Sound Not Working
Solved Sound Not Working
Post by Master on Mon Jun 01, 2009 10:37 pm
Hi GeekPolice,
A couple of days ago I had gotten the trojan "WinCodecPro". There were many warnings that said there was a fatal error and you need to update your media drivers, etc. I have followed the guide written by Doctor Inferno in the Virus Removal Guides forum.
The trojan is now officially removed from my site. However, my sound doesn't work at all!
I posted in the Malware Section and I'm not infected or anything, but Belahzur told me that Doc will help me update my drivers and fix the problem.
Thanks.
Posts Posts : 57
Joined Joined : 2009-03-21
Points Points : 28237
Solved Re: Sound Not Working
Post by Doctor Inferno on Wed Jun 03, 2009 5:15 am
Under volume controls, does it say There are no active mixers available?
Post by Master on Wed Jun 03, 2009 9:07 pm
All of the audio devices are detected everything but when I turn up or turn up the volume in the taskbar or even from the sound settings in the control panel, so sound is heard at all.
Posts Posts : 57
Post by Doctor Inferno on Thu Jun 04, 2009 4:24 am
Make sure that the jack connected to your PC is properly fitted. Open device manger, select Sound, video and game controllers >> right click >> uninstall the audio drive and install this:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
Post by Master on Thu Jun 04, 2009 5:39 am
Thanks. The problem has been fixed. Thank you very much Smile
Posts Posts : 57
