
c:\program files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
c:\program files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
c:\program files\Common Files\AOL\ACS\AOLacsd.exe
c:\program files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
c:\program files\Common Files\AOL\TopSpeed\2.0\aoltpspd.exe
c:\windows\arservice.exe
c:\windows\ehome\ehrecvr.exe
c:\windows\ehome\ehSched.exe
c:\program files\Common Files\LightScribe\LSSrvc.exe
c:\program files\Common Files\Motive\McciCMService.exe
c:\windows\ehome\mcrdsvc.exe
c:\program files\Common Files\AOL\1159822766\EE\services\antiSpywareApp\ver2_0_32_1\AOLSP Scheduler.exe
c:\program files\iTunes\iPod\bin\iPodService.exe
c:\windows\system32\dllhost.exe
c:\windows\ehome\ehmsas.exe
c:\program files\DISC\DiscStreamHub.exe
c:\program files\HP\Digital Imaging\bin\hpqste08.exe
c:\program files\Common Files\Symantec Shared\Security Console\NSCSRVCE.EXE
Completion time: 2009-06-04 11:38 - machine was rebooted
ComboFix-quarantined-files.txt 2009-06-04 16:38
Pre-Run: 215,560,114,176 bytes free
Post-Run: 216,774,676,480 bytes free
927 --- E O F --- 2009-06-01 08:21
dlg2114
Posts Posts : 32
Post by Belahzur on 4th June 2009, 4:47 pm
Now open a new notepad file.
KILLALL::
File::
Folder::
Registry::
"NoDispBackgroundPage"=-
"AntiVirusDisableNotify"=-
Domains::
Points Points : 245091
Post by dlg2114 on 4th June 2009, 5:13 pm
ComboFix 09-06-03.04 - HP_Administrator 06/04/2009 11:52.2 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.2.1252.1.1033.18.447.132 [GMT -5:00]
Command switches used :: c:\documents and settings\HP_Administrator\Desktop\CFScript.txt
FW: Norton Internet Security 2006 *enabled* {7C21A4C9-F61F-4AC4-B722-A6E19C16F220}
FILE ::
"c:\windows\system32\tempo-setup2.exe"
c:\program files\AskSearch\bin\DefaultSearch.dll
c:\program files\LimeWire\commons-httpclient.jar
c:\program files\LimeWire\GenericWindowsUtils.dll
c:\program files\LimeWire\hs_err_pid3512.log
c:\program files\LimeWire\i18n.jar
c:\program files\LimeWire\id3v2.jar
c:\program files\LimeWire\jl011.jar
c:\program files\LimeWire\LimeWire20.dll
c:\program files\LimeWire\MessagesBundles.jar
c:\program files\LimeWire\mp3sp14.jar
c:\program files\LimeWire\vorbis.jar
c:\program files\LimeWire\WindowsFirewall.dll
c:\program files\LimeWire\WindowsV5PlusUtils.dll
c:\program files\LimeWire\xerces.jar
c:\program files\LimeWire\xml-apis.jar
c:\program files\WinBlueSoft Software\WinBlueSoft\data.bin
c:\program files\WinBlueSoft Software\WinBlueSoft\WinBlueSoft.exe
c:\spyware cleaner 2009\UP\up.rn
2009-05-14 02:42 . 2009-06-04 16:49 -------- d-----w- c:\documents and settings\All Users\Application Data\ATTToolbar
2009-06-04 16:50 . 2006-05-14 09:20 -------- d-----w- c:\program files\Common Files\Symantec Shared
dlg2114
Posts Posts : 32
Rootkit scan 2009-06-04 11:59
- - - - - - - > 'winlogon.exe'(648)
- - - - - - - > 'explorer.exe'(1656)
c:\hp\KBD\kbd.exe
Completion time: 2009-06-04 12:09 - machine was rebooted
ComboFix-quarantined-files.txt 2009-06-04 17:09
ComboFix2.txt 2009-06-04 16:38
Pre-Run: 216,799,539,200 bytes free
Post-Run: 216,779,063,296 bytes free
224 --- E O F --- 2009-06-01 08:21
dlg2114
Posts Posts : 32
Post by Belahzur on 4th June 2009, 5:15 pm
ComboFix /u
Post by dlg2114 on 4th June 2009, 5:24 pm
The machine is running great. You guys are amazing! I will be giving a donation. I thought my computer was GONE. I was getting frustrated because nothing was working. Thank you so much. Also, when my computer was infected, I put a USB flash into my computer to get some music I didn't want to lose. The computer was in Safe Mode when I did so. Do you think I should still use the flash drive or throw it away? thanks
dlg2114
Posts Posts : 32
Post by Belahzur on 4th June 2009, 5:41 pm
You can still use it, we just need to make sure it's clean.
Please download [You must be registered and logged in to see this link.] to your Desktop and run it by double clicking the program's icon.
  1. Wait a couple of seconds for initial scan to finish.
  2. Connect all of your USB storage devices to the PC, one at a time, and keep each one connected at least for 10 seconds.
  3. If there are more USB storage devices to scan, please take a note about the order in which these were connected.
  4. After all the devices are scanned, right click in the Monitor tab, and choose "Save log". That will open the log in Notepad. Please copy and paste the log into this thread.
