[solved]Infected with WinBlue Soft ... Please help !
Post by silverb on Wed Jun 03, 2009 7:20 pm
Infected with WinBlue Soft ... Please help!
My PC is infected with this winblue soft too .
The symton is:
- When Windows is running in normal mode, there is a message " My computer is infected with virus ... etc..." and I can run any program on this normal mode .
- On safe mode I can run some program.
- I can connect to the internet .. but most of the time it is redired to some other site.
- Before, I found this site I have followed some other advises ... in trying to remove this infection ... but all failed so far .
- I read some of the threads in this forum .. and download Trend Micro HijackThis v2.0.2 from here and install but it does not install .. the same for any other anti-spywares I want to install to try out .
- On my PC I have Lavasoft, and Sysmantec installed . I could run them in safemode .. but they detect NOTHING . In other words, it does not help with this problem .
- I have tried something to fix ... as finding those as: blocker.dll, program files/winblue soft,
hex registry relate to winblue soft .... and delete but it does not cure the problem neither ... And I am stuck ... do not know what to do next .
Please help me .
Thank in advance .
Silverb
silverb
Posts Posts : 39
Joined Joined : 2009-06-03
OS OS : XP home
Points Points : 27567
Re: [solved]Infected with WinBlue Soft ... Please help !
Post by Belahzur on Wed Jun 03, 2009 7:23 pm
Hello
  • Restart your computer
  • Select the first option, to run Windows in Safe Mode, then press Enter.
  • Choose your usual account.
Try running the Hijack This setup in safe mode.
Points Points : 245049
Post by silverb on Wed Jun 03, 2009 7:39 pm
Hi Belahzur,
I followed yours instruction ...
Run windows in safe mode
Run install Hijack This .... It aks : choose the directory ... I click OK ... then I saw an icon (short cut) appears on my desk top ... That is ALL ... I do not think the program is installed properly -terminated somehow in the process and does not give any message - ( since it does not ask me to agree on anything ... etc ..)
I also try to click on the ICON ( short cut) ... Nothing happens .
Please tell me what am I going to try next ,
Regards,
Silverb
silverb
Posts Posts : 39
OS OS : XP home
Post by Belahzur on Wed Jun 03, 2009 7:45 pm
Hmm.
In safe mode, try deleting this file in bold:
C:\windows\system32\blocker.dll
Post by silverb on Wed Jun 03, 2009 7:48 pm
I try to install by other way "RUN" ... it gives me a message :
C:\Document and Settings\ Owner\DesktopHJTinstal.exe
A device attatched to the system is not functioning .
silverb
Posts Posts : 39
OS OS : XP home
Post by silverb on Wed Jun 03, 2009 7:50 pm
[You must be registered and logged in to see this link.] wrote:Hmm.
Yes, I did remove this blocker.dll in system32 before
silverb
Posts Posts : 39
OS OS : XP home
Post by Belahzur on Wed Jun 03, 2009 7:52 pm
Check again, see if it's come back.
My bet it has.
I don't have my users delete it manually unless I'm certain it won't come back, but I don't have logs from your machine, so I'm not certain of anything right now.
Post by silverb on Wed Jun 03, 2009 8:01 pm
I am doing SEARCH and manually go into that system 32 folder to find this file (blocker.dll) again ... But so far no luck .
That "my fault" ( read and try to do thing) not yours ....
Do we have any other way to this problem . Or I am stuck here .
Regards,
SB
silverb
Posts Posts : 39
OS OS : XP home
Post by Belahzur on Wed Jun 03, 2009 8:34 pm
No problem. Wink
Give MGTools a try, I've had success in the past when other tools don't work.
Info and links;
Post by silverb on Wed Jun 03, 2009 9:06 pm
Hi Belahzur,
Yes, MGtools does work ... I am having a MGlogs zip files on my computer now ... I could not find the the way to upload (attach) the file with this post .
Since my computer runs in safe mode the screen kind of "weird" => it is hard to see the "functions" provided for users in this forums . I try to find "upload , attach ..." file but can't locate .... Can you point me where ... Or I have to unzip the file and posted here...
Thanks very much for your time .
Best regards,
SB
silverb
Posts Posts : 39
OS OS : XP home
Post by Belahzur on Wed Jun 03, 2009 9:11 pm
Your right, we don't have an attach feature here.
I need you to upload the zip file to somewhere like rapidshare or mediafire.com for me.
Post by silverb on Wed Jun 03, 2009 9:21 pm
Hi Belahzur,
Below is the link for the MGtools zip file :
Regards,
SB
silverb
Posts Posts : 39
OS OS : XP home
Post by Belahzur on Wed Jun 03, 2009 9:22 pm
An exe file? did you upload the wrong file? or pack the zip inside an exe? LMBO or ROFL
Post by silverb on Wed Jun 03, 2009 9:32 pm
Hi Belahzurs,
I am sorry, I did upload the wrong file . This winblue soft drives me nut .Smile
Here is the correct one :
silverb
Posts Posts : 39
OS OS : XP home
Post by Belahzur on Wed Jun 03, 2009 9:40 pm
Hello. Go into your C:\ drive, open the MGTools FOLDER, and inside there, there's an "analyze", which is actually Hijack This. So were gonna use that.
  • Open HijackThis (Analyze.exe)
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
    F2 - REG:system.ini: UserInit=userinit.exe,C:\Documents and Settings\Owner\svbrin.exe \s
    O3 - Toolbar: (no name) - {517BDDE4-E3A7-4570-B21E-2B52B6139FC7} - (no file)
    O17 - HKLM\System\CCS\Services\Tcpip\..\{04151670-06B6-475B-84BE-8CF38D55679E}: NameServer = 85.255.112.197,85.255.112.183
    O17 - HKLM\System\CS1\Services\Tcpip\Parameters: NameServer = 85.255.112.166,85.255.112.67
    O17 - HKLM\System\CS1\Services\Tcpip\..\{04151670-06B6-475B-84BE-8CF38D55679E}: NameServer = 85.255.112.166,85.255.112.67
    O17 - HKLM\System\CS2\Services\Tcpip\Parameters: NameServer = 85.255.112.197,85.255.112.183
    O17 - HKLM\System\CS2\Services\Tcpip\..\{04151670-06B6-475B-84BE-8CF38D55679E}: NameServer = 85.255.112.197,85.255.112.183
    O17 - HKLM\System\CS3\Services\Tcpip\Parameters: NameServer = 85.255.112.197,85.255.112.183
    O17 - HKLM\System\CS3\Services\Tcpip\..\{04151670-06B6-475B-84BE-8CF38D55679E}: NameServer = 85.255.112.197,85.255.112.183
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: NameServer = 85.255.112.197,85.255.112.183
    O23 - Service: MySQL - Unknown owner - C:\Program.exe (file missing)
Next,
  • Download combofix from here
  • See [You must be registered and logged in to see this link.] for how to disable your AV. (Symantec and Ad-watch)
Post by silverb on Wed Jun 03, 2009 11:14 pm
Re_edit
Reason : Wrong & incomplete file .
SB
Last edited by silverb on Thu Jun 04, 2009 2:54 am; edited 1 time in total (Reason for editing : Wrong & incomplete file ...)
silverb
Posts Posts : 39
OS OS : XP home
Post by silverb on Wed Jun 03, 2009 11:18 pm
Hi Belahzurs,
What should I do next ?
After scan, the message "Your computer is infected with spywares ..." on my computer is gone .
You are great!
