I am a Winbluesoft victim.... I really need help!
Post by Hackattack on 3rd June 2009, 4:09 am
I am new to this website, but I am ok with working with computers.
It looks like a video codec, or something of that nature, installed itself on my Laptop. The screen then turned blue, some words came out, and the computer then restarted with the winbluesoft problem. The desktop background has some virus warnings, but I cannot change that. Or run anything like an exe. either. It seems all Administrator privaledges are locked.
I am running it in safe mode now, and it is letting me run executes. I am using windows vista. As for now I am using a virus-safe iMac to get instruction on what I can possibly do, if anything to remove this virus. I will be waiting, hopefully someone can help me...javascript:emoticonp('Indifferent or Blank')
Hackattack
Joined Joined : 2009-06-03
OS OS : Vista
Points Points : 27483
Re: I am a Winbluesoft victim.... I really need help!
Post by Belahzur on 3rd June 2009, 11:48 am
Points Points : 245121