Explanation: USB storage devices are all the USB devices that get their own partition letter at connecting to the PC, e.g. flash drives (thumb/pen drives, USB sticks), external HDDs, MP3/MP4 players, digital cameras, memory cards (SD cards, Sony Memory Stick, MultiMedia Cards etc.), some mobile phones, some GPS navigation devices etc.
Post by dlg2114 on 4th June 2009, 5:56 pm
Thanks, also is it ok to remove Hijackthis or should I keep it on my desktop?
USBNoRisk 2.4 (1 June 2009) by bobby
Started at 6/4/2009 12:53:48 PM
Searching for connected USB Mass storage...
Searching for other storage...
C: {6f3462f6-4c1b-11db-95ac-806d6172696f}
D: {6f3462f7-4c1b-11db-95ac-806d6172696f}
Scanning fixed storage...
No blocked files found on C:
No Autorun.inf files found on C:
No mountpoint found for C:
No mountpoint found for 6f3462f6-4c1b-11db-95ac-806d6172696f
No Desktop.ini files found on C:
No blocked files found on D:
No Autorun.inf files found on D:
No mountpoint found for D:
No mountpoint found for 6f3462f7-4c1b-11db-95ac-806d6172696f
Desktop.ini found at D:\cmdcons\ contains interesting CLSID string
[.ShellClassInfo]
CLSID={7f67036b-66f1-411a-ad85-759fb9c5b0db}
[ShellvRTF]
RTFPath="protect.ed"
HKCR\CLSID\{7f67036b-66f1-411a-ad85-759fb9c5b0db}\InprocServer32,@ = C:\WINDOWS\system32\ShellvRTF.dll
HKLM\Software\Classes\CLSID\{7f67036b-66f1-411a-ad85-759fb9c5b0db}\InprocServer32,@ = C:\WINDOWS\system32\ShellvRTF.dll
Desktop.ini found at D:\MiniNT\ contains interesting CLSID string
[.ShellClassInfo]
[ShellvRTF]
Desktop.ini found at D:\PRELOAD\ contains interesting CLSID string
[.ShellClassInfo]
[ShellvRTF]
Desktop.ini found at D:\I386\ contains interesting CLSID string
[.ShellClassInfo]
[ShellvRTF]
Desktop.ini found at D:\HP\ contains interesting CLSID string
[.ShellClassInfo]
[ShellvRTF]
Desktop.ini found at D:\TOOLS\ contains interesting CLSID string
[.ShellClassInfo]
[ShellvRTF]
Desktop.ini found at D:\RECOVERY\ contains interesting CLSID string
[.ShellClassInfo]
[ShellvRTF]
Desktop.ini found at D:\Recycled\ contains interesting CLSID string
[.ShellClassInfo]
CLSID={645FF040-5081-101B-9F08-00AA002F954E}
HKCR\CLSID\{645FF040-5081-101B-9F08-00AA002F954E},InfoTip = @%SystemRoot%\system32\SHELL32.dll,-22915
HKCR\CLSID\{645FF040-5081-101B-9F08-00AA002F954E},IntroText = @%SystemRoot%\system32\SHELL32.dll,-31748
HKCR\CLSID\{645FF040-5081-101B-9F08-00AA002F954E},LocalizedString = @%SystemRoot%\system32\SHELL32.dll,-8964
HKCR\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\DefaultIcon,@ = %SystemRoot%\System32\shell32.dll,31
HKCR\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\DefaultIcon,Empty = %SystemRoot%\System32\shell32.dll,31
HKCR\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\DefaultIcon,Full = %SystemRoot%\System32\shell32.dll,32
HKCR\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\InProcServer32,@ = shell32.dll
HKLM\Software\Classes\CLSID\{645FF040-5081-101B-9F08-00AA002F954E},InfoTip = @%SystemRoot%\system32\SHELL32.dll,-22915
HKLM\Software\Classes\CLSID\{645FF040-5081-101B-9F08-00AA002F954E},IntroText = @%SystemRoot%\system32\SHELL32.dll,-31748
HKLM\Software\Classes\CLSID\{645FF040-5081-101B-9F08-00AA002F954E},LocalizedString = @%SystemRoot%\system32\SHELL32.dll,-8964
HKLM\Software\Classes\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\DefaultIcon,@ = %SystemRoot%\System32\shell32.dll,31
HKLM\Software\Classes\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\DefaultIcon,Empty = %SystemRoot%\System32\shell32.dll,31
HKLM\Software\Classes\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\DefaultIcon,Full = %SystemRoot%\System32\shell32.dll,32
HKLM\Software\Classes\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\InProcServer32,@ = shell32.dll
Initial scan finished!
New device connected at 6/4/2009 12:54:09 PM
Scanning for connected USB mass storage...
New drive connected, but USBNoRisk can't find it
New device connected at 6/4/2009 12:54:12 PM
K: {60fa02ad-1a8a-11de-96c1-00038a000015}
Added K:
Scanning USB mass storage for files...
No blocked files found on K:
No Autorun.inf files found on K:
No mountpoint found for 60fa02ad-1a8a-11de-96c1-00038a000015
No Desktop.ini files found on K:
No mimics found on drive K:
New device connected at 6/4/2009 12:54:13 PM
Scanning for connected removable storage...
Scanning removable storage for files...
dlg2114
Posts Posts : 32
Post by Belahzur on 4th June 2009, 5:59 pm
Your external hardware is fine, no autorun files on them.