Best regards,
SB
silverb
Posts Posts : 39
OS OS : XP home
Post by Origin on Thu Jun 04, 2009 12:39 am
The ComboFix log is incomplete, can you please post all the contents of the log, it should be located some where in your C:\ drive
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31463
Post by silverb on Thu Jun 04, 2009 1:51 am
Thanks Origin ! And sorry for my carelesness
ComboFix 09-06-03.01 - Owner 06/03/2009 18:45.1 - NTFSx86 NETWORK
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.1278.957 [GMT -4:00]
Running from: c:\documents and settings\Owner\Desktop\Combo-Fix.exe
AV: Symantec AntiVirus Corporate Edition *On-access scanning enabled* (Updated) {FB06448E-52B8-493A-90F3-E43226D3305C}
C:\Autorun.inf
c:\documents and settings\LocalService\Application Data\wsnpoem
c:\documents and settings\LocalService\Application Data\wsnpoem\audio.dll
c:\windows\10275vi5uz9.ocx
c:\windows\109z3not-a-viru915b.ocx
c:\windows\110499ac5tool448z.exe
c:\windows\11952hacktoo9z77.ocx
c:\windows\11dzir9395.cpl
c:\windows\1293v9rus56z.dll
c:\windows\13020virus599z.bin
c:\windows\13258hacktooz2f79.exe
c:\windows\135ebaczdoor10669.cpl
c:\windows\136109pamb5t6za.cpl
c:\windows\13671wo5mza9.dll
c:\windows\14393wzrm645.bin
c:\windows\147z8sp59bot1f2.ocx
c:\windows\14938wozm5f95.dll
c:\windows\14cdbackdoor359z.ocx
c:\windows\14z85hrea9115.cpl
c:\windows\150029ozm75d.bin
c:\windows\156365pambot3e9z.cpl
c:\windows\15740worz29b9.ocx
c:\windows\159839orm1z3.bin
c:\windows\15b8stzal17009.bin
c:\windows\15z58spambot19c.bin
c:\windows\16462not-9-5irzs478.dll
c:\windows\16494sp5mboz4089.exe
c:\windows\166virz1459.bin
c:\windows\170z9h5cktool54b.dll
c:\windows\171965pambzt7d8.dll
c:\windows\17525hac5tozl297.exe
c:\windows\177115or94z6.bin
c:\windows\1795trojz39.ocx
c:\windows\17z3backdoor995.dll
c:\windows\1809threat56193z.bin
c:\windows\188z7not-a-vi9us265.bin
c:\windows\1922zspy565.bin
c:\windows\19939sp54z8.ocx
c:\windows\1994trzj7dd5.dll
c:\windows\19ca9azkdo5r684.exe
c:\windows\19e59irz595.bin
c:\windows\19z45pa9se250.bin
c:\windows\1a73th9eat30544z.ocx
c:\windows\1badvi95918z.ocx
c:\windows\1d44spz95re468.dll
c:\windows\1e3zspa5se11659.ocx
c:\windows\1e95b5ckzoor602.dll
c:\windows\1ef4dowz5oader9055.bin
c:\windows\1z980spy599.ocx
c:\windows\1zbcspa9se3554.dll
c:\windows\20589v5rusz89.bin
c:\windows\20eszyware9259.ocx
c:\windows\21142hac9toolz5.bin
c:\windows\21297hzcktool47d5.ocx
c:\windows\213999acztool1d5.exe
c:\windows\215z95py163.exe
c:\windows\21835ddwarez985.bin
c:\windows\22425not5a-virz934c.cpl
c:\windows\22658v9ru5z6a.cpl
c:\windows\22997s9y255z.bin
c:\windows\231z45p9143.bin
c:\windows\233625ozm96.dll
c:\windows\23536h95ktozl245.bin
c:\windows\23z97worm7589.cpl
c:\windows\24037spamb95z12.exe
c:\windows\2420stea9z519.exe
c:\windows\242255acktozl6b9.exe
c:\windows\245519acktool5z1.cpl
c:\windows\24931z9ru567a.bin
c:\windows\25917v5ru9ze0.exe
c:\windows\2595virz95.cpl
c:\windows\259abackdoor92z.ocx
c:\windows\25bbs5yware1z29.ocx
c:\windows\2652down9ozder1950.cpl
c:\windows\265z4wor5e99.bin
c:\windows\26899worz559.cpl
c:\windows\27208nzt-a-virus659.exe
c:\windows\274cth5ez2917.bin
c:\windows\27589zpy2d09.ocx
c:\windows\275cspazse915.ocx
c:\windows\27799i514z.dll
c:\windows\27897zot-a-viru955a.dll
c:\windows\27923zpa9bot655.dll
c:\windows\27z58virus292.dll
c:\windows\27z9spambot515.dll
c:\windows\2814zs95mbotb9.exe
c:\windows\284fvirz975.dll
c:\windows\28862spyz95.ocx
c:\windows\28f1zh9ef5430.cpl
c:\windows\29128s5ambot8z9.exe
c:\windows\29132sp54z9.ocx
c:\windows\29155spz219.exe
c:\windows\29181h5ckto9l50z.exe
c:\windows\2920downloaderz095.exe
c:\windows\29269t9ojc5z.dll
c:\windows\29322w9rmz465.bin
c:\windows\293745or97z5.cpl
c:\windows\2940downz5ader351.cpl
c:\windows\29515not-a-vzrus1f9.dll
c:\windows\295aszyware2498.exe
c:\windows\2990vzrus15c.cpl
c:\windows\29919wo5mzc7.cpl
c:\windows\299ezhi5f8939.dll
c:\windows\29cz95ief229.dll
c:\windows\29f6stea9z155.exe
c:\windows\29zdv9r1536.exe
c:\windows\2a549ir15z0.dll
c:\windows\2ba3spyza9e1258.exe
c:\windows\2fa4zpywar931725.dll
c:\windows\2ff2t9reat2613z5.ocx
c:\windows\2z044worm596.ocx
c:\windows\2z8189roj5a95.bin
c:\windows\2z90spyware2563.cpl
c:\windows\2z912not-9-virus355.ocx
c:\windows\301255ozm339.ocx
c:\windows\30305wo9m5zc.dll
c:\windows\3042hack5z9l5fa.bin
c:\windows\30430spz7659.ocx
c:\windows\30625h9cktozl4c9.ocx
c:\windows\30z45v9rus2c5.exe
c:\windows\310479i5usza7.cpl
c:\windows\31533zpy595.ocx
c:\windows\31804zot9a-virus7235.cpl
c:\windows\319z2s9y50e.bin
c:\windows\31c3z5eal1679.exe
c:\windows\31z42tr59652.ocx
c:\windows\3239spa59otzbb.dll
c:\windows\324zpy9905.dll
c:\windows\3332bazk59or1441.ocx
c:\windows\3335spyz559.dll
c:\windows\3447backdo5rz999.bin
c:\windows\34f69hiez1975.exe
c:\windows\35537zpambot6db9.ocx
c:\windows\355avir32z9.bin
c:\windows\3561z9rmf5.dll
[to be continued]
silverb
Posts Posts : 39
OS OS : XP home
Post by silverb on Thu Jun 04, 2009 1:53 am
c:\windows\359z8spy169.ocx
c:\windows\35z85p9rse999.cpl
c:\windows\360cdownlzader9205.ocx
c:\windows\36ezthreat95550.exe
c:\windows\3796s5zwa9e3088.exe
c:\windows\3803dzw5loader4049.dll
c:\windows\3913ad5wa9ez098.cpl
c:\windows\39169hacktoolzeb5.cpl
c:\windows\3938zspam5ot3cf.cpl
c:\windows\395ezownloader685.ocx
c:\windows\3986szyware13475.ocx
c:\windows\399evzr5699.bin
c:\windows\399zs5a9se1104.ocx
c:\windows\39spa5zot1e2.ocx
c:\windows\39z3h9cktool7945.exe
c:\windows\3az2spywar912735.exe
c:\windows\3b04z95al1171.dll
c:\windows\3b09steal435z.exe
c:\windows\3b5cthrea95130z.cpl
c:\windows\3bz5thie9926.dll
c:\windows\3ebzthr5at182769.dll
c:\windows\3ef3zhi592974.exe
c:\windows\4079viz55459.ocx
c:\windows\42b5s95zse2818.dll
c:\windows\4378th9za53573.exe
c:\windows\439b5zeal592.dll
c:\windows\439dbackd5or15z1.exe
c:\windows\43b9dow5loadzr1586.dll
c:\windows\443cbac5dooz8019.cpl
c:\windows\4470spzr95352.dll
c:\windows\4490vi51486z.bin
c:\windows\44b0sp9w5re2389z.cpl
c:\windows\4512virz54b29.bin
c:\windows\4596sp97az5.bin
c:\windows\4599not-a-viru92a0z.dll
c:\windows\45a85ac9zoor1606.cpl
c:\windows\45b9virz4.cpl
c:\windows\45zethief2369.dll
c:\windows\4686haczt5ol59e.bin
c:\windows\4699not5a-viru9z91.exe
c:\windows\46a79hrea51927z.cpl
c:\windows\481e9hr5atz47.ocx
c:\windows\4937s5ambotzde.ocx
c:\windows\499bzte5l1133.dll
c:\windows\49a5downloader908z.dll
c:\windows\49edst5al43z.bin
c:\windows\4ace5ddwzre3099.dll
c:\windows\4ae595arsez555.bin
c:\windows\4d59s5azse1796.cpl
c:\windows\4d59zhie5939.exe
c:\windows\4edd59r859z.exe
c:\windows\4ezthre9513587.exe
c:\windows\4z56spy9are449.bin
c:\windows\4z66v9r2546.bin
c:\windows\4zc4t59eat15102.bin
c:\windows\4zc6add59re1827.cpl
c:\windows\4zc7stea9954.exe
c:\windows\4ze0th5e91142.dll
c:\windows\50026szy297.bin
c:\windows\506z5hac9tool55b.bin
c:\windows\50a9do9nloader5z55.exe
c:\windows\50e3s9arsz2021.ocx
c:\windows\51509spz527.bin
c:\windows\51f6vir19z3.cpl
c:\windows\51z5troj59a.ocx
c:\windows\52097virus5zd.exe
c:\windows\5229tzoj479.dll
c:\windows\5274zhacktool6d9.exe
c:\windows\52ddd9wnlozder30445.ocx
c:\windows\535aspzr9e998.dll
c:\windows\53875spambzt9b8.cpl
c:\windows\5395stzal2669.cpl
c:\windows\540bzp5rse9558.ocx
c:\windows\54358w9rm57z.bin
c:\windows\54597spamzot93f.cpl
c:\windows\5492t5ojz15.exe
c:\windows\54a4t59zat17351.dll
c:\windows\54bfdowzloade52950.bin
c:\windows\5505tzoj905.exe
c:\windows\5529trzj91.ocx
c:\windows\5530z9reat15158.cpl
c:\windows\5540spyware71z9.exe
c:\windows\5548sp9w5re2795z.exe
c:\windows\5556tr9j2ze.exe
c:\windows\555znot-a-9irus6b.dll
c:\windows\5575vi91z98.exe
c:\windows\557a5hrezt109.bin
c:\windows\5595bac95oor309z.dll
c:\windows\55zaad9ware3159.dll
c:\windows\5647wo9m5az.cpl
c:\windows\5656th9zat14474.exe
c:\windows\567backdooz50519.cpl
c:\windows\5696thief1569z.cpl
c:\windows\56e5backdoor195z.exe
c:\windows\56fz5ackdoor21459.ocx
c:\windows\5736dzwn5oa9er3092.bin
c:\windows\575f9ddwzre855.dll
c:\windows\589d9hief25z2.dll
c:\windows\58f3sp9ware175z.bin
c:\windows\59149wozm74f.exe
c:\windows\59419sp97z7.cpl
c:\windows\597869acktooz64f.bin
c:\windows\5a2zdo59loader937.cpl
c:\windows\5ab3downloade91008z.exe
c:\windows\5b59sp59sz1286.ocx
c:\windows\5c45do5nzoa9er1845.ocx
c:\windows\5c59threat95030z.dll
c:\windows\5ce95hreat2481z.dll
c:\windows\5d2zaddw9re1297.bin
c:\windows\5dd0t9izf2698.ocx
c:\windows\5de9zpyware2905.ocx
c:\windows\5ezddw9re2427.cpl
c:\windows\5f0fs5y9zre2933.bin
c:\windows\5fedoznloade978.bin
c:\windows\5feds5ea92919z.exe
c:\windows\5z5v9r215.ocx
c:\windows\5z653spambo97c6.cpl
c:\windows\6104z9ckdoor30555.cpl
c:\windows\6162thi59z664.ocx
c:\windows\619dthrz9t31285.bin
c:\windows\646athre5t3109z.exe
c:\windows\649zaddware1985.cpl
c:\windows\653eaddwa9e1469z.exe
c:\windows\6556thi9fz846.bin
c:\windows\6575spy9cz.dll
c:\windows\65zcvi92994.exe
c:\windows\6696backdo5r2291z.dll
c:\windows\6925wozm39d.ocx
c:\windows\6990addwzr58299.dll
c:\windows\69b7thre5t91z1.cpl
c:\windows\6b0bdownlo5derz936.ocx
c:\windows\6b9dspyware325z5.bin
c:\windows\6c50thzeat94309.exe
c:\windows\6e3spa5ze279.exe
c:\windows\6e655p9rse3131z.cpl
c:\windows\6ec7thr5at65z9.dll
c:\windows\6f109hie5835z.bin
c:\windows\6f53vi9252z.cpl
c:\windows\6fb2down5o9der223z.dll
silverb
Posts Posts : 39
OS OS : XP home
Post by silverb on Thu Jun 04, 2009 1:55 am
c:\windows\70f45ownlozd9r432.ocx
c:\windows\7298addwz9e2554.bin
c:\windows\73615aczdoor3927.bin
c:\windows\7372bac9doo5z191.exe
c:\windows\739edoznloader5195.ocx
c:\windows\7460backdoorz5795.bin
c:\windows\746bt5ief96z.dll
c:\windows\7491not-a-virus15ez.cpl
c:\windows\7503spyz95e1266.exe
c:\windows\7537addware9115z.cpl
c:\windows\754zthi9f150.exe
c:\windows\7569sparse952z.ocx
c:\windows\7797h5c9tzol40b.exe
c:\windows\78f5sparsez6869.dll
c:\windows\7957virus74z.exe
c:\windows\7990sp5mboz683.ocx
c:\windows\7990spy5z59.bin
c:\windows\79f55hzeat177479.exe
c:\windows\79z5addwar51643.bin
c:\windows\7b97ste5l9z2.cpl
c:\windows\7c09vir5444z.bin
c:\windows\7zbbdow9loader1059.dll
c:\windows\82329iz5s295.bin
c:\windows\8516spa5bot5bz9.ocx
c:\windows\866tz9j5cb.dll
c:\windows\874z5pamb9t482.dll
c:\windows\885th95az99.dll
c:\windows\8885tro9173z.bin
c:\windows\8f5vir396z.exe
c:\windows\90905worz6c.exe
c:\windows\9151zp9mb5t377.dll
c:\windows\91574spy701z.exe
c:\windows\92858spy4cz.ocx
c:\windows\9358thi5f578z.dll
c:\windows\93zdownl9a5er2839.cpl
c:\windows\942th5zat31285.cpl
c:\windows\950zthief2702.ocx
c:\windows\95292troz248.exe
c:\windows\95385spy7z5.cpl
c:\windows\95440worm158z.exe
c:\windows\9555zhreat27860.exe
c:\windows\9557zir9s38e.dll
c:\windows\957spywaze1697.cpl
c:\windows\95901tzoj68f5.bin
c:\windows\96171hacktzol5ae.cpl
c:\windows\96558spy5z2.cpl
c:\windows\96650vzrus2fd.bin
c:\windows\9763addwaze1594.cpl
c:\windows\97eespywa5e7z0.bin
c:\windows\984backdoo5z967.cpl
c:\windows\9855backdooz132.dll
c:\windows\9892tz5j47a.exe
c:\windows\98f8thief3z25.exe
c:\windows\991zddwar51299.cpl
c:\windows\9955vizus949.ocx
c:\windows\9969s5azse397.exe
c:\windows\9986nzt-a-virus52.exe
c:\windows\99c6spy5are985z.exe
c:\windows\9aa3spar5ez79.cpl
c:\windows\9dbdvir5z55.bin
c:\windows\9e56ztea52119.exe
c:\windows\9fczpa5s9723.cpl
c:\windows\9z173spambotcb5.bin
c:\windows\9z57vir2578.exe
c:\windows\9zbbaddware5547.bin
c:\windows\9ze3ba5kdoor1751.ocx
c:\windows\b17v9z5410.exe
c:\windows\b82s5a9sez191.dll
c:\windows\c16ste95324z.ocx
c:\windows\c89ad9waze1550.cpl
c:\windows\d08backzoor9541.exe
c:\windows\d4z9py5are1818.exe
c:\windows\d81t9z5at1915.exe
c:\windows\dz29pars5159.dll
c:\windows\ecathzeat201295.ocx
c:\windows\ez7s9a5se898.cpl
c:\windows\system32\10420t9oj7z5.exe
c:\windows\system32\11160hackt5o93zb.bin
c:\windows\system32\11359wo5m799z.cpl
c:\windows\system32\11c9baczdoor655.ocx
c:\windows\system32\11z9downloader1595.cpl
c:\windows\system32\12251n5tza-vir9s43c.dll
c:\windows\system32\12359vi5uszc9.dll
c:\windows\system32\1294zworm95.exe
c:\windows\system32\12dad9wzre2528.dll
c:\windows\system32\12z559acktool7d9.dll
c:\windows\system32\135d9zr5939.dll
c:\windows\system32\13916not59zvirus6e5.bin
c:\windows\system32\13975virzs7e9.dll
c:\windows\system32\13edspy95re111z.ocx
c:\windows\system32\14559spambo5zd8.dll
c:\windows\system32\14717t9o547z.ocx
c:\windows\system32\14729z5rus7c5.ocx
c:\windows\system32\14b15pywarez2209.exe
c:\windows\system32\14z78t5oj19b.dll
c:\windows\system32\15051h9cktzol5835.bin
c:\windows\system32\1507do5nloadzr919.exe
c:\windows\system32\154979zoj55a.ocx
c:\windows\system32\1549thiefz243.cpl
c:\windows\system32\15593spambot75z9.bin
c:\windows\system32\15929zarse357.cpl
c:\windows\system32\16429virus4z75.ocx
c:\windows\system32\16977vi9us6z05.ocx
c:\windows\system32\16b9dzwnloader5397.dll
c:\windows\system32\17e9spzware9659.bin
c:\windows\system32\18130spambot596z.cpl
c:\windows\system32\18d3threat25z59.ocx
c:\windows\system32\1905zviru55b9.ocx
c:\windows\system32\190zd5wnloader3142.exe
c:\windows\system32\19252troj2z5.dll
c:\windows\system32\19278spa5boz9f.cpl
c:\windows\system32\192tzreat107165.exe
c:\windows\system32\194z7w9rm257.bin
c:\windows\system32\1952zspy3615.exe
silverb
Posts Posts : 39
OS OS : XP home
c:\windows\system32\1957spa5b9tzc9.ocx
c:\windows\system32\19597spambot2ze.cpl
c:\windows\system32\19605wozm67c.ocx
c:\windows\system32\19637ha5ktzo95b4.bin
c:\windows\system32\197369zrus5f2.ocx
c:\windows\system32\199315pambzt35e.cpl
c:\windows\system32\199z25ro997.dll
c:\windows\system32\19d6threzt5050.cpl
c:\windows\system32\19d7zhrea515095.exe
c:\windows\system32\19f3addware5z.exe
c:\windows\system32\19fzthreat224145.dll
c:\windows\system32\19z3thi5f1115.cpl
c:\windows\system32\1a65spyza5e1299.bin
c:\windows\system32\1ad19ac5dozr581.cpl
c:\windows\system32\1b925tzal174.exe
c:\windows\system32\1d75viz19309.dll
c:\windows\system32\1df9s9eal795z.exe
c:\windows\system32\1f25pz9are889.dll
c:\windows\system32\1z39h5cktool656.ocx
c:\windows\system32\1z5699py79d.cpl
c:\windows\system32\1z9805py7e9.cpl
c:\windows\system32\20027tr5jz97.cpl
c:\windows\system32\20069spzmb5t88.exe
c:\windows\system32\20220n9t-azviru5118.ocx
c:\windows\system32\2047zi9us3fb5.ocx
c:\windows\system32\20515wo9m6a2z.dll
c:\windows\system32\20951virusdz.exe
c:\windows\system32\2095tzreat14620.exe
c:\windows\system32\20c7sp95are55z.exe
c:\windows\system32\218zsp9mbot70f5.dll
c:\windows\system32\21zfs5eal99.dll
c:\windows\system32\2227not-a9virus5fz.exe
c:\windows\system32\22351h9ckzool63c.cpl
c:\windows\system32\22391zp951c.exe
c:\windows\system32\223e9ir5z2.ocx
c:\windows\system32\224405roj59cz.cpl
c:\windows\system32\2269th59fz137.ocx
c:\windows\system32\229169ot-a-v5zus401.ocx
c:\windows\system32\24099n9t-a-5izus79.cpl
c:\windows\system32\24149hzck9o5l5a2.bin
c:\windows\system32\24259wo5m455z.exe
c:\windows\system32\245zvir1890.cpl
c:\windows\system32\24696wzr555f.bin
c:\windows\system32\246ethzeat959.dll
c:\windows\system32\25296szy510.bin
c:\windows\system32\2558dow9zoader1753.ocx
c:\windows\system32\255fspzrse9962.exe
c:\windows\system32\25655spz295.bin
c:\windows\system32\25bfspyware9z89.dll
c:\windows\system32\25z84w9rm671.ocx
c:\windows\system32\25z97vi5us309.exe
c:\windows\system32\26b7ztea530729.bin
c:\windows\system32\26e8addwarz995.bin
c:\windows\system32\27352spambotz919.bin
c:\windows\system32\274529acktozl45.ocx
c:\windows\system32\2755azdwar9993.bin
c:\windows\system32\27929sp5703z.ocx
c:\windows\system32\27954vi59szda.cpl
c:\windows\system32\2795ste9l569z.dll
c:\windows\system32\27998h5cktooz938.exe
c:\windows\system32\282aspyware9594z.cpl
c:\windows\system32\286099rojz5.bin
c:\windows\system32\28z65spy4d9.ocx
c:\windows\system32\290095ot-a-vzrus229.bin
c:\windows\system32\291ddownloa9zr10925.ocx
c:\windows\system32\2942spambot55z.bin
c:\windows\system32\2946z5acktool58d.dll
c:\windows\system32\29559virzs7a89.exe
c:\windows\system32\29804zro5301.dll
c:\windows\system32\29d8do9nloa5er219z.dll
c:\windows\system32\2az9thi9f1015.cpl
c:\windows\system32\2bdz95ckdoor2658.exe
c:\windows\system32\2cfesz5rse12599.bin
c:\windows\system32\2dzcth9e5t3541.dll
c:\windows\system32\2e95vir195z.ocx
c:\windows\system32\2e9hre5tz6947.cpl
c:\windows\system32\2z9825or920f.ocx
c:\windows\system32\2zd5threat29874.ocx
c:\windows\system32\302not-9-vzrus515.dll
c:\windows\system32\304z0spa5bo96e4.bin
c:\windows\system32\30657not-9-viz5s18a.ocx
c:\windows\system32\3095thrzat22549.cpl
c:\windows\system32\30963not-a-virz5c9.ocx
c:\windows\system32\3102z95rm439.ocx
c:\windows\system32\3145spam9ot7e1z.ocx
c:\windows\system32\31635s5y519z.ocx
c:\windows\system32\31894virz95.exe
c:\windows\system32\31962vzr5s382.ocx
c:\windows\system32\31985zr9j6ba5.dll
c:\windows\system32\323z0vir5s29.exe
c:\windows\system32\32daddware955z.cpl
c:\windows\system32\3455backzoor1944.ocx
c:\windows\system32\34zbsp5ware2269.exe
c:\windows\system32\3652dzwnloader24039.exe
c:\windows\system32\3790troj91z5.exe
c:\windows\system32\39bdth9ez510582.bin
c:\windows\system32\39ec5pywaze3045.exe
c:\windows\system32\3a9ezddwar91957.ocx
c:\windows\system32\3ddbaddwa95z009.cpl
c:\windows\system32\3fba5tezl9650.bin
c:\windows\system32\3fbdviz1954.exe
c:\windows\system32\3z34wo9m6d85.cpl
c:\windows\system32\3z972wor540c.dll
c:\windows\system32\3ze5backdoor1689.dll
c:\windows\system32\400cz5arse2159.dll
c:\windows\system32\4010v9zus4615.cpl
c:\windows\system32\4092stez5798.exe
c:\windows\system32\40e4spa5ze8839.ocx
c:\windows\system32\41a5vi9z6.bin
c:\windows\system32\44baspywz952549.bin
c:\windows\system32\450fspyware2z91.ocx
c:\windows\system32\4554vzr9s625.dll
c:\windows\system32\455fa9dware2929z.bin
c:\windows\system32\45c4d5wz9oader310.ocx
c:\windows\system32\460fba5kdooz9251.bin
c:\windows\system32\465cb5z9door1913.exe
c:\windows\system32\479s9ambo5z68.cpl
c:\windows\system32\47f9s95ware6z2.ocx
c:\windows\system32\48959r5j5z3.ocx
c:\windows\system32\48zevir3590.bin
c:\windows\system32\490zbackdoor452.dll
c:\windows\system32\490zthi5f2605.bin
c:\windows\system32\4950zp95c9.dll
c:\windows\system32\4b45spzware1944.bin
c:\windows\system32\4b50bzckdoor9599.cpl
c:\windows\system32\4c59v9r2z35.dll
c:\windows\system32\4d53thiefz969.exe
c:\windows\system32\4d79dow5loadez780.ocx
c:\windows\system32\4e85ackdozr49.exe
c:\windows\system32\4ez259arse883.cpl
c:\windows\system32\4zef59dware2364.bin
c:\windows\system32\5041sparse157z9.cpl
c:\windows\system32\5105zpa95e581.bin
c:\windows\system32\5155ziru9559.dll
c:\windows\system32\515a9irz590.cpl
c:\windows\system32\5169wzrm901.dll
c:\windows\system32\522spywar932z6.exe
c:\windows\system32\52680s9yz9f.cpl
c:\windows\system32\52879zroj530.cpl
c:\windows\system32\528zvir3219.bin
c:\windows\system32\52eathrezt5904.bin
silverb
Posts Posts : 39
OS OS : XP home
Post by silverb on Thu Jun 04, 2009 1:56 am
c:\windows\system32\539v9z5s132.cpl
c:\windows\system32\53z1addware295.ocx
c:\windows\system32\55189ir274z.cpl
c:\windows\system32\55411troj39z.bin
c:\windows\system32\55519spzmbot9f6.bin
c:\windows\system32\55949hizf969.bin
c:\windows\system32\55z5steal958.exe
c:\windows\system32\56177sp9mbotz6d.dll
c:\windows\system32\56925p9zare1520.cpl
c:\windows\system32\5695zspy2809.cpl
c:\windows\system32\57142szam9ot1a9.bin
c:\windows\system32\5724sp95bot1c0z.bin
c:\windows\system32\5737not-a-9i5uz75c.exe
c:\windows\system32\573zspywar59473.dll
c:\windows\system32\5751v9r357z.dll
c:\windows\system32\57b5t9ief949z.cpl
c:\windows\system32\580downl95dez186.ocx
c:\windows\system32\58559acktozl559.cpl
c:\windows\system32\5871spz5bot389.ocx
c:\windows\system32\5885tzi9f1529.dll
c:\windows\system32\5886spzrs92903.cpl
c:\windows\system32\58ea59arse204z.exe
c:\windows\system32\593bspz5are1019.cpl
c:\windows\system32\5941stzal255.dll
c:\windows\system32\5952hacktool9az.cpl
c:\windows\system32\5989haz9tool551.cpl
c:\windows\system32\5992zo5m8e9.cpl
c:\windows\system32\59f0zownloader23349.ocx
c:\windows\system32\59z0vi554.dll
c:\windows\system32\5ae4downloa9erz792.ocx
c:\windows\system32\5b37t59ez260.cpl
c:\windows\system32\5b9thrzat16619.cpl
c:\windows\system32\5cc7thr9zt13095.dll
c:\windows\system32\5d59backdz5r2587.bin
c:\windows\system32\5ee2downzoa5e91161.ocx
c:\windows\system32\5fb2dowzl9ader1603.cpl
c:\windows\system32\5fc9zhief20879.ocx
c:\windows\system32\5fezhreat31941.exe
c:\windows\system32\5ff1t9iz52359.cpl
c:\windows\system32\5z59h9ck5ool121.exe
c:\windows\system32\5zb4threat51392.bin
c:\windows\system32\5zc8s5eal19699.bin
c:\windows\system32\6150thz9at6175.cpl
c:\windows\system32\61e55h9ef2295z.exe
c:\windows\system32\6255zir2398.ocx
c:\windows\system32\6519worz6d9.bin
c:\windows\system32\6551downloader24z9.exe
c:\windows\system32\655zspy698.exe
c:\windows\system32\656eth5ef984z.cpl
c:\windows\system32\657dspyw9re5455z.ocx
c:\windows\system32\6599zroj4139.ocx
c:\windows\system32\65a0threzt91596.exe
c:\windows\system32\65back9ooz787.cpl
c:\windows\system32\6669szamb5t278.dll
c:\windows\system32\66d8b5ckdoor992z.ocx
c:\windows\system32\66fa9hie52177z.dll
c:\windows\system32\66fbbac59ooz603.bin
c:\windows\system32\689spywzre2252.cpl
c:\windows\system32\6958spz2e5.ocx
c:\windows\system32\6959hacktoz5645.bin
c:\windows\system32\695ambot391z.exe
c:\windows\system32\6964sp5z29.cpl
c:\windows\system32\698aszyw5re1395.dll
c:\windows\system32\69b45ackdozr2535.exe
c:\windows\system32\69e1adzwa5e2949.bin
c:\windows\system32\69efa9dware1581z.exe
c:\windows\system32\69fzvi5995.cpl
c:\windows\system32\6a26spzware25549.exe
c:\windows\system32\6d59zackdoor994.ocx
c:\windows\system32\6e94azdware450.cpl
c:\windows\system32\6e99vz51503.cpl
c:\windows\system32\6fa9zief2560.bin
c:\windows\system32\6z415acktool499.exe
c:\windows\system32\6z89backd5or59.bin
c:\windows\system32\6za5vi92847.dll
c:\windows\system32\6zfbvir8795.dll
c:\windows\system32\7030steal1959z.ocx
c:\windows\system32\7043n5z-a-virus190.bin
c:\windows\system32\70a3d5wnloz9er959.exe
c:\windows\system32\7104thi5f1z09.exe
c:\windows\system32\716a9ow5zoader1305.exe
c:\windows\system32\71d9ste5l5z5.bin
c:\windows\system32\7327t9r5at2273z.dll
c:\windows\system32\73ebvirz9365.dll
c:\windows\system32\73f65pywarz970.ocx
c:\windows\system32\7543spzware9502.cpl
c:\windows\system32\755asparze3249.dll
c:\windows\system32\7571spy929z.exe
c:\windows\system32\7576addwaze595.bin
c:\windows\system32\7633backzoor94645.bin
c:\windows\system32\7645addzar92492.bin
c:\windows\system32\773ba9dw5re64z.cpl
c:\windows\system32\7789s9yware25z8.bin
c:\windows\system32\77czbackdoor2595.ocx
c:\windows\system32\77d4spar5e290z9.dll
c:\windows\system32\782as9ealz6275.exe
c:\windows\system32\7887s5zrse2895.ocx
c:\windows\system32\795zsteal1983.cpl
c:\windows\system32\79a4vzr9055.dll
c:\windows\system32\7a5f5parse19z6.exe
c:\windows\system32\7c09addwar5z797.exe
c:\windows\system32\8356h9cktzol66c.exe
c:\windows\system32\8546zack5ool69d.exe
c:\windows\system32\8749acktozl575.cpl
c:\windows\system32\8775tz5j951.bin
c:\windows\system32\87cthi593082z.bin
c:\windows\system32\905bvzr1187.bin
c:\windows\system32\9136v9r5s1zf.exe
c:\windows\system32\9152n5t-a-virus4zf.exe
c:\windows\system32\91805not-z-virus668.dll
c:\windows\system32\9190hackto5lzc0.exe
c:\windows\system32\9238threat284z5.ocx
c:\windows\system32\9255zparse1004.ocx
c:\windows\system32\9275zworm10e.dll
c:\windows\system32\928thre5t17932z.exe
c:\windows\system32\93945w5rm5bz.cpl
c:\windows\system32\94187not-a-vi5usz18.dll
c:\windows\system32\9445v9rusz65.dll
c:\windows\system32\95azthief3069.bin
silverb
Posts Posts : 39
OS OS : XP home
Post by silverb on Thu Jun 04, 2009 1:58 am
c:\windows\system32\95z6spamb5tc0.cpl
c:\windows\system32\9601zpy5595.exe
c:\windows\system32\96589irus158z.ocx
c:\windows\system32\9705hac9tool395z.ocx
c:\windows\system32\9753addwa5e995z.cpl
c:\windows\system32\9790tr9j1z5.exe
c:\windows\system32\97z8worm9635.ocx
c:\windows\system32\98426tzoj7f5.ocx
c:\windows\system32\98576vizus435.cpl
c:\windows\system32\99352zpy5b5.cpl
c:\windows\system32\9972v5r744z.exe
c:\windows\system32\9980add5zre1736.cpl
c:\windows\system32\99925spy5za.exe
c:\windows\system32\99z9threa55460.bin
c:\windows\system32\9a5vir945z.cpl
c:\windows\system32\9af8spz5are988.exe
c:\windows\system32\9d68vir10z55.exe
c:\windows\system32\9decs5zal1545.ocx
c:\windows\system32\9z225spyb5.cpl
c:\windows\system32\9z605orm66a.dll
c:\windows\system32\9z630spambot5b6.dll
c:\windows\system32\9z7csp5ware1989.cpl
c:\windows\system32\b7a5pywa9e3z6.bin
c:\windows\system32\b9spzrse1515.ocx
c:\windows\system32\c.ico
c:\windows\system32\c6bth5eaz94053.bin
c:\windows\system32\drivers\gxvxcgmmlmfdadixjmdxduilrnttvypykvkay.sys
c:\windows\system32\drivers\gxvxchnoemicixedntlppxpurowyljmexehlc.sys
c:\windows\system32\drivers\gxvxcxlswolmjdxqtkwxgwquufeultjnpunji.sys
c:\windows\system32\drivers\RKHit.sys
c:\windows\system32\e19dd5are1605z.dll
c:\windows\system32\e85thz9f2959.cpl
c:\windows\system32\edzsteal9156.ocx
c:\windows\system32\f05s9yzare658.dll
c:\windows\system32\f4ds5ywar9272z.exe
c:\windows\system32\gxvxcbyojdolkielwpxheloqvxrteondpqjmv.dll
c:\windows\system32\gxvxcnlpaogbryasvphxlsbhobksewcsacjmu.dll
c:\windows\system32\m.ico
c:\windows\system32\s.ico
c:\windows\system32\z0002hac5tool9ca.dll
c:\windows\system32\z062959y351.dll
c:\windows\system32\z15cvir9221.exe
c:\windows\system32\z186t59j3d.dll
c:\windows\system32\z193d95nloader1470.exe
c:\windows\system32\z2226viru95c2.dll
c:\windows\system32\z313down9oader2550.ocx
c:\windows\system32\z36959roj19e.exe
c:\windows\system32\z375vir5s7a9.dll
c:\windows\system32\z4592spam5ot96.exe
c:\windows\system32\z47wor51399.ocx
c:\windows\system32\z5129t5oj2b7.ocx
c:\windows\system32\z519thief938.dll
c:\windows\system32\z5626spam95t577.bin
c:\windows\system32\z590thre9t16648.exe
c:\windows\system32\z5fbsteal9662.dll
c:\windows\system32\z6c9thie919215.dll
c:\windows\system32\z7993hac5tool94.exe
c:\windows\system32\z8393s5y620.cpl
c:\windows\system32\z8805v5r9s4f1.bin
c:\windows\system32\z89835ot-a-virus3e7.bin
c:\windows\system32\z97495roj2b9.ocx
c:\windows\system32\z9894s5ambot5f1.cpl
c:\windows\system32\z99955orm71f.dll
c:\windows\system32\zabthief39845.cpl
c:\windows\system32\zbee5ir9844.ocx
c:\windows\system32\zcd5spywar93144.dll
c:\windows\system32\zd05backdoo9325.ocx
c:\windows\Tasks\{5B57CF47-0BFA-43c6-ACF9-3B3653DCADBA}.job
silverb
Posts Posts : 39
OS OS : XP home
Post by silverb on Thu Jun 04, 2009 1:59 am
c:\windows\z030t5reat1192.bin
c:\windows\z0535d9ware959.ocx
c:\windows\z09vir9925.bin
c:\windows\z2695ack9oor1523.bin
c:\windows\z3567hackt9ol56d.exe
c:\windows\z4176s5y3b09.ocx
c:\windows\z4505orm26d9.cpl
c:\windows\z52athi9f910.dll
c:\windows\z56e9hi5f310.cpl
c:\windows\z573spambo579e.ocx
c:\windows\z652v9r145.cpl
c:\windows\z69fthreat158445.ocx
c:\windows\z895ha9ktool6a6.ocx
c:\windows\z92wor52b9.bin
c:\windows\z93dsparse959.ocx
c:\windows\z9656hacktoo53b59.bin
c:\windows\z969thief3505.exe
c:\windows\z9b1spywa5e953.exe
c:\windows\zca2s5yware17069.bin
c:\windows\zdd9backdo5r3039.cpl
c:\windows\ze57backdo5r309.dll
G:\Autorun.inf
-------\Service_GXVXCSERV.SYS
-------\Legacy_RKHIT
((((((((((((((((((((((((( Files Created from 2009-05-03 to 2009-06-03 )))))))))))))))))))))))))))))))
2009-06-03 20:47 . 2009-06-03 20:51 127958 ----a-w- C:\MGlogs.zip
2009-06-03 20:47 . 2009-06-03 21:56 -------- d-----w- C:\MGtools
2009-06-03 20:44 . 2009-06-03 20:44 1342151 ----a-w- C:\MGtools.exe
2009-06-03 18:22 . 2009-06-03 18:22 -------- d-----w- c:\program files\Trend Micro
2009-06-03 05:12 . 2008-12-11 12:38 159600 ----a-w- c:\windows\system32\drivers\pctgntdi.sys
2009-06-03 05:11 . 2009-04-03 15:18 130936 ----a-w- c:\windows\system32\drivers\PCTCore.sys
2009-06-03 05:11 . 2008-12-18 16:16 73840 ----a-w- c:\windows\system32\drivers\PCTAppEvent.sys
2009-06-03 05:11 . 2009-06-03 07:19 -------- d-----w- c:\program files\Common Files\PC Tools
2009-06-03 05:11 . 2008-12-10 15:36 64392 ----a-w- c:\windows\system32\drivers\pctplsg.sys
2009-06-03 05:11 . 2009-06-03 07:23 -------- d-----w- c:\program files\Spyware Doctor
2009-06-03 05:11 . 2009-06-03 05:11 -------- d-----w- c:\documents and settings\All Users\Application Data\PC Tools
2009-06-03 05:11 . 2009-06-03 05:11 -------- d-----w- c:\docume~1\Owner\APPLIC~1\PC Tools
2009-06-03 04:09 . 2009-06-03 04:09 1507 ----a-w- c:\documents and settings\All Users\Application Data\SecTaskMan\icn_D33A333FC5212A23D8ECC5D54132E172.dll
2009-06-03 04:09 . 2009-06-03 04:09 10 ----a-w- c:\documents and settings\All Users\Application Data\SecTaskMan\icn_D7314F9862C648A4DB8BE2A5B47BE100.dll
2009-06-03 04:09 . 2009-06-03 04:09 27 ----a-w- c:\documents and settings\All Users\Application Data\SecTaskMan\icn_4EA42A62D9304AC4784BF238120611FF.dll
2009-06-03 04:09 . 2009-06-03 04:09 754 ----a-w- c:\documents and settings\All Users\Application Data\SecTaskMan\icn_46EF2F92ECFE5CF4F8BE616B8875F898.dll
2009-06-03 04:09 . 2009-06-03 04:09 1456 ----a-w- c:\documents and settings\All Users\Application Data\SecTaskMan\icn_28BE1674DB8E4A541BB985F69A1D7D6E.dll
2009-06-03 03:58 . 2009-06-03 03:58 -------- d-sh--w- c:\documents and settings\Owner\IECompatCache
2009-06-03 02:25 . 2009-06-03 02:25 -------- d-----w- c:\documents and settings\Administrator\Application Data\Ipswitch
2009-06-03 02:24 . 2009-06-03 02:24 -------- d-sh--w- c:\documents and settings\Administrator\IETldCache
2009-06-01 02:57 . 2009-06-01 02:58 -------- d-----w- c:\program files\E.M. Magic Swf2Avi
2009-05-30 22:18 . 2009-05-30 22:18 -------- d-sh--w- c:\documents and settings\LocalService\IETldCache
2009-05-30 20:17 . 2009-05-30 20:17 -------- d-sh--w- c:\documents and settings\Owner\PrivacIE
2009-05-30 20:14 . 2009-05-30 20:14 -------- d-sh--w- c:\documents and settings\Owner\IETldCache
2009-05-30 20:11 . 2009-05-30 20:11 -------- d-----w- c:\windows\ie8updates
2009-05-30 20:06 . 2009-05-30 20:08 -------- dc-h--w- c:\windows\ie8
2009-05-30 20:03 . 2009-05-12 05:11 102912 -c----w- c:\windows\system32\dllcache\iecompat.dll
2009-05-30 16:32 . 2009-05-30 16:35 -------- d-----w- c:\program files\Power MIDI to MP3
2009-05-29 19:27 . 2009-05-29 19:27 -------- d-----w- c:\documents and settings\Owner\Local Settings\Application Data\Yahoo
2009-05-29 19:26 . 2009-05-26 23:50 607472 ----a-w- c:\documents and settings\All Users\Application Data\Yahoo!\YUpdater\yupdater.exe
2009-05-29 16:58 . 2009-05-29 16:58 -------- d-----w- c:\docume~1\Owner\APPLIC~1\Media Player Classic
2009-05-29 16:53 . 2008-09-16 19:23 168448 ----a-w- c:\windows\system32\unrar.dll
2009-05-29 16:53 . 2009-05-29 16:58 -------- d-----w- c:\program files\K-Lite Codec Pack
2009-05-29 16:26 . 2009-06-03 00:45 -------- d-----w- C:\downloads
2009-05-29 16:26 . 2009-05-29 16:26 -------- d-----w- c:\docume~1\Owner\APPLIC~1\GrabPro
2009-05-29 16:26 . 2009-06-03 04:39 -------- d-----w- c:\program files\Orbitdownloader
2009-05-29 16:26 . 2009-06-03 00:46 -------- d-----w- c:\docume~1\Owner\APPLIC~1\Orbit
2009-05-27 18:49 . 2009-05-27 18:49 314200 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\threatwork.exe
2009-05-27 18:49 . 2009-05-27 18:49 25440 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\savapibridge.dll
2009-05-27 18:49 . 2009-05-27 18:49 169312 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\lavamessage.dll
2009-05-27 18:49 . 2009-05-27 18:49 15688 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\lsdelete.exe
2009-05-27 18:49 . 2009-05-27 18:49 348496 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\lavalicense.dll
2009-05-27 18:49 . 2009-05-27 18:49 294240 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\UpdateManager.dll
2009-05-27 18:49 . 2009-05-27 18:49 83808 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\ShellExt.dll
2009-05-27 18:48 . 2009-05-27 18:48 1630048 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\Resources.dll
2009-05-27 18:48 . 2009-05-27 18:48 212848 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\RPAPI.dll
2009-05-27 18:48 . 2009-05-27 18:48 640360 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\CEAPI.dll
2009-05-27 18:48 . 2009-05-27 18:48 40288 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\PrivacyClean.dll
2009-05-27 18:48 . 2009-05-27 18:48 540536 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\Ad-AwareCommand.exe
2009-05-27 18:48 . 2009-05-27 18:48 559464 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\Ad-AwareAdmin.exe
2009-05-27 18:48 . 2009-05-27 18:48 2352456 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\Ad-Aware.exe
2009-05-27 18:48 . 2009-05-27 18:48 627536 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\AAWWSC.exe
2009-05-27 18:48 . 2009-05-27 18:48 518488 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\AAWTray.exe
2009-05-27 18:48 . 2009-05-27 18:48 1005904 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\AAWService.exe
silverb
Posts Posts : 39
OS OS : XP home
Post by silverb on Thu Jun 04, 2009 2:00 am
2009-06-03 23:02 . 2008-09-14 22:30 -------- d-----w- c:\program files\Symantec AntiVirus
2009-06-03 23:01 . 2008-09-14 17:50 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2009-06-03 23:00 . 2008-09-14 23:20 -------- d-----w- c:\docume~1\Owner\APPLIC~1\DMCache
2009-06-03 16:33 . 2008-11-10 10:01 -------- d-----w- c:\documents and settings\All Users\Application Data\SecTaskMan
2009-06-02 23:04 . 2009-04-16 14:31 -------- d-----w- c:\program files\WS_FTP Pro
2009-06-01 01:51 . 2008-09-27 04:52 -------- d-----w- c:\documents and settings\All Users\Application Data\TechSmith
2009-05-30 20:19 . 2008-09-16 00:58 -------- d-----w- c:\documents and settings\All Users\Application Data\Yahoo! Companion
2009-05-30 14:42 . 2008-09-16 00:58 -------- d-----w- c:\docume~1\Owner\APPLIC~1\Yahoo!
2009-05-29 19:27 . 2008-09-14 18:31 -------- d-----w- c:\program files\Yahoo!
2009-05-29 19:27 . 2008-09-16 00:07 -------- d-----w- c:\documents and settings\All Users\Application Data\Yahoo!
2009-05-27 18:49 . 2008-05-16 15:58 15688 ----a-w- c:\windows\system32\lsdelete.exe
2009-05-14 07:06 . 2008-09-15 03:26 -------- d-----w- c:\documents and settings\All Users\Application Data\Microsoft Help
2009-04-22 18:45 . 2009-04-22 18:46 64160 ----a-w- c:\windows\system32\drivers\Lbd.sys
2009-04-22 18:45 . 2009-04-22 18:45 64160 ----a-w- c:\documents and settings\All Users\Application Data\Lavasoft\Ad-Aware\update\Drivers\32\lbd.sys
2009-04-22 18:42 . 2009-04-22 18:42 -------- dc-h--w- c:\documents and settings\All Users\Application Data\{7972B2E5-3E09-4E5E-81B7-FE5819D6772F}
2009-04-22 18:39 . 2008-09-29 00:45 -------- d-----w- c:\program files\Common Files\Wise Installation Wizard
2009-04-20 16:49 . 2009-04-20 16:49 -------- d-----w- c:\program files\Easy Button Menu Maker
2009-04-20 16:28 . 2009-04-20 16:27 -------- d-----w- c:\program files\EZWebButtons
2009-04-18 04:53 . 2009-04-18 04:53 -------- d-----w- c:\documents and settings\All Users\Application Data\Ipswitch
2009-04-18 03:54 . 2008-09-20 19:40 -------- d-----w- c:\program files\WashAndGo
2009-04-18 03:50 . 2009-04-18 03:50 -------- d-----w- c:\program files\RhinoSoft.com
2009-04-18 02:44 . 2008-09-21 02:16 -------- d-----w- c:\docume~1\Owner\APPLIC~1\RhinoSoft.com
2009-04-16 14:31 . 2009-04-16 14:31 -------- d-----w- c:\docume~1\Owner\APPLIC~1\Ipswitch
2009-04-16 12:32 . 2009-04-16 12:32 -------- d-----w- c:\docume~1\Owner\APPLIC~1\VSRevoGroup
2009-04-10 16:39 . 2008-09-14 17:10 -------- d--h--w- c:\program files\InstallShield Installation Information
2009-04-09 21:29 . 2009-04-09 21:28 -------- d-----w- c:\program files\Unlocker
2009-04-05 23:19 . 2009-04-05 23:19 -------- d-----w- c:\program files\Paltalk Messenger
2009-04-05 23:19 . 2009-04-05 23:19 -------- d-----w- c:\docume~1\Owner\APPLIC~1\Paltalk
2009-03-16 06:50 . 2008-09-15 02:52 216896 ----a-w- c:\documents and settings\Owner\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-03-12 08:17 . 2009-04-22 18:42 2902048 -c--a-w- c:\documents and settings\All Users\Application Data\{7972B2E5-3E09-4E5E-81B7-FE5819D6772F}\Ad-AwareAE.exe
2009-03-08 08:34 . 2006-06-23 18:33 914944 ----a-w- c:\windows\system32\wininet.dll
2009-03-08 08:34 . 2003-07-16 20:32 43008 ----a-w- c:\windows\system32\licmgr10.dll
2009-03-08 08:33 . 2003-07-16 20:25 18944 ----a-w- c:\windows\system32\corpol.dll
2009-03-08 08:33 . 2003-07-16 20:49 420352 ----a-w- c:\windows\system32\vbscript.dll
2009-03-08 08:32 . 2003-07-16 20:23 72704 ----a-w- c:\windows\system32\admparse.dll
2009-03-08 08:32 . 2003-07-16 20:30 71680 ----a-w- c:\windows\system32\iesetup.dll
2009-03-08 08:31 . 2003-07-16 20:30 34816 ----a-w- c:\windows\system32\imgutil.dll
2009-03-08 08:31 . 2003-07-16 20:35 48128 ----a-w- c:\windows\system32\mshtmler.dll
2009-03-08 08:31 . 2003-07-16 20:35 45568 ----a-w- c:\windows\system32\mshta.exe
2009-03-08 08:22 . 2003-07-16 20:36 156160 ----a-w- c:\windows\system32\msls31.dll
2009-03-06 14:22 . 2003-07-16 20:41 284160 ----a-w- c:\windows\system32\pdh.dll
2008-11-05 04:01 . 2008-11-05 04:01 604 ---ha-w- c:\program files\STLL Notifier
2008-10-02 04:39 . 2008-10-02 04:38 315 ----a-w- c:\program files\setuplog.txt
"IDMan"="c:\program files\Internet Download Manager\IDMan.exe" [2008-10-16 2606512]
"RegistryMechanic"="c:\program files\Registry Mechanic\RegMech.exe" [2008-07-08 2828184]
"ILO_Office_Manager"="IntEdReg.exe" - c:\windows\system32\intedreg.exe [2002-10-15 53760]
"IgfxTray"="c:\windows\System32\igfxtray.exe" [2005-06-22 155648]
"HotKeysCmds"="c:\windows\System32\hkcmd.exe" [2005-06-22 126976]
"ccApp"="c:\program files\Common Files\Symantec Shared\ccApp.exe" [2005-06-02 48752]
"vptray"="c:\progra~1\SYMANT~1\VPTray.exe" [2005-06-24 85696]
"Ad-Watch"="c:\program files\Lavasoft\Ad-Aware\AAWTray.exe" [2009-05-27 518488]
"NoDispBackgroundPage"= 1 (0x1)
BootExecute REG_MULTI_SZ PDBoot.exe\0autocheck autochk *\0lsdelete
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\aawservice]
"c:\\Program Files\\Microsoft Office\\Office12\\GROOVE.EXE"=
"c:\\Program Files\\RhinoSoft.com\\FTP Voyager\\FTPVoyager.exe"=
"c:\\Program Files\\RhinoSoft.com\\FTP Voyager\\FVScheduler.exe"=
"c:\\Program Files\\Paltalk Messenger\\paltalk.exe"=
"c:\\Program Files\\WS_FTP Pro\\wsftpgui.exe"=
"c:\\Program Files\\Orbitdownloader\\orbitdm.exe"=
"c:\\Program Files\\Orbitdownloader\\orbitnet.exe"=
R0 Lbd;Lbd;c:\windows\system32\drivers\Lbd.sys [4/22/2009 2:46 PM 64160]
R0 PCTCore;PCTools KDS;c:\windows\system32\drivers\PCTCore.sys [6/3/2009 1:11 AM 130936]
R2 Apache2.2;Apache2.2;c:\apache2\bin\httpd.exe [6/13/2008 4:05 AM 24635]
R2 PD91Agent;PD91Agent;c:\program files\Raxco\PerfectDisk2008\PD91Agent.exe [12/31/2008 1:12 PM 693512]
R3 CLEDX;Team H2O CLEDX service;c:\windows\system32\drivers\cledx.sys [11/13/2008 4:17 AM 33792]
S3 PD91Engine;PD91Engine;c:\program files\Raxco\PerfectDisk2008\PD91Engine.exe [12/31/2008 1:12 PM 910600]
S3 SavRoam;SAVRoam;c:\program files\Symantec AntiVirus\SavRoam.exe [6/23/2005 10:27 PM 124608]
S3 sdauxservice;PC Tools Auxiliary Service;c:\program files\Spyware Doctor\pctsAuxs.exe [6/3/2009 1:11 AM 348752]
silverb
Posts Posts : 39
OS OS : XP home
Post by silverb on Thu Jun 04, 2009 2:01 am
*Deregistered* - EraserUtilDrv10910
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\Nitro PDF Professional]
cscript //B "c:\program files\Nitro PDF\Professional\RemoveOldAddins.vbs"
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{A509B1FF-37FF-4bFF-8CFF-4F3A747040FF}]
c:\windows\system32\rundll32.exe c:\windows\system32\advpack.dll,LaunchINFSectionEx c:\program files\Internet Explorer\clrtour.inf,DefaultInstall.ResetTour,,12
2009-06-01 c:\windows\Tasks\Ad-Aware Update (Weekly).job
- c:\program files\Lavasoft\Ad-Aware\Ad-AwareAdmin.exe [2009-03-09 18:48]
2009-06-03 c:\windows\Tasks\RegCure Program Check.job
- c:\program files\RegCure\RegCure.exe [2008-04-21 07:24]
2009-05-28 c:\windows\Tasks\RegCure.job
ShellExecuteHooks-{56F9679E-7826-4C84-81F3-532071A8BCC5} - (no file)
SafeBoot-procexp90.Sys
SafeBoot-Lavasoft Ad-Aware Service
IE: &Download by Orbit - c:\program files\Orbitdownloader\orbitmxt.dll/201
IE: &Grab video by Orbit - c:\program files\Orbitdownloader\orbitmxt.dll/204
IE: Do&wnload selected by Orbit - c:\program files\Orbitdownloader\orbitmxt.dll/203
IE: Down&load all by Orbit - c:\program files\Orbitdownloader\orbitmxt.dll/202
IE: Download all links with IDM - c:\program files\Internet Download Manager\IEGetAll.htm
IE: Download FLV video content with IDM - c:\program files\Internet Download Manager\IEGetVL.htm
IE: Download with IDM - c:\program files\Internet Download Manager\IEExt.htm
IE: {{4EAFEF58-EEFA-4116-983D-03B49BCBFFFE} - c:\program files\Paltalk Messenger\Paltalk.exe
FF - ProfilePath - c:\docume~1\Owner\APPLIC~1\Mozilla\Firefox\Profiles\elh2zkus.default\
FF - prefs.js: browser.search.selectedEngine - Yahoo
---- FIREFOX POLICIES ----
Rootkit scan 2009-06-03 18:59
[HKEY_LOCAL_MACHINE\System\ControlSet002\Services\MySQL]
"ImagePath"="\"c:\program files\MySQL\MySQL Server 5.0\bin\mysqld-nt\" --defaults-file=\"c:\program files\MySQL\MySQL Server 5.0\my.ini\" MySQL"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{0A23C812-28A4-A3EF-EC599404379BDED8}\{EDDB7AE9-60BA-FC8B-2A36AEA66116E16E}\{30AFDBAC-89B1-0DCB-309A1919CB2D0BED}*]
"{3EE4C831-B7E0-4ed1-B9FC-EDC523C9612F}1"=hex:01,00,01,00,0c,00,00,00,ff,7c,76,
0b,e8,67,72,ab,45,27,f8,cc,39,35,f7,51,03,bf,06,38,54,32,cd,7d,6d,0e,64,38,\
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{4E801B1F-2C34-C71B-55752B4DE71FAE4A}\{6707E13D-DFA5-4083-2A160A7F601D7F5F}\{38345692-AD4C-2D4A-1F4885FC450939AB}*]
"1D1OWFM6WKF6TLM3S2BGKKUUDG1"=hex:01,00,01,00,00,00,00,00,71,4a,e0,45,b7,4f,44,
fb,35,81,92,71,e8,29,5a,84,14,35,16,70,d8,6e,ff,61
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{580924E7-4534-80EF-AD4675C17646FF10}\{0EFB2AA0-1A3E-507D-F9B34D5CF29081CD}\{BBABFA65-B0A6-C96D-B621BCAFF6A8D6D6}*]
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{7B8E9164-324D-4A2E-A46D-0165FB2000EC}]
@Denied: (Full) (Everyone)
"scansk"=hex(0):53,ad,2f,f2,f7,0f,43,4c,44,88,57,be,c2,76,44,6f,42,f6,46,d3,20,
a1,2c,9e,7b,cb,a7,88,7f,a8,fc,47,e1,ab,cf,c7,e8,83,7d,8a,00,00,00,00,00,00,\
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{9bf60bbd-ee12-403a-bf30-10e9c0758df3}]
"Model"=dword:0000011e
"Therad"=dword:00000019
"MData"=hex(0):cb,9b,ad,ef,27,7d,29,69,f5,02,f0,76,aa,4a,f1,7c,d3,d9,67,7f,6a,
4b,7b,ad,04,7a,b1,b5,76,9b,27,47,75,9e,50,cf,22,7a,d1,f7,cd,85,4a,9f,9a,10,\
silverb
Posts Posts : 39
OS OS : XP home
Post by silverb on Thu Jun 04, 2009 2:02 am
- - - - - - - > 'explorer.exe'(428)
c:\program files\Internet Download Manager\idmmkb.dll
c:\windows\system32\OneX.DLL
c:\windows\system32\eappprxy.dll
c:\program files\RhinoSoft.com\FTP Voyager\ftpshext.dll
c:\program files\Lavasoft\Ad-Aware\AAWService.exe
c:\program files\Common Files\Symantec Shared\ccSetMgr.exe
c:\program files\Symantec AntiVirus\DefWatch.exe
c:\program files\Symantec AntiVirus\Rtvscan.exe
c:\program files\Common Files\Symantec Shared\ccEvtMgr.exe
c:\windows\system32\wbem\unsecapp.exe
c:\program files\Internet Download Manager\IEMonitor.exe
Completion time: 2009-06-03 19:10 - machine was rebooted
ComboFix-quarantined-files.txt 2009-06-03 23:10
Pre-Run: 12,314,267,648 bytes free
Post-Run: 14,859,976,704 bytes free
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /fastdetect /NoExecute=OptIn
1018 --- E O F --- 2009-05-14 07:06
silverb
Posts Posts : 39
OS OS : XP home
Post by silverb on Thu Jun 04, 2009 2:06 am
Hi Origin,
Is this the right file ?
It is too long I have to break it into small parts .
Thanks for reminding,
Regards,
SB
silverb
Posts Posts : 39
OS OS : XP home
Post by Origin on Thu Jun 04, 2009 3:29 am
Yes it is the right log, please do the following:
Now open a new notepad file.
Registry::
"NoDispBackgroundPage"=-
"DisableMonitoring"=-
Posts Posts : 2685
Post by silverb on Thu Jun 04, 2009 3:47 am
ComboFix 09-06-03.04 - Owner 06/03/2009 23:36.2 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.1278.613 [GMT -4:00]
Command switches used :: c:\documents and settings\Owner\Desktop\CFScript.txt
AV: Symantec AntiVirus Corporate Edition *On-access scanning disabled* (Updated) {FB06448E-52B8-493A-90F3-E43226D3305C}
((((((((((((((((((((((((( Files Created from 2009-05-04 to 2009-06-04 )))))))))))))))))))))))))))))))
2009-06-03 05:11 . 2009-06-03 05:11 -------- d-----w- c:\documents and settings\Owner\Application Data\PC Tools
2009-05-29 16:58 . 2009-05-29 16:58 -------- d-----w- c:\documents and settings\Owner\Application Data\Media Player Classic
silverb
Posts Posts : 39
OS OS : XP home
Post by silverb on Thu Jun 04, 2009 3:48 am
2009-05-29 16:26 . 2009-05-29 16:26 -------- d-----w- c:\documents and settings\Owner\Application Data\GrabPro
2009-05-29 16:26 . 2009-06-03 00:46 -------- d-----w- c:\documents and settings\Owner\Application Data\Orbit
2009-06-04 03:42 . 2008-09-14 23:20 -------- d-----w- c:\documents and settings\Owner\Application Data\DMCache
2009-06-04 03:34 . 2008-09-14 22:30 -------- d-----w- c:\program files\Symantec AntiVirus
2009-05-30 14:42 . 2008-09-16 00:58 -------- d-----w- c:\documents and settings\Owner\Application Data\Yahoo!
2009-04-18 02:44 . 2008-09-21 02:16 -------- d-----w- c:\documents and settings\Owner\Application Data\RhinoSoft.com
2009-04-16 14:31 . 2009-04-16 14:31 -------- d-----w- c:\documents and settings\Owner\Application Data\Ipswitch
2009-04-16 12:32 . 2009-04-16 12:32 -------- d-----w- c:\documents and settings\Owner\Application Data\VSRevoGroup
2009-04-05 23:19 . 2009-04-05 23:19 -------- d-----w- c:\documents and settings\Owner\Application Data\Paltalk
2009-03-14 08:02 . 2009-03-14 08:02 7168 ----a-w- c:\documents and settings\Owner\Application Data\Thinstall\VeryDOC PowerPoint to Flash Converter v2.0\300000003400002i\dwwin.exe
2009-03-14 08:02 . 2009-03-14 08:02 7168 ----a-w- c:\documents and settings\Owner\Application Data\Thinstall\VeryDOC PowerPoint to Flash Converter v2.0\1000000500002i\regsvr32.exe
silverb
Posts Posts : 39
OS OS : XP home
Post by silverb on Thu Jun 04, 2009 3:49 am
silverb
Posts Posts : 39
OS OS : XP home
FF - ProfilePath - c:\documents and settings\Owner\Application Data\Mozilla\Firefox\Profiles\elh2zkus.default\
Rootkit scan 2009-06-03 23:41
silverb
Posts Posts : 39
OS OS : XP home
Post by silverb on Thu Jun 04, 2009 3:50 am
- - - - - - - > 'explorer.exe'(2032)
Completion time: 2009-06-04 23:45
ComboFix-quarantined-files.txt 2009-06-04 03:45
ComboFix2.txt 2009-06-03 23:11
Pre-Run: 15,236,128,768 bytes free
Post-Run: 15,227,670,528 bytes free
243 --- E O F --- 2009-05-14 07:06
silverb
Posts Posts : 39
OS OS : XP home
Post by Origin on Thu Jun 04, 2009 3:55 am
Posts Posts : 2685
Post by silverb on Thu Jun 04, 2009 4:01 am
Malwarebytes' Anti-Malware 1.37
Database version: 2227
6/4/2009 12:00:06 AM
mbam-log-2009-06-04 (00-00-05).txt
Objects scanned: 92131
Time elapsed: 5 minute(s), 13 second(s)
Registry Keys Infected: 3
Files Infected: 1
HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\{c48635ad-d6b5-3ee4-aaa2-540d5a173658} (Backdoor.Bot) -> Quarantined and deleted successfully.
HKEY_USERS\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\{c48635ad-d6b5-3ee4-aaa2-540d5a173658} (Backdoor.Bot) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\WinBlueSoft (Rogue.WinBlue) -> Quarantined and deleted successfully.
c:\WINDOWS\system32\svch0st.2.exe (Heuristics.Reserved.Word.Exploit) -> Quarantined and deleted successfully.
silverb
Posts Posts : 39
OS OS : XP home
Post by Origin on Thu Jun 04, 2009 4:01 am
ComboFix /u
Posts Posts : 2685
Post by silverb on Thu Jun 04, 2009 4:38 am
Hi Origin,
I followed the instructions and did all the things ...
I saw the the message "combofix is uninstalled"
My computer seems running normal now .
Is there anything more that I need to do ?
Also, I would like to ask this question:
- Before I found this website, I have tried following some suggestions on NET and installed some other anti_spywares programs which I probably do not need . Should I uninstall all those not needed in my computer?
- I have both programs HiJackThis & MGtools installed in my PC (HijackThis installed first - but it could not install itself properly- Then Belahzurs told me to try MGtools and it worked ) . My question is : Do I keep both programs as they currently are or I should remove one / or both of them out of my PC ?
Your guys are great and I sincerely thank for your services .
Best Regards,
SB
(I have referred your website - very professional & courtesy sevice - to members of my community forums ... and I think fews have come here seeking help . For me, probably a donation will be sent soon)
silverb
Posts Posts : 39
OS OS : XP home
Post by Origin on Thu Jun 04, 2009 4:42 am
yes it is suppose to uninstall, What kind are the names of the tools you downloaded? I would dispose of HijackThis and keep MGTools.
Glad we could help Wink
Posts Posts : 2685
Re: [solved]Infected with WinBlue Soft ... Please help !
Post by silverb on Thu Jun 04, 2009 5:31 am
Dear Origin and Belahzurs,
Oh, as said, before I found yours, this nasty WinBlue Soft drove me nut ...
(I got infected when I was in Greeting 123 to find an electronic birthday card for a friend ... I did not know HOW it could find way to attack my PC ... since I have antivirus -Sysmantec- & antispyware - Lavasoft - ON all the time - )
So, I surf the net to find solution ... Some suggest this or that program would be able to fix the problem ... such as... Spyware Doctor, Registry Mechanic ... and few others too .. I tried them all but with no good result .. Until I am here .
Again, thanks for your services and those last "instructions & advises" .
Wish you all the best !
Regards,
Silverb
silverb
Posts Posts : 39
Joined Joined : 2009-06-03
OS OS : XP home
Points Points : 27567
